yuri.vivaldi Posted January 31, 2023 Share Posted January 31, 2023 Hi everyone, I'm working on a bunch of arm boards, where I installed armbian on the eMMC I'm trying to re-flash some of them, via SD and then via nand-sata-install, but something is wrong A fresh SD works, as in: boot from SD run nand-sata-install select eMMC run and wait But as soon as I try to do it a second time, on a second board, it breaks, meaning that nand-sata-install doesn't show any storage device, while /dev/mmc* it's recognized from linux (image 1) INFO: Armbian monitor log $ uname -a Linux rockpi-s 6.0.10-rockchip64 #22.11.1 SMP PREEMPT Wed Nov 30 11:20:25 UTC 2022 aarch64 GNU/Linux 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 31, 2023 Share Posted January 31, 2023 28 minutes ago, yuri.vivaldi said: But as soon as I try to do it a second time, on a second board You mean you pull out SD card and move it to the next it fails? Not sure if we ever tested this scenario. I don't known any amateur user that would need such feature. 0 Quote Link to comment Share on other sites More sharing options...
yuri.vivaldi Posted January 31, 2023 Author Share Posted January 31, 2023 (edited) 2 minutes ago, Igor said: You mean you pull out SD card and move it to the next it fails? Yes, flash the first device, then move it to a second one and try to nand-sata-install it Do I need to reset some sort of checked file in the in the SD, some sort of lock? Also, I did it on other armbian installations and hardware, and it worked Edited January 31, 2023 by yuri.vivaldi Clarifications 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 31, 2023 Share Posted January 31, 2023 1 minute ago, yuri.vivaldi said: Do I need to reset some sort of checked file in the in the SD, some sort of lock? I don't work on technical support. Like I said, such functioning was not predicted in design. Its not exactly a bug as it was not planned. In case you need some assurance that someone will look into ... but as this is open source, anyone can add and test functionality you need. 0 Quote Link to comment Share on other sites More sharing options...
yuri.vivaldi Posted January 31, 2023 Author Share Posted January 31, 2023 Allright thanks 0 Quote Link to comment Share on other sites More sharing options...
