if you need to use chroot for whatever and have an image-file with only one partition:
1) (sudo) fdisk -l /path/to/image.img
this will tell you the blocksize (usually 512 byte) and the startblock (lets say 2048)
2) (sudo) mount /path/to/image.img -o offset=$((512 * 2048)) /path/to/mount    ((yey, there are the 512 and 2048 again...)
3) now you can follow your mentioned guide again...  (copy the qemu-arm-static, mount -o bind the dev, sys and proc and so on....)
But just for curiosity: Why you need chroot when getting a complete image?
