jpm Posted February 9, 2023 Posted February 9, 2023 Has anyone managed to get video encoder working with the latest mainline kernel? I'm getting stuck trying to compile the cedar_ve kernel driver from https://github.com/uboborov/sunxi-cedar-mainline I have downloaded the kernel source using armbian-config and then built the sunxi-cedar-mainline kernel driver. However, I fail to load the driver due to version magic: Quote root@nanopineo:~# modprobe cedar_ve modprobe: ERROR: could not insert 'cedar_ve': Exec format error root@nanopineo:~# dmesg | tail -n 1 [ 653.998366] cedar_ve: version magic '5.15.80 SMP mod_unload ARMv7 thumb2 p2v8 ' should be '5.15.80-sunxi SMP mod_unload ARMv7 thumb2 p2v8 ' When trying to force the load: Quote root@nanopineo:~# modprobe -f cedar_ve modprobe: ERROR: could not insert 'cedar_ve': Exec format error But no dmesg message about magic check failure. 0 Quote
jpm Posted February 18, 2023 Author Posted February 18, 2023 Some updates: 1) Updated the dts file as required in https://github.com/uboborov/sunxi-cedar-mainline 2) Fixed cedar_ve compilation issues / kernel name 3) after loading the cedar_ve.ko, get only this is dmesg: Quote [ 71.096286] cedar_ve: loading out-of-tree module taints kernel. [ 71.097176] cedar_ve: module verification failed: signature and/or required key missing - tainting kernel [ 71.098546] sunxi cedar version 0.1 @ubobrov I would appreciate any insights. 0 Quote
jpm Posted February 19, 2023 Author Posted February 19, 2023 @ning Thanks for the link. But if I understand correctly - this is for decode. I need to encode h264. 0 Quote
schunckt Posted September 22 Posted September 22 Hi ! @jpm how exactly did you solve 2) Fixed cedar_ve compilation issues / kernel name ? I'm gettinf the same "modprobe: ERROR: could not insert 'cedar_ve': Exec format error" T. 0 Quote
sasa Posted September 29 Posted September 29 Hi, maybe someone will find this patch useful. It adds JPEG and H264 encoding to the main Cedrus driver. Both encoders use a stable stateful API, so they can be used with any multimedia software, such as gstreamer, ffmpeg, etc. gst-launch-1.0 videotestsrc pattern=smpte ! video/x-raw,width=1920,height=1080 ! v4l2h264enc ! h264parse ! matroskamux ! filesink location=test_h264.mkv gst-launch-1.0 videotestsrc ! v4l2jpegenc ! matroskamux ! filesink location=test_mjpeg.mkv I tested it on T113 (jpeg) and A40 (jpeg, h264) processors and I think it should work with H3 as well. It doesn't work with 64-bit processors like H616/T507 because their encoders have been updated, and as far as I know, they haven't been reverse-engineered yet. linux-6.12.28-cedrus-enc.patch 0 Quote
going Posted September 30 Posted September 30 14 часов назад, sasa сказал: Hi, maybe someone will find this patch useful. It adds JPEG and H264 encoding to the main Cedrus driver. Both encoders use a stable stateful API, so they can be used with any multimedia software, such as gstreamer, ffmpeg, etc. gst-launch-1.0 videotestsrc pattern=smpte ! video/x-raw,width=1920,height=1080 ! v4l2h264enc ! h264parse ! matroskamux ! filesink location=test_h264.mkv gst-launch-1.0 videotestsrc ! v4l2jpegenc ! matroskamux ! filesink location=test_mjpeg.mkv I tested it on T113 (jpeg) and A40 (jpeg, h264) processors and I think it should work with H3 as well. It doesn't work with 64-bit processors like H616/T507 because their encoders have been updated, and as far as I know, they haven't been reverse-engineered yet. linux-6.12.28-cedrus-enc.patch 66.8 \u041a\u0431 · 2 скачивания Please tell me the source of this patch. 0 Quote
sasa Posted September 30 Posted September 30 1 час назад, going сказал: Please tell me the source of this patch. This is internal development for our boards, unfortunately, there is no public repository for our kernel. The code is borrowed from reverse-engineered POCs h264 + * Based on https://github.com/jemk/cedrus + * Copyright (c) 2014-2015 Jens Kuske <jenskuske@gmail.com> jpeg + * Based on https://gitorious.org/recedro/jepoc + * Copyright (c) 2014 Manuel Braga <mul.braga@gmail.com> 0 Quote
piernov Posted Tuesday at 03:26 PM Posted Tuesday at 03:26 PM Thanks a lot for the patch. Got the H264 encoder to encode the test pattern on Allwinner V3s, with the additional following patches: https://lkml.org/lkml/2020/11/16/486 "ARM: dts: sun8i: v3s: Add node for system control", https://lkml.org/lkml/2020/11/16/485 "ARM: dts: sun8i: v3s: Add video engine node", and the patch in attachment to enable JPEG/H264 encoder capabilities on V3s. However the lack of RAM on V3s causes the kernel CMA to really struggle so I have only been able to run the encoder at low definitions for now. 0001-media-cedrus-v3s-H264-and-JPEG-and-capabilities.patch 0 Quote
