Andrew_ww Posted September 5, 2015 Share Posted September 5, 2015 Hi! I am experiencing problems with sd image install into NAND. Steps to reproduce: -Start with fresh cubie2 board (single a20 processor, image on this page: http://cubieboard.org/2013/06/19/cubieboard2-is-here/ )-Image from link ( http://www.igorpecovnik.com/2013/12/24/cubietruck-debian-wheezy-sd-card-image/ )-Selected "Cubieboard 2" / "Debian wheezy" / "24.8.2015, 3.4.108", image: ( http://mirror.igorpecovnik.com/Armbian_4.2_Cubieboard2_Debian_wheezy_3.4.108.zip )-In the end, its a file "Armbian_4.2_Cubieboard2_Debian_wheezy_3.4.108.raw"-Use win32diskimager, write it to sd card, then boot from-First time root password is "1234" it will ask for a change, do it-Then:-----------------------------------------------------------root@cubieboard2:~# fdisk /dev/nandCommand (m for help): nPartition type: p primary (0 primary, 0 extended, 4 free) e extendedSelect (default p):Using default response pPartition number (1-4, default 1): 2First sector (2048-7782399, default 2048):Using default value 2048Last sector, +sectors or +size{K,M,G} (2048-7782399, default 7782399):Using default value 7782399Command (m for help): wThe partition table has been altered!Calling ioctl() to re-read partition table.Syncing disks.root@cubieboard2:~#------------------------------------------------------------root@cubieboard2:~# cd /rootroot@cubieboard2:~# lsnand-sata-installroot@cubieboard2:~# ./nand-sata-install-------------------------------------------------------------It will tell you, all data will be deleted on nand, and after a second or so it will inform you, should reload that script after reboot-Let it reboot-After:------------------------------------------------------------root@cubieboard2:~# cd /rootroot@cubieboard2:~# lsnand-sata-installroot@cubieboard2:~# ./nand-sata-install-------------------------------------------------------------It will build the system while some minutes-After done, it informs to press a key, and after shutdown, remove the sd card-Do push a button, remove the sd card, power up cubieboard again-What happens now: on power up, green led is blinking, dhcp server tells me, there is no client around, cubieboard doesnt start (?)-What should happen: normal restart of cubieboard-Am i missed something? Can someone confirm plz? Link to comment Share on other sites More sharing options...
Igor Posted September 5, 2015 Share Posted September 5, 2015 - don't do anything to NAND with fdisk. - my script creates NAND partitions and format them - after restart it copy system there In case of troubles. There is a described walkaround which I think is mandatory in your case - Phoenix tools, install some stock linux to restore NAND boot. Then start with clean image, don't touch NAND, only start nand-sata-install script and follow instructions. Link to comment Share on other sites More sharing options...
Andrew_ww Posted September 5, 2015 Author Share Posted September 5, 2015 Nand-sata-install asks for /dev/nand2 device, what does not exist, and until that, tool stucks (Edit: should script create it? Cuz it doesnt..). On a fresh a20 cubie, there is only /dev/nand. That is the reason why i used fdisk - to create /dev/nand2. Have PhoenixSuit 1.10 from sunxi, what reports, there is no attached device. Dont know its reason, either tool is wrong, or i found a broken board (?). Actually i dont know about any tool what can help me to test device usb port on cubie, so i have only ethernet connection this time. Link to comment Share on other sites More sharing options...
