JeremyA Posted November 2, 2022 Posted November 2, 2022 lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye hwinfo --disk 20: PCI 00.0: 10600 Disk [Created at block.245] Unique ID: wLCS.EJHvc9MwvZ7 Parent ID: VCu0.AxGd7hiuG+6 SysFS ID: /class/block/nvme0n1 SysFS BusID: nvme0 SysFS Device Link: /devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/nvme/nvme0 Hardware Class: disk Model: "Samsung Electronics NVMe SSD Controller SM981/PM981/PM983" Vendor: pci 0x144d "Samsung Electronics Co Ltd" Device: pci 0xa808 "NVMe SSD Controller SM981/PM981/PM983" SubVendor: pci 0x144d "Samsung Electronics Co Ltd" SubDevice: pci 0xa801 Driver: "nvme" Driver Modules: "nvme" Device File: /dev/nvme0n1 Device Files: /dev/nvme0n1, /dev/disk/by-id/nvme-eui.002538540142ff22, /dev/disk/by-path/platform-f8000000.pcie-pci-0000:01:00.0-nvme-1, /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_250GB_S4EUNJ0N451054H Device Number: block 259:0 Geometry (Logical): CHS 238475/64/32 Size: 488397168 sectors a 512 bytes Capacity: 232 GB (250059350016 bytes) Config Status: cfg=new, avail=yes, need=no, active=unknown Attached to: #1 (Non-Volatile memory controller) 21: None 00.0: 10600 Disk [Created at block.245] Unique ID: kLao.Fxp0d3BezAE Parent ID: OBK3._NN+DZ1HDn4 SysFS ID: /class/block/mmcblk1 SysFS BusID: mmc1:aaaa SysFS Device Link: /devices/platform/fe320000.mmc/mmc_host/mmc1/mmc1:aaaa Hardware Class: disk Model: "Disk" Driver: "dwmmc_rockchip", "mmcblk" Device File: /dev/mmcblk1 Device Files: /dev/mmcblk1, /dev/disk/by-path/platform-fe320000.mmc, /dev/disk/by-id/mmc-SC16G_0xe2e82a63 Device Number: block 179:0-179:31 Geometry (Logical): CHS 486192/4/16 Size: 31116288 sectors a 512 bytes Capacity: 14 GB (15931539456 bytes) Config Status: cfg=new, avail=yes, need=no, active=unknown Attached to: #15 (MMC Controller) lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk1 179:0 0 14.8G 0 disk └─mmcblk1p1 179:1 0 14.7G 0 part /media/mmcboot nvme0n1 259:0 0 232.9G 0 disk └─nvme0n1p1 259:1 0 232.9G 0 part / hdparm -t --direct /dev/nvme0n1p1 /dev/nvme0n1p1: Timing O_DIRECT disk reads: 1088 MB in 3.00 seconds = 362.25 MB/sec In comparison I have seen reports of other Rockchip systems with speeds around 1500 MB/sec. The drive is a Samsumg 970 EvoPlus 0 Quote
Werner Posted November 2, 2022 Posted November 2, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
JeremyA Posted November 2, 2022 Author Posted November 2, 2022 armbianmonitor -u http://ix.io/4eJI 0 Quote
