PiRat Posted February 1, 2023 Share Posted February 1, 2023 Orange Pi Zero 2 running on current image (from release date: Jan 10, 2023) fail to boot after upgrade. The boot log: U-Boot 2018.05-armbian (Jan 10 2023 - 07:48:03 +0000) Xunlong Software [00.535]CPU: Allwinner H616 [00.538]Model: Orange Pi Zero 2 I2C: ready [00.542]DRAM: 1 GiB Relocation Offset is: 35ec7000 [00.583]secure enable bit: 0 [00.586]PMU: AXP806 [00.591]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.773]sunxi overlay merged okqv [00.776]drv_disp_init [00.805]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.811]drv_disp_init finish [00.813]gic: sec monitor mode [00.819]flash init start [00.821]workmode = 0,storage type = 1 [00.824]MMC: 0 [00.825][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.832][mmc]: get sdc_type fail and use default host:tm1. [00.842][mmc]: Using default timing para [00.846][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.872][mmc]: card_caps:0x3000000a [00.876][mmc]: host_caps:0x3000003f [00.881]sunxi flash init ok [00.884]Loading Environment from FAT... [00.888][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.894][mmc]: get sdc_type fail and use default host:tm1. [00.904][mmc]: Using default timing para [00.908][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [00.919]usb burn from boot delay time 0 weak:otg_phy_config [00.932]usb prepare ok [01.104]usb sof ok [01.106]usb probe ok [01.108]usb setup ok set address 0x12 set address 0x12 ok [04.114]do_burn_from_boot usb : have no handshake [04.118]boot_gui_init:start 190 bytes read in 11 ms (16.6 KiB/s) Set HDMI disp_mode to 1080p60 190 bytes read in 10 ms (18.6 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [04.430]boot_gui_init:finish [04.433]bmp_name=/boot/boot.bmp 230454 bytes read in 32 ms (6.9 MiB/s) [04.481]update dts Net: [04.484]No ethernet found. Hit any key to stop autoboot: 1 0 no mmc device at slot 1 [05.520][mmc]: card_caps:0x3000000a [05.523][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3259 bytes read in 13 ms (244.1 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 190 bytes read in 10 ms (18.6 KiB/s) 262144 bytes read in 38 ms (6.6 MiB/s) ** File not found /boot/dtb/allwinner/overlay/-fixup.scr ** 7225390 bytes read in 618 ms (11.1 MiB/s) ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. armbian# After some investigation it appears that the problem occurs when updating armbian-bsp-cli-orangepizero2 to version 22.11.4, holding the package on version 22.11.3 prevent the bug and allow to update all other packages, including kernel updates (last check on 31.01.2023) without issue. Thank you for your great work on this distribution and have a nice day. 0 Quote Link to comment Share on other sites More sharing options...
inkflaw Posted February 7, 2023 Share Posted February 7, 2023 Thx, you are right, I have same problem. But why armbian-bsp-cli-orangepizero2 update will break boot? 0 Quote Link to comment Share on other sites More sharing options...
ALIGMSTEN Posted February 10, 2023 Share Posted February 10, 2023 On 2/1/2023 at 4:38 PM, PiRat said: ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... Upgrade overwrites: build/config/bootscripts/boot-sun50iw9.cmd 0 Quote Link to comment Share on other sites More sharing options...
peppelongo96 Posted February 13, 2023 Share Posted February 13, 2023 Just re-apply kernel upgrade freezing on armbian-config is working too. Seems like "armbian-bsp-cli-orangepizero2" escaped from default freezed setting. 0 Quote Link to comment Share on other sites More sharing options...
ALIGMSTEN Posted February 13, 2023 Share Posted February 13, 2023 It would be interesting, well sort-of, what the output of uname -a is, after holding back >> On 2/1/2023 at 4:38 PM, PiRat said: armbian-bsp-cli-orangepizero2 22.11.3 build/config/bootscripts/boot-sun50iw9.cmd and specifically line 67 is what legacy expects bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} implicitly build/config/bootscripts/boot-sun50i-next.cmd referencing line 77 is what boot found booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} I can only posit that build/config/boards/orangepizero2.conf line 12 is a culprit # Allwinner H616 quad core 512MB/1GB RAM SoC WiFi SPI USB-C BOARD_NAME="Orange Pi Zero2" BOARDFAMILY="sun50iw9" BOOTCONFIG="orangepi_zero2_defconfig" MODULES_LEGACY="uwe5622_bsp_sdio sprdbt_tty sprdwl_ng" MODULES_BLACKLIST="lima" DEFAULT_CONSOLE="serial" HAS_VIDEO_OUTPUT="no" SERIALCON="ttyS0" KERNEL_TARGET="legacy,current,edge" PACKAGE_LIST_BOARD="rfkill bluetooth bluez bluez-tools" FORCE_BOOTSCRIPT_UPDATE="yes" and again surmise that bsp-cli.sh from lines 172 in particular from lines 186, would need looking at. EOF # install bootscripts if they are not present. Fix upgrades from old images if [[ $FORCE_BOOTSCRIPT_UPDATE == yes ]]; then cat <<- EOF >> "${destination}"/DEBIAN/postinst if [ true ]; then # this package recreate boot scripts EOF else cat <<- EOF >> "${destination}"/DEBIAN/postinst if [ ! -f /boot/$bootscript_dst ]; then # if boot script does not exits its recreated EOF fi I rarely go very deep into the build scripts, so please correct if completely wrong. I also would not intend to look much myself on this right now, and rather focus on mainline and putting what time have towards improving that. Armbian-next is the future with master code freeze anyhow. 0 Quote Link to comment Share on other sites More sharing options...
nordonsimf Posted March 1, 2023 Share Posted March 1, 2023 I also updated the system and Orange stopped loading 0 Quote Link to comment Share on other sites More sharing options...
plus90 Posted March 9, 2023 Share Posted March 9, 2023 My Orange Pi Zero 2 fails to boot after running `sudo apt upgrade` and `sudo reboot` as well. Lights on the ethernet port blink, but it won't boot. See video: https://streamable.com/mih5nk 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 9, 2023 Share Posted March 9, 2023 I have tried yesterday https://github.com/armbian/build/issues/4892#issuecomment-1460176070 and last image + update, everything is fine. At least for me. 0 Quote Link to comment Share on other sites More sharing options...
