November 10, 20224 yr Good morning, I cannot seem to get the the newest image (22.08 Bullseye) to boot. I've noticed the disk arrangement is significantly different than the known working image I am using. Here is what I see on the known working image... #fdisk -l Disk /dev/mmcblk0: 28.9 GiB, 30985420800 bytes, 60518400 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 2A33F1A5-75EA-4125-AC19-16C0435D774A Device Start End Sectors Size Type /dev/mmcblk0p1 64 8063 8000 3.9M Linux filesystem /dev/mmcblk0p2 16384 24575 8192 4M Linux filesystem /dev/mmcblk0p3 24576 32767 8192 4M Linux filesystem /dev/mmcblk0p4 32768 262143 229376 112M EFI System /dev/mmcblk0p5 262144 60518366 60256223 28.7G Linux filesystem #cat /etc/debian_version 9.9 The newest image is in has a DOS partition table and only one partition. Disk /dev/sdc: 28.91 GiB, 31016878080 bytes, 60579840 sectors Disk model: STORAGE DEVICE Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x1640add5 Device Boot Start End Sectors Size Id Type /dev/sdc1 32768 3833855 3801088 1.8G 83 Linux Also may be important to note my rock pi S has no onboard flash, only SD slot. Am I missing something? Thank you for your time.
November 10, 20224 yr 7 hours ago, 0xFF said: Good morning, Good evening This image (I assume you tried that) https://redirect.armbian.com/rockpi-s/Bullseye_edge boots on my Rockpi S Logs: https://paste.armbian.com/huvaluwuvi 7 hours ago, 0xFF said: disk arrangement is significantly different Armbian images are not using vendors proprietary partition arrangements. Most (almost all) our images are single partition. 7 hours ago, 0xFF said: cat /etc/debian_version Irrelevant information. "Debian" plays not role here: https://docs.armbian.com/User-Guide_FAQ/ https://www.armbian.com/bugs (console boot log would be extremely helpful) 7 hours ago, 0xFF said: Also may be important to note my rock pi S has no onboard flash, only SD slot. My has it and in that case you need to follow instructions on this page https://www.armbian.com/rockpi-s/ Perhaps your hardware revision is unable to boot modern software? @brentr Any ideas?
November 13, 20223 yr Author hello again and thank you for your response. 1. Yes the link you have provided to Armbian_22.08.7_bullseye_edge is the image i have tried with no luck on the SD card. It does not even seem to load the bootloader, and I have no serial output with the 22.08.7 image. Could the SD card require a different partition expectation than the on board flash? I am still new regarding how the board knows where to look in which flash device for how to boot. The serial output of the working image (rockpis_debian_stretch_minimal_arm64_190806_0234-gpt.img) I have placed here https://paste.armbian.com/lubowiroji . If this image is pushed on to an SD card it loads without pushing any buttons. 2. For the difference in partitioning, in the radxa image has partition 4 as EFI and contains the kernel/rd. Would it be of any value to try and replicate the partition by extracting the contents of the boot directory in the Armbian bullseye image? I would like to help.
November 13, 20223 yr 3 hours ago, 0xFF said: Could the SD card require a different partition expectation than the on board flash? Partition type is not relevant as boot process happens outside. Don't know exactly how different is RK3308 from this https://opensource.rock-chips.com/wiki_Boot_option but you get the picture. 3 hours ago, 0xFF said: I have no serial output with the 22.08.7 image Are you listening on correct UART? Stock firmware could use a different one. You are clearly having different hardware revision as our test device and this could already be good enough reasons why it doesn't boot. Perhaps modern boot loader does not have support for different memory chips or similar. 3 hours ago, 0xFF said: I would like to help. We can help dealing you with your problem more, when our problems are covered. Since budget for what you are asking here is way less then zero, we can only provide best effort support. If you want to help boosting this hardware support for you, everyone else and our competition, just find a way to finance development. If you want to help, forget about your problem and focus on common problems. List is a bit outdated, because HR staff also wants to eat something.
January 29, 20233 yr Hello @0xFF, I have the same issue as you, last working image for me is Armbian_21.08.1_Rockpi-s_bullseye_current_5.10.60_minimal.img.xz All newer images could not boot, and UART is silent. As a workaround I flashed and booted that version and then just did : apt update && apt upgrade then the new version Armbian 22.11.4 Bullseye with Linux 5.15.89-rockchip64 booted up without any issue.
