Sharelter Posted February 27, 2023 Posted February 27, 2023 Hi, I just downloaded the newest release of Armbian and flashed into the SD card, it boots up fine from the SD Card. But I wanna install the system into the Samsung PM9A1 SSD, So I followed the instruction on the armbian page, partioned the drive and made a ext4 filesystem. but I got stuck when I tried to boot up from SSD. I hooked up a serial cable and got this information Any idea about this? 0 Quote
Sharelter Posted February 28, 2023 Author Posted February 28, 2023 Hi, I solved this problem by editing the `boot.cmd` file under /boot I checked `/boot/armbianEnv.txt` and got nothing wrong, but the `boot.cmd` still uses the old `mmcblk0p1` which is not correct. After I edited it and compiled it to boot.scr, and the system finally boots up normally again! 0 Quote
lurk101 Posted March 1, 2023 Posted March 1, 2023 (edited) Quote I checked `/boot/armbianEnv.txt` and got nothing wrong, but the `boot.cmd` still uses the old `mmcblk0p1` which is not correct. After I edited it and compiled it to boot.scr, and the system finally boots up normally again! Expand Odd, my boot.cmd file has setenv rootdev "/dev/mmcblk0p1" yet boots just fine from nvme, without sdcard of emmc installed. How did you create boot.scr from boot.cmd? Found it! # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Edited March 1, 2023 by lurk101 addition 0 Quote
