gordian Posted September 12, 2015 Posted September 12, 2015 Hello, I'd like to use I2S output on my A20, I can see on armbian website Enabled audio devices: analog, HDMI, spdif and I2S (if wired and enabled in HW configuration) but I have no idea on how to activate the HW configuration. I tried to simply plug i2s input and output and type aplay -l but the system can't see any soundcard Can you please help ? Cheers
Igor Posted September 12, 2015 Posted September 12, 2015 You need to enable it in .fex configuration. It's enabled by default on Cubietruck, but on BananaPRO you need to use bananapipro.fex and activate it. https://github.com/igorpecovnik/lib/blob/second/config/bananapipro.fex#L943 [i2s_para] i2s_used = 1 i2s_channel = 2 i2s_mclk = port:PB05<2><1><default><default> i2s_bclk = port:PB06<2><1><default><default> i2s_lrclk = port:PB07<2><1><default><default> i2s_dout0 = port:PB08<2><1><default><default> i2s_dout1 = i2s_dout2 = i2s_dout3 = i2s_din = port:PB12<2><1><default><default> Note that I2S is not wired to connector on all A20 boards. I know that Banana PRO and Cubietruck works.
gordian Posted September 12, 2015 Author Posted September 12, 2015 thanks for your lightspeed reply I feel a bit stupid but I can't find any .fex file in my system edit : tried Vanilla and Legacy kernel and I can't find any .fex file anywhere that is maybe part of the problem
petrmaje Posted September 12, 2015 Posted September 12, 2015 thanks for your lightspeed reply I feel a bit stupid but I can't find any .fex file in my system edit : tried Vanilla and Legacy kernel and I can't find any .fex file anywhere that is maybe part of the problem You must convert /boot/script.bin to fex by bin2fex tool, edit and convert back by fex2bin tool. What device do you want to connect? I have piface with LCD display, which is also connected by SPI (MCP23s17 expander), I tried it some time before with my R1, but without success. If you will make SPI working, post your experiences here, please
gordian Posted September 12, 2015 Author Posted September 12, 2015 Thanks both of you, that did the trick. Sorry Petrmaje, I have no experience with SPI/piface, I had to google it to understand what it was about... I barely understand what I'm doing
drummer44 Posted September 19, 2015 Posted September 19, 2015 Hello Igor, I managed to install your image on nand Lime2, as well edited the .bin file to enable I2S. When I play a wav track with a aplay, following error occurs: [iIS] dma trigger start [iIS] 0x01c22400+0x24 = 0x91, line= 256 aplay: pcm_write:1710: [write error: Input/output error [iIS] dma trigger stop Any idea what could be the cause ? Kindregards drummer44
Igor Posted September 20, 2015 Posted September 20, 2015 Your I2S device is probably not connected to right pins. 1
drummer44 Posted September 20, 2015 Posted September 20, 2015 Hi Igor, ok, after remapping in script.bin to i2s_dout0 and PB08 it seems to be gone. Yet, if I now play a 192kHz 24bit WAV file the output in aplay shows only 'signed 16 bit Little Endian, Rate 192kHz, Stereo. Playing the same song in 24 bit 192 kHz m4a format outputs 'unsigned 8 bit, Rate 8kHz, Mono ... Any ideas ? Was the iis driver not supposed to enable 24 bit as well ? Q- are u using Nikkovs kernel patch to enable sunxi7 soc or which do you use ? http://www.cubieforums.com/index.php/topic,1081.30.html Do we need to write a new kernel driver file in order to enable ALL 3 I2S channels accordingly. Why: Want to use lime2 as 2-way digital crossover - hence 4 channels needed .... Yet when I look at all available kernel patches, only 2 iis channels are enabled and only one i2s line om A20. Wouls highly appreciate any thoughts. Thank you drummer44
drummer44 Posted September 20, 2015 Posted September 20, 2015 Hi, Info/update: if I disable sunxi-codec - the onboard DAC - in script.bin and only enable the sunxi-sndi2s, the above mentioned DMA and Pcm error occurs. This is independent, to which i2s line on A20 I map ... Unfortunately .... so, eihter way, the 24 bit challenge remains. My assumption that nikkovs a20 i2s patch would be needed ... Kind regards drummer44
Igor Posted September 20, 2015 Posted September 20, 2015 I am using Nikkov's driver implementation but this part is not merged yet: http://www.cubieforums.com/index.php/topic,1081.msg23222.html#msg23222
drummer44 Posted September 20, 2015 Posted September 20, 2015 Hi Igor, wow, quite a response time. Many thanks , So, do we have an understanding, that i2s only works with nikkovs patch ? Yes/no ? Or did somebody successfully connect and play a i2s dac to your current sunxi i2s driver version ? My strong assumption is, that your wonderfull image would only work for i2s on a20 with this part merged: https://github.com/nikkov/linux-sunxi/tree/dan-3.4.106/sound/soc/sunxi/i2splus the patches described the mentioned thread ... Ok, any plans to merge nikkovs stuff into you line soon ? If not, any good tips how I could merge myself into your mainline, where is your repo located ? Kind regards drummer44
Igor Posted September 20, 2015 Posted September 20, 2015 I2S works with current driver which is from Nikkov. Working is confirmed by some people. (I don't have I2S hw) https://github.com/dan-and/linux-sunxi I am using this repo together with Daniel. He is working mostly on official patches, me unofficial. No idea when things will be merged ... it's one of the small / not urgent tasks. Help is always welcome!
drummer44 Posted September 21, 2015 Posted September 21, 2015 Hi Igor, Ok. Do you have links available in this forum to "some people ..." that reported i2s works for them ? Their experience would sure help to hunt this pcm error down .... . "Help is always welcome" - how do you see this welcome in detail ? Requests on github, own branches, kernel versions ? Can you be a little bit explicit ? Thank you and kind regards.
Igor Posted September 21, 2015 Posted September 21, 2015 http://www.lemaker.org/forum.php?mod=viewthread&tid=11807&extra=page%3D1&page=2 http://forum.armbian.com/index.php/topic/147-i2s-force-mclk/?hl=sound Help. Request on github or prepared patch against my branch ... For me is just a little more work than replaying to this post but it helps I am having a selection of patches which eventually are merged but until then, they are here: https://github.com/igorpecovnik/lib/tree/second/patch
Igor Posted September 21, 2015 Posted September 21, 2015 Patch is added, so you only need to rebuild or wait for next Armbian build. https://github.com/igorpecovnik/lib/commit/61d76da51584000f564a6e6326a73cc48055aacb
robert.w Posted September 27, 2015 Posted September 27, 2015 Hello for me i2s working fantastic in olinuxino micro - in lime2 unfortunetly no -h/w problems ? check my post at olimex board Armbian_4.2_Micro_Debian_wheezy_3.4.108 for micro: 1. configure fex [i2s_para] i2s_used = 1 i2s_channel = 2 i2s_mclk = port:PB05<2><1><default><default> i2s_bclk = port:PB06<2><1><default><default> i2s_lrclk = port:PB07<2><1><default><default> i2s_dout0 = port:PB08<2><1><default><default> i2s_dout1 = i2s_dout2 = i2s_dout3 = i2s_din = port:PB12<2><1><default><default> 2. add modules to /etc/modules sndspdif sunxi-sndspdif sunxi-spdif sunxi-spdma 3. reboot after this you can check your audio card root@micro:~# cat /proc/asound/cards 0 [sunxicodec ]: sunxi-CODEC - sunxi-CODEC sunxi-CODEC Audio Codec 1 [sunxisndspdif ]: sunxi-sndspdif - sunxi-sndspdif sunxi-sndspdif 2 [sunxisndi2s ]: sunxi-sndi2s - sunxi-sndi2s sunxi-sndi2s 0 = analog output 1 = spdif 2 = i2s important that i2s working for me only in configuration 48KHZ and 44.1 KHz i have tested it using Digilent PmodI2S (CS4344) My own board CS4351
