camstar Posted July 12, 2022 Posted July 12, 2022 Armbian version 22.05.3 Focal Nanopi M4V2 There seem to be only default modes available with the nanopiM4V2. Manual adding a resolution does not work (it is added, but has no effect when selected) NanoPIM4V2 Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 4096 x 4096 HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axi> 1920x1080 60.00* 60.00 50.00 1920x1080i 60.00 50.00 1280x1024 60.02 1280x960 60.00 1280x720 60.00 50.00 1024x768 60.00 800x600 60.32 56.25 720x576 50.00 720x480 59.94 The monitor is a Philips 498P (5120 x 1440). On my Pine64 with Armbian (22.05.3 Jammy) it does support additional resolutions up to 4K. I would like the 2560 x 1440 resolution to work. It looks like the nanopi is not able to read the edid data from the monitor. I have also mentioned this to NicoD and he did confirm this finding. Pine64 Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 8192 x 8192 HDMI-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axi> 3840x1080 59.97 + 3840x2160 30.00 25.00 24.00 29.97 23.98 2560x1440 74.97* 59.95 1920x1080 60.00 60.00 50.00 59.94 1920x1080i 60.00 50.00 59.94 1680x1050 59.88 1280x1024 75.02 60.02 1440x900 59.90 1280x960 60.00 1280x720 60.00 50.00 59.94 1024x768 75.03 70.07 60.00 832x624 74.55 800x600 72.19 75.00 60.32 56.25 720x576 50.00 720x480 60.00 59.94 640x480 75.00 72.81 66.67 60.00 59.94 720x400 70.08 I have read that in the past this or a similar problem existed which was solved by removing the edid reading from u-boot. I have unsuccessfully tried that by building a new u-boot. Does anyone have a solution?
Myron Posted July 12, 2022 Posted July 12, 2022 Providing logs with armbianmonitor -u might help with troubleshooting and significantly does raise the chances that issues gets addressed. Someone, hopefully, might spot a clue to the fault in the diagnostic report.
camstar Posted July 12, 2022 Author Posted July 12, 2022 I did log an issue and successfully followed the procedure a couple of months ago (will look it it up and update). This included the armbianmonitor -u upload. But never heard of it again. So I hoped another nanopi M4V2 user had maybe solved the problem. I know I am not the only one encountering this problem, but you have to connect a monitor capable of > 1920 x 1080 resolution to see this happening.
camstar Posted July 12, 2022 Author Posted July 12, 2022 Just looking into the bug report, and I can't find it anymore. I must have made an error somewhere on the way. Created a new one, the link is http://ix.io/44c8
camstar Posted August 4, 2022 Author Posted August 4, 2022 (edited) Small update: It seeems the EDID is read by the nanopi. By using cros-chameleon to convert the edid binary to readable JASON id did get the info for my monitor: { "Base": { "Basic Display": { "Aspect ratio (landscape)": null, "Aspect ratio (portrait)": null, "Color Bit Depth": null, "Continuous frequency supported": false, "DPM active-off supported": true, "DPM standby supported": false, "DPM suspend supported": false, "Digital Video Interface Standard Support": null, "Display color type": "RGB 4:4:4 + YCrCb 4:4:4", "Display gamma": 2.2, "Maximum dimensions (cm)": { "x": 119, "y": 34 }, "Preferred timing includes native timing pixel format and refresh rate": true, "Video input type": "Digital", "sRGB Standard is default colour space": true }, "Chromaticity": { "Blue": { "x": 153, "y": 68 }, "Green": { "x": 287, "y": 660 }, "Red": { "x": 691, "y": 321 }, "White": { "x": 320, "y": 337 } }, "Descriptors": [ { "Addressable": { "x": 3840, "y": 1080 }, "Blanking": { "x": 160, "y": 31 }, "Border": { "x": 0, "y": 0 }, "Front porch": { "x": 48, "y": 3 }, "Image size (mm)": { "x": 1193, "y": 336 }, "Interlace": false, "Pixel clock (MHz)": 266.5, "Stereo viewing": "No stereo", "Sync pulse": { "x": 32, "y": 10 }, "Sync type": { "Horizontal sync (outside of V-sync)": "Positive", "Type": "Digital Separate Sync", "Vertical sync": "Negative" }, "Type": "Detailed Timing Descriptor" }, { "Data string": "AU02102000537", "Type": "Display Product Serial Number" }, { "Data string": "PHL 498P9", "Type": "Display Product Name" }, { "Horizontal rate (kHz)": { "Maximum": 114, "Minimum": 30 }, "Pixel clock (MHz)": 600, "Subtype": "Default GTF supported", "Type": "Display Range Limits Descriptor", "Vertical rate (Hz)": { "Maximum": 75, "Minimum": 48 } } ], "Established Timing": { "1024x768 @ 60 Hz": true, "1024x768 @ 72 Hz": true, "1024x768 @ 75 Hz": true, "1024x768 @ 87 Hz, interlaced (1024x768i)": false, "1152x870 @ 75 Hz (Apple Macintosh II)": false, "1280x1024 @ 75 Hz": true, "640x480 @ 60 Hz": true, "640x480 @ 67 Hz": true, "640x480 @ 72 Hz": true, "640x480 @ 75 Hz": true, "720x400 @ 70 Hz": true, "720x400 @ 88 Hz": false, "800x600 @ 56 Hz": true, "800x600 @ 60 Hz": true, "800x600 @ 72 Hz": true, "800x600 @ 75 Hz": true, "832x624 @ 75 Hz": true, "Manufacturer specific display mode 1": false, "Manufacturer specific display mode 2": false, "Manufacturer specific display mode 3": false, "Manufacturer specific display mode 4": false, "Manufacturer specific display mode 5": false, "Manufacturer specific display mode 6": false, "Manufacturer specific display mode 7": false }, "Manufacturer Info": { "ID Product Code": 2388, "Manufacturer ID": "PHL", "Model year": null, "Serial number": 537, "Week of manufacture": 2, "Year of manufacture": 2021 }, "Standard Timing": [ { "Frequency": 60, "Ratio": "16:9", "X resolution": 1920 }, { "Frequency": 60, "Ratio": "16:10", "X resolution": 1680 }, { "Frequency": 60, "Ratio": "16:10", "X resolution": 1440 }, { "Frequency": 60, "Ratio": "5:4", "X resolution": 1280 }, { "Frequency": 60, "Ratio": "4:3", "X resolution": 1280 }, { "Frequency": 60, "Ratio": "16:9", "X resolution": 1280 } ] }, "Extensions": [ { "Basic audio": true, "Data blocks": [ { "Short video descriptors": [ { "Nativity": "Non-native", "VIC": 16 }, { "Nativity": "Non-native", "VIC": 31 }, { "Nativity": "Non-native", "VIC": 5 }, { "Nativity": "Non-native", "VIC": 20 }, { "Nativity": "Non-native", "VIC": 4 }, { "Nativity": "Non-native", "VIC": 19 }, { "Nativity": "Non-native", "VIC": 3 }, { "Nativity": "Non-native", "VIC": 18 }, { "Nativity": "Non-native", "VIC": 2 }, { "Nativity": "Non-native", "VIC": 17 }, { "Nativity": "Non-native", "VIC": 1 }, { "Nativity": "Unspecified", "VIC": 96 }, { "Nativity": "Unspecified", "VIC": 97 }, { "Nativity": "Unspecified", "VIC": 93 }, { "Nativity": "Unspecified", "VIC": 94 }, { "Nativity": "Unspecified", "VIC": 95 } ], "Type": "Video Data Block" }, { "Short audio descriptors": [ { "Bit depth": { "16 bit": true, "20 bit": true, "24 bit": true }, "Max channel count": 2, "Supported sampling": { "176.4kHz": false, "192kHz": false, "32kHz": true, "44.1kHz": true, "48kHz": true, "88.2kHz": false, "96kHz": false }, "Type": "Linear Pulse Code Modulation (LPCM)" } ], "Type": "Audio Data Block" }, { "Speaker allocation": { "Front Center": false, "Front Center High": false, "Front Left / Front Right": true, "Front Left Center / Front Right Center": false, "Front Left High / Front Right High": false, "Front Left Wide / Front Right Wide": false, "LFE": false, "Rear Center": false, "Rear Left / Rear Right": false, "Rear Left Center / Rear Right Center": false, "Top Center": false }, "Type": "Speaker Allocation Block" }, { "Data payload": [ 16, 0, 0, 60 ], "IEEE OUI": "00-0c-03", "Type": "Vendor-Specific Data Block" }, { "Data payload": [ 1, 120, 128, 0 ], "IEEE OUI": "c4-5d-d8", "Type": "Vendor-Specific Data Block" }, { "Supported descriptor indices": [ 11, 12 ], "Type": "YCbCr 4:2:0 Capability Map Data Block" }, { "Data payload": [ 1, 1, 48, 75, 230 ], "IEEE OUI": "00-00-1a", "Type": "Vendor-Specific Data Block" } ], "Descriptors": [ { "Addressable": { "x": 3840, "y": 1080 }, "Blanking": { "x": 160, "y": 31 }, "Border": { "x": 0, "y": 0 }, "Front porch": { "x": 48, "y": 3 }, "Image size (mm)": { "x": 1193, "y": 336 }, "Interlace": false, "Pixel clock (MHz)": 333.3, "Stereo viewing": "No stereo", "Sync pulse": { "x": 32, "y": 10 }, "Sync type": { "Horizontal sync (outside of V-sync)": "Positive", "Type": "Digital Separate Sync", "Vertical sync": "Negative" }, "Type": "Detailed Timing Descriptor" }, { "Addressable": { "x": 2560, "y": 1440 }, "Blanking": { "x": 106, "y": 41 }, "Border": { "x": 0, "y": 0 }, "Front porch": { "x": 8, "y": 3 }, "Image size (mm)": { "x": 1193, "y": 336 }, "Interlace": false, "Pixel clock (MHz)": 296.0, "Stereo viewing": "No stereo", "Sync pulse": { "x": 32, "y": 5 }, "Sync type": { "Horizontal sync (outside of V-sync)": "Positive", "Type": "Digital Separate Sync", "Vertical sync": "Negative" }, "Type": "Detailed Timing Descriptor" }, { "Addressable": { "x": 2560, "y": 1440 }, "Blanking": { "x": 160, "y": 41 }, "Border": { "x": 0, "y": 0 }, "Front porch": { "x": 48, "y": 3 }, "Image size (mm)": { "x": 1193, "y": 336 }, "Interlace": false, "Pixel clock (MHz)": 241.5, "Stereo viewing": "No stereo", "Sync pulse": { "x": 32, "y": 5 }, "Sync type": { "Horizontal sync (outside of V-sync)": "Positive", "Type": "Digital Separate Sync", "Vertical sync": "Positive" }, "Type": "Detailed Timing Descriptor" } ], "Native DTD count": 1, "Type": "CEA-861 Series Timing Extension", "Underscan": true, "Version": 3, "YCbCr 4:2:2": true, "YCbCr 4:4:4": true } ], "Version": "1.3" } This was found in the /sys/class/drm/card0-HDMI-A-1/edid file. If I look in the Xorg.log there are two sets of modes, the default and the EDID modes under Supported established timings and the Philips monitor timings under supported detailed timings, but the latter cannot be selected or activated in the display settings. [ 20.481] (II) modeset(0): Supported established timings: [ 20.481] (II) modeset(0): 720x400@70Hz [ 20.481] (II) modeset(0): 640x480@60Hz [ 20.481] (II) modeset(0): 640x480@67Hz [ 20.481] (II) modeset(0): 640x480@72Hz [ 20.481] (II) modeset(0): 640x480@75Hz [ 20.481] (II) modeset(0): 800x600@56Hz [ 20.481] (II) modeset(0): 800x600@60Hz [ 20.481] (II) modeset(0): 800x600@72Hz [ 20.481] (II) modeset(0): 800x600@75Hz [ 20.481] (II) modeset(0): 832x624@75Hz [ 20.481] (II) modeset(0): 1024x768@60Hz [ 20.481] (II) modeset(0): 1024x768@70Hz [ 20.481] (II) modeset(0): 1024x768@75Hz [ 20.481] (II) modeset(0): 1280x1024@75Hz [ 20.481] (II) modeset(0): Manufacturer's mask: 0 [ 20.481] (II) modeset(0): Supported standard timings: [ 20.481] (II) modeset(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361 [ 20.481] (II) modeset(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179 [ 20.481] (II) modeset(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149 [ 20.481] (II) modeset(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 [ 20.481] (II) modeset(0): #4: hsize: 1280 vsize 960 refresh: 60 vid: 16513 [ 20.481] (II) modeset(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281 [ 20.481] (II) modeset(0): Supported detailed timing: [ 20.481] (II) modeset(0): clock: 266.5 MHz Image Size: 1193 x 336 mm [ 20.481] (II) modeset(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0 [ 20.481] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1111 v_border: 0 [ 20.481] (II) modeset(0): Serial No: AU02102000537 [ 20.481] (II) modeset(0): Monitor name: PHL 498P9 [ 20.481] (II) modeset(0): Ranges: V min: 48 V max: 75 Hz, H min: 30 H max: 114 kHz, PixClock max 605 MHz [ 20.481] (II) modeset(0): Supported detailed timing: [ 20.481] (II) modeset(0): clock: 333.3 MHz Image Size: 1193 x 336 mm [ 20.481] (II) modeset(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0 [ 20.481] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1111 v_border: 0 [ 20.481] (II) modeset(0): Supported detailed timing: [ 20.481] (II) modeset(0): clock: 296.0 MHz Image Size: 1193 x 336 mm [ 20.482] (II) modeset(0): h_active: 2560 h_sync: 2568 h_sync_end 2600 h_blank_end 2666 h_border: 0 [ 20.482] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0 [ 20.482] (II) modeset(0): Supported detailed timing: [ 20.482] (II) modeset(0): clock: 241.5 MHz Image Size: 1193 x 336 mm [ 20.482] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0 [ 20.482] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0 [ 20.482] (II) modeset(0): Number of EDID sections to follow: 1 There was an entry in the log regarding the dimensions of the screen (it is a 5k ultra wide Philips 498P) , but keeping in mind the resolutions above 1920x1080 also don't work on a regular sized 4K monitor I don't think this is a problem: [ 51.351] (WW) modeset(0): Output HDMI-1: Strange aspect ratio (1193/336), consider adding a quirk [ 51.352] (WW) modeset(0): Output HDMI-1: Strange aspect ratio (1193/336), consider adding a quirk [ 51.352] (WW) modeset(0): Output HDMI-1: Strange aspect ratio (1193/336), consider adding a quirk [ 51.352] (WW) modeset(0): Output HDMI-1: Strange aspect ratio (1193/336), consider adding a quirk Also I don't now how to add a quirk to solve this. How to make these resolutions availabe in X11? I have tried the XRANDR and CVT route, but without success. Edited August 4, 2022 by camstar added quirk info
