erpomata Posted October 9, 2016 Share Posted October 9, 2016 Hello everyone I do not know how long, but I found out today that they no longer the wlan0 interface slla my lambo r1.I do not remember to have done in the configuration file changes lately.What can I check?These are the message by the boot if they can help: [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.7.3-sunxi (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #26 SMP Wed Sep 14 19:50:18 CEST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Lamobo R1 [ 0.000000] cma: Reserved 16 MiB at 0x7e800000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 260119 [ 0.000000] free_area_init_node: node 0, pgdat c0e9ea00, node_mem_map ef701000 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:31 [ 0.000000] HighMem zone: 63511 pages, LIFO batch:15 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 14 pages/cpu @ef6bd000 s27916 r8192 d21236 u57344 [ 0.000000] pcpu-alloc: s27916 r8192 d21236 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258391 [ 0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 999456K/1040476K available (9902K kernel code, 672K rwdata, 2240K rodata, 1024K init, 308K bss, 24636K reserved, 16384K cma-reserved, 237660K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0cdbb64 (13135 kB) .init : 0xc0d00000 - 0xc0e00000 (1024 kB) .data : 0xc0e00000 - 0xc0ea830c ( 673 kB) .bss : 0xc0eaa000 - 0xc0ef7158 ( 309 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000022] Switching to timer-based delay loop, resolution 41ns [ 0.000598] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000865] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.001289] Console: colour dummy device 80x30 [ 0.001446] console [tty1] enabled [ 0.001478] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.001493] pid_max: default: 32768 minimum: 301 [ 0.001686] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001701] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002732] CPU: Testing write buffer coherency: ok [ 0.002797] ftrace: allocating 29758 entries in 88 pages [ 0.054826] /cpus/cpu@0 missing clock-frequency property [ 0.054866] /cpus/cpu@1 missing clock-frequency property [ 0.054882] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.054933] Setting up static identity map for 0x40100000 - 0x40100058 [ 0.067508] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.067650] Brought up 2 CPUs [ 0.067676] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.067683] CPU: All CPU(s) started in HYP mode. [ 0.067688] CPU: Virtualization extensions available. [ 0.068843] devtmpfs: initialized [ 0.085104] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 0.085501] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.086373] xor: measuring software checksum speed [ 0.177467] arm4regs : 1130.800 MB/sec [ 0.277543] 8regs : 787.200 MB/sec [ 0.377626] 32regs : 764.800 MB/sec [ 0.477703] neon : 1142.000 MB/sec [ 0.477712] xor: using function: neon (1142.000 MB/sec) [ 0.477865] pinctrl core: initialized pinctrl subsystem [ 0.479360] NET: Registered protocol family 16 [ 0.480697] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.507854] cpuidle: using governor ladder [ 0.537874] cpuidle: using governor menu [ 0.546459] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.546479] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.718116] raid6: int32x1 gen() 159 MB/s [ 0.888363] raid6: int32x1 xor() 146 MB/s [ 1.058684] raid6: int32x2 gen() 192 MB/s [ 1.228733] raid6: int32x2 xor() 156 MB/s [ 1.398930] raid6: int32x4 gen() 198 MB/s [ 1.569050] raid6: int32x4 xor() 155 MB/s [ 1.739181] raid6: int32x8 gen() 185 MB/s [ 1.909237] raid6: int32x8 xor() 127 MB/s [ 2.079517] raid6: neonx1 gen() 447 MB/s [ 2.249624] raid6: neonx1 xor() 328 MB/s [ 2.419782] raid6: neonx2 gen() 587 MB/s [ 2.589872] raid6: neonx2 xor() 426 MB/s [ 2.760088] raid6: neonx4 gen() 651 MB/s [ 2.930259] raid6: neonx4 xor() 450 MB/s [ 3.100429] raid6: neonx8 gen() 625 MB/s [ 3.270582] raid6: neonx8 xor() 435 MB/s [ 3.270590] raid6: using algorithm neonx4 gen() 651 MB/s [ 3.270597] raid6: .... xor() 450 MB/s, rmw enabled [ 3.270604] raid6: using intx1 recovery algorithm [ 3.270971] reg-fixed-voltage ahci-5v: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/ahci_pwr_pin@0, deferring probe [ 3.271031] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_vbus_pin@0, deferring probe [ 3.271070] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe [ 3.271106] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe [ 3.272011] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/gmac_power_pin@0, deferring probe [ 3.273344] SCSI subsystem initialized [ 3.273725] libata version 3.00 loaded. [ 3.274085] usbcore: registered new interface driver usbfs [ 3.274160] usbcore: registered new interface driver hub [ 3.274247] usbcore: registered new device driver usb [ 3.274541] media: Linux media interface: v0.10 [ 3.274599] Linux video capture interface: v2.00 [ 3.274695] pps_core: LinuxPPS API ver. 1 registered [ 3.274704] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.274729] PTP clock support registered [ 3.276519] clocksource: Switched to clocksource arch_sys_counter [ 3.335721] VFS: Disk quotas dquot_6.6.0 [ 3.335839] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 3.337129] simple-framebuffer 7f817000.framebuffer: framebuffer at 0x7f817000, 0x7e9000 bytes, mapped to 0xf0900000 [ 3.337152] simple-framebuffer 7f817000.framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=7680 [ 3.373988] Console: switching to colour frame buffer device 240x67 [ 3.409685] simple-framebuffer 7f817000.framebuffer: fb0: simplefb registered! [ 3.420910] NET: Registered protocol family 2 [ 3.421773] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 3.421888] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 3.422018] TCP: Hash tables configured (established 8192 bind 8192) [ 3.422137] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 3.422206] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 3.422486] NET: Registered protocol family 1 [ 3.423078] RPC: Registered named UNIX socket transport module. [ 3.423096] RPC: Registered udp transport module. [ 3.423103] RPC: Registered tcp transport module. [ 3.423110] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.424194] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 3.425601] futex hash table entries: 512 (order: 3, 32768 bytes) [ 3.426348] Initialise system trusted keyrings [ 3.427012] workingset: timestamp_bits=12 max_order=18 bucket_order=6 [ 3.436989] zbud: loaded [ 3.440468] NFS: Registering the id_resolver key type [ 3.440560] Key type id_resolver registered [ 3.440568] Key type id_legacy registered [ 3.440598] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.440608] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 3.442267] JFS: nTxBlock = 7936, nTxLock = 63490 [ 3.453544] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 3.462745] Key type asymmetric registered [ 3.462855] bounce: pool size: 64 pages [ 3.463212] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 3.463403] io scheduler noop registered [ 3.463418] io scheduler deadline registered [ 3.463483] io scheduler cfq registered (default) [ 3.464469] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe [ 3.468053] sun7i-a20-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 3.544597] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 3.568556] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 44, base_baud = 1500000) is a U6_16550A [ 3.592471] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 45, base_baud = 1500000) is a U6_16550A [ 3.616395] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 46, base_baud = 1500000) is a U6_16550A [ 3.621958] brd: module loaded [ 3.631000] loop: module loaded [ 3.635102] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.635121] ehci-platform: EHCI generic platform driver [ 3.635493] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.635529] ohci-platform: OHCI generic platform driver [ 3.635935] usbcore: registered new interface driver usb-storage [ 3.637300] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0 [ 3.637320] sunxi-rtc 1c20d00.rtc: RTC enabled [ 3.637441] i2c /dev entries driver [ 3.638603] axp20x-i2c 0-0034: AXP20x variant AXP209 found [ 3.651877] input: axp20x-pek as /devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0 [ 3.659788] axp20x-i2c 0-0034: Backup (RTC) battery charging is disabled [ 3.660009] axp20x-i2c 0-0034: AXP20X driver loaded [ 3.679732] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 3.681629] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 3.716834] sunxi-mmc 1c0f000.mmc: base:0xf08f4000 irq:28 [ 3.717851] ledtrig-cpu: registered to indicate activity on CPUs [ 3.717966] hidraw: raw HID events driver (C) Jiri Kosina [ 3.718153] usbcore: registered new interface driver usbhid [ 3.718162] usbhid: USB HID core driver [ 3.719359] Initializing XFRM netlink socket [ 3.720575] NET: Registered protocol family 10 [ 3.721789] NET: Registered protocol family 17 [ 3.721834] NET: Registered protocol family 15 [ 3.721907] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 3.721976] 8021q: 802.1Q VLAN Support v1.8 [ 3.722041] Key type dns_resolver registered [ 3.722467] Registering SWP/SWPB emulation handler [ 3.726615] registered taskstats version 1 [ 3.726632] Loading compiled-in X.509 certificates [ 3.726764] zswap: loaded using pool lzo/zbud [ 3.730042] Btrfs loaded, crc32c=crc32c-generic [ 3.730059] BTRFS: selftest: sectorsize: 4096 nodesize: 4096 [ 3.730067] BTRFS: selftest: sectorsize: 4096 nodesize: 8192 [ 3.730074] BTRFS: selftest: sectorsize: 4096 nodesize: 16384 [ 3.730081] BTRFS: selftest: sectorsize: 4096 nodesize: 32768 [ 3.730087] BTRFS: selftest: sectorsize: 4096 nodesize: 65536 [ 3.735116] Key type encrypted registered [ 3.765097] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.768731] mmc0: new high speed SDHC card at address aaaa [ 3.769653] mmcblk0: mmc0:aaaa SU08G 7.40 GiB [ 3.771500] mmcblk0: p1 [ 3.806616] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP [ 3.806686] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled [ 3.806721] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 3.806739] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc [ 3.808093] scsi host0: ahci-sunxi [ 3.808537] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 33 [ 3.916659] sun7i-dwmac 1c50000.ethernet: no reset control found [ 3.916685] Ring mode enabled [ 3.916694] DMA HW capability register supported [ 3.916703] Normal descriptors [ 3.924431] libphy: stmmac: probed [ 3.924457] eth0: PHY ID 03625f24 at 0 IRQ POLL (stmmac-0:00) active [ 3.924466] eth0: PHY ID 03625f24 at 1 IRQ POLL (stmmac-0:01) [ 3.924476] eth0: PHY ID 03625f24 at 2 IRQ POLL (stmmac-0:02) [ 3.924484] eth0: PHY ID 03625f24 at 3 IRQ POLL (stmmac-0:03) [ 3.924492] eth0: PHY ID 03625f24 at 4 IRQ POLL (stmmac-0:04) [ 3.924501] eth0: PHY ID 03625f24 at 30 IRQ POLL (stmmac-0:1e) [ 3.925042] ehci-platform 1c14000.usb: EHCI Host Controller [ 3.925096] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1 [ 3.925418] ehci-platform 1c14000.usb: irq 30, io mem 0x01c14000 [ 3.936536] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00 [ 3.936920] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.936937] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.936947] usb usb1: Product: EHCI Host Controller [ 3.936957] usb usb1: Manufacturer: Linux 4.7.3-sunxi ehci_hcd [ 3.936967] usb usb1: SerialNumber: 1c14000.usb [ 3.937956] hub 1-0:1.0: USB hub found [ 3.938038] hub 1-0:1.0: 1 port detected [ 3.939033] ehci-platform 1c1c000.usb: EHCI Host Controller [ 3.939087] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2 [ 3.939367] ehci-platform 1c1c000.usb: irq 34, io mem 0x01c1c000 [ 3.956598] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 3.956961] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.956977] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.956987] usb usb2: Product: EHCI Host Controller [ 3.956997] usb usb2: Manufacturer: Linux 4.7.3-sunxi ehci_hcd [ 3.957006] usb usb2: SerialNumber: 1c1c000.usb [ 3.957898] hub 2-0:1.0: USB hub found [ 3.957983] hub 2-0:1.0: 1 port detected [ 3.958885] ohci-platform 1c14400.usb: Generic Platform OHCI controller [ 3.958932] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3 [ 3.959177] ohci-platform 1c14400.usb: irq 31, io mem 0x01c14400 [ 4.020864] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.020882] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.020892] usb usb3: Product: Generic Platform OHCI controller [ 4.020902] usb usb3: Manufacturer: Linux 4.7.3-sunxi ohci_hcd [ 4.020911] usb usb3: SerialNumber: 1c14400.usb [ 4.021778] hub 3-0:1.0: USB hub found [ 4.021854] hub 3-0:1.0: 1 port detected [ 4.022820] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 4.022873] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4 [ 4.023182] ohci-platform 1c1c400.usb: irq 35, io mem 0x01c1c400 [ 4.080822] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.080841] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.080851] usb usb4: Product: Generic Platform OHCI controller [ 4.080861] usb usb4: Manufacturer: Linux 4.7.3-sunxi ohci_hcd [ 4.080870] usb usb4: SerialNumber: 1c1c400.usb [ 4.081807] hub 4-0:1.0: USB hub found [ 4.081899] hub 4-0:1.0: 1 port detected [ 4.082949] usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 4.083568] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 4.083593] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5 [ 4.084051] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.084069] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.084079] usb usb5: Product: MUSB HDRC host driver [ 4.084088] usb usb5: Manufacturer: Linux 4.7.3-sunxi musb-hcd [ 4.084098] usb usb5: SerialNumber: musb-hdrc.1.auto [ 4.085015] hub 5-0:1.0: USB hub found [ 4.085104] hub 5-0:1.0: 1 port detected [ 4.107061] of_cfs_init [ 4.107210] of_cfs_init: OK [ 4.113514] vcc3v0: disabling [ 4.113546] vcc5v0: disabling [ 4.128300] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 4.133512] ata1.00: CFA: Memory Card Adapter, 67281306, max UDMA/66 [ 4.133527] ata1.00: 15130624 sectors, multi 0: LBA [ 4.139036] ata1.00: configured for UDMA/66 [ 4.139925] scsi 0:0:0:0: Direct-Access ATA Memory Card Adap 1306 PQ: 0 ANSI: 5 [ 4.217634] sd 0:0:0:0: [sda] 15130624 512-byte logical blocks: (7.75 GB/7.21 GiB) [ 4.217820] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.218027] sd 0:0:0:0: [sda] Write Protect is off [ 4.218047] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 4.218217] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 4.221012] sda: sda1 [ 4.222602] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 4.234822] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 4.234910] VFS: Mounted root (ext4 filesystem) readonly on device 179:1. [ 4.242994] devtmpfs: mounted [ 4.244355] Freeing unused kernel memory: 1024K (c0d00000 - c0e00000) [ 4.276593] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 4.552520] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available) [ 4.591340] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 4.591807] systemd[1]: Detected architecture 'arm'. [ 4.596618] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 4.604940] systemd[1]: Set hostname to <gw.linux.pg>. [ 4.709242] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 21 bits of entropy available) [ 4.817616] usb 3-1: New USB device found, idVendor=1997, idProduct=2433 [ 4.817643] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.817654] usb 3-1: Product: Mini Keyboard [ 4.817665] usb 3-1: Manufacturer: [ 4.826689] input: Mini Keyboard as /devices/platform/soc@01c00000/1c14400.usb/usb3/3-1/3-1:1.0/0003:1997:2433.0001/input/input1 [ 4.887016] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ Mini Keyboard] on usb-1c14400.usb-1/input0 [ 4.894906] input: Mini Keyboard as /devices/platform/soc@01c00000/1c14400.usb/usb3/3-1/3-1:1.1/0003:1997:2433.0002/input/input2 [ 4.944511] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 4.946967] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ Mini Keyboard] on usb-1c14400.usb-1/input1 [ 4.975224] systemd-sysv-generator[143]: Overwriting existing symlink /run/systemd/generator.late/apache2.service with real service [ 4.978970] systemd-sysv-generator[143]: Overwriting existing symlink /run/systemd/generator.late/hostapd.service with real service [ 4.984160] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 4.985390] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 4.986634] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 5.004941] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 5.005708] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 5.005884] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 5.055340] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of entropy available) [ 5.238677] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 5.242512] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 5.243059] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 5.243179] systemd[1]: Expecting device dev-ttyS0.device... [ 5.243985] systemd[1]: Starting Remote File Systems (Pre). [ 5.244561] systemd[1]: Reached target Remote File Systems (Pre). [ 5.244842] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 5.246216] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 5.246356] systemd[1]: Starting Encrypted Volumes. [ 5.247043] systemd[1]: Reached target Encrypted Volumes. [ 5.247224] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 5.247561] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 5.247644] systemd[1]: Starting Paths. [ 5.248167] systemd[1]: Reached target Paths. [ 5.248270] systemd[1]: Expecting device dev-sda1.device... [ 5.248714] systemd[1]: Starting Root Slice. [ 5.249277] systemd[1]: Created slice Root Slice. [ 5.249370] systemd[1]: Starting User and Session Slice. [ 5.250125] systemd[1]: Created slice User and Session Slice. [ 5.250224] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 5.251044] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 5.251145] systemd[1]: Starting Delayed Shutdown Socket. [ 5.251814] systemd[1]: Listening on Delayed Shutdown Socket. [ 5.251916] systemd[1]: Starting Journal Socket (/dev/log). [ 5.252653] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.252807] systemd[1]: Starting udev Control Socket. [ 5.253483] systemd[1]: Listening on udev Control Socket. [ 5.253622] systemd[1]: Starting udev Kernel Socket. [ 5.254223] systemd[1]: Listening on udev Kernel Socket. [ 5.254364] systemd[1]: Starting Journal Socket. [ 5.255067] systemd[1]: Listening on Journal Socket. [ 5.255304] systemd[1]: Starting System Slice. [ 5.256146] systemd[1]: Created slice System Slice. [ 5.256299] systemd[1]: Starting system-openvpn.slice. [ 5.257448] systemd[1]: Created slice system-openvpn.slice. [ 5.257567] systemd[1]: Starting system-serial\x2dgetty.slice. [ 5.258504] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 5.258604] systemd[1]: Starting system-getty.slice. [ 5.259451] systemd[1]: Created slice system-getty.slice. [ 5.259684] systemd[1]: Starting Increase datagram queue length... [ 5.297584] systemd[1]: Starting Restore / save the current clock... [ 5.305401] systemd[1]: Mounting Debug File System... [ 5.312533] systemd[1]: Starting udev Coldplug all Devices... [ 5.322300] systemd[1]: Mounting POSIX Message Queue File System... [ 5.338766] systemd[1]: Started Set Up Additional Binary Formats. [ 5.384439] systemd[1]: Starting Load Kernel Modules... [ 5.437791] systemd[1]: Mounted Huge Pages File System. [ 5.438549] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 5.444163] systemd[1]: Starting LSB: Set keymap... [ 5.449089] systemd[1]: Starting Slices. [ 5.464325] systemd[1]: Reached target Slices. [ 5.471204] systemd[1]: Mounted POSIX Message Queue File System. [ 5.473667] systemd[1]: Mounted Debug File System. [ 5.476796] systemd[1]: Started Increase datagram queue length. [ 5.485284] systemd[1]: Started Restore / save the current clock. [ 5.494335] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 5.497880] systemd[1]: Started LSB: Set keymap. [ 5.498956] fuse init (API version 7.25) [ 5.502125] systemd[1]: Time has been changed [ 5.619569] systemd[1]: Starting Create Static Device Nodes in /dev... [ 5.643659] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 5.659959] Registered IR keymap rc-empty [ 5.660424] input: sunxi-ir as /devices/platform/soc@01c00000/1c21800.ir/rc/rc0/input3 [ 5.660465] rc rc0: sunxi-ir as /devices/platform/soc@01c00000/1c21800.ir/rc/rc0 [ 5.666389] sunxi-ir 1c21800.ir: initialized sunXi IR driver [ 5.668529] lirc_dev: IR Remote Control driver registered, major 246 [ 5.670858] systemd[1]: Starting Syslog Socket. [ 5.674523] systemd[1]: Listening on Syslog Socket. [ 5.674758] systemd[1]: Starting Journal Service... [ 5.675850] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 5.675875] IR LIRC bridge handler initialized [ 5.683045] systemd[1]: Started Journal Service. [ 5.965461] systemd-udevd[188]: starting version 215 [ 6.665694] sun4i-ss 1c15000.crypto-engine: no reset control found [ 6.667511] sun4i-ss 1c15000.crypto-engine: Die ID 0 [ 6.849147] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro [ 7.215634] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SSFS [ 8.567015] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 8.726857] systemd-journald[178]: Received request to flush runtime journal from PID 1 [ 9.396561] usb 2-1: device descriptor read/64, error -110 [ 24.626628] usb 2-1: device descriptor read/64, error -110 [ 24.856634] usb 2-1: new high-speed USB device number 3 using ehci-platform [ 25.321660] b53_common: found switch: BCM53125, rev 4 [ 25.325829] RX IPC Checksum Offload disabled [ 25.325882] No MAC Management Counters available [ 25.326887] usb 4-1: new full-speed USB device number 2 using ohci-platform [ 27.227912] PPP generic driver version 2.4.2 [ 27.316815] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 27.325994] NET: Registered protocol family 24 [ 29.427711] br0: port 1(eth0.102) entered blocking state [ 29.427742] br0: port 1(eth0.102) entered disabled state [ 29.428175] device eth0.102 entered promiscuous mode [ 29.433718] device eth0 entered promiscuous mode [ 29.440614] br0: port 1(eth0.102) entered blocking state [ 29.440647] br0: port 1(eth0.102) entered forwarding state [ 30.204863] random: nonblocking pool is initialized [ 30.506713] usb 4-1: device descriptor read/64, error -110 [ 31.543852] tun: Universal TUN/TAP device driver, 1.6 [ 31.543858] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 32.636694] ip_tables: (C) 2000-2006 Netfilter Core Team [ 32.722387] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 45.797736] usb 4-1: device descriptor read/64, error -110 [ 46.087663] usb 4-1: new full-speed USB device number 3 using ohci-platform [ 49.518127] fw:ip:OUTPUT:drop IN= OUT=br0 SRC=192.168.10.254 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0x154 [ 50.018122] fw:ip:OUTPUT:drop IN= OUT=br0 SRC=192.168.10.254 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0x154 [ 51.268349] usb 4-1: device descriptor read/64, error -110 Thank you Link to comment Share on other sites More sharing options...
Igor Posted October 9, 2016 Share Posted October 9, 2016 What do you get from: iwconfig Note that on recent kernel, we don't have wlan0 device but some strange name so you need to either rename it to wlan0 or use that name. I build and try 4.8.1 and its show up, will do some brief test later. Link to comment Share on other sites More sharing options...
Igor Posted October 9, 2016 Share Posted October 9, 2016 BTW: it happen to me too - no wireless at another boot so this could easily be is a power related problem. Check other topics for hardware hacks to fix this. Link to comment Share on other sites More sharing options...
erpomata Posted October 11, 2016 Author Share Posted October 11, 2016 Here I am sorry for the delay. iwconfig ppp0 no wireless extensions. eth0.101 no wireless extensions. bond0 no wireless extensions. eth0.104 no wireless extensions. eth0.102 no wireless extensions. tun0 no wireless extensions. lo no wireless extensions. eth0 no wireless extensions. br0 no wireless extensions. What does it mean: BTW: it happen to me too - no wireless at another boot so this could easily be is a power related problem. Check other topics for hardware hacks to fix this. which topic? Link to comment Share on other sites More sharing options...
Igor Posted October 11, 2016 Share Posted October 11, 2016 which topic? There are many topics from R1, probably you should check this one: http://forum.armbian.com/index.php/topic/182-freezing-problems-with-bpi-r1 and do more general forum search with: lamobo power, power issues, power problems, ... Link to comment Share on other sites More sharing options...
erpomata Posted October 11, 2016 Author Share Posted October 11, 2016 I never had power problems but will check. Surely the wifi worked.May I have your list of loaded modules and USB devices?(lsmod, lsusb)? Link to comment Share on other sites More sharing options...
tkaiser Posted October 11, 2016 Share Posted October 11, 2016 I never had power problems but will check. You would be the first one Ok, your case is different since you don't have a disk connected but just a slow flash media adapter? Anyway: the first thing to check on this board is always voltage available. With mainline kernel when using Armbian all the information is available through sysfs. Link to comment Share on other sites More sharing options...
