Jae Woo Song Posted October 13, 2016 Posted October 13, 2016 Hi, I am using orangepi+, i have a problem. My os version is Armbian_5.20_Orangepiplus_Debian_jessie_3.4.112_server. but, when i use reboot command, somtimes it's stopped, it's stop point is -> Starting LSB: set CPUFreq Kernel parameters... I don't know why it's stoped.. plz reply. Thanks.
Igor Posted October 13, 2016 Posted October 13, 2016 Do you have anything attached to the board? What kind of PSU do you use?
tkaiser Posted October 13, 2016 Posted October 13, 2016 it's stop point is -> Starting LSB: set CPUFreq Kernel parameters... This is the moment where default cpufreq setup in u-boot (1008 MHz) switches to cpufrequtils settings (1296 MHz needing a lot more VDD_CPUX voltage). If the board always freezes at this point most likely underpowering problems occur (forget about PSU ratings printed somewhere, replace the PSU or measure on the board's test points)
Jae Woo Song Posted October 14, 2016 Author Posted October 14, 2016 Hi Igor, I am using 5v 3A Power, and i am using CSR Ble board with UART3..
Jae Woo Song Posted October 14, 2016 Author Posted October 14, 2016 tkaiser, It's not always, sometimes, when i use reboot command, i can't see any text, just black screen..
