technik007_cz Posted December 23, 2022 Posted December 23, 2022 Hi, I have got Rock-3C board recently. It is not Rockpi4 C. Main difference compared to Rock-3A is missing pci-e connector form back of the board, soldered wifi module and only 5V input power. There is no system available for this board. Any ideas how to get this board working? 0 Quote
technik007_cz Posted December 28, 2022 Author Posted December 28, 2022 I messaged radxa developer yesterday and I got link to system images. https://github.com/radxa-build/rock-3c/releases 0 Quote
Igor Posted December 29, 2022 Posted December 29, 2022 On 12/23/2022 at 11:06 PM, technik007_cz said: Any ideas how to get this board working? Doesn't boot with 3A images? 0 Quote
technik007_cz Posted December 29, 2022 Author Posted December 29, 2022 2 hours ago, Igor said: Doesn't boot with 3A images? If you mean Armbian Rock-3A images unfortunately these does not boot up. I tried few, downloaded from this site or compiled ones. Only green led was on and nothing on hdmi or serial terminal (except few broken letters). Hopefully Radxa latest images are working fine but you must avoid upgrading kernel and firmware. I tested these 2: rock-3c_debian_bullseye_cli.img.xz and rock-3c_debian_bullseye_kde.img.xz I got email explaining why firmware breaks, etc... 0 Quote
Philip Couling Posted June 1, 2023 Posted June 1, 2023 Same problem here. I'll add a note that Radxa official images likewise do not boot each other's board. IE you can't use the official 3a image on the 3c board. 0 Quote
Nick1664 Posted March 28, 2024 Posted March 28, 2024 I just got a Rock 3C v1.32 and installed the image Rock-3c-bookworm from the weekly build https://github.com/armbian/community/releases/latest It's working good so far, thanks to everybody working on that project ! 0 Quote
technik007_cz Posted April 19, 2024 Author Posted April 19, 2024 Hi, I am glad we have a working image for Rock 3C. I compiled mine and it also works. I have tested HDMI output, network, wifi, and USB. Also, lxd has no issue with the latest kernel. Because it is an unofficial image I found a missing feature to get wifi working as a hotspot. There were a lot of disappeared lines in /etc/hostpad.conf and also there was a message from the console reporting the hostapd is masked in other words is not running during testing maximum wifi speed. 0 Quote
Gavin Munday Posted June 20, 2024 Posted June 20, 2024 (edited) i cant get any of the weeklies to boot on my 3c? Edited June 20, 2024 by Gavin Munday 0 Quote
north1 Posted June 24, 2024 Posted June 24, 2024 Agreed, I can't get the latest Bookworm image with kernel 6.6.35 to boot 0 Quote
Igor Posted June 24, 2024 Posted June 24, 2024 1 hour ago, north1 said: with kernel 6.6.35 to boot 6.1.y works? 0 Quote
north1 Posted June 24, 2024 Posted June 24, 2024 I haven't tried 6.1.y images but eg 6.6.32 worked fine (built this myself using standard 3C configurations in the build tool). The latest weekly build gets stuck in some kind of loop during the boot process. 0 Quote
north1 Posted June 24, 2024 Posted June 24, 2024 I have not been able to recreate the initial problem. Perhaps there was a problem with my sd card or the power source earlier. I did not change either one, but I can now boot with 6.6.35 without any further problems. I would recommend to Gavin to try a different SD card or power source. I would stay clear of the gnome desktop images though, my experience is that the 3c will freeze up after idling for 10-20 mins if you run with gnome. 0 Quote
