http://apt.armbian.com/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
Go to solution Solved by Igor,
Recently, successfully, upgraded from Ubuntu Focal to Ubuntu Jammy.  Does anyone know the correct procedure to sort out the apt-key deprecation issue?
I've read apt-key(8), but I don't fully understand what I need to do. I think a Linux guru is needed here.  🙂
~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
myron@loki:~$ s apt-get update
Hit:1 http://ports.ubuntu.com jammy InRelease
Hit:2 http://ports.ubuntu.com jammy-security InRelease
Hit:3 http://ports.ubuntu.com jammy-updates InRelease
Hit:4 http://ports.ubuntu.com jammy-backports InRelease
Hit:5 http://packages.azlux.fr/debian bullseye InRelease
Hit:7 https://armbian.github.io/configurator stable InRelease
Hit:6 http://armbian.hosthatch.com/apt jammy InRelease
W: http://apt.armbian.com/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
@Igor, seems to be a bit of a problem. Server returning error 500.
myron@loki:~/Install Armbian repo key$ sudo wget https://apt.armbian.com/armbian.key -O key
--2022-08-16 18:04:47--  https://apt.armbian.com/armbian.key
Resolving apt.armbian.com (apt.armbian.com)... 107.175.134.226
Connecting to apt.armbian.com (apt.armbian.com)|107.175.134.226|:443... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
2022-08-16 18:04:47 ERROR 500: Internal Server Error.
Working here ... re-director is currently under some re-work. Could be related. Its should be a temporal problem.
i am new to armbian not use to deb way.
that i use to rpm way from fedora. (it did work on pine64)
The problem is i need klipper to work for 3d printer, but did not work on fedora and i discovery most come from deb so i start doing on armbain because of pine64 arm.
i had problem apt update (first time tonight before no problem) give error and i had dig info but at end i wipe gpg off and apt key del all. and i found your link and rebutli. it seem work but gpg still do same error.
i would like clean gpg off and rebutli refresh and lastest gpg so i can get apt update to work.   i did not know why it come out error like that tonight first time. it was work well than broken.
i copy and paste show you.
klipper@192.168.0.23's password:
 ____  _             __   _  _
|  _ \(_)_ __   ___ / /_ | || |
| |_) | | '_ \ / _ \ '_ \| || |_
|  __/| | | | |  __/ (_) |__   _|
|_|   |_|_| |_|\___|\___/   |_|
Welcome to Armbian 22.05.3 Jammy with Linux 5.15.48-sunxi64
System load:   77%              Up time:       26 min
Memory usage:  11% of 1.94G     IP:            192.168.0.23
CPU temp:      41°C             Usage of /:    19% of 29G
[ General system configuration (beta): armbian-config ]
Last login: Wed Aug 17 23:18:18 2022 from 192.168.0.1
klipper@pine64:~$ sudo apt update
[sudo] password for klipper:
Hit:3 http://deb.volian.org/volian scar InRelease
Hit:1 https://ryanfortner.github.io/box64-debs/debian ./ InRelease
Hit:5 http://ports.ubuntu.com jammy InRelease
Hit:2 https://cli.github.com/packages stable InRelease
Hit:4 http://au-mirror.bret.dk/armbian/apt jammy InRelease
Hit:6 http://ports.ubuntu.com jammy-security InRelease
Hit:7 http://ports.ubuntu.com jammy-updates InRelease
Hit:8 http://ports.ubuntu.com jammy-backports InRelease
Err:5 http://ports.ubuntu.com jammy InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
Err:6 http://ports.ubuntu.com jammy-security InRelease
Err:7 http://ports.ubuntu.com jammy-updates InRelease
Err:8 http://ports.ubuntu.com jammy-backports InRelease
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ports.ubuntu.com jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ports.ubuntu.com jammy-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ports.ubuntu.com jammy-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ports.ubuntu.com jammy-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: Failed to fetch http://ports.ubuntu.com/dists/jammy/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: Failed to fetch http://ports.ubuntu.com/dists/jammy-security/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: Failed to fetch http://ports.ubuntu.com/dists/jammy-updates/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: Failed to fetch http://ports.ubuntu.com/dists/jammy-backports/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 871920D1991BC93C
W: Some index files failed to download. They have been ignored, or old ones used instead.
klipper@pine64:~$
This is Ubuntu problem, but the solution is probably
sudo apt install ca-certificates
Also check if your clock / date is correct.
I ran into a similar problem wit the Rock5B.
#  apt update
Get:11 http://armbian.hosthatch.com/apt kinetic InRelease [29.4 kB]
Err:11 http://armbian.hosthatch.com/apt kinetic InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
W: GPG error: http://armbian.hosthatch.com/apt kinetic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
My solution was posted earlier, using the ubuntu keyserver (dexrock's reply) as the quick & dirty solution.
Looks to me like the solution above (the one references in the github lines) downloads a different key.
Edited by specs
