$ systemctl status
● henry
   State: degraded
    Jobs: 0 queued
  Failed: 1 units
   Since: Sat 2022-12-03 10:19:04 GMT; 24h ago
$ systemctl list-units --failed
 UNIT              LOAD   ACTIVE SUB    DESCRIPTION
● logrotate.service loaded failed failed Rotate log files
$ journalctl -u logrotate.service
Journal file /var/log/journal/c87d7c4913d949949100f089ec48b092/system.journal is truncated, ignoring file.
-- Journal begins at Sun 2022-12-04 00:00:06 GMT, ends at Sun 2022-12-04 10:33:57 GMT. --
Dec 04 00:00:06 henry armbian-ramlog[2714]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2715]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2716]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2717]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2718]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2719]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2720]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2721]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry armbian-ramlog[2722]: /usr/lib/armbian/armbian-ramlog: line 153: /var/log/./journal-20220019-00:00:05/c8>
Dec 04 00:00:06 henry systemd[1]: logrotate.service: Control process exited, code=exited, status=1/FAILURE
Dec 04 00:00:06 henry systemd[1]: logrotate.service: Failed with result 'exit-code'.
Dec 04 00:00:06 henry systemd[1]: Failed to start Rotate log files.
Dec 04 00:00:06 henry systemd[1]: logrotate.service: Consumed 5.879s CPU time.
1 hour ago, Malbonulo said:
systemctl status
We have been applying many fixes for this ... is this happening with latest image? Or this is some old build with upgrades? Always provide this.
Apologies. It's an old build updated to bullseye.
 ___      _           _     _   _   _  ____ _
/ _ \  __| |_ __ ___ (_) __| | | | | |/ ___/ |
| | | |/ _` | '__/ _ \| |/ _` | | |_| | |   | |
| |_| | (_| | | | (_) | | (_| | |  _  | |___| |
\___/ \__,_|_|  \___/|_|\__,_| |_| |_|\____|_|
Welcome to Armbian 22.11.1 Bullseye with Linux 5.4.225-odroidxu4
System load:   1%               Up time:       2 days 3:00
Memory usage:  10% of 1.94G     Zram usage:    5% of 0.97G      IP:            81.187.18.18
CPU temp:      28°C             Usage of /:    6% of 29G
storage/:      57% of 916G
RX today:      Error: Interface "--oneline" not found in database.
[ General system configuration (beta): armbian-config ]
Last login: Mon Dec  5 15:46:03 2022 from 2001:8b0:1312:0:f7c9:e052:f864:973d
admin@henry:~$ sudo armbianmonitor -u
[sudo] password for admin:
System diagnosis information will now be uploaded to https://paste.armbian.com/mulukovagu
Please post the URL in the forum where you've been asked for.
