Никола Ивахнов Posted June 24, 2022 Posted June 24, 2022 Hello. I try to install ambian https://www.armbian.com/orange-pi-zero-2/ to orange pi zero 2 and get there on first start: ▒[100]HELLO! BOOT0 is starting May 13 2020 14:10:04! [105]BOOT0 commit : 593cf83 [107]set pll start [110]periph0 has been enabled [113]set pll end [115]unknow PMU [117]PMU: AXP806 [124]vaild para:8 select dram para0 [127]board init ok [129]DRAM BOOT DRIVE INFO: V0.52 [132]the chip id is 0x5000 [135]chip id check OK [137]DRAM_VCC set to 1500 mv [141]read_calibration error [145]read_calibration error [149]read_calibration error [153]read_calibration error [157]read_calibration error [161]read_calibration error [165]read_calibration error [169]read_calibration error [173]read_calibration error [177]read_calibration error [180]retraining final error [184][AUTO DEBUG]32bit,1 ranks training success! [192]DRAM CLK =720 MHZ [194]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [200]Actual DRAM SIZE =1024 M [203]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [216]DRAM simple test OK. [219]rtc standby flag is 0x0, super standby flag is 0x0 [224]dram size =1024 [226]*****dram handle ok**** [230]card no is 0 [231]sdcard 0 line count 4 [234][mmc]: mmc driver ver 2019-12-19 10:41 [238][mmc]: sdc0 spd mode error, 2 [242][mmc]: set f_max to 50M, set f_max_ddr to 25M [247][mmc]: mmc 0 bias 0 [255][mmc]: Wrong media type 0x0 [258][mmc]: ***Try SD card 0*** [267][mmc]: HSSDR52/SDR25 4 bit [270][mmc]: 50000000 Hz [272][mmc]: 15200 MB [274][mmc]: ***SD/MMC 0 init OK!!!*** [373]Loading boot-pkg Succeed(index=0). [377]Entry_name = u-boot [386]Entry_name = monitor [390]Entry_name = dtbo [393]Entry_name = dtb [397]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-orangepi (Mar 31 2022 - 11:47:20 +0800) Xunlong Software [00.474]CPU: Allwinner H616 [00.477]Model: Orange Pi Zero 2 I2C: ready [00.482]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.522]secure enable bit: 0 [00.525]PMU: AXP806 [00.530]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.717]sunxi overlay merged okqv [00.720]drv_disp_init [00.748]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.753]drv_disp_init finish [00.756]gic: sec monitor mode [00.761]flash init start [00.763]workmode = 0,storage type = 1 [00.767]MMC: 0 [00.768][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.774][mmc]: get sdc_type fail and use default host:tm1. [00.785][mmc]: Using default timing para [00.788][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.806][mmc]: card_caps:0x3000000a [00.809][mmc]: host_caps:0x3000003f [00.813]sunxi flash init ok [00.816]Loading Environment from FAT... [00.820][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.826][mmc]: get sdc_type fail and use default host:tm1. [00.836][mmc]: Using default timing para [00.840][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.851]usb burn from boot delay time 0 weak:otg_phy_config [00.864]usb prepare ok [01.667]overtime [01.671]do_burn_from_boot usb : no usb exist [01.675]boot_gui_init:start 206 bytes read in 8 ms (24.4 KiB/s) Set HDMI disp_mode to 1080p60 206 bytes read in 8 ms (24.4 KiB/s) Set fb0_width to 1920 Set fb0_height to 1080 [01.976]boot_gui_init:finish [01.978]bmp_name=/boot/boot.bmp 230456 bytes read in 105 ms (2.1 MiB/s) [02.098]update dts Net: [02.101]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 [03.128][mmc]: card_caps:0x3000000a [03.131][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2771 bytes read in 10 ms (270.5 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 206 bytes read in 8 ms (24.4 KiB/s) 8484924 bytes read in 3769 ms (2.1 MiB/s) 24129608 bytes read in 4252 ms (5.4 MiB/s) ## Booting kernel from Legacy Image at 41000000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 24129544 Bytes = 23 MiB Load Address: 41000000 Entry Point: 41000000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8484860 Bytes = 8.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Ramdisk to 497e8000, end 49fff7fc ... OK reserving fdt memory region: addr=48000000 size=1000000 ## Linux machid: 00000000, FDT addr: 7be86d60 Starting kernel ... ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒&[100]HELLO! BOOT0 is starting May 13 2020 14:10:04! [105]BOOT0 commit : 593cf83 [107]set pll start [110]periph0 has been enabled [113]set pll end [115]unknow PMU [117]PMU: AXP806 [124]vaild para:8 select dram para0 [127]board init ok [129]DRAM BOOT DRIVE INFO: V0.52 [133]the chip id is 0x5000 [135]chip id check OK [137]DRAM_VCC set to 1500 mv [141]read_calibration error [145]read_calibration error [149]read_calibration error [153]read_calibration error [157]read_calibration error [161]read_calibration error [165]read_calibration error [169]read_calibration error [173]read_calibration error [177]read_calibration error [180]retraining final error [184][AUTO DEBUG]32bit,1 ranks training success! [192]DRAM CLK =720 MHZ [194]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [200]Actual DRAM SIZE =1024 M [203]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [216]DRAM simple test OK. [219]rtc standby flag is 0x0, super standby flag is 0x0 [224]dram size =1024 [226]*****dram handle ok**** [230]card no is 0 [232]sdcard 0 line count 4 [234][mmc]: mmc driver ver 2019-12-19 10:41 [238][mmc]: sdc0 spd mode error, 2 [242][mmc]: set f_max to 50M, set f_max_ddr to 25M [247][mmc]: mmc 0 bias 0 [255][mmc]: Wrong media type 0x0 [258][mmc]: ***Try SD card 0*** [267][mmc]: HSSDR52/SDR25 4 bit [270][mmc]: 50000000 Hz [272][mmc]: 15200 MB [274][mmc]: ***SD/MMC 0 init OK!!!*** [375]Loading boot-pkg Succeed(index=0). [378]Entry_name = u-boot [387]Entry_name = monitor [391]Entry_name = dtbo [394]Entry_name = dtb [398]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-orangepi (Mar 31 2022 - 11:47:20 +0800) Xunlong Software [00.475]CPU: Allwinner H616 [00.477]Model: Orange Pi Zero 2 I2C: ready [00.482]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.523]secure enable bit: 0 [00.525]PMU: AXP806 [00.530]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.717]sunxi overlay merged okqv [00.721]drv_disp_init [00.748]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.754]drv_disp_init finish [00.756]gic: sec monitor mode [00.762]flash init start [00.764]workmode = 0,storage type = 1 [00.767]MMC: 0 [00.769][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.775][mmc]: get sdc_type fail and use default host:tm1. [00.785][mmc]: Using default timing para [00.789][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.807][mmc]: card_caps:0x3000000a [00.810][mmc]: host_caps:0x3000003f [00.813]sunxi flash init ok [00.817]Loading Environment from FAT... [00.820][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.826][mmc]: get sdc_type fail and use default host:tm1. [00.837][mmc]: Using default timing para [00.840][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.852]usb burn from boot delay time 0 weak:otg_phy_config [00.865]usb prepare ok [01.668]overtime [01.672]do_burn_from_boot usb : no usb exist [01.676]boot_gui_init:start 206 bytes read in 15 ms (12.7 KiB/s) Set HDMI disp_mode to 1080p60 206 bytes read in 9 ms (21.5 KiB/s) Set fb0_width to 1920 Set fb0_height to 1080 [01.984]boot_gui_init:finish [01.986]bmp_name=/boot/boot.bmp 230456 bytes read in 127 ms (1.7 MiB/s) [02.128]update dts Net: [02.131]No ethernet found. Hit any key to stop autoboot: 0 orangepi# ls -l /dev | grep -E 'sd|hd' syntax error orangep orangepi# fdisk Unknown command 'fdisk' - try 'help' orangepi# help ? - alias for 'help' base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol bootz - boot Linux zImage image from memory cmp - memory compare colorbar- show colorbar coninfo - print console devices and information cp - memory copy crc32 - checksum calculation dhcp - boot image via network using DHCP/TFTP protocol echo - echo args to console editenv - edit environment variable efex - run to efex env - environment handling commands erase - erase FLASH memory exit - exit script ext2load- load binary file from a Ext2 filesystem ext2ls - list files in a directory (default /) ext4load- load binary file from a Ext4 filesystem ext4ls - list files in a directory (default /) ext4size- determine a file's size ext4write- create a file in the root directory false - do nothing, unsuccessfully fastboot- fastboot - enter USB Fastboot protocol fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fatsize - determine a file's size fatwrite- write file into a dos filesystem fdt - flattened device tree utility commands flinfo - print FLASH memory information fstype - Look up a filesystem type go - start application at address 'addr' gpt - GUID Partition Table help - print command description/usage i2c - I2C sub-system itest - return true/false on integer compare load - load binary file from a filesystem loadb - load binary file over serial line (kermit mode) loads - load S-Record file over serial line loadx - load binary file over serial line (xmodem mode) loady - load binary file over serial line (ymodem mode) logo - show default logo loop - infinite loop on address range ls - list files in a directory (default /) md - memory display memtester- start application at address 'addr' mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - display MMC info mw - memory write (fill) nfs - boot image via network using NFS protocol nm - memory modify (constant address) part - disk partition related commands pbread - read data from private data ping - send ICMP ECHO_REQUEST to network host poweroff- Perform POWEROFF of the device printenv- print environment variables protect - enable or disable FLASH write protection pxe - commands to get and boot from pxe files reset - Perform RESET of the CPU run - run commands in an environment variable save - save file to a filesystem saveenv - save environment variables to persistent storage screen_char- show default screen chars setenv - set environment variables setexpr - set environment variable as the result of eval expression showvar - print local hushshell variables size - determine a file's size sleep - delay execution for some time source - run script from memory sprite_test- do a sprite test sunxi_axp- sunxi_axp sub-system sunxi_bmp_info- manipulate BMP image data sunxi_bmp_show- manipulate BMP image data sunxi_card0_probe- probe sunxi card0 device sunxi_flash- sunxi_flash sub-system sunxi_nand_test- sunxi_nand_test sub systerm sysboot - command to get and boot from syslinux files test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol timer_test- do a timer and int test timer_test1- do a timer and int test true - do nothing, successfully uburn - do a burn from boot version - print monitor, compiler and linker version orangepi# fsck Unknown command 'fsck' - try 'help' orangepi# ls ls - list files in a directory (default /) Usage: ls <interface> [<dev[:part]> [directory]] - List files in directory 'directory' of partition 'part' on device type 'interface' instance 'dev'. orangepi# cd / Unknown command 'cd' - try 'help' orangepi# ls / ** No device specified ** orangepi# fstab Unknown command 'fstab' - try 'help' orangepi# tune2fs Unknown command 'tune2fs' - try 'help' orangepi# touch /forcefsck Unknown command 'touch' - try 'help' orangepi# help ? - alias for 'help' base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol bootz - boot Linux zImage image from memory cmp - memory compare colorbar- show colorbar coninfo - print console devices and information cp - memory copy crc32 - checksum calculation dhcp - boot image via network using DHCP/TFTP protocol echo - echo args to console editenv - edit environment variable efex - run to efex env - environment handling commands erase - erase FLASH memory exit - exit script ext2load- load binary file from a Ext2 filesystem ext2ls - list files in a directory (default /) ext4load- load binary file from a Ext4 filesystem ext4ls - list files in a directory (default /) ext4size- determine a file's size ext4write- create a file in the root directory false - do nothing, unsuccessfully fastboot- fastboot - enter USB Fastboot protocol fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fatsize - determine a file's size fatwrite- write file into a dos filesystem fdt - flattened device tree utility commands flinfo - print FLASH memory information fstype - Look up a filesystem type go - start application at address 'addr' gpt - GUID Partition Table help - print command description/usage i2c - I2C sub-system itest - return true/false on integer compare load - load binary file from a filesystem loadb - load binary file over serial line (kermit mode) loads - load S-Record file over serial line loadx - load binary file over serial line (xmodem mode) loady - load binary file over serial line (ymodem mode) logo - show default logo loop - infinite loop on address range ls - list files in a directory (default /) md - memory display memtester- start application at address 'addr' mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - display MMC info mw - memory write (fill) nfs - boot image via network using NFS protocol nm - memory modify (constant address) part - disk partition related commands pbread - read data from private data ping - send ICMP ECHO_REQUEST to network host poweroff- Perform POWEROFF of the device printenv- print environment variables protect - enable or disable FLASH write protection pxe - commands to get and boot from pxe files reset - Perform RESET of the CPU run - run commands in an environment variable save - save file to a filesystem saveenv - save environment variables to persistent storage screen_char- show default screen chars setenv - set environment variables setexpr - set environment variable as the result of eval expression showvar - print local hushshell variables size - determine a file's size sleep - delay execution for some time source - run script from memory sprite_test- do a sprite test sunxi_axp- sunxi_axp sub-system sunxi_bmp_info- manipulate BMP image data sunxi_bmp_show- manipulate BMP image data sunxi_card0_probe- probe sunxi card0 device sunxi_flash- sunxi_flash sub-system sunxi_nand_test- sunxi_nand_test sub systerm sysboot - command to get and boot from syslinux files test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol timer_test- do a timer and int test timer_test1- do a timer and int test true - do nothing, successfully uburn - do a burn from boot version - print monitor, compiler and linker version orangepi# reboot Unknown command 'reboot' - try 'help' orangepi# ▒▒[100]HELLO! BOOT0 is starting May 13 2020 14:10:04! [105]BOOT0 commit : 593cf83 [107]set pll start [110]periph0 has been enabled [113]set pll end [115]unknow PMU [117]PMU: AXP806 [124]vaild para:8 select dram para0 [127]board init ok [129]DRAM BOOT DRIVE INFO: V0.52 [132]the chip id is 0x5000 [135]chip id check OK [137]DRAM_VCC set to 1500 mv [141]read_calibration error [145]read_calibration error [149]read_calibration error [153]read_calibration error [157]read_calibration error [161]read_calibration error [165]read_calibration error [169]read_calibration error [173]read_calibration error [177]read_calibration error [180]retraining final error [184][AUTO DEBUG]32bit,1 ranks training success! [192]DRAM CLK =720 MHZ [194]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [200]Actual DRAM SIZE =1024 M [203]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [216]DRAM simple test OK. [219]rtc standby flag is 0x0, super standby flag is 0x0 [224]dram size =1024 [226]*****dram handle ok**** [230]card no is 0 [232]sdcard 0 line count 4 [234][mmc]: mmc driver ver 2019-12-19 10:41 [238][mmc]: sdc0 spd mode error, 2 [242][mmc]: set f_max to 50M, set f_max_ddr to 25M [247][mmc]: mmc 0 bias 0 [255][mmc]: Wrong media type 0x0 [258][mmc]: ***Try SD card 0*** [267][mmc]: HSSDR52/SDR25 4 bit [270][mmc]: 50000000 Hz [272][mmc]: 15200 MB [274][mmc]: ***SD/MMC 0 init OK!!!*** [373]Loading boot-pkg Succeed(index=0). [377]Entry_name = u-boot [386]Entry_name = monitor [390]Entry_name = dtbo [393]Entry_name = dtb [397]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-orangepi (Mar 31 2022 - 11:47:20 +0800) Xunlong Software [00.474]CPU: Allwinner H616 [00.476]Model: Orange Pi Zero 2 I2C: ready [00.481]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.522]secure enable bit: 0 [00.524]PMU: AXP806 [00.529]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.716]sunxi overlay merged okqv [00.720]drv_disp_init [00.747]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.753]drv_disp_init finish [00.755]gic: sec monitor mode [00.761]flash init start [00.763]workmode = 0,storage type = 1 [00.766]MMC: 0 [00.768][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.774][mmc]: get sdc_type fail and use default host:tm1. [00.784][mmc]: Using default timing para [00.788][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.806][mmc]: card_caps:0x3000000a [00.809][mmc]: host_caps:0x3000003f [00.812]sunxi flash init ok [00.816]Loading Environment from FAT... [00.819][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.825][mmc]: get sdc_type fail and use default host:tm1. [00.836][mmc]: Using default timing para [00.839][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.851]usb burn from boot delay time 0 weak:otg_phy_config [00.864]usb prepare ok [01.667]overtime [01.671]do_burn_from_boot usb : no usb exist [01.675]boot_gui_init:start 206 bytes read in 8 ms (24.4 KiB/s) Set HDMI disp_mode to 1080p60 206 bytes read in 8 ms (24.4 KiB/s) Set fb0_width to 1920 Set fb0_height to 1080 [01.976]boot_gui_init:finish [01.978]bmp_name=/boot/boot.bmp 230456 bytes read in 83 ms (2.6 MiB/s) [02.076]update dts Net: [02.080]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 [03.106][mmc]: card_caps:0x3000000a [03.109][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2771 bytes read in 11 ms (245.1 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 206 bytes read in 8 ms (24.4 KiB/s) 8484924 bytes read in 3720 ms (2.2 MiB/s) 24129608 bytes read in 4498 ms (5.1 MiB/s) ## Booting kernel from Legacy Image at 41000000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 24129544 Bytes = 23 MiB Load Address: 41000000 Entry Point: 41000000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8484860 Bytes = 8.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Ramdisk to 497e8000, end 49fff7fc ... OK reserving fdt memory region: addr=48000000 size=1000000 ## Linux machid: 00000000, FDT addr: 7be86d60 Starting kernel ... ▒[96]HELLO! BOOT0 is starting May 13 2020 14:10:04! [101]BOOT0 commit : 593cf83 [103]set pll start [106]periph0 has been enabled [109]set pll end [111]unknow PMU [113]PMU: AXP806 [120]vaild para:1 select dram para0 [123]board init ok [125]DRAM BOOT DRIVE INFO: V0.52 [128]the chip id is 0x5000 [131]chip id check OK [133]DRAM_VCC set to 1500 mv [137]read_calibration error [141]read_calibration error [145]read_calibration error [149]read_calibration error [153]read_calibration error [157]read_calibration error [161]read_calibration error [165]read_calibration error [169]read_calibration error [173]read_calibration error [175]retraining final error [180][AUTO DEBUG]32bit,1 ranks training success! [187]DRAM CLK =720 MHZ [190]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [196]Actual DRAM SIZE =1024 M [199]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [212]DRAM simple test OK. [215]rtc standby flag is 0x0, super standby flag is 0x0 [220]dram size =1024 [222]*****dram handle ok**** [226]card no is 0 [227]sdcard 0 line count 4 [230][mmc]: mmc driver ver 2019-12-19 10:41 [234][mmc]: sdc0 spd mode error, 2 [238][mmc]: set f_max to 50M, set f_max_ddr to 25M [243][mmc]: mmc 0 bias 0 [251][mmc]: Wrong media type 0x0 [254][mmc]: ***Try SD card 0*** [263][mmc]: HSSDR52/SDR25 4 bit [266][mmc]: 50000000 Hz [268][mmc]: 15200 MB [270][mmc]: ***SD/MMC 0 init OK!!!*** [369]Loading boot-pkg Succeed(index=0). [373]Entry_name = u-boot [382]Entry_name = monitor [386]Entry_name = dtbo [389]Entry_name = dtb [393]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-armbian (Jun 22 2022 - 07:19:38 +0000) Xunlong Software [00.468]CPU: Allwinner H616 [00.471]Model: Orange Pi Zero 2 I2C: ready [00.476]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.516]secure enable bit: 0 [00.519]PMU: AXP806 [00.524]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.706]sunxi overlay merged okqv [00.709]drv_disp_init [00.738]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.744]drv_disp_init finish [00.746]gic: sec monitor mode [00.752]flash init start [00.754]workmode = 0,storage type = 1 [00.757]MMC: 0 [00.759][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.765][mmc]: get sdc_type fail and use default host:tm1. [00.775][mmc]: Using default timing para [00.779][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.796][mmc]: card_caps:0x3000000a [00.799][mmc]: host_caps:0x3000003f [00.803]sunxi flash init ok [00.806]Loading Environment from FAT... [00.810][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.816][mmc]: get sdc_type fail and use default host:tm1. [00.827][mmc]: Using default timing para [00.830][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.841]usb burn from boot delay time 0 weak:otg_phy_config [00.855]usb prepare ok [01.658]overtime [01.662]do_burn_from_boot usb : no usb exist [01.666]boot_gui_init:start 141 bytes read in 9 ms (14.6 KiB/s) Set HDMI disp_mode to 1080p60 141 bytes read in 8 ms (16.6 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [01.967]boot_gui_init:finish [01.970]bmp_name=/boot/boot.bmp 230454 bytes read in 30 ms (7.3 MiB/s) [02.013]update dts Net: [02.016]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 [03.043][mmc]: card_caps:0x3000000a [03.046][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3202 bytes read in 10 ms (312.5 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 141 bytes read in 8 ms (16.6 KiB/s) 262144 bytes read in 35 ms (7.1 MiB/s) ** File not found /boot/dtb/allwinner/overlay/-fixup.scr ** 6995219 bytes read in 595 ms (11.2 MiB/s) ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. armbian# ** Bad device mmc 1 ** Unknown command '**' - try 'help' armbian# mmc rescan [63.143][mmc]: card_caps:0x3000000a [63.146][mmc]: host_caps:0x3000003f armbian# fatls mmc 0:0 ** Unrecognized filesystem type ** armbian# fatls mmc 1:0 ** Bad device mmc 1 ** armbian# fatls mmc 1:0 ** Bad device mmc 1 ** armbian# fatls mmc 0:1 ** Unrecognized filesystem type ** armbian# [90]HELLO! BOOT0 is starting May 13 2020 14:10:04! [95]BOOT0 commit : 593cf83 [97]set pll start [100]periph0 has been enabled [103]set pll end [105]unknow PMU [106]PMU: AXP806 [114]vaild para:1 select dram para0 [117]board init ok [119]DRAM BOOT DRIVE INFO: V0.52 [122]the chip id is 0x5000 [125]chip id check OK [127]DRAM_VCC set to 1500 mv [131]read_calibration error [135]read_calibration error [139]read_calibration error [143]read_calibration error [147]read_calibration error [151]read_calibration error [155]read_calibration error [159]read_calibration error [163]read_calibration error [166]read_calibration error [169]retraining final error [174][AUTO DEBUG]32bit,1 ranks training success! [181]DRAM CLK =720 MHZ [183]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [190]Actual DRAM SIZE =1024 M [193]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [206]DRAM simple test OK. [208]rtc standby flag is 0x0, super standby flag is 0x0 [214]dram size =1024 [216]*****dram handle ok**** [220]card no is 0 [221]sdcard 0 line count 4 [224][mmc]: mmc driver ver 2019-12-19 10:41 [228][mmc]: sdc0 spd mode error, 2 [232][mmc]: set f_max to 50M, set f_max_ddr to 25M [237][mmc]: mmc 0 bias 0 [245][mmc]: Wrong media type 0x0 [248][mmc]: ***Try SD card 0*** [257][mmc]: HSSDR52/SDR25 4 bit [260][mmc]: 50000000 Hz [262][mmc]: 15200 MB [264][mmc]: ***SD/MMC 0 init OK!!!*** [363]Loading boot-pkg Succeed(index=0). [367]Entry_name = u-boot [376]Entry_name = monitor [380]Entry_name = dtbo [383]Entry_name = dtb [386]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-armbian (Jun 22 2022 - 07:19:38 +0000) Xunlong Software [00.463]CPU: Allwinner H616 [00.466]Model: Orange Pi Zero 2 I2C: ready [00.471]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.511]secure enable bit: 0 [00.514]PMU: AXP806 [00.519]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.701]sunxi overlay merged okqv [00.704]drv_disp_init [00.733]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.739]drv_disp_init finish [00.741]gic: sec monitor mode [00.747]flash init start [00.749]workmode = 0,storage type = 1 [00.752]MMC: 0 [00.754][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.760][mmc]: get sdc_type fail and use default host:tm1. [00.770][mmc]: Using default timing para [00.774][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.792][mmc]: card_caps:0x3000000a [00.795][mmc]: host_caps:0x3000003f [00.798]sunxi flash init ok [00.802]Loading Environment from FAT... [00.805][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.811][mmc]: get sdc_type fail and use default host:tm1. [00.822][mmc]: Using default timing para [00.825][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.837]usb burn from boot delay time 0 weak:otg_phy_config [00.850]usb prepare ok [01.653]overtime [01.657]do_burn_from_boot usb : no usb exist [01.661]boot_gui_init:start 141 bytes read in 9 ms (14.6 KiB/s) Set HDMI disp_mode to 1080p60 141 bytes read in 8 ms (16.6 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [01.962]boot_gui_init:finish [01.965]bmp_name=/boot/boot.bmp 230454 bytes read in 29 ms (7.6 MiB/s) [02.008]update dts Net: [02.011]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 [03.038][mmc]: card_caps:0x3000000a [03.041][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3202 bytes read in 11 ms (284.2 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 141 bytes read in 9 ms (14.6 KiB/s) 262144 bytes read in 35 ms (7.1 MiB/s) ** File not found /boot/dtb/allwinner/overlay/-fixup.scr ** 6995219 bytes read in 594 ms (11.2 MiB/s) ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. armbian# File not found /boot/Imageprintenv Unknown command 'File' - try 'help' armbian# printenv arch=arm baudrate=115200 board=sunxi board_name=sunxi boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_disp=1034 boot_disp1=0 boot_disp2=0 boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_fb0=7bf4fcc0,500,2d0,20,1400,1e0,f0,320,1e0 boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=fel mmc_auto pxe dhcp bootargs=root=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c rootwait rootfstype=ext4 console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=f9fc421d-01 usb-storage.quirks= cgroup_enable=memory swapaccount=1 bootcmd=run distro_bootcmd bootcmd_dhcp=if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi; bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_mmc1=setenv devnum 1; run mmc_boot bootcmd_mmc_auto=if test ${mmc_bootdev} -eq 1; then run bootcmd_mmc1; run bootcmd_mmc0; elif test ${mmc_bootdev} -eq 0; then run bootcmd_mmc0; run bootcmd_mmc1; fi bootcmd_pxe=dhcp; if pxe get; then pxe boot; fi bootdelay=1 bootfstype=ext4 bootlogo=false bootm_size=0xa000000 bootreason=unknow console=serial consoleargs=console=ttyS0,115200 cpu=armv7 devnum=0 devplist=1 devtype=mmc dfu_alt_info_ram=kernel ram 0x41000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43300000 0x4000000 disp_mode=1080p60 disp_reserve=3686400,0x7bf4fcc0 distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done docker_optimizations=on fb0_height=720 fb0_width=1280 fdt_addr_r=0x43000000 fdtaddr=43000000 fdtcontroladdr=7be87560 fdtfile=sunxi/sun50i-h616-orangepi-zero2.dtb fileaddr=43300000 filesize=6abd13 kernel_addr_r=0x41000000 load_addr=0x45000000 mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi overlay_error=false partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system}; partuuid=f9fc421d-01 pxefile_addr_r=0x43200000 ramdisk_addr_r=0x43300000 rootdev=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c rootfstype=ext4 scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x43100000 snum=ac00143c519446f23ce soc=sunxi stderr=serial stdin=serial stdout=serial tv_vdid=2078814848 uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3 verbosity=1 Environment size: 3588/131068 bytes armbian# clear Unknown command 'clear' - try 'help' armbian# cls Unknown command 'cls' - try 'help' armbian# clsscr Unknown command 'clsscr' - try 'help' armbian# printenv arch=arm baudrate=115200 board=sunxi board_name=sunxi boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_disp=1034 boot_disp1=0 boot_disp2=0 boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_fb0=7bf4fcc0,500,2d0,20,1400,1e0,f0,320,1e0 boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=fel mmc_auto pxe dhcp bootargs=root=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c rootwait rootfstype=ext4 console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=f9fc421d-01 usb-storage.quirks= cgroup_enable=memory swapaccount=1 bootcmd=run distro_bootcmd bootcmd_dhcp=if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi; bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_mmc1=setenv devnum 1; run mmc_boot bootcmd_mmc_auto=if test ${mmc_bootdev} -eq 1; then run bootcmd_mmc1; run bootcmd_mmc0; elif test ${mmc_bootdev} -eq 0; then run bootcmd_mmc0; run bootcmd_mmc1; fi bootcmd_pxe=dhcp; if pxe get; then pxe boot; fi bootdelay=1 bootfstype=ext4 bootlogo=false bootm_size=0xa000000 bootreason=unknow console=serial consoleargs=console=ttyS0,115200 cpu=armv7 devnum=0 devplist=1 devtype=mmc dfu_alt_info_ram=kernel ram 0x41000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43300000 0x4000000 disp_mode=1080p60 disp_reserve=3686400,0x7bf4fcc0 distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done docker_optimizations=on fb0_height=720 fb0_width=1280 fdt_addr_r=0x43000000 fdtaddr=43000000 fdtcontroladdr=7be87560 fdtfile=sunxi/sun50i-h616-orangepi-zero2.dtb fileaddr=43300000 filesize=6abd13 kernel_addr_r=0x41000000 load_addr=0x45000000 mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi overlay_error=false partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system}; partuuid=f9fc421d-01 pxefile_addr_r=0x43200000 ramdisk_addr_r=0x43300000 rootdev=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c rootfstype=ext4 scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x43100000 snum=ac00143c519446f23ce soc=sunxi stderr=serial stdin=serial stdout=serial tv_vdid=2078814848 uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3 verbosity=1 Environment size: 3588/131068 bytes armbian# mtest Unknown command 'mtest' - try 'help' armbian# ls ls - list files in a directory (default /) Usage: ls <interface> [<dev[:part]> [directory]] - List files in directory 'directory' of partition 'part' on device type 'interface' instance 'dev'. armbian# 0 Quote
ALIGMSTEN Posted July 11, 2022 Posted July 11, 2022 Doesn't look Armbian, seems to be Legacy image from Orangepi. [100]HELLO! BOOT0 is starting May 13 2020 14:10:04! [105]BOOT0 commit : 593cf83 U-Boot 2018.05-orangepi (Mar 31 2022 - 11:47:20 +0800) Xunlong Software [00.474]CPU: Allwinner H616 [00.477]Model: Orange Pi Zero 2 0 Quote
Werner Posted July 11, 2022 Posted July 11, 2022 Or vendor kernel/uboot which is used in legacy images. 0 Quote
ALIGMSTEN Posted July 11, 2022 Posted July 11, 2022 Oh ok interesting yes could be, do know about vendor source - haven't spent much time with Armbian legacy, still thought its debug was different to above output though. Anyway not helping! Back to @Werner 's question, if OP lets us know the exact image, perhaps some guidance can be given. 0 Quote
gyrex Posted August 22, 2022 Posted August 22, 2022 (edited) After testing a few images in a bid to try and get a working image where wireless works, I can confirm that this issue happens with the current 'supported' Bullseye image: Armbian_22.05.3_Orangepizero2_bullseye_legacy_4.9.255.img As well as a bunch of other 'current' images in the archive. Edited August 22, 2022 by gyrex 0 Quote
gyrex Posted August 22, 2022 Posted August 22, 2022 Boot log from Armbian_22.05.3_Orangepizero2_bullseye_legacy_4.9.255.img [64]HELLO! BOOT0 is starting May 13 2020 14:10:04! [69]BOOT0 commit : 593cf83 [72]set pll start [74]periph0 has been enabled [78]set pll end [79]unknow PMU [81]PMU: AXP806 [88]vaild para:1 select dram para0 [91]board init ok [93]DRAM BOOT DRIVE INFO: V0.52 [96]the chip id is 0x5000 [99]chip id check OK [101]DRAM_VCC set to 1500 mv [105]read_calibration error [109]read_calibration error [113]read_calibration error [117]read_calibration error [121]read_calibration error [125]read_calibration error [128]read_calibration error [132]read_calibration error [136]read_calibration error [140]read_calibration error [143]retraining final error [148][AUTO DEBUG]32bit,1 ranks training success! [155]DRAM CLK =720 MHZ [157]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [164]Actual DRAM SIZE =1024 M [167]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041 [180]DRAM simple test OK. [182]rtc standby flag is 0x0, super standby flag is 0x0 [188]dram size =1024 [190]*****dram handle ok**** [193]card no is 0 [195]sdcard 0 line count 4 [198][mmc]: mmc driver ver 2019-12-19 10:41 [202][mmc]: sdc0 spd mode error, 2 [205][mmc]: set f_max to 50M, set f_max_ddr to 25M [210][mmc]: mmc 0 bias 0 [218][mmc]: Wrong media type 0x0 [221][mmc]: ***Try SD card 0*** [231][mmc]: HSSDR52/SDR25 4 bit [234][mmc]: 50000000 Hz [236][mmc]: 29818 MB [238][mmc]: ***SD/MMC 0 init OK!!!*** [338]Loading boot-pkg Succeed(index=0). [342]Entry_name = u-boot [351]Entry_name = monitor [355]Entry_name = dtbo [357]Entry_name = dtb [361]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-armbian (Jun 22 2022 - 07:19:38 +0000) Xunlong Software [00.437]CPU: Allwinner H616 [00.440]Model: Orange Pi Zero 2 I2C: ready [00.445]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.485]secure enable bit: 0 [00.488]PMU: AXP806 [00.493]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.675]sunxi overlay merged okqv [00.678]drv_disp_init [00.707]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.713]drv_disp_init finish [00.715]gic: sec monitor mode [00.721]flash init start [00.723]workmode = 0,storage type = 1 [00.726]MMC: 0 [00.728][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.734][mmc]: get sdc_type fail and use default host:tm1. [00.744][mmc]: Using default timing para [00.748][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.766][mmc]: card_caps:0x3000000a [00.769][mmc]: host_caps:0x3000003f [00.773]sunxi flash init ok [00.776]Loading Environment from FAT... [00.780][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.786][mmc]: get sdc_type fail and use default host:tm1. [00.796][mmc]: Using default timing para [00.800][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.811]usb burn from boot delay time 0 weak:otg_phy_config [00.824]usb prepare ok [01.627]overtime [01.631]do_burn_from_boot usb : no usb exist [01.635]boot_gui_init:start 141 bytes read in 20 ms (6.8 KiB/s) Set HDMI disp_mode to 1080p60 141 bytes read in 20 ms (6.8 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [01.961]boot_gui_init:finish [01.963]bmp_name=/boot/boot.bmp 230454 bytes read in 44 ms (5 MiB/s) [02.021]update dts Net: [02.024]No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 [03.051][mmc]: card_caps:0x3000000a [03.054][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3202 bytes read in 26 ms (120.1 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 141 bytes read in 19 ms (6.8 KiB/s) 262144 bytes read in 52 ms (4.8 MiB/s) ** File not found /boot/dtb/allwinner/overlay/-fixup.scr ** 6995219 bytes read in 622 ms (10.7 MiB/s) ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. armbian# % 0 Quote
ALIGMSTEN Posted August 22, 2022 Posted August 22, 2022 Hi @gyrex, I haven't read all your posts, perhaps you have already tried. (EDIT: see you have!) Last working legacy image I booted from: Armbian_22.02.2_Orangepizero2_bullseye_legacy_4.9.255.img Have various images in various states of experimental chaos, but have used this above for legacy where all was working, well, I mainly use headless, and minimal builds and then add what needed for purpose, so stand to be corrected on features. 0 Quote
