Jeriyant Posted July 27, 2022 Posted July 27, 2022 Please Help me How to Edit File /sys/firmware/devicetree/base/model ? ARMBIAN 5.88 user-built Ubuntu 18.04.2 LTS 5.1.0-aml-s905
Myron Posted July 31, 2022 Posted July 31, 2022 I think this is done by editing the device tree using ... sudo armbian-config Why do you want to edit the model name?
SteeMan Posted July 31, 2022 Posted July 31, 2022 Given the build version info, you are not using an official Armbian build. What sbc are you working with? And I would also like to ask, what are you trying to accomplish? Editing dtb's is an expert level task. I want to make sure you are going down the right path to accomplish your goals.
c0rnelius Posted July 31, 2022 Posted July 31, 2022 If you open the dts file for said board, you'll see something like this a few lines down from the top -> model = "Hardkernel ODROID-C4"; Whatever you put in there is what will spit out the model. You can name it -> model = "Hookers and Flapjacks"; Although, beyond laughs I see no real point in changing this.
