I have built an image for BananaPi M3 using build and docker.
I can install fine on 16GB cards, but anything larger is failing on the mmcblk0 partition resize and then is going into repeated fsck's and failed boots.
I have built armbian debian stretch years before and had it installing and running fine on the BananaPi M3, on 256GB uSD Cards.
I tried manually extending the partition from an imaged smaller one running parted followed by resize2fs and it had the same crashing on boot. The boots a bit too fast to ascertain where its crashing but it might be the uDev step.
Can anyone offer any help with this
Edited by AaronNGray
Like today and from latest sources? Can you provide information exactly which image did you build?
Changes to the partition management has been merged last week and they could cause those problems:
https://github.com/armbian/build/pull/4184
https://github.com/armbian/build/pull/4138
@going
2 часа назад, AaronNGray сказал:
Most likely, your sd card has finished its life cycle.
You can check this using the utility fsck
Built from yesterdays master HEAD on WSL Ubuntu with
./compile.sh docker EXPERT="yes" BOARD=bananapim3 RELEASE=buster
Armbian_22.11.0-trunk_Bananapim3_buster_current_5.15.67.img
It seems to be happening with a version of Focal on an older build as well :- Armbian_21.08.1_Bananapim3_focal_current_5.10.60.img
I dont get to a command line on the target system and don't have access to a a uSD Card with Windows Subsystem for Linux. I would have to form an image and mount it to do that.
40 минут назад, AaronNGray сказал:
You have all the tools.
Start Banana PiM 3 with a 16GB card.
Insert a 250GB card via a usb adapter into the BananaPi M3.
The card should be defined as /dev/sda.
sudo fsck /dev/sda
help:
man fsck
I have managed to create a new second partition on the 256GB uSD Card and it seems fine ! This is without the USB adapter, but actually on the working drive.
