Wizzard Posted February 14, 2023 Share Posted February 14, 2023 I own a T95Z Plus box and tried that armbian build (lunar and sid). It works, but none of them have sound working. Sid does not have wifi working either. Tried also this and the sound works there. What may be a problem? https://github.com/debiangamer/build/releases/tag/v2021.05 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted February 15, 2023 Share Posted February 15, 2023 Which dtb are you using? Since you found someone who apparently got these things working, you would probably be best served by reaching out to them to see what they did to get wifi/sound working on this box. It looks like they forked their build from armbian a while back and here is a link to the diff between the base armbian they forked from and their set of changes: https://github.com/armbian/build/compare (Your answers are somewhere in that diff). Since I don't own that box, there isn't much I can do beyond pointing you in these directions. 1 Quote Link to comment Share on other sites More sharing options...
Wizzard Posted February 15, 2023 Author Share Posted February 15, 2023 (edited) I am using meson-gxm-q200.dtb. Also tried to use this dtb from debiangamer's build (same name), it is slightly different, but it did not help. I know it will be a long way to solve it. I was just interested if anyone had similar box and got it working. When I fully updated debiangamer's build using apt, Firefox stopped working correctly, it had some issues with GUI and graphics, it was broken. Chromium worked still and even the sound still works there. But, when I test the audio in KDE system settings, I have the same error like in the latest Armbian community build (something with the driver). edit: the link to original (locked) post: Edited February 15, 2023 by Wizzard 0 Quote Link to comment Share on other sites More sharing options...
