Unable to Disable Armbian Patch by Creating a Blank File in userpatches
Any patch files I put in  build/userpatches/kernel/archive/sunxi-6.1/ are applied correctly, however I cannot disable an Armbian patche.
When I put a blank file in userpatches the original patch file remains active.
I'm trying to disable:
patch/kernel/archive/sunxi-6.1/patches.armbian/arm64-dts-sun50i-h6-orangepi.dtsi-Rollback-r_rsb-to-r_i2c.patch
I put a blank file in:
build/userpatches/kernel/archive/sunxi-6.1/patches.armbian/arm64-dts-sun50i-h6-orangepi.dtsi-Rollback-r_rsb-to-r_i2c.patch
I've also tried putting a blank file in:-
build/userpatches/kernel/archive/sunxi-6.1/arm64-dts-sun50i-h6-orangepi.dtsi-Rollback-r_rsb-to-r_i2c.patch
Please can somebody tell me what I'm doing wrong?
Please try with armbian-next
https://www.armbian.com/newsflash/code-freeze-and-moving-to-new-framework/
Current master branch is going towards EOL soon. If we have a bug, it will only be fixed in the new system.
Worse case use a workaround - remove it withing build script - remove file patch/kernel/archive/sunxi-6.1/patches.armbian/arm64-dts-sun50i-h6-orangepi.dtsi-Rollback-r_rsb-to-r_i2c.patch
6 часов назад, paulsykes сказал:
In order to disable the patch, it is enough to put a minus sign at the beginning of the line with this patch in the "series.conf" file.
These patches exist, but they don't apply.
