my Orange PI Plus is no Wifi.
when i give lsusb is it no wifi modul.
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 05e3:0718 Genesys Logic, Inc. IDE/SATA Adapter
Bus 002 Device 003: ID 05ac:0256 Apple, Inc.
Bus 002 Device 002: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Armbian and Lubuntu the same.
any idea?
What do you get from:
iwconfig
Not all wifi modules are connected via USB. On those boards, many are using SDIO interface.
I would suggest:
sudo modprobe 8189es
iwconfig
and if then still no Wi-Fi interface is available the output from 'sudo armbianmonitor -u' would be helpful. BTW: 'lshw' on SBCs is the better idea than 'lsusb' (but needs an 'sudo apt-get install lshw' with Armbian).
iwconfig
root@orangepiplus:~# iwconfig
lo        no wireless extensions.
tunl0     no wireless extensions.
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
eth0      no wireless extensions.
sudo modprob 8189es
iwconfig
root@orangepiplus:~# sudo modprobe 8189es
          Sensitivity:0/0
          Encryption key:off
          Sensitivity:0/0
          Encryption key:off
Next steps:
no the # for the interfaces is no change.
iwconfig say the same
wlan4     unassociated  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
          Encryption key:off
with nmtui is no activate from the wifi. when plug in the stick this is working are the onboard wifi nothing.
the antenna is right plugged in.
