Cannot perform kernel update
Go to solution Solved by Igor,
Hello, when I try to update the kernel via armbian-config (System -> Other ), I always get the message "Test installed failed. Can't change firmware".
I use the Image "Armbian_22.08.5_Uefi-x86_bullseye_current_5.15.73"
The /tmp/switch_kernel.log says the following
linux-image-current-x86=22.08.6 linux-dtb-current-x86=22.08.6
Edited by Mister-XY
Thx, i have upgrade the kernel, because i have change the functions.sh file.But there are also problems with header. Is not possible to compile with debian.
make
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
  You are using:           gcc (Debian 10.2.1-6) 10.2.1 20210110
  CC [M]  /root/it87-it8688E/it87.o
/root/it87-it8688E/it87.c: In function ‘get_temp_type’:
/root/it87-it8688E/it87.c:1494:7: warning: this statement may fall through [-Wimplicit-fallthrough=]
 1494 |    if (index < 3)
/root/it87-it8688E/it87.c:1496:3: note: here
 1496 |   case it8655:
scripts/basic/fixdep: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by scripts/basic/fixdep)
scripts/basic/fixdep: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by scripts/basic/fixdep)
make[2]: *** [scripts/Makefile.build:289: /root/it87-it8688E/it87.o] Fehler 1
make[2]: *** Datei „/root/it87-it8688E/it87.o“ wird gelöscht
make[1]: *** [Makefile:1898: /root/it87-it8688E] Fehler 2
make: *** [Makefile:71: modules] Fehler 2
Known problem, yes. We are working on solving it for some time, but don't know how far we got. @rpardini Are we addressing this problem in the armbian-next somehow?
Basically we need to compile kernel + headers per distribution/gcc which means 4 x more kernels to build, pack and distribute. From around 40 to 160 kernels + headers packages. This will be a bit of a problem as we only have around 1000 CPU cores for CI compilation :huh: ... which is already on the edge.
  • Solution
26 minutes ago, Mister-XY said:
How can i change to the new kernel 5.15.80 for bullseye? I don't see it under the other kernel Menu.
In a couple of days once repository is updated and synced across download network. Or switching to beta repository ... which is good for testing not recommended for production. Kernel recompilation per release is not yet in function. I only tested it, but we don't have enough build hardware for native compilation.
