_NemO_ Posted September 8, 2015 Posted September 8, 2015 Hello! Thanks for this great project! I've tried to clean install Armbian 4.2 with 4.1.6 kernel on Cubietrack. I've tried Debian Jessie and Wheezy. I've been waiting up to 5 min, but can't find my Cubietrack in network. Boot hangs on (from serial console): U-Boot SPL 2015.07-dirty (Aug 25 2015 - 19:12:58) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 U-Boot 2015.07-dirty (Aug 25 2015 - 19:12:58 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment Setting up a 1024x768 vga console Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga SCSI: SUNXI SCSI INIT Target spinup took 0 ms. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found Hit any key to stop autoboot: 0 6944 bytes read in 225 ms (29.3 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 1821 bytes read in 272 ms (5.9 KiB/s) ## Executing script at 43100000 0 bytes read in 191 ms (0 Bytes/s) 26391 bytes read in 303 ms (85 KiB/s) 5344440 bytes read in 614 ms (8.3 MiB/s) Kernel image @ 0x46000000 [ 0x000000 - 0x518cb8 ] ## Flattened Device Tree blob at 49000000 Booting using the fdt blob at 0x49000000 Using Device Tree in place at 49000000, end 49009716 Starting kernel ... Uncompressing Linux... done, booting the kernel. I've rad that default console on 4.x is HDMI. But there was no green LED blinks during 5 min from boot process start. What did I do wrong? PS: Armbian 4.2 Debian Jessie kernel 3.x works fine.
Igor Posted September 8, 2015 Posted September 8, 2015 Power cycle. Ethernet sometimes hangs if you switch systems with reset only. There is no led blinking on kernel 4.x ... you can enlarge loglevel to 7 in boot.cmd / boot.scr to see more. Images are tested. They work.
_NemO_ Posted September 8, 2015 Author Posted September 8, 2015 Hmmm..., really. It works! PS: I have Li-Ion battery installed, so that's why NIC hangs on reset. 1
_NemO_ Posted September 9, 2015 Author Posted September 9, 2015 /sys/class/power_supply/* is not available in 4.x ?
Igor Posted September 9, 2015 Posted September 9, 2015 Nope, we need different approach at the moment. Under development: http://forum.armbian.com/index.php/topic/45-battery/ Already published but then I disabled because it doesn't work good. https://github.com/igorpecovnik/lib/blob/second/scripts/bashrc#L80
