when booting Armbian Sid minimal rolling 6.1.11, there is no serial console login.
Console output:
1993 bytes read in 146 ms (12.7 KiB/s)
## Executing script at 12000000
93 bytes read in 94 ms (0 Bytes/s)
38318 bytes read in 2603 ms (13.7 KiB/s)
33621022 bytes read in 3482 ms (9.2 MiB/s)
11215360 bytes read in 1257 ms (8.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 14800000 ...
   Image Name:   uInitrd
   Data Size:    33620958 Bytes = 32.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800c5ad
Starting kernel ...
Is there a way to enable console login to use the device headlessly?
Thanks
There is serial login. I more assume that boot fails for some reason.
increase verbosity via armbianEnv.txt to 7 and boot again to see what happens.
This is armbianEnv.txt:
verbosity=1
bootlogo=false
rootdev=UUID=30b36fce-65d1-44c4-bcec-3677c9fe01bd
rootfstype=ext4
4 hours ago, cvxx said:
But the serial stays quiet
IIRC serial on imx6 kernel broke down year(s) ago and it seems it stayed that way. When that happened? No idea. Just saying this is possibility.
