HassIO install with Soft on an OrangePiPCPlus
Go to solution Solved by Werner,
ix.io/48Zd
I've simply installed
Armbian 22.05 Jammy
Kernel 5.15.y, Size: 307Mb, Updated: Jul 2, 2022
on my aforementioned subject title / tagged OrangePiPCPlus.
I can't seem to get hassio to install with
armbian-config
and then with Software > Softy
it doesn't seem like the image for homeassistant io gets pulled, because when I check with docker images list or docker ps I don't get anything returned.  Plus the checkbox isn't checked in Soft for hassio when I go back.  What could I be doing wrong here?
I did install Docker first, anyone have any tips?
  • Solution
Correct. That way of installation has been removed by HASS and therefore broke our installer which then got removed:https://github.com/home-assistant/supervised-installer/commit/ece9fcc9468be41c67d052e043a9e70bad16a67a
You have to figure some manual way of installation. No idea though what packages are available and so on.
