ParadoxX27 Posted October 26, 2016 Share Posted October 26, 2016 Hello! The problem is that the system goes into hibernation, but does not resume - just a black screen. It helps only the power reset. What's the matter? What's wrong with the resume from hibernation? Please help! Link to comment Share on other sites More sharing options...
Igor Posted October 26, 2016 Share Posted October 26, 2016 None of those boards were meant to be used this way so this is not implemented AFAIK. Only standby / resume and that should work out of the box.Or this happen when screen saver kicks in and you don't use Armbian desktop? Link to comment Share on other sites More sharing options...
ParadoxX27 Posted October 26, 2016 Author Share Posted October 26, 2016 None of those boards were meant to be used this way so this is not implemented AFAIK. Only standby / resume and that should work out of the box. Or this happen when screen saver kicks in and you don't use Armbian desktop? I compiled and included image hibernation. After the command "systemctl hibernate" OPi goes into hibernation, but it does not wake up when the power is reconnected, hanging on a black screen. I guess, the system can not properly restore data from a swap, but normally goes into hibernation. Maybe it is possible to somehow fix it? ps Sorry for my English, I use a translator. Link to comment Share on other sites More sharing options...
Igor Posted October 27, 2016 Share Posted October 27, 2016 Maybe it is possible to somehow fix it? Probably it is, but we are overwhelmed with tasks. You will be faster on your own. 1 Link to comment Share on other sites More sharing options...
