Hi, I have a few Orange Pi PC Plus using Armbian bulldog and have two questions / issues. its my 1st post and not sure where best to ask
1. I have a python program that starts on a service, this can take around 25 seconds to start, I would like sub 20, less than 15 would be fantastic but not sure what service's to remove. reading a few posts here, I have an svg log but unable to see how i can attach?. It boots from eMMC. The program uses USB, I2C and internal UART and wi-fi
2. on a few OPi the wifi will not work. if I type in "sudo iwlist wlan0 scan" it returns " no scan results" if I reboot, it finds this. I have a lot of OPi and some have a wifi issue so I would like to either see if I can reset/interface with the 818fs chip or see why it does not work. I have looked at dmseg and "lsmod | grep 8189sf" and nothing jumps out.
Thanks in advance
5 hours ago, digby26 said:
Armbian bulldog
Sorry, just had to smirk at this 😂
Edit: but sorry, I can't answer your questions. Maybe somebody more knowledgeable will...
I noticed soon as I posted but I was unable to edit it to Bullseye, good way to start a post 😂
some more info. I type "systemd-analyze blame" and I get the below result, is there some easy wins to get the boot time down?
15.021s bootsplash-hide-when-booted.service
 4.823s logrotate.service
 4.301s armbian-hardware-optimize.service
 3.223s armbian-ramlog.service
 2.129s networkd-dispatcher.service
 1.907s armbian-zram-config.service
 1.827s systemd-random-seed.service
 1.392s dev-mmcblk2p1.device
 1.248s man-db.service
  960ms e2scrub_reap.service
  947ms loadcpufreq.service
  877ms systemd-logind.service
  783ms ssh.service
  681ms systemd-udev-trigger.service
  643ms NetworkManager.service
  600ms chrony.service
  585ms user@1000.service
  573ms hostapd.service
  524ms cpufrequtils.service
  503ms keyboard-setup.service
  453ms smartmontools.service
  405ms apt-daily-upgrade.service
  382ms apt-daily.service
  312ms alsa-restore.service
  277ms systemd-journald.service
  270ms sysstat-summary.service
  256ms rsyslog.service
  231ms run-rpc_pipefs.mount
  198ms rc-local.service
  185ms sys-kernel-tracing.mount
  184ms modprobe@fuse.service
  182ms dev-mqueue.mount
  181ms modprobe@drm.service
  181ms fake-hwclock.service
  181ms modprobe@configfs.service
  176ms armbian-led-state.service
  174ms systemd-udevd.service
  174ms kmod-static-nodes.service
  173ms sys-kernel-debug.mount
  160ms networking.service
  154ms sysstat.service
  150ms systemd-modules-load.service
  146ms wpa_supplicant.service
  144ms systemd-remount-fs.service
  140ms systemd-tmpfiles-clean.service
  126ms sysfsutils.service
  113ms systemd-user-sessions.service
  104ms systemd-sysctl.service
   93ms systemd-update-utmp-runlevel.service
   73ms systemd-tmpfiles-setup-dev.service
   72ms systemd-update-utmp.service
   72ms systemd-sysusers.service
   72ms sys-fs-fuse-connections.mount
   69ms systemd-tmpfiles-setup.service
   66ms sys-kernel-config.mount
   66ms polkit.service
   61ms nfs-config.service
   57ms console-setup.service
   56ms rpcbind.service
   50ms sysstat-collect.service
   45ms systemd-rfkill.service
   44ms user-runtime-dir@1000.service
   42ms systemd-journal-flush.service
   25ms tmp.mount
   25ms armbian-hardware-monitor.service
   15ms ifupdown-pre.service
For the Wi-Fi issue, I have done more digging. When the pi does not connect to wifi, if I "dmesg | grep mmc" I get the below response
[    3.436390] mmc1: new high speed SDIO card at address 0001
[    4.067827] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    5.645923] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[   20.916301] sunxi-mmc 1c10000.mmc: data error, sending stop command
[   20.916334] sunxi-mmc 1c10000.mmc: send stop command failed
where on a pi where wifi is good, I do not get the bottom 2 lines, is this a good way to log the issue or is it just a coincidence?
If I "lsmod | grep 8189" I get the below when it can not scan for wifi and when it can
8189fs                901120  0
cfg80211              516096  1 8189fs
If there is any commands you would like me to try, please let me know
Setting fixed IP address might get you some savings.
Thanks Igor, we have from 50 to 100 on each network so they can only be on DHCP, they do get moved around so setting to static will be impossible to manage
Elsewhere you won't get much.
Boot loader waits 1 or 2 seconds for input. This you can disable. Other services all together are close to nothing ... you can get down by shrinking kernel to support your use case only and use busy-box https://busybox.net/ and completely shrink OS functions, but its some work - if you can afford according to your use case. DHCP will sadly remain bottleneck, its also dependant on DHCP server ... this doesn't look like a hobby project?
is there a way to have my service start sooner? The service is currently set to
"After=network.target"
but I have also tried below and that doesn't seem to make it start faster
After=system.slice
Just now, atone said:
Which kind of SD card
its on eMMC
this is the critical chain from my device
graphical.target @17.998s
└─multi-user.target @17.997s
  └─sysfsutils.service @14.776s +1.603s
    └─cpufrequtils.service @12.423s +2.227s
      └─loadcpufreq.service @11.393s +937ms
        └─basic.target @11.297s
          └─armbian-hardware-optimize.service @7.022s +4.270s
            └─sysinit.target @7.008s
              └─systemd-update-utmp.service @6.950s +56ms
                └─systemd-tmpfiles-setup.service @6.854s +71ms
                  └─systemd-journal-flush.service @6.803s +45ms
                    └─systemd-journald.service @6.520s +277ms
                      └─armbian-ramlog.service @3.314s +3.196s
                        └─var-log.mount @3.412s
                          └─dev-zram1.device @2.789s
23 minutes ago, atone said:
system.slice seems to be one of the last elements of the critical chain
My bad, the tree is upside down.
Don't know how it works, but "network.target" is not listed.
Edit: neither is system.slice
