adrian-rnd Posted December 16, 2022 Posted December 16, 2022 Hi Team, i have a lcd touchscreen android rockchip rk3288 ( armeabi-v7a ) and i want change the OS with armbian and install it on sd card , which image that should i use? regards, Adrian 0 Quote
Igor Posted December 16, 2022 Posted December 16, 2022 7 hours ago, adrian-rnd said: Hi Team This is community forum, welcome! If you want to contact team, check here. But without becoming a partner nobody will be doing any research for you. In custom hardware, team doesn't know to answer without a research. 0 Quote
