rwk Posted March 15, 2023 Posted March 15, 2023 Hello, I have been building images for the NanoPC-T4 with armbian successfully in the past. However I now get the error "could not resolve 'ports.ubuntu.com'" when the build tries to install ping_5.1-1_arm64.deb (full log below). Do you have any idea what this comes from and how I could solve/debug this ? Thank you Additional info : I added 8.8.8.8 as an alternative DNS server on my machine, I can ping ports.ubuntu.com successfully. I have cloned the armbian build and head points to this commit https://github.com/armbian/build/commit/5b8d86ae5f6f34cf6cc13edf6b1def2773f66f0a Best regards, Rick Spoiler # Armbian ANSI build logs for d42a3aa9-4268-47db-87f0-64b17653a3d0 - use "less -SR" to view # Armbian build at Wed Mar 15 10:06:22 CET 2023 on a12a13pctsp ------------------------------------------------------------------------------------------------------------ # ARGs: 'PREFER_DOCKER=no' 'CREATE_PATCHES=yes' 'ARMBIAN_RELAUNCHED=yes' 'SET_OWNER_TO_UID=1000' 'build' ------------------------------------------------------------------------------------------------------------ # GIT revision commit 5b8d86ae5f6f34cf6cc13edf6b1def2773f66f0a (HEAD -> main, origin/main, origin/HEAD, origin/AR-1609) Author: 瑞 <rui.crater@gmail.com> Enable kernel Ion system for running Android (#4948) ------------------------------------------------------------------------------------------------------------ # GIT status On branch main Your branch is up to date with 'origin/main'. nothing to commit, working tree clean ------------------------------------------------------------------------------------------------------------ ### config_early_init.log --> (1) INFO: Starting single build process [ no BOARD set ] --> (1) INFO: Checking [ basic host setup ] --> (1) INFO: Build host OS release [ jammy ] --> (1) INFO: Build host architecture [ amd64 ] --> (4) INFO: Generating list of all available boards [ might take a while ] ------------------------------------------------------------------------------------------------------------ ### config_source_board_file.log --> (8) INFO: Sourcing board configuration [ /home/reds/patch_series_pcie_ep/build/config/boards/nanopct4.conf ] ------------------------------------------------------------------------------------------------------------ ### do_main_configuration.log --> (12) INFO: Starting main configuration --> (13) INFO: Sourcing family configuration [ /home/reds/patch_series_pcie_ep/build/config/sources/families/media.conf ] --> (13) INFO: Enabling extension [ rkbin-tools ] --> (13) INFO: Determined BOOT_SOC from BOOTCONFIG [ BOOT_SOC: 'rk3399'; BOOTCONFIG: 'nanopc-t4-rk3399_defconfig' ] --> (13) INFO: Sourcing arch configuration [ arm64.conf ] --> (13) INFO: Extension manager [ processed 4 Extension Methods calls and 4 Extension Method implementations ] ------------------------------------------------------------------------------------------------------------ ### config_post_main.log --> (23) INFO: Configuration prepared for BOARD build [ nanopct4.conf ] --> (23) EXT: Repeat Build Options (early) [ ./compile.sh BOARD=nanopct4 BRANCH=edge RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_ONLY=no KERNEL_CONFIGURE=yes DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DESKTOP_APPGROUPS_SELECTED="3dsupport browsers desktop_tools editors internet programming remote_desktop" COMPRESS_OUTPUTIMAGE=sha,img ] ------------------------------------------------------------------------------------------------------------ ### check_dir_for_mount_options.log --> (23) INFO: Checked directory OK for mount options [ /home/reds/patch_series_pcie_ep/build/.tmp ('main temporary dir') ] ------------------------------------------------------------------------------------------------------------ ### prepare_host_noninteractive.log --> (23) INFO: Preparing [ host ] --> (24) COMMAND: update-ccache-symlinks --> (24) INFO: Syncing clock [ host ] --> (24) COMMAND: ntpdate pool.ntp.org 15 Mar 09:37:44 ntpdate[5675]: adjust time server 62.12.167.109 offset -0.001978 sec --> (30) INFO: Ignoring toolchains [ SKIP_EXTERNAL_TOOLCHAINS: yes ] --> (30) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/templates/customize-image.sh.template /home/reds/patch_series_pcie_ep/build/userpatches/customize-image.sh '/home/reds/patch_series_pcie_ep/build/config/templates/customize-image.sh.template' -> '/home/reds/patch_series_pcie_ep/build/userpatches/customize-image.sh' ------------------------------------------------------------------------------------------------------------ ### aggregate_packages.log --> (30) INFO: Aggregating packages [ rootfs ] --> (30) INFO: Python3 version [ 3.10.6 - 'Python 3.10.6' ] --> (31) INFO: pip3 version [ 22.0.2: 'pip 22.0.2 from /usr/lib/python3/dist-packages/pip (python 3.10)' ] --> (31) INFO: Installing pip packages for Python tools [ c40672ecb3 ] --> (31) COMMAND: rm -fv /home/reds/patch_series_pcie_ep/build/cache/pip/pip_pkg_hash* --> (31) COMMAND: env -i 'PYTHONUSERBASE=/home/reds/patch_series_pcie_ep/build/cache/pip/base' 'PYTHONUNBUFFERED=yes' 'PYTHONPYCACHEPREFIX=/home/reds/patch_series_pcie_ep/build/cache/pip/pycache' /usr/bin/python3 -m pip install --no-warn-script-location --user unidiff==0.7.4 GitPython==3.1.30 unidecode==1.3.6 coloredlogs==15.0.1 Collecting unidiff==0.7.4 Using cached unidiff-0.7.4-py2.py3-none-any.whl (14 kB) Collecting GitPython==3.1.30 Using cached GitPython-3.1.30-py3-none-any.whl (184 kB) Collecting unidecode==1.3.6 Using cached Unidecode-1.3.6-py3-none-any.whl (235 kB) Collecting coloredlogs==15.0.1 Using cached coloredlogs-15.0.1-py2.py3-none-any.whl (46 kB) Collecting gitdb<5,>=4.0.1 Using cached gitdb-4.0.10-py3-none-any.whl (62 kB) Collecting humanfriendly>=9.1 Using cached humanfriendly-10.0-py2.py3-none-any.whl (86 kB) Collecting smmap<6,>=3.0.1 Using cached smmap-5.0.0-py3-none-any.whl (24 kB) Installing collected packages: unidiff, unidecode, smmap, humanfriendly, gitdb, coloredlogs, GitPython Successfully installed GitPython-3.1.30 coloredlogs-15.0.1 gitdb-4.0.10 humanfriendly-10.0 smmap-5.0.0 unidecode-1.3.6 unidiff-0.7.4 WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv --> (32) COMMAND: touch /home/reds/patch_series_pcie_ep/build/cache/pip/pip_pkg_hash_c40672ecb319ec9a04b3471e3c6da8d006211683c969a19c9412cdb42c737c51 --> (32) COMMAND: [...shortened...] /usr/bin/python3 /home/reds/patch_series_pcie_ep/build/lib/tools/aggregation.py Summary: Aggregation: debootstrap: 8; rootfs: 113; image: 1; desktop: 150; apt-sources: 3; hash: bcf5b56cab61ec8f --> (32) COMMAND: rm -f /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.vqWieXUjMQ ------------------------------------------------------------------------------------------------------------ ### clean_deprecated_mountpoints.log --> (32) INFO: artifact [ uboot :: uboot() ] ------------------------------------------------------------------------------------------------------------ ### artifact_prepare_version.log --> (33) INFO: Producing new & caching [ GIT_INFO_UBOOT ] --> (33) INFO: Fetching SHA1 of tag v2022.04^{} [ https://github.com/u-boot/u-boot ] --> (33) INFO: SHA1 of tag v2022.04^{} [ 'e4b6ebd3de982ae7185dbf689a030e73fd06e0d2' ] ------------------------------------------------------------------------------------------------------------ ### artifact_is_available_in_remote_cache.log --> (33) INFO: Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-uboot/uboot-nanopct4-edge:2022.04-Se4b6-Pd69e-B6324 ] --> (33) INFO: Downloading required [ ORAS tooling ] --> (33) COMMAND: wget --no-verbose --progress=dot:giga -O /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64.tar.gz.tmp https://github.com/oras-project/oras/releases/download/v0.16.0/oras_0.16.0_linux_amd64.tar.gz --> (34) COMMAND: mv /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64.tar.gz.tmp /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64.tar.gz --> (34) COMMAND: tar -xf /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64.tar.gz -C /home/reds/patch_series_pcie_ep/build/cache/tools/oras oras --> (34) COMMAND: rm -rf /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64.tar.gz --> (34) COMMAND: mv /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64 --> (34) COMMAND: chmod +x /home/reds/patch_series_pcie_ep/build/cache/tools/oras/oras_0.16.0_linux_amd64 --> (34) INFO: Artifact is not available in remote cache [ ghcr.io/armbian/cache-uboot/uboot-nanopct4-edge:2022.04-Se4b6-Pd69e-B6324 ] ------------------------------------------------------------------------------------------------------------ ### fetch_and_build_host_tools.log --> (34) INFO: Getting sources from Git [ rkbin-tools master ] --> (34) INFO: Initializing empty git local copy [ git init: rkbin-tools master ] --> (34) COMMAND: git --no-pager init -q . --> (34) INFO: Fetching updates from remote repository [ rkbin-tools master ] --> (34) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/armbian/rkbin master From https://github.com/armbian/rkbin * branch master -> FETCH_HEAD --> (38) INFO: git: Fetch from remote completed, rev-parsing... [ 'rkbin-tools' 'master' 'FETCH_HEAD' ] --> (38) COMMAND: git --no-pager checkout -f -q 03d632d7c247fa7eb3468ced32e78c34a37b4cbe --> (38) COMMAND: git --no-pager clean -q -d -f --> (38) INFO: Installing [ rkbin-tools ] --> (38) COMMAND: /usr/bin/git --no-pager rev-parse @ --> (38) INFO: Cloning u-boot from mainline into bare tree [ this might take a somewhat-long time ] --> (38) COMMAND: git clone --verbose --progress --tags --no-checkout https://github.com/u-boot/u-boot /home/reds/patch_series_pcie_ep/build/cache/git-bare/u-boot --> (56) INFO: Getting sources from Git [ u-boot v2022.04 ] --> (56) COMMAND: git -C /home/reds/patch_series_pcie_ep/build/cache/git-bare/u-boot worktree add /home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04 master --no-checkout --force --> (56) COMMAND: echo /home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04/.git > /home/reds/patch_series_pcie_ep/build/cache/git-bare/u-boot/.git/worktrees/v2022.04/gitdir --> (57) INFO: Fetching updates from remote repository [ u-boot v2022.04 ] --> (57) COMMAND: /usr/bin/git --no-pager fetch --verbose --progress --recurse-submodules=no --no-tags https://github.com/u-boot/u-boot tags/v2022.04 --> (57) INFO: git: Fetch from remote completed, rev-parsing... [ 'u-boot' 'v2022.04' 'FETCH_HEAD' ] --> (57) COMMAND: git --no-pager checkout -f -q 4727ad8881b26b56100c2778840f6242cf044918 --> (58) COMMAND: git --no-pager clean -q -d -f --> (58) INFO: Using u-boot revision SHA1 [ 4727ad8881b26b56100c2778840f6242cf044918 ] ------------------------------------------------------------------------------------------------------------ ### compile_uboot.log --> (58) INFO: Compiling u-boot [ 2022.04 /home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04 ] --> (58) INFO: Compiler version [ aarch64-linux-gnu-gcc '11.3.0' ] --> (58) INFO: {u-boot:1} Checking out to clean sources SHA1 4727ad8881b26b56100c2778840f6242cf044918 [ {u-boot-worktree/u-boot/v2022.04} for u-boot-dtb.bin ] --> (59) INFO: Calling Python patching script [ for u-boot target ] --> (59) COMMAND: [...shortened u-boot patching...] /usr/bin/python3 /home/reds/patch_series_pcie_ep/build/lib/tools/patching.py Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0050-add-board-rock-pi-s.patch(:1): 'Target without source: +++ b/arch/arm/dts/rk3308-rock-pi-s.dts 2020-12-25 15:53:15.775897762 +0200' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0180-rk3399-always-init-rkclk.patch(:1): 'Hunk diff line expected: rkclk_init(priv->cru);' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0230-u-boot-rk3399-roc-pc-plus.patch(:1): 'Unexpected new file found: new file mode 100644' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0240-u-boot-rk3399-roc-pc-plus-dts.patch(:1): 'Unexpected new file found: new file mode 100644' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0310-u-boot-rk-rk3399-opi800-config.patch(:1): 'Unexpected new file found: new file mode 100644' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0320-u-boot-rk-rk3399-opi800-dts.patch(:1): 'Unexpected new file found: new file mode 100644' Failed to parse unidiff for file /home/reds/patch_series_pcie_ep/build/patch/u-boot/u-boot-media/0340-u-boot-rk-rk3399-opi800-uboot-dtsi.patch(:1): 'Unexpected new file found: new file mode 100644' Applying 38 patches from 38 files of which 38 patches in regular, sorted files... -> 01/38: 0010-add-board-helios64(:1) (+2111/-0)[2M, 10A] {rk3399-kobol-helios64.dts, helios64.c, sys_otp.c, helios64-rk3399_defconfig, rk3399-kobol-helios64-u-boot.dtsi, helios64.h, Kconfig, sys_otp.h, MAINTAINERS, Makefile} -> 02/38: 0020-add-board-nanopi-m4v2(:1) (+185/-0)[1M, 3A] {rk3399-nanopi-m4v2.dts, nanopi-m4v2-rk3399_defconfig, rk3399-nanopi-m4v2-u-boot.dtsi, Makefile} -> 03/38: 0030-add-board-orangepi-4(:1) (+299/-0)[1M, 3A] {rk3399-orangepi-4.dts, orangepi-4-rk3399_defconfig, rk3399-orangepi-4-u-boot.dtsi, Makefile} -> 04/38: 0040-add-board-orangepi-r1plus(:1) (+157/-0)[1M, 3A] {orangepi_r1_plus_rk3328_defconfig, rk3328-orangepi-r1-plus.dts, rk3328-orangepi-r1-plus-u-boot.dtsi, Makefile} -> 05/38: 0050-add-board-rock-pi-s(:1) -> 06/38: 0060-add-board-tinker-board-2(:1) (+762/-1)[5M, 7A] {rk3399-tinker-2.dts, tinker-2-rk3399_defconfig, rk3399-tinker-2-u-boot.dtsi, tinker-2-rk3399.c, tinker-2_rk3399.h, Kconfig, Makefile, fan53555.c, fan53555.h} -> 07/38: 0070-add-trust-ini(:1) (+15/-0)[1A] {trust.ini} -> 08/38: 0080-board-pinebook-pro-0003-spi-flash-support(:1) (+14/-1)[2M] {pinebook-pro-rk3399_defconfig, rk3399-pinebook-pro-u-boot.dtsi} -> 09/38: 0090-board-pinebook-pro-0005-panel-reset(:1) (+9/-1)[1M] {pinebook-pro-rk3399.c} -> 10/38: 0100-board-pinebook-pro-0007-increase-nvme-timeout(:1) (+6/-0)[1M] {nvme.c} -> 11/38: 0110-board-rockpro64-advanced-recovery(:1) (+9/-0)[1M] {rockpro64-rk3399_defconfig} -> 12/38: 0120-enable-DT-overlays-support(:1) (+2/-0)[1M] {Kconfig} -> 13/38: 0130-general-add-xtx-spi-nor-chips(:1) (+11/-0)[2M] {Kconfig, spi-nor-ids.c} -> 14/38: 0140-general-set-eth1addr(:1) (+5/-0)[1M] {misc.c} -> 15/38: 0150-general-support-recovery-button(:1) (+173/-0)[2M] {boot_mode.c, Kconfig} -> 16/38: 0160-general-support-rmii-integrated-phy(:1) (+453/-46)[10M] {clk_rk3328.c, rk3229-evb.dts, clk_rk322x.c, phy.txt, rk322x.dtsi, evb-rk3229_defconfig, evb-rk3328_defconfig, gmac_rockchip.c, cru_rk322x.h} -> 17/38: 0170-rk3328-efuse-driver(:1) (+87/-2)[2M] {rockchip-efuse.c, rk3328_common.h} -> 18/38: 0180-rk3399-always-init-rkclk(:1) -> 19/38: 0190-rk3399-enable-stable-mac(:1) (+4/-0)[1M] {rk3399_common.h} -> 20/38: 0200-rk3399-populate-child-node-of-syscon(:1) (+3/-0)[1M] {syscon_rk3399.c} -> 21/38: 0210-sdmmc-force-fifo-mode-in-spl(:1) (+4/-0)[1M] {rockchip_dw_mmc.c} -> 22/38: 0220-u-boot-0010-rk-usb-start(:1) (+1/-1)[1M] {rockchip-common.h} -> 23/38: 0230-u-boot-rk3399-roc-pc-plus(:1) -> 24/38: 0240-u-boot-rk3399-roc-pc-plus-dts(:1) -> 25/38: 0250-u-boot-rk-rk3328-dtsi(:1) (+85/-12)[1M] {rk3328.dtsi} -> 26/38: 0260-u-boot-rk-rk3328-roc-cc-dts(:1) (+32/-0)[1M] {rk3328-roc-cc.dts} -> 27/38: 0270-u-boot-rk-rk3328-roc-pc-config(:1) (+107/-0)[1A] {roc-pc-rk3328_defconfig} -> 28/38: 0280-u-boot-rk-rk3328-roc-pc-dts(:1) (+124/-0)[1A] {rk3328-roc-pc.dts} -> 29/38: 0290-u-boot-rk-rk3328-roc-pc-include(:1) (+18/-0)[1A] {roc_rk3328_pc.h} -> 30/38: 0300-u-boot-rk-rk3328-roc-pc-make-dts(:1) (+1/-0)[1M] {Makefile} -> 31/38: 0301-u-boot-rk-rk3328-roc-pc-u-boot-dtsi(:1) (+68/-0)[1A] {rk3328-roc-pc-u-boot.dtsi} -> 32/38: 0310-u-boot-rk-rk3399-opi800-config(:1) -> 33/38: 0320-u-boot-rk-rk3399-opi800-dts(:1) -> 34/38: 0330-u-boot-rk-rk3399-opi800-makefile(:1) (+1/-0)[1M] {Makefile} -> 35/38: 0340-u-boot-rk-rk3399-opi800-uboot-dtsi(:1) -> 36/38: 0350-u-boot-rk-rk3399-usb-start(:1) (+1/-1)[1M] {rockchip-common.h} -> 37/38: 0360-u-boot-rk-rk3399-usb-start-firefly-rk3399(:1) (+9/-0)[1M] {firefly-rk3399_defconfig} -> 38/38: 0370-u-boot-rk-rk3399-usb-start-nanopc-t4(:1) (+6/-0)[1M] {nanopc-t4-rk3399_defconfig} Summary: u-boot patching: 38 total patches; 38 applied; 37 with problems; 22 needs_rebase; 30 not_mbox; 7 invalid_diff --> (59) COMMAND: cat /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.B5xpNmQrjK --> (59) COMMAND: rm -f /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.B5xpNmQrjK --> (59) WARNING: @TODO [ @TODO armbian-next ] --> (59) WARNING: Make your changes in this directory: [ /home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04 ] --> (59) WARNING: Press <Enter> after you are done [ waiting ] --> (273) WARNING: No changes found, skipping patch creation 3.2.1.--> (276) INFO: {u-boot:1} Preparing u-boot config [ 2022.04 u-boot-dtb.bin ] --> (276) COMMAND: CCACHE_BASEDIR=/home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04 PATH=/usr/bin::/usr/lib/ccache:/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin KCFLAGS=-fdiagnostics-color=always unbuffer make -j36 nanopc-t4-rk3399_defconfig CROSS_COMPILE="ccache aarch64-linux-gnu-" HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o YACC scripts/kconfig/zconf.tab.c LEX scripts/kconfig/zconf.lex.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf arch/../configs/nanopc-t4-rk3399_defconfig:69:warning: override: reassigning to symbol USB_GADGET # # configuration written to .config # --> (278) INFO: {u-boot:1} Compiling u-boot [ 2022.04 u-boot-dtb.bin with gcc '11.3.0' ] --> (278) COMMAND: ccache --zero-stats Statistics zeroed --> (278) COMMAND: CFLAGS='-fdiagnostics-color=always -Wno-error=maybe-uninitialized -Wno-error=misleading-indentation -Wno-error=attributes -Wno-error=address-of-packed-member -Wno-error=array-parameter' KCFLAGS='-fdiagnostics-color=always -Wno-error=maybe-uninitialized -Wno-error=misleading-indentation -Wno-error=attributes -Wno-error=address-of-packed-member -Wno-error=array-parameter' CCACHE_BASEDIR=/home/reds/patch_series_pcie_ep/build/cache/sources/u-boot-worktree/u-boot/v2022.04 PATH=/usr/bin::/usr/lib/ccache:/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin unbuffer make u-boot-dtb.bin -j36 CROSS_COMPILE="ccache aarch64-linux-gnu-" scripts/kconfig/conf --syncconfig Kconfig .config:2138:warning: override: reassigning to symbol BOOTDELAY UPD include/config.h CFG u-boot.cfg GEN include/autoconf.mk.dep CFG spl/u-boot.cfg CFG tpl/u-boot.cfg GEN include/autoconf.mk GEN tpl/include/autoconf.mk GEN spl/include/autoconf.mk UPD include/generated/dt.h ENVC include/generated/env.txt UPD include/generated/timestamp_autogenerated.h UPD include/config/uboot.release ENVP include/generated/env.in ENVT include/generated/environment.h HOSTCC scripts/dtc/dtc.o UPD include/generated/version_autogenerated.h HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.h YACC scripts/dtc/dtc-parser.tab.c CC lib/asm-offsets.s CC arch/arm/lib/asm-offsets.s UPD include/generated/generic-asm-offsets.h UPD include/generated/asm-offsets.h LDS u-boot.lds HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/dtc HOSTCC tools/bmp_logo HOSTCC tools/gen_eth_addr HOSTCC tools/gen_ethaddr_crc.o WRAP tools/lib/crc8.c HOSTCC tools/img2srec HOSTCC tools/mkenvimage.o HOSTCC tools/os_support.o WRAP tools/lib/crc32.c HOSTCC tools/aisimage.o HOSTCC tools/atmelimage.o HOSTCC tools/fit_common.o HOSTCC tools/fit_image.o HOSTCC tools/image-host.o WRAP tools/boot/image-fit.c HOSTCC tools/image-sig-host.o WRAP tools/boot/image-fit-sig.c WRAP tools/boot/image-cipher.c WRAP tools/boot/fdt_region.c WRAP tools/boot/bootm.c HOSTCC tools/lib/crc32.o HOSTCC tools/default_image.o WRAP tools/lib/fdtdec_common.c WRAP tools/lib/fdtdec.c WRAP tools/boot/image.c WRAP tools/boot/image-host.c HOSTCC tools/imagetool.o HOSTCC tools/imximage.o HOSTCC tools/imx8image.o HOSTCC tools/imx8mimage.o HOSTCC tools/kwbimage.o WRAP tools/lib/md5.c HOSTCC tools/lpc32xximage.o HOSTCC tools/mxsimage.o HOSTCC tools/omapimage.o HOSTCC tools/pblimage.o HOSTCC tools/pbl_crc32.o HOSTCC tools/vybridimage.o HOSTCC tools/stm32image.o WRAP tools/lib/rc4.c HOSTCC tools/rkcommon.o HOSTCC tools/rkimage.o HOSTCC tools/rksd.o HOSTCC tools/rkspi.o HOSTCC tools/socfpgaimage.o HOSTCC tools/sunxi_egon.o WRAP tools/lib/crc16.c WRAP tools/lib/hash-checksum.c WRAP tools/lib/sha1.c WRAP tools/lib/sha256.c WRAP tools/lib/sha512.c WRAP tools/common/hash.c HOSTCC tools/ublimage.o HOSTCC tools/zynqimage.o HOSTCC tools/zynqmpimage.o HOSTCC tools/zynqmpbif.o WRAP tools/lib/fdt-libcrypto.c HOSTCC tools/libfdt/fdt.o HOSTCC tools/libfdt/fdt_ro.o HOSTCC tools/libfdt/fdt_wip.o HOSTCC tools/libfdt/fdt_sw.o HOSTCC tools/libfdt/fdt_rw.o HOSTCC tools/libfdt/fdt_strerror.o HOSTCC tools/libfdt/fdt_empty_tree.o HOSTCC tools/libfdt/fdt_addresses.o HOSTCC tools/libfdt/fdt_overlay.o HOSTCC tools/gpimage.o HOSTCC tools/gpimage-common.o HOSTCC tools/mtk_image.o WRAP tools/lib/ecdsa/ecdsa-libcrypto.c WRAP tools/lib/rsa/rsa-sign.c WRAP tools/lib/rsa/rsa-verify.c WRAP tools/lib/rsa/rsa-mod-exp.c WRAP tools/lib/aes/aes-encrypt.c WRAP tools/lib/aes/aes-decrypt.c HOSTCC tools/dumpimage.o HOSTCC tools/boot/image-fit.o HOSTCC tools/boot/image-fit-sig.o HOSTCC tools/boot/image-cipher.o HOSTCC tools/boot/fdt_region.o HOSTCC tools/boot/bootm.o HOSTCC tools/lib/fdtdec_common.o HOSTCC tools/lib/fdtdec.o HOSTCC tools/boot/image.o HOSTCC tools/boot/image-host.o HOSTCC tools/lib/md5.o HOSTCC tools/lib/rc4.o HOSTCC tools/lib/crc16.o HOSTCC tools/lib/hash-checksum.o HOSTCC tools/lib/sha1.o HOSTCC tools/lib/sha256.o HOSTCC tools/lib/sha512.o HOSTCC tools/common/hash.o HOSTCC tools/lib/fdt-libcrypto.o HOSTCC tools/lib/ecdsa/ecdsa-libcrypto.o HOSTCC tools/lib/rsa/rsa-sign.o HOSTCC tools/lib/rsa/rsa-verify.o HOSTCC tools/lib/rsa/rsa-mod-exp.o HOSTCC tools/lib/aes/aes-encrypt.o HOSTCC tools/lib/aes/aes-decrypt.o HOSTCC tools/mkimage.o HOSTCC tools/fit_check_sign.o HOSTCC tools/fit_info.o HOSTCC tools/proftool HOSTCC tools/relocate-rela HOSTCC tools/fdtgrep.o tools/bmp_logo --gen-info ./tools/logos/denx.bmp > include/bmp_logo.h HOSTCC tools/spl_size_limit tools/bmp_logo --gen-bmp ./tools/logos/denx.bmp > include/bmp_logo_data.h HOSTCC tools/lib/crc8.o HOSTLD tools/mkenvimage HOSTLD tools/gen_ethaddr_crc HOSTLD tools/fdtgrep HOSTLD tools/dumpimage HOSTLD tools/mkimage HOSTLD tools/fit_info HOSTLD tools/fit_check_sign AR arch/arm/cpu/built-in.o CC arch/arm/cpu/armv8/cpu.o CC arch/arm/cpu/armv8/generic_timer.o CC arch/arm/cpu/armv8/cache_v8.o AS arch/arm/cpu/armv8/cache.o AS arch/arm/cpu/armv8/exceptions.o AS arch/arm/lib/crt0_64.o CC arch/arm/cpu/armv8/exception_level.o AS arch/arm/lib/setjmp_aarch64.o AS arch/arm/cpu/armv8/tlb.o AS arch/arm/lib/relocate_64.o AS arch/arm/cpu/armv8/transition.o CC arch/arm/mach-rockchip/boot_mode.o CC arch/arm/cpu/armv8/fwcall.o CC arch/arm/lib/bootm-fdt.o CC arch/arm/cpu/armv8/cpu-dt.o CC arch/arm/mach-rockchip/board.o CC arch/arm/lib/bootm.o CC board/rockchip/evb_rk3399/evb-rk3399.o AS arch/arm/cpu/armv8/smccc-call.o CC arch/arm/mach-rockchip/misc.o AS arch/arm/cpu/armv8/start.o CC arch/arm/lib/image.o CC arch/arm/mach-rockchip/cpu-info.o CC arch/arm/lib/zimage.o CC arch/arm/mach-rockchip/sdram.o CC arch/arm/lib/bdinfo.o CC boot/bootm.o CC arch/arm/mach-rockchip/rk3399/clk_rk3399.o CC arch/arm/lib/sections.o CC boot/bootm_os.o CC arch/arm/mach-rockchip/rk3399/rk3399.o CC arch/arm/lib/stack.o CC disk/part.o CC disk/part_dos.o CC boot/pxe_utils.o AR cmd/arm/built-in.o CC common/init/board_init.o CC arch/arm/mach-rockchip/rk3399/syscon_rk3399.o CC boot/image.o CC cmd/boot.o CC common/main.o CC disk/part_iso.o CC boot/image-board.o CC arch/arm/lib/interrupts_64.o CC disk/part_efi.o CC boot/image-android.o CC common/exports.o CC arch/arm/lib/psci-dt.o AR board/rockchip/evb_rk3399/built-in.o CC arch/arm/lib/cache.o CC common/cli_hush.o AR arch/arm/lib/lib.a CC common/autoboot.o CC boot/image-android-dt.o CC cmd/bootm.o AS arch/arm/lib/crt0_aarch64_efi.o CC cmd/help.o AR arch/arm/cpu/armv8/built-in.o CC cmd/panic.o CC arch/arm/lib/reloc_aarch64_efi.o CC cmd/version.o CC common/board_f.o CC cmd/blk_common.o CC cmd/source.o CC boot/image-fit.o CC boot/image-fdt.o CC common/board_r.o CC common/board_info.o AR arch/arm/mach-rockchip/rk3399/built-in.o AR drivers/usb/cdns3/built-in.o AR common/init/built-in.o CC cmd/bdinfo.o CC drivers/adc/adc-uclass.o CC common/fdt_support.o CC cmd/blkcache.o CC drivers/adc/rockchip-saradc.o AR drivers/ata/built-in.o CC cmd/bootefi.o CC common/miiphyutil.o CC cmd/bootz.o CC drivers/usb/common/common.o AR arch/arm/lib/built-in.o AR disk/built-in.o CC cmd/booti.o CC common/usb.o CC cmd/console.o CC common/usb_hub.o CC cmd/dm.o CC common/usb_storage.o CC drivers/block/blk-uclass.o AR drivers/axi/built-in.o CC cmd/echo.o AR boot/built-in.o CC cmd/elf.o CC drivers/usb/dwc3/core.o CC common/iomux.o CC drivers/block/blkcache.o AR drivers/cache/built-in.o AR drivers/bus/built-in.o AR drivers/usb/emul/built-in.o CC cmd/exit.o CC drivers/core/device.o AR drivers/usb/common/built-in.o CC drivers/core/fdtaddr.o AR drivers/adc/built-in.o CC drivers/usb/eth/usb_ether.o CC drivers/usb/gadget/epautoconf.o AR drivers/clk/analogbits/built-in.o CC drivers/core/lists.o CC drivers/usb/gadget/config.o CC drivers/clk/rockchip/clk_pll.o CC common/edid.o CC drivers/core/root.o AR drivers/clk/imx/built-in.o CC common/splash.o CC drivers/usb/gadget/usbstring.o AR drivers/dfu/built-in.o CC drivers/usb/gadget/udc/udc-core.o CC drivers/clk/rockchip/clk_rk3399.o CC common/menu.o AR drivers/crypto/aspeed/built-in.o CC common/usb_kbd.o AR drivers/block/built-in.o CC drivers/usb/dwc3/gadget.o CC drivers/usb/host/usb-uclass.o CC drivers/usb/host/ohci-hcd.o CC drivers/usb/gadget/udc/udc-uclass.o CC drivers/usb/gadget/g_dnl.o AR drivers/clk/tegra/built-in.o CC cmd/ext4.o CC cmd/ext2.o CC drivers/usb/eth/asix.o AR drivers/usb/mtu3/built-in.o CC drivers/usb/eth/asix88179.o CC drivers/core/uclass.o CC drivers/fastboot/fb_common.o CC drivers/fastboot/fb_getvar.o CC drivers/usb/gadget/f_fastboot.o CC drivers/usb/eth/mcs7830.o AR drivers/crypto/hash/built-in.o CC drivers/crypto/fsl/sec.o CC cmd/fat.o CC drivers/firmware/firmware-uclass.o CC drivers/usb/eth/smsc95xx.o CC cmd/fdt.o AR drivers/clk/rockchip/built-in.o AR drivers/crypto/rsa_mod_exp/built-in.o CC drivers/usb/eth/r8152.o CC drivers/gpio/gpio-uclass.o CC drivers/usb/dwc3/ep0.o CC cmd/fs.o CC drivers/usb/host/ehci-hcd.o CC drivers/usb/dwc3/dwc3-generic.o CC drivers/core/util.o AR drivers/usb/gadget/udc/built-in.o CC drivers/firmware/psci.o CC drivers/usb/eth/r8152_fw.o CC common/cli_readline.o AR drivers/usb/gadget/built-in.o AR drivers/clk/ti/built-in.o CC drivers/i2c/i2c-uclass.o AR drivers/crypto/fsl/built-in.o CC common/cli_simple.o CC drivers/core/device-remove.o CC drivers/core/simple-bus.o CC drivers/input/key_matrix.o CC drivers/fastboot/fb_command.o CC drivers/core/dump.o CC drivers/input/input.o CC drivers/clk/clk-uclass.o CC drivers/fastboot/fb_mmc.o CC drivers/usb/host/ehci-generic.o CC drivers/usb/host/xhci.o AR drivers/firmware/built-in.o AR drivers/usb/eth/built-in.o CC drivers/gpio/rk_gpio.o CC drivers/core/regmap.o CC cmd/itest.o AR drivers/usb/dwc3/dwc3.o CC drivers/i2c/rk_i2c.o CC drivers/core/syscon-uclass.o CC common/bouncebuf.o AR drivers/usb/musb/built-in.o AR drivers/iommu/built-in.o CC drivers/clk/clk_fixed_rate.o AR drivers/mailbox/built-in.o CC drivers/clk/clk_fixed_factor.o AR drivers/fastboot/built-in.o AR drivers/memory/built-in.o CC drivers/input/keyboard-uclass.o CC drivers/misc/misc-uclass.o CC drivers/misc/rockchip-efuse.o CC drivers/core/of_extra.o CC cmd/load.o AR drivers/gpio/built-in.o CC drivers/core/ofnode.o CC drivers/core/read_extra.o CC common/console.o AR drivers/i2c/built-in.o CC drivers/usb/host/xhci-mem.o CC drivers/mmc/mmc.o AR drivers/usb/musb-new/built-in.o CC cmd/mem.o AR drivers/input/built-in.o CC drivers/usb/phy/rockchip_usb2_phy.o CC drivers/mmc/mmc-uclass.o AR drivers/misc/built-in.o CC drivers/mmc/mmc_write.o CC drivers/usb/host/xhci-ring.o AR drivers/usb/ulpi/built-in.o AR drivers/mtd/nand/built-in.o CC cmd/mii.o AR drivers/core/built-in.o AR drivers/mtd/onenand/built-in.o CC drivers/mtd/spi/sf-uclass.o CC cmd/mdio.o CC drivers/mtd/spi/sf_probe.o CC cmd/sleep.o AR drivers/usb/phy/built-in.o CC common/dlmalloc.o CC drivers/mtd/spi/spi-nor-ids.o CC drivers/usb/host/xhci-dwc3.o CC env/common.o CC drivers/nvme/nvme-uclass.o CC drivers/mmc/dw_mmc.o AR drivers/net/mscc_eswitch/built-in.o CC drivers/mtd/spi/spi-nor-core.o CC drivers/mmc/rockchip_dw_mmc.o CC drivers/net/phy/phy.o CC cmd/mmc.o CC cmd/legacy-mtd-utils.o CC drivers/nvme/nvme.o CC drivers/nvme/nvme_show.o CC cmd/net.o CC env/env.o CC drivers/usb/host/dwc3-of-simple.o CC common/malloc_simple.o CC drivers/mmc/sdhci.o CC common/hash.o AR drivers/net/qe/built-in.o AR drivers/net/phy/built-in.o CC drivers/mmc/rockchip_sdhci.o AR drivers/mtd/spi/spi-nor.o CC drivers/nvme/nvme_pci.o CC env/attr.o CC cmd/part.o CC env/flags.o AR drivers/net/ti/built-in.o AR drivers/usb/host/built-in.o CC env/callback.o CC cmd/pci.o AR drivers/mmc/built-in.o CC common/memsize.o CC common/stdio.o AR drivers/nvme/built-in.o CC common/cli.o CC env/mmc.o CC fs/ext4/ext4fs.o CC cmd/pinmux.o CC drivers/pci/pci_rom.o CC common/command.o CC drivers/pci/pci-uclass.o CC drivers/pci/pci_auto.o AR env/built-in.o CC fs/ext4/ext4_common.o CC cmd/pxe.o CC common/s_record.o CC drivers/pci/pci_auto_common.o CC fs/fs.o CC fs/fat/fat_write.o CC fs/fs_internal.o CC fs/ext4/dev.o CC cmd/nvme.o CC drivers/pci/pci_common.o CC cmd/sf.o AR fs/ext4/built-in.o CC drivers/pci/pcie_rockchip.o AR fs/fat/built-in.o CC net/arp.o CC cmd/sysboot.o AR lib/crypto/built-in.o AR drivers/pci/built-in.o CC net/bootp.o CC cmd/time.o CC lib/efi_driver/efi_uclass.o CC cmd/test.o CC net/eth-uclass.o CC lib/efi_driver/efi_block_device.o CC cmd/unlz4.o CC net/eth_common.o AR lib/efi_driver/built-in.o CC cmd/unzip.o CC net/net.o CC cmd/lzmadec.o CC net/nfs.o CC cmd/usb.o CC net/ping.o CC cmd/disk.o CC net/tftp.o CC cmd/fastboot.o AR net/built-in.o CC cmd/ximg.o AR drivers/usb/dwc3/built-in.o CC drivers/net/designware.o CC drivers/net/gmac_rockchip.o CC lib/efi_loader/efi_bootmgr.o CC cmd/gpt.o CC lib/efi_loader/efi_boottime.o AR drivers/clk/built-in.o CC common/xyzModem.o CC cmd/nvedit.o CC lib/charset.o AR drivers/mtd/spi/built-in.o AR arch/arm/mach-rockchip/built-in.o AR fs/built-in.o CC lib/crc8.o CC lib/efi_loader/efi_helper.o AR drivers/crypto/built-in.o CC lib/efi_loader/efi_console.o CC lib/lzma/LzmaDec.o CC lib/crc16.o CC lib/efi_loader/efi_device_path.o CC lib/lzma/LzmaTools.o CC lib/errno_str.o CC lib/libfdt/fdt.o CC drivers/pwm/pwm-uclass.o AR drivers/phy/marvell/built-in.o AR drivers/phy/cadence/built-in.o CC lib/zlib/zlib.o CC lib/libfdt/fdt_ro.o CC drivers/reset/reset-uclass.o AR drivers/power/battery/built-in.o AR drivers/phy/allwinner/built-in.o AR drivers/pinctrl/broadcom/built-in.o CC drivers/ram/rockchip/sdram_rk3399.o AR drivers/rtc/built-in.o CC lib/libfdt/fdt_wip.o CC drivers/pwm/rk_pwm.o AR drivers/pinctrl/nxp/built-in.o CC drivers/ram/ram-uclass.o AR cmd/built-in.o CC lib/libfdt/fdt_strerror.o CC drivers/ram/rockchip/sdram_common.o AR drivers/net/built-in.o CC drivers/reset/reset-rockchip.o CC drivers/phy/rockchip/phy-rockchip-inno-usb2.o CC drivers/phy/rockchip/phy-rockchip-pcie.o CC lib/fdtdec_common.o CC drivers/pinctrl/pinctrl-uclass.o CC drivers/phy/rockchip/phy-rockchip-typec.o CC drivers/phy/phy-uclass.o CC lib/efi_loader/efi_device_path_to_text.o AR lib/lzma/built-in.o AR common/built-in.o CC drivers/pinctrl/rockchip/pinctrl-rockchip-core.o CC lib/efi_loader/efi_device_path_utilities.o AR drivers/power/mfd/built-in.o CC lib/libfdt/fdt_sw.o CC lib/efi_loader/efi_dt_fixup.o AR drivers/phy/socionext/built-in.o AR drivers/power/fuel_gauge/built-in.o AR drivers/phy/ti/built-in.o AR drivers/pwm/built-in.o CC lib/efi_loader/efi_file.o AR lib/zlib/built-in.o CC lib/efi_loader/efi_hii.o CC drivers/pinctrl/pinctrl-generic.o CC drivers/power/pmic/pmic-uclass.o AR drivers/ram/rockchip/built-in.o CC lib/smbios.o CC lib/image-sparse.o CC drivers/power/pmic/rk8xx.o CC lib/libfdt/fdt_rw.o CC drivers/pinctrl/rockchip/pinctrl-rk3399.o CC lib/efi_loader/efi_image_loader.o CC lib/ldiv.o CC lib/net_utils.o CC lib/libfdt/fdt_empty_tree.o CC drivers/power/regulator/regulator-uclass.o AR drivers/reset/built-in.o CC lib/rc4.o CC drivers/power/regulator/pwm_regulator.o AR drivers/scsi/built-in.o AR drivers/mtd/built-in.o CC lib/efi_loader/efi_load_options.o CC drivers/power/regulator/regulator_common.o CC drivers/serial/serial-uclass.o AR drivers/smem/built-in.o CC lib/libfdt/fdt_addresses.o CC lib/list_sort.o CC lib/md5.o CC lib/libfdt/fdt_overlay.o AR drivers/soc/built-in.o AR drivers/phy/rockchip/built-in.o CC lib/hash-checksum.o CC drivers/power/regulator/fixed.o CC drivers/power/regulator/rk8xx.o AR drivers/pinctrl/rockchip/built-in.o CC lib/efi_loader/efi_memory.o CC lib/sha1.o CC lib/efi_loader/efi_root_node.o CC drivers/serial/ns16550.o CC lib/efi_loader/efi_runtime.o AR drivers/power/pmic/built-in.o AR drivers/sound/built-in.o CC lib/efi_loader/efi_setup.o CC lib/efi_loader/efi_string.o CC drivers/spi/spi-uclass.o CC lib/sha256.o CC drivers/spi/spi-mem.o CC lib/efi_loader/efi_unicode_collation.o AR drivers/spmi/built-in.o CC lib/efi_loader/efi_var_common.o AR drivers/thermal/built-in.o CC drivers/sysreset/sysreset-uclass.o CC lib/gunzip.o AR drivers/power/regulator/built-in.o CC drivers/sysreset/sysreset_rockchip.o CC lib/efi_loader/efi_var_mem.o AR drivers/ufs/built-in.o AR lib/libfdt/built-in.o CC lib/efi_loader/efi_var_file.o AR drivers/watchdog/built-in.o CC lib/efi_loader/efi_variable.o CC lib/lz4_wrapper.o CC lib/efi_loader/efi_watchdog.o AR drivers/ram/built-in.o AR drivers/serial/built-in.o CC lib/efi_loader/efi_gop.o CC lib/fdtdec.o AR drivers/spi/built-in.o CC lib/qsort.o CC lib/efi_loader/efi_disk.o AR drivers/video/bridge/built-in.o CC lib/efi_loader/efi_net.o CC lib/hashtable.o CC drivers/video/backlight-uclass.o CC lib/efi_loader/efi_smbios.o CC lib/errno.o CC drivers/video/rockchip/rk_vop.o CC drivers/video/pwm_backlight.o CC drivers/video/console_normal.o AR drivers/video/sunxi/built-in.o AR drivers/sysreset/built-in.o CC lib/display_options.o CC lib/efi_loader/efi_load_initrd.o AR drivers/video/ti/built-in.o CC drivers/video/rockchip/rk_hdmi.o CC lib/crc32.o CC drivers/video/rockchip/rk3399_hdmi.o CC drivers/video/rockchip/rk3399_vop.o CC lib/efi_loader/helloworld.o CC drivers/video/display-uclass.o CC lib/ctype.o CC lib/div64.o AS lib/efi_loader/efi_crt0.o CC drivers/video/video-uclass.o CC lib/hang.o CC drivers/video/vidconsole-uclass.o CC lib/efi_loader/efi_reloc.o CC lib/linux_compat.o CC drivers/video/video_bmp.o CC lib/efi_loader/dtbdump.o CC lib/linux_string.o CC lib/efi_loader/efi_freestanding.o CC lib/lmb.o CC drivers/video/panel-uclass.o CC lib/efi_loader/initrddump.o CC drivers/video/simple_panel.o TTF drivers/video/u_boot_logo.S AR drivers/phy/built-in.o CC lib/slre.o CC drivers/video/dw_hdmi.o AR lib/efi_loader/built-in.o CC lib/membuff.o AR drivers/pinctrl/built-in.o AS drivers/video/u_boot_logo.o CC lib/string.o CC lib/tables_csum.o AR drivers/video/rockchip/built-in.o CC lib/time.o CC lib/hexdump.o CC lib/uuid.o LD lib/efi_loader/helloworld_efi.so LD lib/efi_loader/initrddump_efi.so CC lib/rand.o CC lib/panic.o CC lib/vsprintf.o AR drivers/power/built-in.o CC lib/abuf.o CC lib/strto.o CC lib/date.o CC lib/elf.o CC lib/rtc-lib.o OBJCOPY lib/efi_loader/helloworld.efi LD lib/efi_loader/dtbdump_efi.so OBJCOPY lib/efi_loader/initrddump.efi OBJCOPY lib/efi_loader/dtbdump.efi AR drivers/video/built-in.o AR lib/built-in.o AR drivers/built-in.o LD u-boot OBJCOPY u-boot-nodtb.bin DTC arch/arm/dts/rk3399-evb.dtb DTC arch/arm/dts/rk3399-ficus.dtb DTC arch/arm/dts/rk3399-firefly.dtb DTC arch/arm/dts/rk3399-gru-bob.dtb DTC arch/arm/dts/rk3399-gru-kevin.dtb RELOC u-boot-nodtb.bin DTC arch/arm/dts/rk3399-kobol-helios64.dtb DTC arch/arm/dts/rk3399-khadas-edge.dtb DTC arch/arm/dts/rk3399-khadas-edge-captain.dtb DTC arch/arm/dts/rk3399-khadas-edge-v.dtb DTC arch/arm/dts/rk3399-leez-p710.dtb DTC arch/arm/dts/rk3399-nanopc-t4.dtb DTC arch/arm/dts/rk3399-nanopi-m4.dtb DTC arch/arm/dts/rk3399-nanopi-m4-2gb.dtb DTC arch/arm/dts/rk3399-nanopi-m4b.dtb DTC arch/arm/dts/rk3399-nanopi-m4v2.dtb DTC arch/arm/dts/rk3399-nanopi-neo4.dtb DTC arch/arm/dts/rk3399-nanopi-r4s.dtb DTC arch/arm/dts/rk3399-orangepi.dtb DTC arch/arm/dts/rk3399-orangepi-4.dtb DTC arch/arm/dts/rk3399-orangepi-800.dtb DTC arch/arm/dts/rk3399-pinebook-pro.dtb DTC arch/arm/dts/rk3399-puma-haikou.dtb DTC arch/arm/dts/rk3399-roc-pc.dtb DTC arch/arm/dts/rk3399-roc-pc-mezzanine.dtb DTC arch/arm/dts/rk3399-roc-pc-plus.dtb DTC arch/arm/dts/rk3399-rock-pi-4a.dtb DTC arch/arm/dts/rk3399-rock-pi-4b.dtb DTC arch/arm/dts/rk3399-rock-pi-4c.dtb DTC arch/arm/dts/rk3399-rock960.dtb DTC arch/arm/dts/rk3399-rockpro64.dtb DTC arch/arm/dts/rk3399-tinker-2.dtb DTC arch/arm/dts/rk3399pro-rock-pi-n10.dtb SHIPPED dts/dt.dtb CAT u-boot-dtb.bin --> (280) INFO: {u-boot:1} built u-boot target [ 2022.04 in 2 seconds ] --> (280) INFO: {u-boot:1} Postprocessing u-boot [ 2022.04 u-boot-dtb.bin ] --> (280) COMMAND: tools/mkimage -n rk3399 -T rksd -d /home/reds/patch_series_pcie_ep/build/cache/sources/rkbin-tools/rk33/rk3399_ddr_933MHz_v1.25.bin idbloader.bin Image Type: Rockchip RK33 (SD/MMC) boot image Init Data Size: 131072 bytes --> (280) COMMAND: /home/reds/patch_series_pcie_ep/build/cache/sources/rkbin-tools/tools/loaderimage --pack --uboot ./u-boot-dtb.bin uboot.img 0x200000 load addr is 0x200000! pack input ./u-boot-dtb.bin pack file size: 887496 crc = 0x0009cecc pack uboot.img success! --> (280) COMMAND: /home/reds/patch_series_pcie_ep/build/cache/sources/rkbin-tools/tools/trust_merger --replace bl31.elf /home/reds/patch_series_pcie_ep/build/cache/sources/rkbin-tools/rk33/rk3399_bl31_v1.35.elf trust.ini out:trust.bin merge success(trust.bin) --> (280) INFO: {u-boot:1} Preparing u-boot targets packaging [ 2022.04 u-boot-dtb.bin ] --> (280) INFO: {u-boot:1} Deploying u-boot binary target [ 2022.04 u-boot-dtb.bin :: idbloader.bin ] --> (280) COMMAND: cp -v idbloader.bin /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/idbloader.bin 'idbloader.bin' -> '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/idbloader.bin' --> (280) INFO: {u-boot:1} Deploying u-boot binary target [ 2022.04 u-boot-dtb.bin :: uboot.img ] --> (280) COMMAND: cp -v uboot.img /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/uboot.img 'uboot.img' -> '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/uboot.img' --> (280) INFO: {u-boot:1} Deploying u-boot binary target [ 2022.04 u-boot-dtb.bin :: trust.bin ] --> (280) COMMAND: cp -v trust.bin /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/trust.bin 'trust.bin' -> '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/trust.bin' --> (280) INFO: {u-boot:1} Done with u-boot target [ 2022.04 u-boot-dtb.bin ] --> (280) INFO: Preparing u-boot general packaging [ 2022.04 u-boot-dtb.bin ] --> (280) INFO: Das U-Boot .deb package version [ 2022.04-Se4b6-Pd69e-B6324 ] --> (280) COMMAND: cp .config /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/u-boot/nanopc-t4-rk3399_defconfig --> (281) COMMAND: cp Licenses/README /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64/usr/lib/u-boot/LICENSE --> (281) INFO: Building u-boot deb [ (version: 2022.04-Se4b6-Pd69e-B6324) ] --> (281) INFO: shellcheck found no problems in package scripts [ no scripts found for 'linux-u-boot-nanopct4-edge' ] --> (281) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.bH4gMvf4QF/linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64 /home/reds/patch_series_pcie_ep/build/output/debs dpkg-deb: building package 'linux-u-boot-nanopct4-edge' in '/home/reds/patch_series_pcie_ep/build/output/debs/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb'. --> (281) INFO: Built u-boot deb OK [ linux-u-boot-edge-nanopct4_23.05.0-trunk_arm64.deb ] ------------------------------------------------------------------------------------------------------------ ### pack_artifact_to_local_cache.log --> (281) INFO: artifact [ kernel :: kernel() ] ------------------------------------------------------------------------------------------------------------ ### artifact_prepare_version.log --> (281) INFO: Producing new & caching [ GIT_INFO_KERNEL ] --> (281) INFO: Fetching SHA1 of branch linux-6.2.y [ git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git ] --> (281) INFO: SHA1 of branch linux-6.2.y [ 'fbe1871b562af6e9cffcf622247e821d1dd16c64' ] --> (281) INFO: Using kernel config file [ config/kernel/linux-media-edge.config ] ------------------------------------------------------------------------------------------------------------ ### artifact_is_available_in_remote_cache.log --> (281) INFO: Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-kernel/kernel-media-edge:6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 ] --> (282) INFO: Artifact is available in remote cache [ ghcr.io/armbian/cache-kernel/kernel-media-edge:6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 - 'kernel-media-edge - 6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 - version "6.2.6" git revision "fbe1871b562af6e9cffcf622247e821d1dd16c64" codename "Hurr durr Ima ninja sloth" drivers hash "2a58d557d432cc44" patches hash "5f93a1e62336adc5" .config hash "7439a5897f1f4ece" .config hook hash "fe661159ee64825e" framework bash hash "d6b88a4bb72d3422" - type: deb-tar' ] ------------------------------------------------------------------------------------------------------------ ### artifact_obtain_from_remote_cache.log --> (282) INFO: Obtaining artifact from remote cache [ ghcr.io/armbian/cache-kernel/kernel-media-edge:6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 into kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar ] --> (282) COMMAND: mkdir -p /home/reds/patch_series_pcie_ep/build/output/debs/kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar.oras.pull.tmp Downloading 2ece71d1c0bf application/vnd.oci.image.manifest.v1+json Processing 2ece71d1c0bf application/vnd.oci.image.manifest.v1+json Skipped 44136fa355b3 application/vnd.unknown.config.v1+json Downloading 89c661ad2bd7 kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar Downloaded 89c661ad2bd7 kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar Downloaded 2ece71d1c0bf application/vnd.oci.image.manifest.v1+json Pulled ghcr.io/armbian/cache-kernel/kernel-media-edge:6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 Digest: sha256:2ece71d1c0bf3d94dcc5fc5b0f3cbf19bc9ab057b4da2dec554177b8d16784f2 --> (284) COMMAND: mv /home/reds/patch_series_pcie_ep/build/output/debs/kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar.oras.pull.tmp/kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar /home/reds/patch_series_pcie_ep/build/output/debs --> (284) COMMAND: rm -rf /home/reds/patch_series_pcie_ep/build/output/debs/kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar.oras.pull.tmp ------------------------------------------------------------------------------------------------------------ ### unpack_artifact_from_local_cache.log --> (284) INFO: Unpacking artifact [ deb-tar: kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar ] --> (284) COMMAND: tar -C /home/reds/patch_series_pcie_ep/build/output/debs -xvf /home/reds/patch_series_pcie_ep/build/output/debs/kernel-media-edge_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8.tar linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb linux-headers-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb --> (284) CACHEHIT: artifact [ obtained from remote cache: kernel-media-edge 6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8 ] --> (284) INFO: artifact [ firmware :: firmware() ] ------------------------------------------------------------------------------------------------------------ ### artifact_prepare_version.log --> (284) INFO: Producing new & caching [ GIT_INFO_ARMBIAN_FIRMWARE ] --> (284) INFO: Fetching SHA1 of branch master [ https://github.com/armbian/firmware ] --> (285) INFO: SHA1 of branch master [ '56ada00334dcd95a7edd3b55c595fd42818f2f10' ] ------------------------------------------------------------------------------------------------------------ ### artifact_is_available_in_remote_cache.log --> (285) INFO: Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-firmware/armbian-firmware:1-SA56ad-Bf566 ] --> (285) INFO: Artifact is available in remote cache [ ghcr.io/armbian/cache-firmware/armbian-firmware:1-SA56ad-Bf566 - 'armbian-firmware - 1-SA56ad-Bf566 - Armbian firmware git revision "56ada00334dcd95a7edd3b55c595fd42818f2f10" framework bash hash "f5669603470ce4e7" - type: deb' ] ------------------------------------------------------------------------------------------------------------ ### artifact_obtain_from_remote_cache.log --> (285) INFO: Obtaining artifact from remote cache [ ghcr.io/armbian/cache-firmware/armbian-firmware:1-SA56ad-Bf566 into armbian-firmware_1-SA56ad-Bf566_all.deb ] --> (285) COMMAND: mkdir -p /home/reds/patch_series_pcie_ep/build/output/debs/armbian-firmware_1-SA56ad-Bf566_all.deb.oras.pull.tmp Downloading 89b0832ae4f0 application/vnd.oci.image.manifest.v1+json Processing 89b0832ae4f0 application/vnd.oci.image.manifest.v1+json Skipped 44136fa355b3 application/vnd.unknown.config.v1+json Downloading c20bb2fc2877 armbian-firmware_1-SA56ad-Bf566_all.deb Downloaded c20bb2fc2877 armbian-firmware_1-SA56ad-Bf566_all.deb Downloaded 89b0832ae4f0 application/vnd.oci.image.manifest.v1+json Pulled ghcr.io/armbian/cache-firmware/armbian-firmware:1-SA56ad-Bf566 Digest: sha256:89b0832ae4f028204754e30fd72fa9b6745526cbc660cb1ecbf5e54b5eff3fb4 --> (287) COMMAND: mv /home/reds/patch_series_pcie_ep/build/output/debs/armbian-firmware_1-SA56ad-Bf566_all.deb.oras.pull.tmp/armbian-firmware_1-SA56ad-Bf566_all.deb /home/reds/patch_series_pcie_ep/build/output/debs --> (287) COMMAND: rm -rf /home/reds/patch_series_pcie_ep/build/output/debs/armbian-firmware_1-SA56ad-Bf566_all.deb.oras.pull.tmp ------------------------------------------------------------------------------------------------------------ ### unpack_artifact_from_local_cache.log --> (287) CACHEHIT: artifact [ obtained from remote cache: armbian-firmware 1-SA56ad-Bf566 ] ------------------------------------------------------------------------------------------------------------ ### compile_armbian-config.log --> (287) INFO: Building deb [ armbian-config ] --> (287) INFO: Getting sources from Git [ armbian-config master ] --> (287) INFO: Initializing empty git local copy [ git init: armbian-config master ] --> (287) COMMAND: git --no-pager init -q . --> (287) INFO: Fetching updates from remote repository [ armbian-config master ] --> (287) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/armbian/config master From https://github.com/armbian/config * branch master -> FETCH_HEAD --> (289) INFO: git: Fetch from remote completed, rev-parsing... [ 'armbian-config' 'master' 'FETCH_HEAD' ] --> (289) COMMAND: git --no-pager checkout -f -q a5251a1500b76373248ccb24df75220834698c20 --> (289) COMMAND: git --no-pager clean -q -d -f --> (289) INFO: Getting sources from Git [ neofetch 7.1.0 ] --> (289) INFO: Initializing empty git local copy [ git init: neofetch 7.1.0 ] --> (289) COMMAND: git --no-pager init -q . --> (290) INFO: Fetching updates from remote repository [ neofetch 7.1.0 ] --> (290) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/dylanaraps/neofetch tags/7.1.0 From https://github.com/dylanaraps/neofetch * tag 7.1.0 -> FETCH_HEAD --> (296) INFO: git: Fetch from remote completed, rev-parsing... [ 'neofetch' '7.1.0' 'FETCH_HEAD' ] --> (296) COMMAND: git --no-pager checkout -f -q 60d07dee6b76769d8c487a40639fb7b5a1a7bc85 --> (296) COMMAND: git --no-pager clean -q -d -f --> (296) INFO: Getting sources from Git [ wireguard-manager main ] --> (296) INFO: Initializing empty git local copy [ git init: wireguard-manager main ] --> (296) COMMAND: git --no-pager init -q . --> (297) INFO: Fetching updates from remote repository [ wireguard-manager main ] --> (297) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/complexorganizations/wireguard-manager main From https://github.com/complexorganizations/wireguard-manager * branch main -> FETCH_HEAD --> (297) INFO: git: Fetch from remote completed, rev-parsing... [ 'wireguard-manager' 'main' 'FETCH_HEAD' ] --> (297) COMMAND: git --no-pager checkout -f -q 04636ca14732aa77548249c756e3f5c503e5859c --> (297) COMMAND: git --no-pager clean -q -d -f --> (297) INFO: * applying patch/misc/add-armbian-neofetch.patch --> (297) INFO: shellcheck found no problems in package scripts [ no scripts found for 'armbian-config' ] --> (297) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.uAlVDNTZw9/armbian-config_23.05.0-trunk_all dpkg-deb: building package 'armbian-config' in '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.uAlVDNTZw9/armbian-config_23.05.0-trunk_all.deb'. --> (297) COMMAND: rsync --remove-source-files -r /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.uAlVDNTZw9/armbian-config_23.05.0-trunk_all.deb /home/reds/patch_series_pcie_ep/build/output/debs/ ------------------------------------------------------------------------------------------------------------ ### compile_armbian-zsh.log --> (297) INFO: Building deb [ armbian-zsh ] --> (297) INFO: Getting sources from Git [ oh-my-zsh master ] --> (297) INFO: Initializing empty git local copy [ git init: oh-my-zsh master ] --> (297) COMMAND: git --no-pager init -q . --> (298) INFO: Fetching updates from remote repository [ oh-my-zsh master ] --> (298) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/ohmyzsh/ohmyzsh master From https://github.com/ohmyzsh/ohmyzsh * branch master -> FETCH_HEAD --> (299) INFO: git: Fetch from remote completed, rev-parsing... [ 'oh-my-zsh' 'master' 'FETCH_HEAD' ] --> (299) COMMAND: git --no-pager checkout -f -q 72732a224e886933df6b64a49ec6f5e94c884612 --> (299) COMMAND: git --no-pager clean -q -d -f --> (299) INFO: Getting sources from Git [ evalcache master ] --> (299) INFO: Initializing empty git local copy [ git init: evalcache master ] --> (299) COMMAND: git --no-pager init -q . --> (299) INFO: Fetching updates from remote repository [ evalcache master ] --> (299) COMMAND: /usr/bin/git --no-pager fetch --recurse-submodules=no --no-tags https://github.com/mroth/evalcache master From https://github.com/mroth/evalcache * branch master -> FETCH_HEAD --> (300) INFO: git: Fetch from remote completed, rev-parsing... [ 'evalcache' 'master' 'FETCH_HEAD' ] --> (300) COMMAND: git --no-pager checkout -f -q 4b587643c15cdf1dd05609e5ed52f430bcb3946e --> (300) COMMAND: git --no-pager clean -q -d -f --> (300) INFO: Downloading required [ SHELLCHECK tooling ] --> (300) COMMAND: wget --no-verbose --progress=dot:giga -O /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz.tmp https://github.com/koalaman/shellcheck/releases/download/v0.9.0/shellcheck-v0.9.0.linux.x86_64.tar.xz 2023-03-15 09:42:14 URL:https://objects.githubusercontent.com/github-production-release-asset-2e65be/6731432/a5522397-4cfb-436b-9d41-c0d0738cfb66?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20230315%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230315T084214Z&X-Amz-Expires=300&X-Amz-Signature=fec7547d2eb57778b4bfea91095a026917ec0fa5f15cd7c1c34fdef7614a7433&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=6731432&response-content-disposition=attachment%3B%20filename%3Dshellcheck-v0.9.0.linux.x86_64.tar.xz&response-content-type=application%2Foctet-stream [2351560/2351560] -> "/home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz.tmp" [1] --> (300) COMMAND: mv /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz.tmp /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz --> (300) COMMAND: tar -xf /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz -C /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck shellcheck-v0.9.0/shellcheck --> (300) COMMAND: mv /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0/shellcheck /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64 --> (301) COMMAND: rm -rf /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0 /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64.tar.xz --> (301) COMMAND: chmod +x /home/reds/patch_series_pcie_ep/build/cache/tools/shellcheck/shellcheck-v0.9.0.linux.x86_64 --> (301) INFO: shellcheck found no problems in package scripts [ shellchecked 1 scripts in 'armbian-zsh' ] --> (301) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.vFB2e4XQER/armbian-zsh_23.05.0-trunk_all dpkg-deb: building package 'armbian-zsh' in '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.vFB2e4XQER/armbian-zsh_23.05.0-trunk_all.deb'. --> (301) COMMAND: rsync --remove-source-files -r /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.vFB2e4XQER/armbian-zsh_23.05.0-trunk_all.deb /home/reds/patch_series_pcie_ep/build/output/debs/ ------------------------------------------------------------------------------------------------------------ ### compile_plymouth_theme_armbian.log --> (301) INFO: Building deb [ armbian-plymouth-theme ] --> (301) COMMAND: mkdir -p /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/DEBIAN /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian --> (301) COMMAND: cp /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/debian/postinst /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/debian/prerm /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/debian/postrm /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/DEBIAN/ --> (301) COMMAND: convert -resize 256x256 /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/armbian-logo.png /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian/bgrt-fallback.png --> (301) COMMAND: convert -resize 52x52 /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/spinner.gif /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian/throbber-%04d.png --> (301) COMMAND: cp /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/watermark.png /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian/ --> (301) COMMAND: cp /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/bullet.png /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/capslock.png /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/entry.png /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/keyboard.png /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/keymap-render.png /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/lock.png /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian/ --> (301) COMMAND: cp /home/reds/patch_series_pcie_ep/build/packages/plymouth-theme-armbian/armbian.plymouth /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all/usr/share/plymouth/themes/armbian/ --> (301) INFO: shellcheck found no problems in package scripts [ shellchecked 3 scripts in 'armbian-plymouth-theme' ] --> (301) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all dpkg-deb: building package 'armbian-plymouth-theme' in '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all.deb'. --> (301) COMMAND: rsync --remove-source-files -rq /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.Fg3Nre513c/armbian-plymouth-theme_23.05.0-trunk_all.deb /home/reds/patch_series_pcie_ep/build/output/debs/ --> (301) TARGET-REACHED: Kernel build done [ @host ] --> (301) INFO: Target directory [ /home/reds/patch_series_pcie_ep/build/output/debs/ ] --> (301) INFO: File name [ linux-image-edge-media_23.05.0-trunk_arm64.deb ] ------------------------------------------------------------------------------------------------------------ ### create_board_package.log --> (301) INFO: Creating board support package for CLI [ armbian-bsp-cli-nanopct4 ] --> (301) COMMAND: rsync -a /home/reds/patch_series_pcie_ep/build/packages/bsp/common/etc /home/reds/patch_series_pcie_ep/build/packages/bsp/common/lib /home/reds/patch_series_pcie_ep/build/packages/bsp/common/usr /home/reds/patch_series_pcie_ep/build/packages/bsp/common/var /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.SbbyncMWqD/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64 --> (301) INFO: shellcheck found no problems in package scripts [ shellchecked 3 scripts in 'armbian-bsp-cli-nanopct4' ] --> (301) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.SbbyncMWqD/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64 /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.SbbyncMWqD/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb dpkg-deb: building package 'armbian-bsp-cli-nanopct4' in '/home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.SbbyncMWqD/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb'. --> (301) COMMAND: rsync --remove-source-files -r /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.SbbyncMWqD/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb /home/reds/patch_series_pcie_ep/build/output/debs/ ------------------------------------------------------------------------------------------------------------ ### create_desktop_package.log --> (301) INFO: Building desktop package [ armbian-jammy-desktop-xfce_23.05.0-trunk_all ] --> (301) INFO: shellcheck found no problems in package scripts [ shellchecked 1 scripts in 'armbian-jammy-desktop-xfce' ] --> (301) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.IvtaElUDql/nanopct4/armbian-jammy-desktop-xfce_23.05.0-trunk_all /home/reds/patch_series_pcie_ep/build/output/debs/jammy/armbian-jammy-desktop-xfce_23.05.0-trunk_all.deb dpkg-deb: building package 'armbian-jammy-desktop-xfce' in '/home/reds/patch_series_pcie_ep/build/output/debs/jammy/armbian-jammy-desktop-xfce_23.05.0-trunk_all.deb'. ------------------------------------------------------------------------------------------------------------ ### create_bsp_desktop_package.log --> (301) INFO: Creating board support package for desktop --> (301) INFO: shellcheck found no problems in package scripts [ shellchecked 1 scripts in 'armbian-bsp-desktop-nanopct4' ] --> (301) COMMAND: fakeroot dpkg-deb -b -Znone /home/reds/patch_series_pcie_ep/build/.tmp/work-d42a3aa9-4268-47db-87f0-64b17653a3d0/tmp.ixjm9M6Epx/nanopct4/armbian-bsp-desktop-nanopct4_23.05.0-trunk_arm64 /home/reds/patch_series_pcie_ep/build/output/debs/jammy/armbian-bsp-desktop-nanopct4_23.05.0-trunk_arm64.deb dpkg-deb: building package 'armbian-bsp-desktop-nanopct4' in '/home/reds/patch_series_pcie_ep/build/output/debs/jammy/armbian-bsp-desktop-nanopct4_23.05.0-trunk_arm64.deb'. --> (301) TARGET-STARTED: Building image [ nanopct4 ] --> (301) INFO: Checking for rootfs cache [ edge nanopct4 jammy 3dsupport browsers desktop_tools editors internet programming remote_desktop xfce no ] --> (301) INFO: artifact [ rootfs :: rootfs() ] ------------------------------------------------------------------------------------------------------------ ### artifact_prepare_version.log --> (301) INFO: Going to build rootfs [ packages_hash: 'bcf5b56cab61Bed8f36' cache_type: 'xfce' rootfs_cache_id: 'xfce-bcf5b56cab61Bed8f36' ] ------------------------------------------------------------------------------------------------------------ ### artifact_is_available_in_remote_cache.log --> (301) INFO: Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-root/arm64-jammy-xfce:xfce-bcf5b56cab61Bed8f36 ] --> (302) INFO: Artifact is not available in remote cache [ ghcr.io/armbian/cache-root/arm64-jammy-xfce:xfce-bcf5b56cab61Bed8f36 ] ------------------------------------------------------------------------------------------------------------ ### prepare_rootfs_build_params_and_trap.log --> (302) COMMAND: rm -rfv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0 --> (302) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/cache/rootfs /home/reds/patch_series_pcie_ep/build/output/images mkdir: created directory '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0' mkdir: created directory '/home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0' mkdir: created directory '/home/reds/patch_series_pcie_ep/build/output/images' --> (302) INFO: Using tmpfs for rootfs build [ RAM available: 36934MiB > 5000MiB estimated ] ------------------------------------------------------------------------------------------------------------ ### create_new_rootfs_cache.log --> (302) INFO: Creating new rootfs cache [ 'arm64-jammy-xfce-bcf5b56cab61Bed8f36.tar.zst' ] --> (302) INFO: Installing base system with 8 packages [ Stage 1/2 ] --> (302) COMMAND: debootstrap --variant=minbase --arch=arm64 '--include=apt-utils,locales,console-setup,gnupg2,dconf-cli,fonts-noto-color-emoji,libglib2.0-dev,libgtk2.0-bin' '--components=main,universe,restricted' --cache-dir=/home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64/archives --foreign jammy /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/ http://ports.ubuntu.com/ I: Retrieving InRelease I: Checking Release signature I: Valid Release signature (key id F6ECB3762474EDA9D21B7022871920D1991BC93C) I: Retrieving Packages I: Validating Packages I: Retrieving Packages I: Validating Packages I: Retrieving Packages I: Validating Packages I: Resolving dependencies of required packages... I: Resolving dependencies of base packages... I: Checking component main on http://ports.ubuntu.com... I: Checking component restricted on http://ports.ubuntu.com... I: Checking component universe on http://ports.ubuntu.com... I: Retrieving adduser 3.118ubuntu5 I: Validating adduser 3.118ubuntu5 I: Retrieving adwaita-icon-theme 41.0-1ubuntu1 I: Validating adwaita-icon-theme 41.0-1ubuntu1 I: Retrieving apt 2.4.5 I: Validating apt 2.4.5 I: Retrieving apt-utils 2.4.5 I: Validating apt-utils 2.4.5 I: Retrieving base-files 12ubuntu4 I: Validating base-files 12ubuntu4 I: Retrieving base-passwd 3.5.52build1 I: Validating base-passwd 3.5.52build1 I: Retrieving bash 5.1-6ubuntu1 I: Validating bash 5.1-6ubuntu1 I: Retrieving bsdutils 1:2.37.2-4ubuntu3 I: Validating bsdutils 1:2.37.2-4ubuntu3 I: Retrieving console-setup 1.205ubuntu3 I: Validating console-setup 1.205ubuntu3 I: Retrieving console-setup-linux 1.205ubuntu3 I: Validating console-setup-linux 1.205ubuntu3 I: Retrieving coreutils 8.32-4.1ubuntu1 I: Validating coreutils 8.32-4.1ubuntu1 I: Retrieving dash 0.5.11+git20210903+057cd650a4ed-3build1 I: Validating dash 0.5.11+git20210903+057cd650a4ed-3build1 I: Retrieving dconf-cli 0.40.0-3 I: Validating dconf-cli 0.40.0-3 I: Retrieving debconf 1.5.79ubuntu1 I: Validating debconf 1.5.79ubuntu1 I: Retrieving debianutils 5.5-1ubuntu2 I: Validating debianutils 5.5-1ubuntu2 I: Retrieving diffutils 1:3.8-0ubuntu2 I: Validating diffutils 1:3.8-0ubuntu2 I: Retrieving dirmngr 2.2.27-3ubuntu2 I: Validating dirmngr 2.2.27-3ubuntu2 I: Retrieving dpkg 1.21.1ubuntu2 I: Validating dpkg 1.21.1ubuntu2 I: Retrieving e2fsprogs 1.46.5-2ubuntu1 I: Validating e2fsprogs 1.46.5-2ubuntu1 I: Retrieving findutils 4.8.0-1ubuntu3 I: Validating findutils 4.8.0-1ubuntu3 I: Retrieving fontconfig 2.13.1-4.2ubuntu5 I: Validating fontconfig 2.13.1-4.2ubuntu5 I: Retrieving fontconfig-config 2.13.1-4.2ubuntu5 I: Validating fontconfig-config 2.13.1-4.2ubuntu5 I: Retrieving fonts-dejavu-core 2.37-2build1 I: Validating fonts-dejavu-core 2.37-2build1 I: Retrieving fonts-noto-color-emoji 2.034-1 I: Validating fonts-noto-color-emoji 2.034-1 I: Retrieving gcc-12-base 12-20220319-1ubuntu1 I: Validating gcc-12-base 12-20220319-1ubuntu1 I: Retrieving gnupg 2.2.27-3ubuntu2 I: Validating gnupg 2.2.27-3ubuntu2 I: Retrieving gnupg-l10n 2.2.27-3ubuntu2 I: Validating gnupg-l10n 2.2.27-3ubuntu2 I: Retrieving gnupg-utils 2.2.27-3ubuntu2 I: Validating gnupg-utils 2.2.27-3ubuntu2 I: Retrieving gpg 2.2.27-3ubuntu2 I: Validating gpg 2.2.27-3ubuntu2 I: Retrieving gpg-agent 2.2.27-3ubuntu2 I: Validating gpg-agent 2.2.27-3ubuntu2 I: Retrieving gpg-wks-client 2.2.27-3ubuntu2 I: Validating gpg-wks-client 2.2.27-3ubuntu2 I: Retrieving gpg-wks-server 2.2.27-3ubuntu2 I: Validating gpg-wks-server 2.2.27-3ubuntu2 I: Retrieving gpgconf 2.2.27-3ubuntu2 I: Validating gpgconf 2.2.27-3ubuntu2 I: Retrieving gpgsm 2.2.27-3ubuntu2 I: Validating gpgsm 2.2.27-3ubuntu2 I: Retrieving gpgv 2.2.27-3ubuntu2 I: Validating gpgv 2.2.27-3ubuntu2 I: Retrieving grep 3.7-1build1 I: Validating grep 3.7-1build1 I: Retrieving gtk-update-icon-cache 3.24.33-1ubuntu1 I: Validating gtk-update-icon-cache 3.24.33-1ubuntu1 I: Retrieving gzip 1.10-4ubuntu4 I: Validating gzip 1.10-4ubuntu4 I: Retrieving hicolor-icon-theme 0.17-2 I: Validating hicolor-icon-theme 0.17-2 I: Retrieving hostname 3.23ubuntu2 I: Validating hostname 3.23ubuntu2 I: Retrieving humanity-icon-theme 0.6.16 I: Validating humanity-icon-theme 0.6.16 I: Retrieving init-system-helpers 1.62 I: Validating init-system-helpers 1.62 I: Retrieving kbd 2.3.0-3ubuntu4 I: Validating kbd 2.3.0-3ubuntu4 I: Retrieving keyboard-configuration 1.205ubuntu3 I: Validating keyboard-configuration 1.205ubuntu3 I: Retrieving libacl1 2.3.1-1 I: Validating libacl1 2.3.1-1 I: Retrieving libapt-pkg6.0 2.4.5 I: Validating libapt-pkg6.0 2.4.5 I: Retrieving libassuan0 2.5.5-1build1 I: Validating libassuan0 2.5.5-1build1 I: Retrieving libatk1.0-0 2.36.0-3build1 I: Validating libatk1.0-0 2.36.0-3build1 I: Retrieving libatk1.0-data 2.36.0-3build1 I: Validating libatk1.0-data 2.36.0-3build1 I: Retrieving libattr1 1:2.5.1-1build1 I: Validating libattr1 1:2.5.1-1build1 I: Retrieving libaudit-common 1:3.0.7-1build1 I: Validating libaudit-common 1:3.0.7-1build1 I: Retrieving libaudit1 1:3.0.7-1build1 I: Validating libaudit1 1:3.0.7-1build1 I: Retrieving libavahi-client3 0.8-5ubuntu5 I: Validating libavahi-client3 0.8-5ubuntu5 I: Retrieving libavahi-common-data 0.8-5ubuntu5 I: Validating libavahi-common-data 0.8-5ubuntu5 I: Retrieving libavahi-common3 0.8-5ubuntu5 I: Validating libavahi-common3 0.8-5ubuntu5 I: Retrieving libblkid-dev 2.37.2-4ubuntu3 I: Validating libblkid-dev 2.37.2-4ubuntu3 I: Retrieving libblkid1 2.37.2-4ubuntu3 I: Validating libblkid1 2.37.2-4ubuntu3 I: Retrieving libbrotli1 1.0.9-2build6 I: Validating libbrotli1 1.0.9-2build6 I: Retrieving libbsd0 0.11.5-1 I: Validating libbsd0 0.11.5-1 I: Retrieving libbz2-1.0 1.0.8-5build1 I: Validating libbz2-1.0 1.0.8-5build1 I: Retrieving libc-bin 2.35-0ubuntu3 I: Validating libc-bin 2.35-0ubuntu3 I: Retrieving libc-dev-bin 2.35-0ubuntu3 I: Validating libc-dev-bin 2.35-0ubuntu3 I: Retrieving libc6 2.35-0ubuntu3 I: Validating libc6 2.35-0ubuntu3 I: Retrieving libc6-dev 2.35-0ubuntu3 I: Validating libc6-dev 2.35-0ubuntu3 I: Retrieving libcairo2 1.16.0-5ubuntu2 I: Validating libcairo2 1.16.0-5ubuntu2 I: Retrieving libcap-ng0 0.7.9-2.2build3 I: Validating libcap-ng0 0.7.9-2.2build3 I: Retrieving libcap2 1:2.44-1build3 I: Validating libcap2 1:2.44-1build3 I: Retrieving libcom-err2 1.46.5-2ubuntu1 I: Validating libcom-err2 1.46.5-2ubuntu1 I: Retrieving libcrypt-dev 1:4.4.27-1 I: Validating libcrypt-dev 1:4.4.27-1 I: Retrieving libcrypt1 1:4.4.27-1 I: Validating libcrypt1 1:4.4.27-1 I: Retrieving libcups2 2.4.1op1-1ubuntu4 I: Validating libcups2 2.4.1op1-1ubuntu4 I: Retrieving libdatrie1 0.2.13-2 I: Validating libdatrie1 0.2.13-2 I: Retrieving libdb5.3 5.3.28+dfsg1-0.8ubuntu3 I: Validating libdb5.3 5.3.28+dfsg1-0.8ubuntu3 I: Retrieving libdbus-1-3 1.12.20-2ubuntu4 I: Validating libdbus-1-3 1.12.20-2ubuntu4 I: Retrieving libdconf1 0.40.0-3 I: Validating libdconf1 0.40.0-3 I: Retrieving libdebconfclient0 0.261ubuntu1 I: Validating libdebconfclient0 0.261ubuntu1 I: Retrieving libdeflate0 1.10-2 I: Validating libdeflate0 1.10-2 I: Retrieving libdpkg-perl 1.21.1ubuntu2 I: Validating libdpkg-perl 1.21.1ubuntu2 I: Retrieving libelf1 0.186-1build1 I: Validating libelf1 0.186-1build1 I: Retrieving libexpat1 2.4.7-1 I: Validating libexpat1 2.4.7-1 I: Retrieving libext2fs2 1.46.5-2ubuntu1 I: Validating libext2fs2 1.46.5-2ubuntu1 I: Retrieving libffi-dev 3.4.2-4 I: Validating libffi-dev 3.4.2-4 I: Retrieving libffi8 3.4.2-4 I: Validating libffi8 3.4.2-4 I: Retrieving libfontconfig1 2.13.1-4.2ubuntu5 I: Validating libfontconfig1 2.13.1-4.2ubuntu5 I: Retrieving libfreetype6 2.11.1+dfsg-1build1 I: Validating libfreetype6 2.11.1+dfsg-1build1 I: Retrieving libfribidi0 1.0.8-2ubuntu3 I: Validating libfribidi0 1.0.8-2ubuntu3 I: Retrieving libgcc-s1 12-20220319-1ubuntu1 I: Validating libgcc-s1 12-20220319-1ubuntu1 I: Retrieving libgcrypt20 1.9.4-3ubuntu3 I: Validating libgcrypt20 1.9.4-3ubuntu3 I: Retrieving libgdbm-compat4 1.23-1 I: Validating libgdbm-compat4 1.23-1 I: Retrieving libgdbm6 1.23-1 I: Validating libgdbm6 1.23-1 I: Retrieving libgdk-pixbuf-2.0-0 2.42.8+dfsg-1 I: Validating libgdk-pixbuf-2.0-0 2.42.8+dfsg-1 I: Retrieving libgdk-pixbuf2.0-common 2.42.8+dfsg-1 I: Validating libgdk-pixbuf2.0-common 2.42.8+dfsg-1 I: Retrieving libglib2.0-0 2.72.1-1 I: Validating libglib2.0-0 2.72.1-1 I: Retrieving libglib2.0-bin 2.72.1-1 I: Validating libglib2.0-bin 2.72.1-1 I: Retrieving libglib2.0-data 2.72.1-1 I: Validating libglib2.0-data 2.72.1-1 I: Retrieving libglib2.0-dev 2.72.1-1 I: Validating libglib2.0-dev 2.72.1-1 I: Retrieving libglib2.0-dev-bin 2.72.1-1 I: Validating libglib2.0-dev-bin 2.72.1-1 I: Retrieving libgmp10 2:6.2.1+dfsg-3ubuntu1 I: Validating libgmp10 2:6.2.1+dfsg-3ubuntu1 I: Retrieving libgnutls30 3.7.3-4ubuntu1 I: Validating libgnutls30 3.7.3-4ubuntu1 I: Retrieving libgpg-error0 1.43-3 I: Validating libgpg-error0 1.43-3 I: Retrieving libgraphite2-3 1.3.14-1build2 I: Validating libgraphite2-3 1.3.14-1build2 I: Retrieving libgssapi-krb5-2 1.19.2-2 I: Validating libgssapi-krb5-2 1.19.2-2 I: Retrieving libgtk2.0-0 2.24.33-2ubuntu2 I: Validating libgtk2.0-0 2.24.33-2ubuntu2 I: Retrieving libgtk2.0-bin 2.24.33-2ubuntu2 I: Validating libgtk2.0-bin 2.24.33-2ubuntu2 I: Retrieving libgtk2.0-common 2.24.33-2ubuntu2 I: Validating libgtk2.0-common 2.24.33-2ubuntu2 I: Retrieving libharfbuzz0b 2.7.4-1ubuntu3 I: Validating libharfbuzz0b 2.7.4-1ubuntu3 I: Retrieving libhogweed6 3.7.3-1build2 I: Validating libhogweed6 3.7.3-1build2 I: Retrieving libicu70 70.1-2 I: Validating libicu70 70.1-2 I: Retrieving libidn2-0 2.3.2-2build1 I: Validating libidn2-0 2.3.2-2build1 I: Retrieving libjbig0 2.1-3.1build3 I: Validating libjbig0 2.1-3.1build3 I: Retrieving libjpeg-turbo8 2.1.2-0ubuntu1 I: Validating libjpeg-turbo8 2.1.2-0ubuntu1 I: Retrieving libjpeg8 8c-2ubuntu10 I: Validating libjpeg8 8c-2ubuntu10 I: Retrieving libk5crypto3 1.19.2-2 I: Validating libk5crypto3 1.19.2-2 I: Retrieving libkeyutils1 1.6.1-2ubuntu3 I: Validating libkeyutils1 1.6.1-2ubuntu3 I: Retrieving libkrb5-3 1.19.2-2 I: Validating libkrb5-3 1.19.2-2 I: Retrieving libkrb5support0 1.19.2-2 I: Validating libkrb5support0 1.19.2-2 I: Retrieving libksba8 1.6.0-2build1 I: Validating libksba8 1.6.0-2build1 I: Retrieving libldap-2.5-0 2.5.11+dfsg-1~exp1ubuntu3 I: Validating libldap-2.5-0 2.5.11+dfsg-1~exp1ubuntu3 I: Retrieving liblocale-gettext-perl 1.07-4build3 I: Validating liblocale-gettext-perl 1.07-4build3 I: Retrieving liblz4-1 1.9.3-2build2 I: Validating liblz4-1 1.9.3-2build2 I: Retrieving liblzma5 5.2.5-2ubuntu1 I: Validating liblzma5 5.2.5-2ubuntu1 I: Retrieving libmd0 1.0.4-1build1 I: Validating libmd0 1.0.4-1build1 I: Retrieving libmount-dev 2.37.2-4ubuntu3 I: Validating libmount-dev 2.37.2-4ubuntu3 I: Retrieving libmount1 2.37.2-4ubuntu3 I: Validating libmount1 2.37.2-4ubuntu3 I: Retrieving libmpdec3 2.5.1-2build2 I: Validating libmpdec3 2.5.1-2build2 I: Retrieving libncurses6 6.3-2 I: Validating libncurses6 6.3-2 I: Retrieving libncursesw6 6.3-2 I: Validating libncursesw6 6.3-2 I: Retrieving libnettle8 3.7.3-1build2 I: Validating libnettle8 3.7.3-1build2 I: Retrieving libnpth0 1.6-3build2 I: Validating libnpth0 1.6-3build2 I: Retrieving libnsl-dev 1.3.0-2build2 I: Validating libnsl-dev 1.3.0-2build2 I: Retrieving libnsl2 1.3.0-2build2 I: Validating libnsl2 1.3.0-2build2 I: Retrieving libp11-kit0 0.24.0-6build1 I: Validating libp11-kit0 0.24.0-6build1 I: Retrieving libpam-modules 1.4.0-11ubuntu2 I: Validating libpam-modules 1.4.0-11ubuntu2 I: Retrieving libpam-modules-bin 1.4.0-11ubuntu2 I: Validating libpam-modules-bin 1.4.0-11ubuntu2 I: Retrieving libpam-runtime 1.4.0-11ubuntu2 I: Validating libpam-runtime 1.4.0-11ubuntu2 I: Retrieving libpam0g 1.4.0-11ubuntu2 I: Validating libpam0g 1.4.0-11ubuntu2 I: Retrieving libpango-1.0-0 1.50.6+ds-2 I: Validating libpango-1.0-0 1.50.6+ds-2 I: Retrieving libpangocairo-1.0-0 1.50.6+ds-2 I: Validating libpangocairo-1.0-0 1.50.6+ds-2 I: Retrieving libpangoft2-1.0-0 1.50.6+ds-2 I: Validating libpangoft2-1.0-0 1.50.6+ds-2 I: Retrieving libpcre16-3 2:8.39-13build5 I: Validating libpcre16-3 2:8.39-13build5 I: Retrieving libpcre2-16-0 10.39-3build1 I: Validating libpcre2-16-0 10.39-3build1 I: Retrieving libpcre2-32-0 10.39-3build1 I: Validating libpcre2-32-0 10.39-3build1 I: Retrieving libpcre2-8-0 10.39-3build1 I: Validating libpcre2-8-0 10.39-3build1 I: Retrieving libpcre2-dev 10.39-3build1 I: Validating libpcre2-dev 10.39-3build1 I: Retrieving libpcre2-posix3 10.39-3build1 I: Validating libpcre2-posix3 10.39-3build1 I: Retrieving libpcre3 2:8.39-13build5 I: Validating libpcre3 2:8.39-13build5 I: Retrieving libpcre3-dev 2:8.39-13build5 I: Validating libpcre3-dev 2:8.39-13build5 I: Retrieving libpcre32-3 2:8.39-13build5 I: Validating libpcre32-3 2:8.39-13build5 I: Retrieving libpcrecpp0v5 2:8.39-13build5 I: Validating libpcrecpp0v5 2:8.39-13build5 I: Retrieving libperl5.34 5.34.0-3ubuntu1 I: Validating libperl5.34 5.34.0-3ubuntu1 I: Retrieving libpixman-1-0 0.40.0-1build4 I: Validating libpixman-1-0 0.40.0-1build4 I: Retrieving libpng16-16 1.6.37-3build5 I: Validating libpng16-16 1.6.37-3build5 I: Retrieving libprocps8 2:3.3.17-6ubuntu2 I: Validating libprocps8 2:3.3.17-6ubuntu2 I: Retrieving libpython3-stdlib 3.10.4-0ubuntu2 I: Validating libpython3-stdlib 3.10.4-0ubuntu2 I: Retrieving libpython3.10-minimal 3.10.4-3 I: Validating libpython3.10-minimal 3.10.4-3 I: Retrieving libpython3.10-stdlib 3.10.4-3 I: Validating libpython3.10-stdlib 3.10.4-3 I: Retrieving libreadline8 8.1.2-1 I: Validating libreadline8 8.1.2-1 I: Retrieving libsasl2-2 2.1.27+dfsg2-3ubuntu1 I: Validating libsasl2-2 2.1.27+dfsg2-3ubuntu1 I: Retrieving libsasl2-modules-db 2.1.27+dfsg2-3ubuntu1 I: Validating libsasl2-modules-db 2.1.27+dfsg2-3ubuntu1 I: Retrieving libseccomp2 2.5.3-2ubuntu2 I: Validating libseccomp2 2.5.3-2ubuntu2 I: Retrieving libselinux1 3.3-1build2 I: Validating libselinux1 3.3-1build2 I: Retrieving libselinux1-dev 3.3-1build2 I: Validating libselinux1-dev 3.3-1build2 I: Retrieving libsemanage-common 3.3-1build2 I: Validating libsemanage-common 3.3-1build2 I: Retrieving libsemanage2 3.3-1build2 I: Validating libsemanage2 3.3-1build2 I: Retrieving libsepol-dev 3.3-1build1 I: Validating libsepol-dev 3.3-1build1 I: Retrieving libsepol2 3.3-1build1 I: Validating libsepol2 3.3-1build1 I: Retrieving libsmartcols1 2.37.2-4ubuntu3 I: Validating libsmartcols1 2.37.2-4ubuntu3 I: Retrieving libsqlite3-0 3.37.2-2 I: Validating libsqlite3-0 3.37.2-2 I: Retrieving libss2 1.46.5-2ubuntu1 I: Validating libss2 1.46.5-2ubuntu1 I: Retrieving libssl3 3.0.2-0ubuntu1 I: Validating libssl3 3.0.2-0ubuntu1 I: Retrieving libstdc++6 12-20220319-1ubuntu1 I: Validating libstdc++6 12-20220319-1ubuntu1 I: Retrieving libsystemd0 249.11-0ubuntu3 I: Validating libsystemd0 249.11-0ubuntu3 I: Retrieving libtasn1-6 4.18.0-4build1 I: Validating libtasn1-6 4.18.0-4build1 I: Retrieving libthai-data 0.1.29-1build1 I: Validating libthai-data 0.1.29-1build1 I: Retrieving libthai0 0.1.29-1build1 I: Validating libthai0 0.1.29-1build1 I: Retrieving libtiff5 4.3.0-6 I: Validating libtiff5 4.3.0-6 I: Retrieving libtinfo6 6.3-2 I: Validating libtinfo6 6.3-2 I: Retrieving libtirpc-common 1.3.2-2build1 I: Validating libtirpc-common 1.3.2-2build1 I: Retrieving libtirpc-dev 1.3.2-2build1 I: Validating libtirpc-dev 1.3.2-2build1 I: Retrieving libtirpc3 1.3.2-2build1 I: Validating libtirpc3 1.3.2-2build1 I: Retrieving libudev1 249.11-0ubuntu3 I: Validating libudev1 249.11-0ubuntu3 I: Retrieving libunistring2 1.0-1 I: Validating libunistring2 1.0-1 I: Retrieving libuuid1 2.37.2-4ubuntu3 I: Validating libuuid1 2.37.2-4ubuntu3 I: Retrieving libwebp7 1.2.2-2 I: Validating libwebp7 1.2.2-2 I: Retrieving libx11-6 2:1.7.5-1 I: Validating libx11-6 2:1.7.5-1 I: Retrieving libx11-data 2:1.7.5-1 I: Validating libx11-data 2:1.7.5-1 I: Retrieving libxau6 1:1.0.9-1build5 I: Validating libxau6 1:1.0.9-1build5 I: Retrieving libxcb-render0 1.14-3ubuntu3 I: Validating libxcb-render0 1.14-3ubuntu3 I: Retrieving libxcb-shm0 1.14-3ubuntu3 I: Validating libxcb-shm0 1.14-3ubuntu3 I: Retrieving libxcb1 1.14-3ubuntu3 I: Validating libxcb1 1.14-3ubuntu3 I: Retrieving libxcomposite1 1:0.4.5-1build2 I: Validating libxcomposite1 1:0.4.5-1build2 I: Retrieving libxcursor1 1:1.2.0-2build4 I: Validating libxcursor1 1:1.2.0-2build4 I: Retrieving libxdamage1 1:1.1.5-2build2 I: Validating libxdamage1 1:1.1.5-2build2 I: Retrieving libxdmcp6 1:1.1.3-0ubuntu5 I: Validating libxdmcp6 1:1.1.3-0ubuntu5 I: Retrieving libxext6 2:1.3.4-1build1 I: Validating libxext6 2:1.3.4-1build1 I: Retrieving libxfixes3 1:6.0.0-1 I: Validating libxfixes3 1:6.0.0-1 I: Retrieving libxi6 2:1.8-1build1 I: Validating libxi6 2:1.8-1build1 I: Retrieving libxinerama1 2:1.1.4-3 I: Validating libxinerama1 2:1.1.4-3 I: Retrieving libxml2 2.9.13+dfsg-1build1 I: Validating libxml2 2.9.13+dfsg-1build1 I: Retrieving libxrandr2 2:1.5.2-1build1 I: Validating libxrandr2 2:1.5.2-1build1 I: Retrieving libxrender1 1:0.9.10-1build4 I: Validating libxrender1 1:0.9.10-1build4 I: Retrieving libxxhash0 0.8.1-1 I: Validating libxxhash0 0.8.1-1 I: Retrieving libzstd1 1.4.8+dfsg-3build1 I: Validating libzstd1 1.4.8+dfsg-3build1 I: Retrieving linux-libc-dev 5.15.0-25.25 I: Validating linux-libc-dev 5.15.0-25.25 I: Retrieving locales 2.35-0ubuntu3 I: Validating locales 2.35-0ubuntu3 I: Retrieving login 1:4.8.1-2ubuntu2 I: Validating login 1:4.8.1-2ubuntu2 I: Retrieving logsave 1.46.5-2ubuntu1 I: Validating logsave 1.46.5-2ubuntu1 I: Retrieving lsb-base 11.1.0ubuntu4 I: Validating lsb-base 11.1.0ubuntu4 I: Retrieving mawk 1.3.4.20200120-3 I: Validating mawk 1.3.4.20200120-3 I: Retrieving media-types 7.0.0 I: Validating media-types 7.0.0 I: Retrieving mount 2.37.2-4ubuntu3 I: Validating mount 2.37.2-4ubuntu3 I: Retrieving ncurses-base 6.3-2 I: Validating ncurses-base 6.3-2 I: Retrieving ncurses-bin 6.3-2 I: Validating ncurses-bin 6.3-2 I: Retrieving passwd 1:4.8.1-2ubuntu2 I: Validating passwd 1:4.8.1-2ubuntu2 I: Retrieving perl 5.34.0-3ubuntu1 I: Validating perl 5.34.0-3ubuntu1 I: Retrieving perl-base 5.34.0-3ubuntu1 I: Validating perl-base 5.34.0-3ubuntu1 I: Retrieving perl-modules-5.34 5.34.0-3ubuntu1 I: Validating perl-modules-5.34 5.34.0-3ubuntu1 I: Retrieving pinentry-curses 1.1.1-1build2 I: Validating pinentry-curses 1.1.1-1build2 I: Retrieving pkg-config 0.29.2-1ubuntu3 I: Validating pkg-config 0.29.2-1ubuntu3 I: Retrieving procps 2:3.3.17-6ubuntu2 I: Validating procps 2:3.3.17-6ubuntu2 I: Retrieving python3 3.10.4-0ubuntu2 I: Validating python3 3.10.4-0ubuntu2 I: Retrieving python3-distutils 3.10.4-0ubuntu1 I: Validating python3-distutils 3.10.4-0ubuntu1 I: Retrieving python3-lib2to3 3.10.4-0ubuntu1 I: Validating python3-lib2to3 3.10.4-0ubuntu1 I: Retrieving python3-minimal 3.10.4-0ubuntu2 I: Validating python3-minimal 3.10.4-0ubuntu2 I: Retrieving python3.10 3.10.4-3 I: Validating python3.10 3.10.4-3 I: Retrieving python3.10-minimal 3.10.4-3 I: Validating python3.10-minimal 3.10.4-3 I: Retrieving readline-common 8.1.2-1 I: Validating readline-common 8.1.2-1 I: Retrieving rpcsvc-proto 1.4.2-0ubuntu6 I: Validating rpcsvc-proto 1.4.2-0ubuntu6 I: Retrieving sed 4.8-1ubuntu2 I: Validating sed 4.8-1ubuntu2 I: Retrieving sensible-utils 0.0.17 I: Validating sensible-utils 0.0.17 I: Retrieving shared-mime-info 2.1-2 I: Validating shared-mime-info 2.1-2 I: Retrieving sysvinit-utils 3.01-1ubuntu1 I: Validating sysvinit-utils 3.01-1ubuntu1 I: Retrieving tar 1.34+dfsg-1build3 I: Validating tar 1.34+dfsg-1build3 I: Retrieving ubuntu-keyring 2021.03.26 I: Validating ubuntu-keyring 2021.03.26 I: Retrieving ubuntu-mono 20.10-0ubuntu2 I: Validating ubuntu-mono 20.10-0ubuntu2 I: Retrieving ucf 3.0043 I: Validating ucf 3.0043 I: Retrieving usrmerge 25ubuntu2 I: Validating usrmerge 25ubuntu2 I: Retrieving util-linux 2.37.2-4ubuntu3 I: Validating util-linux 2.37.2-4ubuntu3 I: Retrieving uuid-dev 2.37.2-4ubuntu3 I: Validating uuid-dev 2.37.2-4ubuntu3 I: Retrieving xkb-data 2.33-1 I: Validating xkb-data 2.33-1 I: Retrieving zlib1g 1:1.2.11.dfsg-2ubuntu9 I: Validating zlib1g 1:1.2.11.dfsg-2ubuntu9 I: Retrieving zlib1g-dev 1:1.2.11.dfsg-2ubuntu9 I: Validating zlib1g-dev 1:1.2.11.dfsg-2ubuntu9 I: Retrieving gnupg2 2.2.27-3ubuntu2 I: Validating gnupg2 2.2.27-3ubuntu2 I: Chosen extractor for .deb packages: dpkg-deb I: Extracting base-files... I: Extracting base-passwd... I: Extracting bash... I: Extracting bsdutils... I: Extracting coreutils... I: Extracting dash... I: Extracting debconf... I: Extracting debianutils... I: Extracting diffutils... I: Extracting dpkg... I: Extracting e2fsprogs... I: Extracting findutils... I: Extracting gcc-12-base... I: Extracting grep... I: Extracting gzip... I: Extracting hostname... I: Extracting init-system-helpers... I: Extracting libacl1... I: Extracting libattr1... I: Extracting libaudit-common... I: Extracting libaudit1... I: Extracting libblkid1... I: Extracting libbz2-1.0... I: Extracting libc-bin... I: Extracting libc6... I: Extracting libcap-ng0... I: Extracting libcap2... I: Extracting libcom-err2... I: Extracting libcrypt1... I: Extracting libdb5.3... I: Extracting libdebconfclient0... I: Extracting libext2fs2... I: Extracting libgcc-s1... I: Extracting libgcrypt20... I: Extracting libgmp10... I: Extracting libgpg-error0... I: Extracting libgssapi-krb5-2... I: Extracting libk5crypto3... I: Extracting libkeyutils1... I: Extracting libkrb5-3... I: Extracting libkrb5support0... I: Extracting liblz4-1... I: Extracting liblzma5... I: Extracting libmount1... I: Extracting libncurses6... I: Extracting libncursesw6... I: Extracting libnsl2... I: Extracting libpam-modules... I: Extracting libpam-modules-bin... I: Extracting libpam-runtime... I: Extracting libpam0g... I: Extracting libpcre2-8-0... I: Extracting libpcre3... I: Extracting libprocps8... I: Extracting libselinux1... I: Extracting libsemanage-common... I: Extracting libsemanage2... I: Extracting libsepol2... I: Extracting libsmartcols1... I: Extracting libss2... I: Extracting libssl3... I: Extracting libsystemd0... I: Extracting libtinfo6... I: Extracting libtirpc-common... I: Extracting libtirpc3... I: Extracting libudev1... I: Extracting libuuid1... I: Extracting libzstd1... I: Extracting login... I: Extracting logsave... I: Extracting lsb-base... I: Extracting mawk... I: Extracting mount... I: Extracting ncurses-base... I: Extracting ncurses-bin... I: Extracting passwd... I: Extracting perl-base... I: Extracting procps... I: Extracting sed... I: Extracting sensible-utils... I: Extracting sysvinit-utils... I: Extracting tar... I: Extracting usrmerge... I: Extracting util-linux... I: Extracting zlib1g... --> (340) COMMAND: cp -pv /usr/bin/qemu-aarch64-static /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/bin/ '/usr/bin/qemu-aarch64-static' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/bin/qemu-aarch64-static' --> (340) INFO: Installing base system [ Stage 2/2 ] --> (340) COMMAND: LC_ALL=C LANG=C /debootstrap/debootstrap --second-stage /bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8) I: Installing core packages... I: Unpacking required packages... I: Unpacking base-files... I: Unpacking base-passwd... I: Unpacking bash... I: Unpacking bsdutils... I: Unpacking coreutils... I: Unpacking dash... I: Unpacking debconf... I: Unpacking debianutils... I: Unpacking diffutils... I: Unpacking dpkg... I: Unpacking e2fsprogs... I: Unpacking findutils... I: Unpacking gcc-12-base:arm64... I: Unpacking grep... I: Unpacking gzip... I: Unpacking hostname... I: Unpacking init-system-helpers... I: Unpacking libacl1:arm64... I: Unpacking libattr1:arm64... I: Unpacking libaudit-common... I: Unpacking libaudit1:arm64... I: Unpacking libblkid1:arm64... I: Unpacking libbz2-1.0:arm64... I: Unpacking libc-bin... I: Unpacking libc6:arm64... I: Unpacking libcap-ng0:arm64... I: Unpacking libcap2:arm64... I: Unpacking libcom-err2:arm64... I: Unpacking libcrypt1:arm64... I: Unpacking libdb5.3:arm64... I: Unpacking libdebconfclient0:arm64... I: Unpacking libext2fs2:arm64... I: Unpacking libgcc-s1:arm64... I: Unpacking libgcrypt20:arm64... I: Unpacking libgmp10:arm64... I: Unpacking libgpg-error0:arm64... I: Unpacking libgssapi-krb5-2:arm64... I: Unpacking libk5crypto3:arm64... I: Unpacking libkeyutils1:arm64... I: Unpacking libkrb5-3:arm64... I: Unpacking libkrb5support0:arm64... I: Unpacking liblz4-1:arm64... I: Unpacking liblzma5:arm64... I: Unpacking libmount1:arm64... I: Unpacking libncurses6:arm64... I: Unpacking libncursesw6:arm64... I: Unpacking libnsl2:arm64... I: Unpacking libpam-modules:arm64... I: Unpacking libpam-modules-bin... I: Unpacking libpam-runtime... I: Unpacking libpam0g:arm64... I: Unpacking libpcre2-8-0:arm64... I: Unpacking libpcre3:arm64... I: Unpacking libprocps8:arm64... I: Unpacking libselinux1:arm64... I: Unpacking libsemanage-common... I: Unpacking libsemanage2:arm64... I: Unpacking libsepol2:arm64... I: Unpacking libsmartcols1:arm64... I: Unpacking libss2:arm64... I: Unpacking libssl3:arm64... I: Unpacking libsystemd0:arm64... I: Unpacking libtinfo6:arm64... I: Unpacking libtirpc-common... I: Unpacking libtirpc3:arm64... I: Unpacking libudev1:arm64... I: Unpacking libuuid1:arm64... I: Unpacking libzstd1:arm64... I: Unpacking login... I: Unpacking logsave... I: Unpacking lsb-base... I: Unpacking mawk... I: Unpacking mount... I: Unpacking ncurses-base... I: Unpacking ncurses-bin... I: Unpacking passwd... I: Unpacking perl-base... I: Unpacking procps... I: Unpacking sed... I: Unpacking sensible-utils... I: Unpacking sysvinit-utils... I: Unpacking tar... I: Unpacking usrmerge... I: Unpacking util-linux... I: Unpacking zlib1g:arm64... I: Configuring required packages... I: Configuring lsb-base... I: Configuring libtirpc-common... I: Configuring libaudit-common... I: Configuring libsemanage-common... I: Configuring gcc-12-base:arm64... I: Configuring ncurses-base... I: Configuring sensible-utils... I: Configuring libcrypt1:arm64... I: Configuring libgcc-s1:arm64... I: Configuring libc6:arm64... I: Configuring libudev1:arm64... I: Configuring libattr1:arm64... I: Configuring sysvinit-utils... I: Configuring debianutils... I: Configuring mawk... I: Configuring libdebconfclient0:arm64... I: Configuring base-files... I: Configuring libbz2-1.0:arm64... I: Configuring base-passwd... I: Configuring libdb5.3:arm64... I: Configuring libblkid1:arm64... I: Configuring libtinfo6:arm64... I: Configuring bash... I: Configuring libzstd1:arm64... I: Configuring libkeyutils1:arm64... I: Configuring liblzma5:arm64... I: Configuring libgpg-error0:arm64... I: Configuring liblz4-1:arm64... I: Configuring libc-bin... I: Configuring ncurses-bin... I: Configuring libacl1:arm64... I: Configuring libsmartcols1:arm64... I: Configuring libgcrypt20:arm64... I: Configuring zlib1g:arm64... I: Configuring libcom-err2:arm64... I: Configuring diffutils... I: Configuring libcap2:arm64... I: Configuring libkrb5support0:arm64... I: Configuring hostname... I: Configuring libpcre3:arm64... I: Configuring libcap-ng0:arm64... I: Configuring libext2fs2:arm64... I: Configuring libgmp10:arm64... I: Configuring libncurses6:arm64... I: Configuring libaudit1:arm64... I: Configuring libuuid1:arm64... I: Configuring libss2:arm64... I: Configuring libsepol2:arm64... I: Configuring libpcre2-8-0:arm64... I: Configuring libncursesw6:arm64... I: Configuring libk5crypto3:arm64... I: Configuring logsave... I: Configuring e2fsprogs... I: Configuring libsystemd0:arm64... I: Configuring libselinux1:arm64... I: Configuring sed... I: Configuring findutils... I: Configuring libmount1:arm64... I: Configuring libsemanage2:arm64... I: Configuring libprocps8:arm64... I: Configuring bsdutils... I: Configuring tar... I: Configuring coreutils... I: Configuring dpkg... I: Configuring mount... I: Configuring grep... I: Configuring perl-base... I: Configuring init-system-helpers... I: Configuring gzip... I: Configuring usrmerge... I: Configuring procps... I: Configuring debconf... I: Configuring libpam0g:arm64... I: Configuring util-linux... I: Configuring dash... I: Configuring libpam-modules-bin... I: Configuring libssl3:arm64... I: Configuring libkrb5-3:arm64... I: Configuring libgssapi-krb5-2:arm64... I: Configuring libtirpc3:arm64... I: Configuring libnsl2:arm64... I: Configuring libpam-modules:arm64... I: Configuring passwd... I: Configuring libpam-runtime... I: Configuring login... I: Configuring libc-bin... I: Unpacking the base system... I: Unpacking adduser... I: Unpacking adwaita-icon-theme... I: Unpacking apt... I: Unpacking apt-utils... I: Unpacking console-setup... I: Unpacking console-setup-linux... I: Unpacking dconf-cli... I: Unpacking dirmngr... I: Unpacking fontconfig... I: Unpacking fontconfig-config... I: Unpacking fonts-dejavu-core... I: Unpacking fonts-noto-color-emoji... I: Unpacking gnupg... I: Unpacking gnupg-l10n... I: Unpacking gnupg-utils... I: Unpacking gpg... I: Unpacking gpg-agent... I: Unpacking gpg-wks-client... I: Unpacking gpg-wks-server... I: Unpacking gpgconf... I: Unpacking gpgsm... I: Unpacking gpgv... I: Unpacking gtk-update-icon-cache... I: Unpacking hicolor-icon-theme... I: Unpacking humanity-icon-theme... I: Unpacking kbd... I: Unpacking keyboard-configuration... I: Unpacking libapt-pkg6.0:arm64... I: Unpacking libassuan0:arm64... I: Unpacking libatk1.0-0:arm64... I: Unpacking libatk1.0-data... I: Unpacking libavahi-client3:arm64... I: Unpacking libavahi-common-data:arm64... I: Unpacking libavahi-common3:arm64... I: Unpacking libblkid-dev:arm64... I: Unpacking libbrotli1:arm64... I: Unpacking libbsd0:arm64... I: Unpacking libc-dev-bin... I: Unpacking libc6-dev:arm64... I: Unpacking libcairo2:arm64... I: Unpacking libcrypt-dev:arm64... I: Unpacking libcups2:arm64... I: Unpacking libdatrie1:arm64... I: Unpacking libdbus-1-3:arm64... I: Unpacking libdconf1:arm64... I: Unpacking libdeflate0:arm64... I: Unpacking libdpkg-perl... I: Unpacking libelf1:arm64... I: Unpacking libffi-dev:arm64... I: Unpacking libffi8:arm64... I: Unpacking libfontconfig1:arm64... I: Unpacking libfreetype6:arm64... I: Unpacking libfribidi0:arm64... I: Unpacking libgdbm-compat4:arm64... I: Unpacking libgdbm6:arm64... I: Unpacking libgdk-pixbuf-2.0-0:arm64... I: Unpacking libgdk-pixbuf2.0-common... I: Unpacking libglib2.0-0:arm64... I: Unpacking libglib2.0-bin... I: Unpacking libglib2.0-data... I: Unpacking libglib2.0-dev:arm64... I: Unpacking libglib2.0-dev-bin... I: Unpacking libgnutls30:arm64... I: Unpacking libgraphite2-3:arm64... I: Unpacking libgtk2.0-0:arm64... I: Unpacking libgtk2.0-bin... I: Unpacking libgtk2.0-common... I: Unpacking libharfbuzz0b:arm64... I: Unpacking libhogweed6:arm64... I: Unpacking libicu70:arm64... I: Unpacking libidn2-0:arm64... I: Unpacking libjbig0:arm64... I: Unpacking libjpeg-turbo8:arm64... I: Unpacking libjpeg8:arm64... I: Unpacking libksba8:arm64... I: Unpacking libldap-2.5-0:arm64... I: Unpacking liblocale-gettext-perl... I: Unpacking libmd0:arm64... I: Unpacking libmount-dev:arm64... I: Unpacking libmpdec3:arm64... I: Unpacking libnettle8:arm64... I: Unpacking libnpth0:arm64... I: Unpacking libnsl-dev:arm64... I: Unpacking libp11-kit0:arm64... I: Unpacking libpango-1.0-0:arm64... I: Unpacking libpangocairo-1.0-0:arm64... I: Unpacking libpangoft2-1.0-0:arm64... I: Unpacking libpcre16-3:arm64... I: Unpacking libpcre2-16-0:arm64... I: Unpacking libpcre2-32-0:arm64... I: Unpacking libpcre2-dev:arm64... I: Unpacking libpcre2-posix3:arm64... I: Unpacking libpcre3-dev:arm64... I: Unpacking libpcre32-3:arm64... I: Unpacking libpcrecpp0v5:arm64... I: Unpacking libperl5.34:arm64... I: Unpacking libpixman-1-0:arm64... I: Unpacking libpng16-16:arm64... I: Unpacking libpython3-stdlib:arm64... I: Unpacking libpython3.10-stdlib:arm64... I: Unpacking libreadline8:arm64... I: Unpacking libsasl2-2:arm64... I: Unpacking libsasl2-modules-db:arm64... I: Unpacking libseccomp2:arm64... I: Unpacking libselinux1-dev:arm64... I: Unpacking libsepol-dev:arm64... I: Unpacking libsqlite3-0:arm64... I: Unpacking libstdc++6:arm64... I: Unpacking libtasn1-6:arm64... I: Unpacking libthai-data... I: Unpacking libthai0:arm64... I: Unpacking libtiff5:arm64... I: Unpacking libtirpc-dev:arm64... I: Unpacking libunistring2:arm64... I: Unpacking libwebp7:arm64... I: Unpacking libx11-6:arm64... I: Unpacking libx11-data... I: Unpacking libxau6:arm64... I: Unpacking libxcb-render0:arm64... I: Unpacking libxcb-shm0:arm64... I: Unpacking libxcb1:arm64... I: Unpacking libxcomposite1:arm64... I: Unpacking libxcursor1:arm64... I: Unpacking libxdamage1:arm64... I: Unpacking libxdmcp6:arm64... I: Unpacking libxext6:arm64... I: Unpacking libxfixes3:arm64... I: Unpacking libxi6:arm64... I: Unpacking libxinerama1:arm64... I: Unpacking libxml2:arm64... I: Unpacking libxrandr2:arm64... I: Unpacking libxrender1:arm64... I: Unpacking libxxhash0:arm64... I: Unpacking linux-libc-dev:arm64... I: Unpacking locales... I: Unpacking media-types... I: Unpacking perl... I: Unpacking perl-modules-5.34... I: Unpacking pinentry-curses... I: Unpacking pkg-config... I: Unpacking python3... I: Unpacking python3-distutils... I: Unpacking python3-lib2to3... I: Unpacking python3.10... I: Unpacking readline-common... I: Unpacking rpcsvc-proto... I: Unpacking shared-mime-info... I: Unpacking ubuntu-keyring... I: Unpacking ubuntu-mono... I: Unpacking ucf... I: Unpacking uuid-dev:arm64... I: Unpacking xkb-data... I: Unpacking zlib1g-dev:arm64... I: Unpacking gnupg2... I: Configuring the base system... I: Configuring libksba8:arm64... I: Configuring media-types... I: Configuring libgraphite2-3:arm64... I: Configuring libpixman-1-0:arm64... I: Configuring libxau6:arm64... I: Configuring adduser... I: Configuring libpcre16-3:arm64... I: Configuring hicolor-icon-theme... I: Configuring libdatrie1:arm64... I: Configuring fonts-noto-color-emoji... I: Configuring libbrotli1:arm64... I: Configuring libsqlite3-0:arm64... I: Configuring libgdk-pixbuf2.0-common... I: Configuring libunistring2:arm64... I: Configuring libdeflate0:arm64... I: Configuring linux-libc-dev:arm64... I: Configuring xkb-data... I: Configuring libnpth0:arm64... I: Configuring libidn2-0:arm64... I: Configuring libassuan0:arm64... I: Configuring perl-modules-5.34... I: Configuring locales... I: Configuring ubuntu-keyring... I: Configuring libjbig0:arm64... I: Configuring libseccomp2:arm64... I: Configuring libpcre2-16-0:arm64... I: Configuring libsasl2-modules-db:arm64... I: Configuring libpcre2-32-0:arm64... I: Configuring libglib2.0-data... I: Configuring libtirpc-dev:arm64... I: Configuring rpcsvc-proto... I: Configuring libnettle8:arm64... I: Configuring libx11-data... I: Configuring gnupg-l10n... I: Configuring libavahi-common-data:arm64... I: Configuring libdbus-1-3:arm64... I: Configuring libfribidi0:arm64... I: Configuring libpng16-16:arm64... I: Configuring libpcre32-3:arm64... I: Configuring fonts-dejavu-core... I: Configuring libsepol-dev:arm64... I: Configuring ucf... I: Configuring libjpeg-turbo8:arm64... I: Configuring libsasl2-2:arm64... I: Configuring libwebp7:arm64... I: Configuring libatk1.0-data... I: Configuring libffi8:arm64... I: Configuring libpcre2-posix3:arm64... I: Configuring libmd0:arm64... I: Configuring libnsl-dev:arm64... I: Configuring gpgv... I: Configuring libcrypt-dev:arm64... I: Configuring libxxhash0:arm64... I: Configuring libtasn1-6:arm64... I: Configuring libthai-data... I: Configuring libgtk2.0-common... I: Configuring libc-dev-bin... I: Configuring libbsd0:arm64... I: Configuring libelf1:arm64... I: Configuring readline-common... I: Configuring libstdc++6:arm64... I: Configuring liblocale-gettext-perl... I: Configuring libgdbm6:arm64... I: Configuring libicu70:arm64... I: Configuring libjpeg8:arm64... I: Configuring pinentry-curses... I: Configuring libpcrecpp0v5:arm64... I: Configuring libxdmcp6:arm64... I: Configuring libxcb1:arm64... I: Configuring libhogweed6:arm64... I: Configuring libxcb-render0:arm64... I: Configuring libglib2.0-0:arm64... I: Configuring fontconfig-config... I: Configuring libreadline8:arm64... I: Configuring libavahi-common3:arm64... I: Configuring libglib2.0-bin... I: Configuring libxcb-shm0:arm64... I: Configuring libffi-dev:arm64... I: Configuring libdconf1:arm64... I: Configuring libthai0:arm64... I: Configuring libfreetype6:arm64... I: Configuring libapt-pkg6.0:arm64... I: Configuring libp11-kit0:arm64... I: Configuring libgdbm-compat4:arm64... I: Configuring libmpdec3:arm64... I: Configuring gpgconf... I: Configuring libc6-dev:arm64... I: Configuring libx11-6:arm64... I: Configuring libharfbuzz0b:arm64... I: Configuring libatk1.0-0:arm64... I: Configuring libtiff5:arm64... I: Configuring libfontconfig1:arm64... I: Configuring keyboard-configuration... I: Configuring libxcomposite1:arm64... I: Configuring libxml2:arm64... I: Configuring libavahi-client3:arm64... I: Configuring gpg... I: Configuring gnupg-utils... I: Configuring fontconfig... I: Configuring libperl5.34:arm64... I: Configuring libxdamage1:arm64... I: Configuring gpg-agent... I: Configuring dconf-cli... I: Configuring libpcre2-dev:arm64... I: Configuring libxrender1:arm64... I: Configuring libselinux1-dev:arm64... I: Configuring libpcre3-dev:arm64... I: Configuring gpgsm... I: Configuring libpango-1.0-0:arm64... I: Configuring libxext6:arm64... I: Configuring libcairo2:arm64... I: Configuring libpython3.10-stdlib:arm64... I: Configuring perl... I: Configuring libgnutls30:arm64... I: Configuring libxfixes3:arm64... I: Configuring uuid-dev:arm64... I: Configuring shared-mime-info... I: Configuring libxinerama1:arm64... I: Configuring libxrandr2:arm64... I: Configuring libdpkg-perl... I: Configuring gpg-wks-server... I: Configuring libcups2:arm64... I: Configuring zlib1g-dev:arm64... I: Configuring libgdk-pixbuf-2.0-0:arm64... I: Configuring libpangoft2-1.0-0:arm64... I: Configuring libpangocairo-1.0-0:arm64... I: Configuring libpython3-stdlib:arm64... I: Configuring libblkid-dev:arm64... I: Configuring gtk-update-icon-cache... I: Configuring apt... I: Configuring apt-utils... I: Configuring python3.10... I: Configuring libxi6:arm64... I: Configuring libxcursor1:arm64... I: Configuring python3... I: Configuring libldap-2.5-0:arm64... I: Configuring dirmngr... I: Configuring pkg-config... I: Configuring python3-lib2to3... I: Configuring libmount-dev:arm64... I: Configuring python3-distutils... I: Configuring libglib2.0-dev-bin... I: Configuring gpg-wks-client... I: Configuring libglib2.0-dev:arm64... I: Configuring gnupg... I: Configuring gnupg2... I: Configuring adwaita-icon-theme... I: Configuring kbd... I: Configuring console-setup-linux... I: Configuring console-setup... I: Configuring libgtk2.0-0:arm64... I: Configuring humanity-icon-theme... I: Configuring libgtk2.0-bin... I: Configuring ubuntu-mono... I: Configuring libc-bin... I: Base system installed successfully. --> (475) INFO: Diverting [ initctl/start-stop-daemon ] --> (475) COMMAND: LC_ALL=C LANG=C dpkg-divert --quiet --local --rename --add /sbin/initctl /bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8) --> (475) COMMAND: LC_ALL=C LANG=C dpkg-divert --quiet --local --rename --add /sbin/start-stop-daemon /bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8) dpkg-divert: warning: diverting file '/sbin/start-stop-daemon' from an Essential package with rename is dangerous, use --no-rename --> (475) INFO: Configuring locales [ DEST_LANG: en_US.UTF-8 ] --> (475) COMMAND: LC_ALL=C LANG=C locale-gen en_US.UTF-8 /bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8) Generating locales (this might take a while)... en_US.UTF-8... done Generation complete. --> (480) COMMAND: LC_ALL=C LANG=C update-locale LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8 LC_MESSAGES=en_US.UTF-8 --> (481) COMMAND: LC_ALL=C LANG=C setupcon --save --force setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 The keyboard is in some unknown mode Changing to the requested mode may make your keyboard unusable, please use -f to force the change. --> (484) INFO: Adding Armbian repository and authentication key [ /etc/apt/sources.list.d/armbian.list ] --> (484) COMMAND: echo "resolvconf resolvconf/linkify-resolvconf boolean false" | debconf-set-selections --> (485) INFO: Adding APT Source [ githubcli ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/desktop/_all_distributions/appgroups/programming/sources/apt/githubcli.source /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/githubcli.list '/home/reds/patch_series_pcie_ep/build/config/desktop/_all_distributions/appgroups/programming/sources/apt/githubcli.source' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/githubcli.list' --> (485) INFO: Adding GPG Key [ via keyrings: githubcli.list ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/desktop/_all_distributions/appgroups/programming/sources/apt/githubcli.gpg /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/githubcli.gpg '/home/reds/patch_series_pcie_ep/build/config/desktop/_all_distributions/appgroups/programming/sources/apt/githubcli.gpg' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/githubcli.gpg' --> (485) INFO: Adding APT Source [ oibaf ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/desktop/jammy/appgroups/3dsupport/sources/apt/oibaf.source /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/oibaf.list '/home/reds/patch_series_pcie_ep/build/config/desktop/jammy/appgroups/3dsupport/sources/apt/oibaf.source' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/oibaf.list' --> (485) INFO: Adding GPG Key [ via keyrings: oibaf.list ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/desktop/jammy/appgroups/3dsupport/sources/apt/oibaf.gpg /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/oibaf.gpg '/home/reds/patch_series_pcie_ep/build/config/desktop/jammy/appgroups/3dsupport/sources/apt/oibaf.gpg' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/oibaf.gpg' --> (485) INFO: Adding APT Source [ vscodium ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/optional/architectures/arm64/_config/desktop/_all_distributions/appgroups/programming/sources/apt/vscodium.source /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/vscodium.list '/home/reds/patch_series_pcie_ep/build/config/optional/architectures/arm64/_config/desktop/_all_distributions/appgroups/programming/sources/apt/vscodium.source' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d/vscodium.list' --> (485) INFO: Adding GPG Key [ via keyrings: vscodium.list ] --> (485) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/config/optional/architectures/arm64/_config/desktop/_all_distributions/appgroups/programming/sources/apt/vscodium.gpg /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/vscodium.gpg '/home/reds/patch_series_pcie_ep/build/config/optional/architectures/arm64/_config/desktop/_all_distributions/appgroups/programming/sources/apt/vscodium.gpg' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings/vscodium.gpg' --> (485) COMMAND: ls -l /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/usr/share/keyrings total 44 -rw-rw-r-- 1 root root 2236 Mar 15 09:45 armbian.gpg -rw-rw-r-- 1 reds reds 2270 Mar 15 09:34 githubcli.gpg -rw-rw-r-- 1 reds reds 5934 Mar 15 09:34 oibaf.gpg -rw-r--r-- 1 root root 7399 Sep 18 2018 ubuntu-archive-keyring.gpg -rw-r--r-- 1 root root 6713 Oct 27 2016 ubuntu-archive-removed-keys.gpg -rw-r--r-- 1 root root 3023 Mar 27 2021 ubuntu-cloudimage-keyring.gpg -rw-r--r-- 1 root root 0 Jan 17 2018 ubuntu-cloudimage-removed-keys.gpg -rw-r--r-- 1 root root 1227 May 27 2010 ubuntu-master-keyring.gpg -rw-rw-r-- 1 reds reds 2256 Mar 15 09:34 vscodium.gpg --> (485) COMMAND: ls -l /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list.d total 16 -rw-rw-r-- 1 root root 108 Mar 15 09:45 armbian.list -rw-rw-r-- 1 reds reds 93 Mar 15 09:34 githubcli.list -rw-rw-r-- 1 reds reds 121 Mar 15 09:34 oibaf.list -rw-rw-r-- 1 reds reds 120 Mar 15 09:34 vscodium.list --> (485) COMMAND: cat /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/apt/sources.list deb http://ports.ubuntu.com/ jammy main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-security main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-security main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse #deb-src http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse --> (485) INFO: Updating package list [ jammy ] --> (485) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (485) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (485) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (485) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -q -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 update Get:2 http://ports.ubuntu.com jammy InRelease [270 kB] Get:3 http://ports.ubuntu.com jammy-security InRelease [110 kB] Get:4 http://ports.ubuntu.com jammy-updates InRelease [119 kB] Get:5 http://ports.ubuntu.com jammy-backports InRelease [107 kB] Ign:1 https://cli.github.com/packages stable InRelease Get:6 http://mirrors.xtom.de/armbian jammy InRelease [52.4 kB] Ign:7 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:1 https://cli.github.com/packages stable InRelease Get:8 http://ports.ubuntu.com jammy/main arm64 Packages [1,369 kB] Get:9 http://ports.ubuntu.com jammy/main Translation-en [510 kB] Get:10 http://ports.ubuntu.com jammy/restricted arm64 Packages [19.6 kB] Get:11 http://ports.ubuntu.com jammy/restricted Translation-en [18.6 kB] Get:12 http://ports.ubuntu.com jammy/universe arm64 Packages [13.9 MB] Ign:7 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Get:13 http://ports.ubuntu.com jammy/universe Translation-en [5,652 kB] Get:14 http://ports.ubuntu.com jammy/multiverse arm64 Packages [184 kB] Get:15 http://ports.ubuntu.com jammy/multiverse Translation-en [112 kB] Get:16 http://ports.ubuntu.com jammy-security/main arm64 Packages [603 kB] Get:17 http://ports.ubuntu.com jammy-security/main Translation-en [142 kB] Get:18 http://ports.ubuntu.com jammy-security/restricted arm64 Packages [292 kB] Get:19 http://ports.ubuntu.com jammy-security/restricted Translation-en [99.7 kB] Get:20 http://ports.ubuntu.com jammy-security/universe arm64 Packages [593 kB] Get:21 http://ports.ubuntu.com jammy-security/universe Translation-en [114 kB] Get:22 http://ports.ubuntu.com jammy-security/multiverse arm64 Packages [1,436 B] Get:23 http://ports.ubuntu.com jammy-security/multiverse Translation-en [996 B] Ign:1 https://cli.github.com/packages stable InRelease Ign:7 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Get:24 http://ports.ubuntu.com jammy-updates/main arm64 Packages [851 kB] Get:25 http://ports.ubuntu.com jammy-updates/main Translation-en [205 kB] Get:26 http://ports.ubuntu.com jammy-updates/restricted arm64 Packages [303 kB] Get:27 http://ports.ubuntu.com jammy-updates/restricted Translation-en [107 kB] Get:28 http://ports.ubuntu.com jammy-updates/universe arm64 Packages [773 kB] Get:29 http://ports.ubuntu.com jammy-updates/universe Translation-en [175 kB] Get:30 http://ports.ubuntu.com jammy-updates/multiverse arm64 Packages [5,056 B] Get:31 http://ports.ubuntu.com jammy-updates/multiverse Translation-en [3,260 B] Get:32 http://ports.ubuntu.com jammy-backports/main arm64 Packages [40.6 kB] Get:33 http://ports.ubuntu.com jammy-backports/main Translation-en [9,800 B] Get:34 http://ports.ubuntu.com jammy-backports/universe arm64 Packages [19.5 kB] Get:35 http://ports.ubuntu.com jammy-backports/universe Translation-en [14.0 kB] Get:36 http://mirrors.xtom.de/armbian jammy/main all Packages [76.3 kB] Get:37 http://mirrors.xtom.de/armbian jammy/main arm64 Packages [684 kB] Get:38 http://mirrors.xtom.de/armbian jammy/jammy-utils all Packages [27.9 kB] Get:39 http://mirrors.xtom.de/armbian jammy/jammy-utils arm64 Packages [43.8 kB] Get:40 http://mirrors.xtom.de/armbian jammy/jammy-desktop arm64 Packages [146 kB] Get:41 http://mirrors.xtom.de/armbian jammy/jammy-desktop all Packages [20.5 kB] Err:1 https://cli.github.com/packages stable InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 185.199.108.153 443] Err:7 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 35.185.44.232 443] Fetched 27.8 MB in 13s (2,134 kB/s) Reading package lists... W: http://cli.github.com/packages/dists/stable/InRelease: No system certificates available. Try installing ca-certificates. W: http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease: No system certificates available. Try installing ca-certificates. W: http://cli.github.com/packages/dists/stable/InRelease: No system certificates available. Try installing ca-certificates. W: http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease: No system certificates available. Try installing ca-certificates. W: http://cli.github.com/packages/dists/stable/InRelease: No system certificates available. Try installing ca-certificates. W: http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease: No system certificates available. Try installing ca-certificates. W: http://cli.github.com/packages/dists/stable/InRelease: No system certificates available. Try installing ca-certificates. W: http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease: No system certificates available. Try installing ca-certificates. W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 185.199.108.153 443] W: Failed to fetch http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 35.185.44.232 443] W: Some index files failed to download. They have been ignored, or old ones used instead. --> (502) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (502) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (502) INFO: Upgrading base packages [ Armbian ] --> (502) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (502) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (502) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (502) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 upgrade Preconfiguring packages ... (Reading database ... 26665 files and directories currently installed.) Preparing to unpack .../libc6-dev_2.35-0ubuntu3.1_arm64.deb ... Unpacking libc6-dev:arm64 (2.35-0ubuntu3.1) over (2.35-0ubuntu3) ... Preparing to unpack .../libc-dev-bin_2.35-0ubuntu3.1_arm64.deb ... Unpacking libc-dev-bin (2.35-0ubuntu3.1) over (2.35-0ubuntu3) ... Preparing to unpack .../linux-libc-dev_23.02.2_arm64.deb ... Unpacking linux-libc-dev:arm64 (23.02.2) over (5.15.0-25.25) ... Preparing to unpack .../libtirpc-common_1.3.2-2ubuntu0.1_all.deb ... Unpacking libtirpc-common (1.3.2-2ubuntu0.1) over (1.3.2-2build1) ... Setting up libtirpc-common (1.3.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libk5crypto3_1.19.2-2ubuntu0.1_arm64.deb ... Unpacking libk5crypto3:arm64 (1.19.2-2ubuntu0.1) over (1.19.2-2) ... Setting up libk5crypto3:arm64 (1.19.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libkrb5support0_1.19.2-2ubuntu0.1_arm64.deb ... Unpacking libkrb5support0:arm64 (1.19.2-2ubuntu0.1) over (1.19.2-2) ... Setting up libkrb5support0:arm64 (1.19.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libkrb5-3_1.19.2-2ubuntu0.1_arm64.deb ... Unpacking libkrb5-3:arm64 (1.19.2-2ubuntu0.1) over (1.19.2-2) ... Setting up libkrb5-3:arm64 (1.19.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libgssapi-krb5-2_1.19.2-2ubuntu0.1_arm64.deb ... Unpacking libgssapi-krb5-2:arm64 (1.19.2-2ubuntu0.1) over (1.19.2-2) ... Setting up libgssapi-krb5-2:arm64 (1.19.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libcom-err2_1.46.5-2ubuntu1.1_arm64.deb ... Unpacking libcom-err2:arm64 (1.46.5-2ubuntu1.1) over (1.46.5-2ubuntu1) ... Setting up libcom-err2:arm64 (1.46.5-2ubuntu1.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libssl3_3.0.2-0ubuntu1.8_arm64.deb ... Unpacking libssl3:arm64 (3.0.2-0ubuntu1.8) over (3.0.2-0ubuntu1) ... Setting up libssl3:arm64 (3.0.2-0ubuntu1.8) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libtirpc-dev_1.3.2-2ubuntu0.1_arm64.deb ... Unpacking libtirpc-dev:arm64 (1.3.2-2ubuntu0.1) over (1.3.2-2build1) ... Preparing to unpack .../libtirpc3_1.3.2-2ubuntu0.1_arm64.deb ... Unpacking libtirpc3:arm64 (1.3.2-2ubuntu0.1) over (1.3.2-2build1) ... Setting up libtirpc3:arm64 (1.3.2-2ubuntu0.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../gcc-12-base_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking gcc-12-base:arm64 (12.1.0-2ubuntu1~22.04) over (12-20220319-1ubuntu1) ... Setting up gcc-12-base:arm64 (12.1.0-2ubuntu1~22.04) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libgcc-s1_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libgcc-s1:arm64 (12.1.0-2ubuntu1~22.04) over (12-20220319-1ubuntu1) ... Setting up libgcc-s1:arm64 (12.1.0-2ubuntu1~22.04) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libstdc++6_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libstdc++6:arm64 (12.1.0-2ubuntu1~22.04) over (12-20220319-1ubuntu1) ... Setting up libstdc++6:arm64 (12.1.0-2ubuntu1~22.04) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libc6_2.35-0ubuntu3.1_arm64.deb ... Unpacking libc6:arm64 (2.35-0ubuntu3.1) over (2.35-0ubuntu3) ... Setting up libc6:arm64 (2.35-0ubuntu3.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../base-files_12ubuntu4.3_arm64.deb ... Unpacking base-files (12ubuntu4.3) over (12ubuntu4) ... Setting up base-files (12ubuntu4.3) ... Installing new version of config file /etc/issue ... Installing new version of config file /etc/issue.net ... Installing new version of config file /etc/lsb-release ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libsystemd0_249.11-0ubuntu3.7_arm64.deb ... Unpacking libsystemd0:arm64 (249.11-0ubuntu3.7) over (249.11-0ubuntu3) ... Setting up libsystemd0:arm64 (249.11-0ubuntu3.7) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libudev1_249.11-0ubuntu3.7_arm64.deb ... Unpacking libudev1:arm64 (249.11-0ubuntu3.7) over (249.11-0ubuntu3) ... Setting up libudev1:arm64 (249.11-0ubuntu3.7) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../zlib1g-dev_1%3a1.2.11.dfsg-2ubuntu9.2_arm64.deb ... Unpacking zlib1g-dev:arm64 (1:1.2.11.dfsg-2ubuntu9.2) over (1:1.2.11.dfsg-2ubuntu9) ... Preparing to unpack .../zlib1g_1%3a1.2.11.dfsg-2ubuntu9.2_arm64.deb ... Unpacking zlib1g:arm64 (1:1.2.11.dfsg-2ubuntu9.2) over (1:1.2.11.dfsg-2ubuntu9) ... Setting up zlib1g:arm64 (1:1.2.11.dfsg-2ubuntu9.2) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libapt-pkg6.0_2.4.8_arm64.deb ... Unpacking libapt-pkg6.0:arm64 (2.4.8) over (2.4.5) ... Setting up libapt-pkg6.0:arm64 (2.4.8) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../tar_1.34+dfsg-1ubuntu0.1.22.04.1_arm64.deb ... Unpacking tar (1.34+dfsg-1ubuntu0.1.22.04.1) over (1.34+dfsg-1build3) ... Setting up tar (1.34+dfsg-1ubuntu0.1.22.04.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../dpkg_1.21.1ubuntu2.1_arm64.deb ... Unpacking dpkg (1.21.1ubuntu2.1) over (1.21.1ubuntu2) ... Setting up dpkg (1.21.1ubuntu2.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../gzip_1.10-4ubuntu4.1_arm64.deb ... Unpacking gzip (1.10-4ubuntu4.1) over (1.10-4ubuntu4) ... Setting up gzip (1.10-4ubuntu4.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../login_1%3a4.8.1-2ubuntu2.1_arm64.deb ... Unpacking login (1:4.8.1-2ubuntu2.1) over (1:4.8.1-2ubuntu2) ... Setting up login (1:4.8.1-2ubuntu2.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libperl5.34_5.34.0-3ubuntu1.1_arm64.deb ... Unpacking libperl5.34:arm64 (5.34.0-3ubuntu1.1) over (5.34.0-3ubuntu1) ... Preparing to unpack .../perl_5.34.0-3ubuntu1.1_arm64.deb ... Unpacking perl (5.34.0-3ubuntu1.1) over (5.34.0-3ubuntu1) ... Preparing to unpack .../perl-base_5.34.0-3ubuntu1.1_arm64.deb ... Unpacking perl-base (5.34.0-3ubuntu1.1) over (5.34.0-3ubuntu1) ... Setting up perl-base (5.34.0-3ubuntu1.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../perl-modules-5.34_5.34.0-3ubuntu1.1_all.deb ... Unpacking perl-modules-5.34 (5.34.0-3ubuntu1.1) over (5.34.0-3ubuntu1) ... Preparing to unpack .../libc-bin_2.35-0ubuntu3.1_arm64.deb ... Unpacking libc-bin (2.35-0ubuntu3.1) over (2.35-0ubuntu3) ... Setting up libc-bin (2.35-0ubuntu3.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../archives/apt_2.4.8_arm64.deb ... Unpacking apt (2.4.8) over (2.4.5) ... Setting up apt (2.4.8) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../00-apt-utils_2.4.8_arm64.deb ... Unpacking apt-utils (2.4.8) over (2.4.5) ... Preparing to unpack .../01-libksba8_1.6.0-2ubuntu0.2_arm64.deb ... Unpacking libksba8:arm64 (1.6.0-2ubuntu0.2) over (1.6.0-2build1) ... Preparing to unpack .../02-gpg-wks-client_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpg-wks-client (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../03-dirmngr_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking dirmngr (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../04-gnupg-utils_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gnupg-utils (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../05-gpg-wks-server_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpg-wks-server (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../06-gpg-agent_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpg-agent (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../07-gpg_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpg (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../08-gpgconf_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpgconf (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../09-gnupg-l10n_2.2.27-3ubuntu2.1_all.deb ... Unpacking gnupg-l10n (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../10-gnupg_2.2.27-3ubuntu2.1_all.deb ... Unpacking gnupg (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../11-gpgsm_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpgsm (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Preparing to unpack .../12-libsqlite3-0_3.37.2-2ubuntu0.1_arm64.deb ... Unpacking libsqlite3-0:arm64 (3.37.2-2ubuntu0.1) over (3.37.2-2) ... Preparing to unpack .../13-libgnutls30_3.7.3-4ubuntu1.2_arm64.deb ... Unpacking libgnutls30:arm64 (3.7.3-4ubuntu1.2) over (3.7.3-4ubuntu1) ... Setting up libgnutls30:arm64 (3.7.3-4ubuntu1.2) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libsasl2-modules-db_2.1.27+dfsg2-3ubuntu1.2_arm64.deb ... Unpacking libsasl2-modules-db:arm64 (2.1.27+dfsg2-3ubuntu1.2) over (2.1.27+dfsg2-3ubuntu1) ... Preparing to unpack .../libsasl2-2_2.1.27+dfsg2-3ubuntu1.2_arm64.deb ... Unpacking libsasl2-2:arm64 (2.1.27+dfsg2-3ubuntu1.2) over (2.1.27+dfsg2-3ubuntu1) ... Preparing to unpack .../libldap-2.5-0_2.5.13+dfsg-0ubuntu0.22.04.1_arm64.deb ... Unpacking libldap-2.5-0:arm64 (2.5.13+dfsg-0ubuntu0.22.04.1) over (2.5.11+dfsg-1~exp1ubuntu3) ... Preparing to unpack .../gpgv_2.2.27-3ubuntu2.1_arm64.deb ... Unpacking gpgv (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Setting up gpgv (2.2.27-3ubuntu2.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libpam0g_1.4.0-11ubuntu2.3_arm64.deb ... Unpacking libpam0g:arm64 (1.4.0-11ubuntu2.3) over (1.4.0-11ubuntu2) ... Setting up libpam0g:arm64 (1.4.0-11ubuntu2.3) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libpam-modules-bin_1.4.0-11ubuntu2.3_arm64.deb ... Unpacking libpam-modules-bin (1.4.0-11ubuntu2.3) over (1.4.0-11ubuntu2) ... Setting up libpam-modules-bin (1.4.0-11ubuntu2.3) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../libpam-modules_1.4.0-11ubuntu2.3_arm64.deb ... Unpacking libpam-modules:arm64 (1.4.0-11ubuntu2.3) over (1.4.0-11ubuntu2) ... Setting up libpam-modules:arm64 (1.4.0-11ubuntu2.3) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../logsave_1.46.5-2ubuntu1.1_arm64.deb ... Unpacking logsave (1.46.5-2ubuntu1.1) over (1.46.5-2ubuntu1) ... Preparing to unpack .../libext2fs2_1.46.5-2ubuntu1.1_arm64.deb ... Unpacking libext2fs2:arm64 (1.46.5-2ubuntu1.1) over (1.46.5-2ubuntu1) ... Setting up libext2fs2:arm64 (1.46.5-2ubuntu1.1) ... (Reading database ... 26681 files and directories currently installed.) Preparing to unpack .../0-e2fsprogs_1.46.5-2ubuntu1.1_arm64.deb ... Unpacking e2fsprogs (1.46.5-2ubuntu1.1) over (1.46.5-2ubuntu1) ... Preparing to unpack .../1-python3-distutils_3.10.6-1~22.04_all.deb ... Unpacking python3-distutils (3.10.6-1~22.04) over (3.10.4-0ubuntu1) ... Preparing to unpack .../2-python3-lib2to3_3.10.6-1~22.04_all.deb ... Unpacking python3-lib2to3 (3.10.6-1~22.04) over (3.10.4-0ubuntu1) ... Preparing to unpack .../3-python3.10_3.10.6-1~22.04.2_arm64.deb ... Unpacking python3.10 (3.10.6-1~22.04.2) over (3.10.4-3) ... Preparing to unpack .../4-libpython3.10-stdlib_3.10.6-1~22.04.2_arm64.deb ... Unpacking libpython3.10-stdlib:arm64 (3.10.6-1~22.04.2) over (3.10.4-3) ... Preparing to unpack .../5-python3.10-minimal_3.10.6-1~22.04.2_arm64.deb ... Unpacking python3.10-minimal (3.10.6-1~22.04.2) over (3.10.4-3) ... Preparing to unpack .../6-libpython3.10-minimal_3.10.6-1~22.04.2_arm64.deb ... Unpacking libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) over (3.10.4-3) ... Preparing to unpack .../7-libexpat1_2.4.7-1ubuntu0.2_arm64.deb ... Unpacking libexpat1:arm64 (2.4.7-1ubuntu0.2) over (2.4.7-1) ... Setting up libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) ... Setting up libexpat1:arm64 (2.4.7-1ubuntu0.2) ... Setting up python3.10-minimal (3.10.6-1~22.04.2) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../python3-minimal_3.10.6-1~22.04_arm64.deb ... Unpacking python3-minimal (3.10.6-1~22.04) over (3.10.4-0ubuntu2) ... Setting up python3-minimal (3.10.6-1~22.04) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../python3_3.10.6-1~22.04_arm64.deb ... Unpacking python3 (3.10.6-1~22.04) over (3.10.4-0ubuntu2) ... Preparing to unpack .../libpython3-stdlib_3.10.6-1~22.04_arm64.deb ... Unpacking libpython3-stdlib:arm64 (3.10.6-1~22.04) over (3.10.4-0ubuntu2) ... Preparing to unpack .../libpam-runtime_1.4.0-11ubuntu2.3_all.deb ... Unpacking libpam-runtime (1.4.0-11ubuntu2.3) over (1.4.0-11ubuntu2) ... Setting up libpam-runtime (1.4.0-11ubuntu2.3) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../libpcre2-dev_10.39-3ubuntu0.1_arm64.deb ... Unpacking libpcre2-dev:arm64 (10.39-3ubuntu0.1) over (10.39-3build1) ... Preparing to unpack .../libpcre2-16-0_10.39-3ubuntu0.1_arm64.deb ... Unpacking libpcre2-16-0:arm64 (10.39-3ubuntu0.1) over (10.39-3build1) ... Preparing to unpack .../libpcre2-32-0_10.39-3ubuntu0.1_arm64.deb ... Unpacking libpcre2-32-0:arm64 (10.39-3ubuntu0.1) over (10.39-3build1) ... Preparing to unpack .../libpcre2-posix3_10.39-3ubuntu0.1_arm64.deb ... Unpacking libpcre2-posix3:arm64 (10.39-3ubuntu0.1) over (10.39-3build1) ... Preparing to unpack .../libpcre2-8-0_10.39-3ubuntu0.1_arm64.deb ... Unpacking libpcre2-8-0:arm64 (10.39-3ubuntu0.1) over (10.39-3build1) ... Setting up libpcre2-8-0:arm64 (10.39-3ubuntu0.1) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../libpcre3-dev_2%3a8.39-13ubuntu0.22.04.1_arm64.deb ... Unpacking libpcre3-dev:arm64 (2:8.39-13ubuntu0.22.04.1) over (2:8.39-13build5) ... Preparing to unpack .../libpcre16-3_2%3a8.39-13ubuntu0.22.04.1_arm64.deb ... Unpacking libpcre16-3:arm64 (2:8.39-13ubuntu0.22.04.1) over (2:8.39-13build5) ... Preparing to unpack .../libpcre32-3_2%3a8.39-13ubuntu0.22.04.1_arm64.deb ... Unpacking libpcre32-3:arm64 (2:8.39-13ubuntu0.22.04.1) over (2:8.39-13build5) ... Preparing to unpack .../libpcrecpp0v5_2%3a8.39-13ubuntu0.22.04.1_arm64.deb ... Unpacking libpcrecpp0v5:arm64 (2:8.39-13ubuntu0.22.04.1) over (2:8.39-13build5) ... Preparing to unpack .../libpcre3_2%3a8.39-13ubuntu0.22.04.1_arm64.deb ... Unpacking libpcre3:arm64 (2:8.39-13ubuntu0.22.04.1) over (2:8.39-13build5) ... Setting up libpcre3:arm64 (2:8.39-13ubuntu0.22.04.1) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../passwd_1%3a4.8.1-2ubuntu2.1_arm64.deb ... Unpacking passwd (1:4.8.1-2ubuntu2.1) over (1:4.8.1-2ubuntu2) ... Setting up passwd (1:4.8.1-2ubuntu2.1) ... (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../00-libss2_1.46.5-2ubuntu1.1_arm64.deb ... Unpacking libss2:arm64 (1.46.5-2ubuntu1.1) over (1.46.5-2ubuntu1) ... Preparing to unpack .../01-kbd_2.3.0-3ubuntu4.22.04_arm64.deb ... Unpacking kbd (2.3.0-3ubuntu4.22.04) over (2.3.0-3ubuntu4) ... Preparing to unpack .../02-libdbus-1-3_1.12.20-2ubuntu4.1_arm64.deb ... Unpacking libdbus-1-3:arm64 (1.12.20-2ubuntu4.1) over (1.12.20-2ubuntu4) ... Preparing to unpack .../03-libfribidi0_1.0.8-2ubuntu3.1_arm64.deb ... Unpacking libfribidi0:arm64 (1.0.8-2ubuntu3.1) over (1.0.8-2ubuntu3) ... Preparing to unpack .../04-libglib2.0-dev-bin_2.72.4-0ubuntu1_arm64.deb ... Unpacking libglib2.0-dev-bin (2.72.4-0ubuntu1) over (2.72.1-1) ... Preparing to unpack .../05-libglib2.0-dev_2.72.4-0ubuntu1_arm64.deb ... Unpacking libglib2.0-dev:arm64 (2.72.4-0ubuntu1) over (2.72.1-1) ... Preparing to unpack .../06-libglib2.0-data_2.72.4-0ubuntu1_all.deb ... Unpacking libglib2.0-data (2.72.4-0ubuntu1) over (2.72.1-1) ... Preparing to unpack .../07-libglib2.0-bin_2.72.4-0ubuntu1_arm64.deb ... Unpacking libglib2.0-bin (2.72.4-0ubuntu1) over (2.72.1-1) ... Preparing to unpack .../08-libglib2.0-0_2.72.4-0ubuntu1_arm64.deb ... Unpacking libglib2.0-0:arm64 (2.72.4-0ubuntu1) over (2.72.1-1) ... Preparing to unpack .../09-libxml2_2.9.13+dfsg-1ubuntu0.2_arm64.deb ... Unpacking libxml2:arm64 (2.9.13+dfsg-1ubuntu0.2) over (2.9.13+dfsg-1build1) ... Preparing to unpack .../10-locales_2.35-0ubuntu3.1_all.deb ... Unpacking locales (2.35-0ubuntu3.1) over (2.35-0ubuntu3) ... Preparing to unpack .../11-fonts-noto-color-emoji_2.038-0ubuntu1_all.deb ... Unpacking fonts-noto-color-emoji (2.038-0ubuntu1) over (2.034-1) ... Preparing to unpack .../12-libgdk-pixbuf2.0-common_2.42.8+dfsg-1ubuntu0.2_all.deb ... Unpacking libgdk-pixbuf2.0-common (2.42.8+dfsg-1ubuntu0.2) over (2.42.8+dfsg-1) ... Preparing to unpack .../13-libjbig0_2.1-3.1ubuntu0.22.04.1_arm64.deb ... Unpacking libjbig0:arm64 (2.1-3.1ubuntu0.22.04.1) over (2.1-3.1build3) ... Preparing to unpack .../14-libtiff5_4.3.0-6ubuntu0.4_arm64.deb ... Unpacking libtiff5:arm64 (4.3.0-6ubuntu0.4) over (4.3.0-6) ... Preparing to unpack .../15-libgdk-pixbuf-2.0-0_2.42.8+dfsg-1ubuntu0.2_arm64.deb ... Unpacking libgdk-pixbuf-2.0-0:arm64 (2.42.8+dfsg-1ubuntu0.2) over (2.42.8+dfsg-1) ... Preparing to unpack .../16-gtk-update-icon-cache_3.24.33-1ubuntu2_arm64.deb ... Unpacking gtk-update-icon-cache (3.24.33-1ubuntu2) over (3.24.33-1ubuntu1) ... Preparing to unpack .../17-libcups2_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking libcups2:arm64 (2.4.1op1-1ubuntu4.1) over (2.4.1op1-1ubuntu4) ... Preparing to unpack .../18-libdpkg-perl_1.21.1ubuntu2.1_all.deb ... Unpacking libdpkg-perl (1.21.1ubuntu2.1) over (1.21.1ubuntu2) ... Preparing to unpack .../19-libfreetype6_2.11.1+dfsg-1ubuntu0.1_arm64.deb ... Unpacking libfreetype6:arm64 (2.11.1+dfsg-1ubuntu0.1) over (2.11.1+dfsg-1build1) ... Preparing to unpack .../20-libharfbuzz0b_2.7.4-1ubuntu3.1_arm64.deb ... Unpacking libharfbuzz0b:arm64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu3) ... Preparing to unpack .../21-libpangoft2-1.0-0_1.50.6+ds-2ubuntu1_arm64.deb ... Unpacking libpangoft2-1.0-0:arm64 (1.50.6+ds-2ubuntu1) over (1.50.6+ds-2) ... Preparing to unpack .../22-libpango-1.0-0_1.50.6+ds-2ubuntu1_arm64.deb ... Unpacking libpango-1.0-0:arm64 (1.50.6+ds-2ubuntu1) over (1.50.6+ds-2) ... Preparing to unpack .../23-libpangocairo-1.0-0_1.50.6+ds-2ubuntu1_arm64.deb ... Unpacking libpangocairo-1.0-0:arm64 (1.50.6+ds-2ubuntu1) over (1.50.6+ds-2) ... Preparing to unpack .../24-libpixman-1-0_0.40.0-1ubuntu0.22.04.1_arm64.deb ... Unpacking libpixman-1-0:arm64 (0.40.0-1ubuntu0.22.04.1) over (0.40.0-1build4) ... Preparing to unpack .../25-gnupg2_2.2.27-3ubuntu2.1_all.deb ... Unpacking gnupg2 (2.2.27-3ubuntu2.1) over (2.2.27-3ubuntu2) ... Setting up libksba8:arm64 (1.6.0-2ubuntu0.2) ... Setting up libpcrecpp0v5:arm64 (2:8.39-13ubuntu0.22.04.1) ... Setting up libpixman-1-0:arm64 (0.40.0-1ubuntu0.22.04.1) ... Setting up apt-utils (2.4.8) ... Setting up libpcre16-3:arm64 (2:8.39-13ubuntu0.22.04.1) ... Setting up fonts-noto-color-emoji (2.038-0ubuntu1) ... Setting up libglib2.0-0:arm64 (2.72.4-0ubuntu1) ... No schema files found: doing nothing. Setting up libsqlite3-0:arm64 (3.37.2-2ubuntu0.1) ... Setting up libgdk-pixbuf2.0-common (2.42.8+dfsg-1ubuntu0.2) ... Setting up linux-libc-dev:arm64 (23.02.2) ... Setting up perl-modules-5.34 (5.34.0-3ubuntu1.1) ... Setting up locales (2.35-0ubuntu3.1) ... Generating locales (this might take a while)... en_US.UTF-8... done Generation complete. Setting up libjbig0:arm64 (2.1-3.1ubuntu0.22.04.1) ... Setting up libpcre2-16-0:arm64 (10.39-3ubuntu0.1) ... Setting up libsasl2-modules-db:arm64 (2.1.27+dfsg2-3ubuntu1.2) ... Setting up libpython3.10-stdlib:arm64 (3.10.6-1~22.04.2) ... Setting up libpcre2-32-0:arm64 (10.39-3ubuntu0.1) ... Setting up libglib2.0-data (2.72.4-0ubuntu1) ... Setting up libtirpc-dev:arm64 (1.3.2-2ubuntu0.1) ... Setting up libfreetype6:arm64 (2.11.1+dfsg-1ubuntu0.1) ... Setting up gnupg-l10n (2.2.27-3ubuntu2.1) ... Setting up libdbus-1-3:arm64 (1.12.20-2ubuntu4.1) ... Setting up libfribidi0:arm64 (1.0.8-2ubuntu3.1) ... Setting up libpcre32-3:arm64 (2:8.39-13ubuntu0.22.04.1) ... Setting up libss2:arm64 (1.46.5-2ubuntu1.1) ... Setting up logsave (1.46.5-2ubuntu1.1) ... Setting up libsasl2-2:arm64 (2.1.27+dfsg2-3ubuntu1.2) ... Setting up libcups2:arm64 (2.4.1op1-1ubuntu4.1) ... Setting up libpcre2-posix3:arm64 (10.39-3ubuntu0.1) ... Setting up gpgconf (2.2.27-3ubuntu2.1) ... Setting up libharfbuzz0b:arm64 (2.7.4-1ubuntu3.1) ... Setting up kbd (2.3.0-3ubuntu4.22.04) ... Setting up libtiff5:arm64 (4.3.0-6ubuntu0.4) ... Setting up libc-dev-bin (2.35-0ubuntu3.1) ... Setting up libxml2:arm64 (2.9.13+dfsg-1ubuntu0.2) ... Setting up gpg (2.2.27-3ubuntu2.1) ... Setting up libpython3-stdlib:arm64 (3.10.6-1~22.04) ... Setting up gnupg-utils (2.2.27-3ubuntu2.1) ... Setting up libperl5.34:arm64 (5.34.0-3ubuntu1.1) ... Setting up gpg-agent (2.2.27-3ubuntu2.1) ... Setting up python3.10 (3.10.6-1~22.04.2) ... Setting up gpgsm (2.2.27-3ubuntu2.1) ... Setting up libpango-1.0-0:arm64 (1.50.6+ds-2ubuntu1) ... Setting up libglib2.0-bin (2.72.4-0ubuntu1) ... Setting up e2fsprogs (1.46.5-2ubuntu1.1) ... Setting up python3 (3.10.6-1~22.04) ... Setting up libldap-2.5-0:arm64 (2.5.13+dfsg-0ubuntu0.22.04.1) ... Setting up dirmngr (2.2.27-3ubuntu2.1) ... Setting up perl (5.34.0-3ubuntu1.1) ... Setting up libdpkg-perl (1.21.1ubuntu2.1) ... Setting up gpg-wks-server (2.2.27-3ubuntu2.1) ... Setting up libc6-dev:arm64 (2.35-0ubuntu3.1) ... Setting up libgdk-pixbuf-2.0-0:arm64 (2.42.8+dfsg-1ubuntu0.2) ... Setting up libpangoft2-1.0-0:arm64 (1.50.6+ds-2ubuntu1) ... Setting up python3-lib2to3 (3.10.6-1~22.04) ... Setting up libpangocairo-1.0-0:arm64 (1.50.6+ds-2ubuntu1) ... Setting up python3-distutils (3.10.6-1~22.04) ... Setting up libglib2.0-dev-bin (2.72.4-0ubuntu1) ... Setting up gtk-update-icon-cache (3.24.33-1ubuntu2) ... Setting up libpcre2-dev:arm64 (10.39-3ubuntu0.1) ... Setting up gpg-wks-client (2.2.27-3ubuntu2.1) ... Setting up libpcre3-dev:arm64 (2:8.39-13ubuntu0.22.04.1) ... Setting up zlib1g-dev:arm64 (1:1.2.11.dfsg-2ubuntu9.2) ... Setting up gnupg (2.2.27-3ubuntu2.1) ... Setting up gnupg2 (2.2.27-3ubuntu2.1) ... Setting up libglib2.0-dev:arm64 (2.72.4-0ubuntu1) ... Processing triggers for libc-bin (2.35-0ubuntu3.1) ... Processing triggers for fontconfig (2.13.1-4.2ubuntu5) ... --> (600) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (600) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (600) INFO: Installing the main packages for [ Armbian ] --> (600) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (600) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (600) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (600) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --dry-run install bc bridge-utils ca-certificates chrony command-not-found console-setup cron curl dbus-user-session debconf-utils debsums device-tree-compiler ethtool fake-hwclock fdisk figlet htop inetutils-ping init initramfs-tools jq logrotate less linux-base man-db mmc-utils ncurses-term nano netplan.io network-manager openssh-server parted psmisc rsync rsyslog sudo sysfsutils sysstat toilet tzdata u-boot-tools usbutils vlan wget wireless-tools wpasupplicant gpiod cpufrequtils mtd-utils nocache alsa-utils apt-file apt-utils aptitude automake avahi-autoipd bash-completion bison btrfs-progs build-essential cracklib-runtime dkms dosfstools evtest expect f2fs-tools f3 fbset flex git gnupg2 haveged hdparm html2text i2c-tools ifenslave iotop iperf3 iptables keyboard-configuration libdigest-sha-perl libfuse2 libnl-3-dev libnl-genl-3-dev libnss-myhostname libpam-systemd libproc-processtable-perl libssl-dev libwrap0-dev lsof mc network-manager-openvpn nfs-common ntfs-3g pciutils plymouth plymouth-themes pv python3-distutils python3-lib2to3 qrencode rfkill rng-tools screen software-properties-common smartmontools stress unattended-upgrades unicode-data unzip vnstat wireless-regdb iozone3 2>&1 | { grep --line-buffered -v -e '^Conf ' -e '^Inst ' || true; } --> (612) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (612) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (612) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (612) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (612) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (612) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --download-only install bc bridge-utils ca-certificates chrony command-not-found console-setup cron curl dbus-user-session debconf-utils debsums device-tree-compiler ethtool fake-hwclock fdisk figlet htop inetutils-ping init initramfs-tools jq logrotate less linux-base man-db mmc-utils ncurses-term nano netplan.io network-manager openssh-server parted psmisc rsync rsyslog sudo sysfsutils sysstat toilet tzdata u-boot-tools usbutils vlan wget wireless-tools wpasupplicant gpiod cpufrequtils mtd-utils nocache alsa-utils apt-file apt-utils aptitude automake avahi-autoipd bash-completion bison btrfs-progs build-essential cracklib-runtime dkms dosfstools evtest expect f2fs-tools f3 fbset flex git gnupg2 haveged hdparm html2text i2c-tools ifenslave iotop iperf3 iptables keyboard-configuration libdigest-sha-perl libfuse2 libnl-3-dev libnl-genl-3-dev libnss-myhostname libpam-systemd libproc-processtable-perl libssl-dev libwrap0-dev lsof mc network-manager-openvpn nfs-common ntfs-3g pciutils plymouth plymouth-themes pv python3-distutils python3-lib2to3 qrencode rfkill rng-tools screen software-properties-common smartmontools stress unattended-upgrades unicode-data unzip vnstat wireless-regdb iozone3 --> (631) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (631) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (631) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (631) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (631) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (631) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends install bc bridge-utils ca-certificates chrony command-not-found console-setup cron curl dbus-user-session debconf-utils debsums device-tree-compiler ethtool fake-hwclock fdisk figlet htop inetutils-ping init initramfs-tools jq logrotate less linux-base man-db mmc-utils ncurses-term nano netplan.io network-manager openssh-server parted psmisc rsync rsyslog sudo sysfsutils sysstat toilet tzdata u-boot-tools usbutils vlan wget wireless-tools wpasupplicant gpiod cpufrequtils mtd-utils nocache alsa-utils apt-file apt-utils aptitude automake avahi-autoipd bash-completion bison btrfs-progs build-essential cracklib-runtime dkms dosfstools evtest expect f2fs-tools f3 fbset flex git gnupg2 haveged hdparm html2text i2c-tools ifenslave iotop iperf3 iptables keyboard-configuration libdigest-sha-perl libfuse2 libnl-3-dev libnl-genl-3-dev libnss-myhostname libpam-systemd libproc-processtable-perl libssl-dev libwrap0-dev lsof mc network-manager-openvpn nfs-common ntfs-3g pciutils plymouth plymouth-themes pv python3-distutils python3-lib2to3 qrencode rfkill rng-tools screen software-properties-common smartmontools stress unattended-upgrades unicode-data unzip vnstat wireless-regdb iozone3 Preconfiguring packages ... Selecting previously unselected package libapparmor1:arm64. (Reading database ... 26811 files and directories currently installed.) Preparing to unpack .../0-libapparmor1_3.0.4-2ubuntu2.2_arm64.deb ... Unpacking libapparmor1:arm64 (3.0.4-2ubuntu2.2) ... Selecting previously unselected package libargon2-1:arm64. Preparing to unpack .../1-libargon2-1_0~20171227-0.3_arm64.deb ... Unpacking libargon2-1:arm64 (0~20171227-0.3) ... Selecting previously unselected package libdevmapper1.02.1:arm64. Preparing to unpack .../2-libdevmapper1.02.1_2%3a1.02.175-2.1ubuntu4_arm64.deb ... Unpacking libdevmapper1.02.1:arm64 (2:1.02.175-2.1ubuntu4) ... Selecting previously unselected package libjson-c5:arm64. Preparing to unpack .../3-libjson-c5_0.15-3~ubuntu1.22.04.1_arm64.deb ... Unpacking libjson-c5:arm64 (0.15-3~ubuntu1.22.04.1) ... Selecting previously unselected package libcryptsetup12:arm64. Preparing to unpack .../4-libcryptsetup12_2%3a2.4.3-1ubuntu1.1_arm64.deb ... Unpacking libcryptsetup12:arm64 (2:2.4.3-1ubuntu1.1) ... Selecting previously unselected package libip4tc2:arm64. Preparing to unpack .../5-libip4tc2_1.8.7-1ubuntu5_arm64.deb ... Unpacking libip4tc2:arm64 (1.8.7-1ubuntu5) ... Selecting previously unselected package libkmod2:arm64. Preparing to unpack .../6-libkmod2_29-1ubuntu1_arm64.deb ... Unpacking libkmod2:arm64 (29-1ubuntu1) ... Selecting previously unselected package systemd. Preparing to unpack .../7-systemd_249.11-0ubuntu3.7_arm64.deb ... Unpacking systemd (249.11-0ubuntu3.7) ... Setting up libapparmor1:arm64 (3.0.4-2ubuntu2.2) ... Setting up libargon2-1:arm64 (0~20171227-0.3) ... Setting up libdevmapper1.02.1:arm64 (2:1.02.175-2.1ubuntu4) ... Setting up libjson-c5:arm64 (0.15-3~ubuntu1.22.04.1) ... Setting up libcryptsetup12:arm64 (2:2.4.3-1ubuntu1.1) ... Setting up libip4tc2:arm64 (1.8.7-1ubuntu5) ... Setting up libkmod2:arm64 (29-1ubuntu1) ... Setting up systemd (249.11-0ubuntu3.7) ... Created symlink /etc/systemd/system/getty.target.wants/getty@tty1.service → /lib/systemd/system/getty@.service. Created symlink /etc/systemd/system/multi-user.target.wants/remote-fs.target → /lib/systemd/system/remote-fs.target. Created symlink /etc/systemd/system/dbus-org.freedesktop.resolve1.service → /lib/systemd/system/systemd-resolved.service. Created symlink /etc/systemd/system/multi-user.target.wants/systemd-resolved.service → /lib/systemd/system/systemd-resolved.service. Created symlink /etc/systemd/system/sysinit.target.wants/systemd-pstore.service → /lib/systemd/system/systemd-pstore.service. Initializing machine ID from random generator. Selecting previously unselected package systemd-sysv. (Reading database ... 27627 files and directories currently installed.) Preparing to unpack .../systemd-sysv_249.11-0ubuntu3.7_arm64.deb ... Unpacking systemd-sysv (249.11-0ubuntu3.7) ... Setting up systemd-sysv (249.11-0ubuntu3.7) ... Selecting previously unselected package init. (Reading database ... 27644 files and directories currently installed.) Preparing to unpack .../archives/init_1.62_arm64.deb ... Unpacking init (1.62) ... Selecting previously unselected package cron. Preparing to unpack .../cron_3.0pl1-137ubuntu3_arm64.deb ... Unpacking cron (3.0pl1-137ubuntu3) ... Selecting previously unselected package libfuse3-3:arm64. Preparing to unpack .../libfuse3-3_3.10.5-1build1_arm64.deb ... Unpacking libfuse3-3:arm64 (3.10.5-1build1) ... Selecting previously unselected package fuse3. Preparing to unpack .../fuse3_3.10.5-1build1_arm64.deb ... Unpacking fuse3 (3.10.5-1build1) ... Selecting previously unselected package libntfs-3g89. Preparing to unpack .../libntfs-3g89_1%3a2021.8.22-3ubuntu1.2_arm64.deb ... Unpacking libntfs-3g89 (1:2021.8.22-3ubuntu1.2) ... Setting up libfuse3-3:arm64 (3.10.5-1build1) ... Setting up fuse3 (3.10.5-1build1) ... Selecting previously unselected package ntfs-3g. (Reading database ... 27710 files and directories currently installed.) Preparing to unpack .../00-ntfs-3g_1%3a2021.8.22-3ubuntu1.2_arm64.deb ... Unpacking ntfs-3g (1:2021.8.22-3ubuntu1.2) ... Selecting previously unselected package libpopt0:arm64. Preparing to unpack .../01-libpopt0_1.18-3build1_arm64.deb ... Unpacking libpopt0:arm64 (1.18-3build1) ... Selecting previously unselected package rsync. Preparing to unpack .../02-rsync_3.2.7-0ubuntu0.22.04.2_arm64.deb ... Unpacking rsync (3.2.7-0ubuntu0.22.04.2) ... Selecting previously unselected package libcpufreq0. Preparing to unpack .../03-libcpufreq0_008-2build1_arm64.deb ... Unpacking libcpufreq0 (008-2build1) ... Selecting previously unselected package cpufrequtils. Preparing to unpack .../04-cpufrequtils_008-2build1_arm64.deb ... Unpacking cpufrequtils (008-2build1) ... Selecting previously unselected package distro-info-data. Preparing to unpack .../05-distro-info-data_0.52ubuntu0.2_all.deb ... Unpacking distro-info-data (0.52ubuntu0.2) ... Selecting previously unselected package lsb-release. Preparing to unpack .../06-lsb-release_11.1.0ubuntu4_all.deb ... Unpacking lsb-release (11.1.0ubuntu4) ... Selecting previously unselected package kmod. Preparing to unpack .../07-kmod_29-1ubuntu1_arm64.deb ... Unpacking kmod (29-1ubuntu1) ... Selecting previously unselected package gcc-11-base:arm64. Preparing to unpack .../08-gcc-11-base_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking gcc-11-base:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package libisl23:arm64. Preparing to unpack .../09-libisl23_0.24-2build1_arm64.deb ... Unpacking libisl23:arm64 (0.24-2build1) ... Selecting previously unselected package libmpfr6:arm64. Preparing to unpack .../10-libmpfr6_4.1.0-3build3_arm64.deb ... Unpacking libmpfr6:arm64 (4.1.0-3build3) ... Selecting previously unselected package libmpc3:arm64. Preparing to unpack .../11-libmpc3_1.2.1-2build1_arm64.deb ... Unpacking libmpc3:arm64 (1.2.1-2build1) ... Selecting previously unselected package cpp-11. Preparing to unpack .../12-cpp-11_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking cpp-11 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package cpp. Preparing to unpack .../13-cpp_4%3a11.2.0-1ubuntu1_arm64.deb ... Unpacking cpp (4:11.2.0-1ubuntu1) ... Selecting previously unselected package libcc1-0:arm64. Preparing to unpack .../14-libcc1-0_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libcc1-0:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package binutils-common:arm64. Preparing to unpack .../15-binutils-common_2.38-4ubuntu2.1_arm64.deb ... Unpacking binutils-common:arm64 (2.38-4ubuntu2.1) ... Selecting previously unselected package libbinutils:arm64. Preparing to unpack .../16-libbinutils_2.38-4ubuntu2.1_arm64.deb ... Unpacking libbinutils:arm64 (2.38-4ubuntu2.1) ... Selecting previously unselected package libctf-nobfd0:arm64. Preparing to unpack .../17-libctf-nobfd0_2.38-4ubuntu2.1_arm64.deb ... Unpacking libctf-nobfd0:arm64 (2.38-4ubuntu2.1) ... Selecting previously unselected package libctf0:arm64. Preparing to unpack .../18-libctf0_2.38-4ubuntu2.1_arm64.deb ... Unpacking libctf0:arm64 (2.38-4ubuntu2.1) ... Selecting previously unselected package binutils-aarch64-linux-gnu. Preparing to unpack .../19-binutils-aarch64-linux-gnu_2.38-4ubuntu2.1_arm64.deb ... Unpacking binutils-aarch64-linux-gnu (2.38-4ubuntu2.1) ... Selecting previously unselected package binutils. Preparing to unpack .../20-binutils_2.38-4ubuntu2.1_arm64.deb ... Unpacking binutils (2.38-4ubuntu2.1) ... Selecting previously unselected package libgomp1:arm64. Preparing to unpack .../21-libgomp1_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libgomp1:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libitm1:arm64. Preparing to unpack .../22-libitm1_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libitm1:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libatomic1:arm64. Preparing to unpack .../23-libatomic1_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libatomic1:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libasan6:arm64. Preparing to unpack .../24-libasan6_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking libasan6:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package liblsan0:arm64. Preparing to unpack .../25-liblsan0_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking liblsan0:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libtsan0:arm64. Preparing to unpack .../26-libtsan0_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking libtsan0:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package libubsan1:arm64. Preparing to unpack .../27-libubsan1_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libubsan1:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libhwasan0:arm64. Preparing to unpack .../28-libhwasan0_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libhwasan0:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libgcc-11-dev:arm64. Preparing to unpack .../29-libgcc-11-dev_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking libgcc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package gcc-11. Preparing to unpack .../30-gcc-11_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking gcc-11 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package gcc. Preparing to unpack .../31-gcc_4%3a11.2.0-1ubuntu1_arm64.deb ... Unpacking gcc (4:11.2.0-1ubuntu1) ... Selecting previously unselected package cpp-12. Preparing to unpack .../32-cpp-12_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking cpp-12 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libasan8:arm64. Preparing to unpack .../33-libasan8_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libasan8:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libtsan2:arm64. Preparing to unpack .../34-libtsan2_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libtsan2:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libgcc-12-dev:arm64. Preparing to unpack .../35-libgcc-12-dev_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libgcc-12-dev:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package gcc-12. Preparing to unpack .../36-gcc-12_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking gcc-12 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package bzip2. Preparing to unpack .../37-bzip2_1.0.8-5build1_arm64.deb ... Unpacking bzip2 (1.0.8-5build1) ... Selecting previously unselected package xz-utils. Preparing to unpack .../38-xz-utils_5.2.5-2ubuntu1_arm64.deb ... Unpacking xz-utils (5.2.5-2ubuntu1) ... Selecting previously unselected package patch. Preparing to unpack .../39-patch_2.7.6-7build2_arm64.deb ... Unpacking patch (2.7.6-7build2) ... Selecting previously unselected package make. Preparing to unpack .../40-make_4.3-4.1build1_arm64.deb ... Unpacking make (4.3-4.1build1) ... Selecting previously unselected package lto-disabled-list. Preparing to unpack .../41-lto-disabled-list_24_all.deb ... Unpacking lto-disabled-list (24) ... Selecting previously unselected package dpkg-dev. Preparing to unpack .../42-dpkg-dev_1.21.1ubuntu2.1_all.deb ... Unpacking dpkg-dev (1.21.1ubuntu2.1) ... Selecting previously unselected package libstdc++-11-dev:arm64. Preparing to unpack .../43-libstdc++-11-dev_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking libstdc++-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package g++-11. Preparing to unpack .../44-g++-11_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking g++-11 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package g++. Preparing to unpack .../45-g++_4%3a11.2.0-1ubuntu1_arm64.deb ... Unpacking g++ (4:11.2.0-1ubuntu1) ... Selecting previously unselected package build-essential. Preparing to unpack .../46-build-essential_12.9ubuntu3_arm64.deb ... Unpacking build-essential (12.9ubuntu3) ... Selecting previously unselected package dctrl-tools. Preparing to unpack .../47-dctrl-tools_2.24-3build2_arm64.deb ... Unpacking dctrl-tools (2.24-3build2) ... Setting up distro-info-data (0.52ubuntu0.2) ... Setting up lsb-release (11.1.0ubuntu4) ... Selecting previously unselected package dkms. (Reading database ... 29911 files and directories currently installed.) Preparing to unpack .../000-dkms_2.8.7-2ubuntu2.1_all.deb ... Unpacking dkms (2.8.7-2ubuntu2.1) ... Selecting previously unselected package libsigsegv2:arm64. Preparing to unpack .../001-libsigsegv2_2.13-1ubuntu3_arm64.deb ... Unpacking libsigsegv2:arm64 (2.13-1ubuntu3) ... Selecting previously unselected package m4. Preparing to unpack .../002-m4_1.4.18-5ubuntu2_arm64.deb ... Unpacking m4 (1.4.18-5ubuntu2) ... Selecting previously unselected package flex. Preparing to unpack .../003-flex_2.6.4-8build2_arm64.deb ... Unpacking flex (2.6.4-8build2) ... Selecting previously unselected package libevent-core-2.1-7:arm64. Preparing to unpack .../004-libevent-core-2.1-7_2.1.12-stable-1build3_arm64.deb ... Unpacking libevent-core-2.1-7:arm64 (2.1.12-stable-1build3) ... Selecting previously unselected package libnfsidmap1:arm64. Preparing to unpack .../005-libnfsidmap1_1%3a2.6.1-1ubuntu1.2_arm64.deb ... Unpacking libnfsidmap1:arm64 (1:2.6.1-1ubuntu1.2) ... Selecting previously unselected package libwrap0:arm64. Preparing to unpack .../006-libwrap0_7.6.q-31build2_arm64.deb ... Unpacking libwrap0:arm64 (7.6.q-31build2) ... Selecting previously unselected package rpcbind. Preparing to unpack .../007-rpcbind_1.2.6-2build1_arm64.deb ... Unpacking rpcbind (1.2.6-2build1) ... Selecting previously unselected package keyutils. Preparing to unpack .../008-keyutils_1.6.1-2ubuntu3_arm64.deb ... Unpacking keyutils (1.6.1-2ubuntu3) ... Selecting previously unselected package nfs-common. Preparing to unpack .../009-nfs-common_1%3a2.6.1-1ubuntu1.2_arm64.deb ... Unpacking nfs-common (1:2.6.1-1ubuntu1.2) ... Selecting previously unselected package libedit2:arm64. Preparing to unpack .../010-libedit2_3.1-20210910-1build1_arm64.deb ... Unpacking libedit2:arm64 (3.1-20210910-1build1) ... Selecting previously unselected package libcbor0.8:arm64. Preparing to unpack .../011-libcbor0.8_0.8.0-2ubuntu1_arm64.deb ... Unpacking libcbor0.8:arm64 (0.8.0-2ubuntu1) ... Selecting previously unselected package libfido2-1:arm64. Preparing to unpack .../012-libfido2-1_1.10.0-1_arm64.deb ... Unpacking libfido2-1:arm64 (1.10.0-1) ... Selecting previously unselected package openssh-client. Preparing to unpack .../013-openssh-client_1%3a8.9p1-3ubuntu0.1_arm64.deb ... Unpacking openssh-client (1:8.9p1-3ubuntu0.1) ... Selecting previously unselected package openssh-sftp-server. Preparing to unpack .../014-openssh-sftp-server_1%3a8.9p1-3ubuntu0.1_arm64.deb ... Unpacking openssh-sftp-server (1:8.9p1-3ubuntu0.1) ... Selecting previously unselected package openssh-server. Preparing to unpack .../015-openssh-server_1%3a8.9p1-3ubuntu0.1_arm64.deb ... Unpacking openssh-server (1:8.9p1-3ubuntu0.1) ... Selecting previously unselected package udev. Preparing to unpack .../016-udev_249.11-0ubuntu3.7_arm64.deb ... Unpacking udev (249.11-0ubuntu3.7) ... Selecting previously unselected package rng-tools-debian. Preparing to unpack .../017-rng-tools-debian_2.3_arm64.deb ... Unpacking rng-tools-debian (2.3) ... Selecting previously unselected package vnstat. Preparing to unpack .../018-vnstat_2.9-1_arm64.deb ... Unpacking vnstat (2.9-1) ... Selecting previously unselected package libbpf0:arm64. Preparing to unpack .../019-libbpf0_1%3a0.5.0-1ubuntu22.04.1_arm64.deb ... Unpacking libbpf0:arm64 (1:0.5.0-1ubuntu22.04.1) ... Selecting previously unselected package libmnl0:arm64. Preparing to unpack .../020-libmnl0_1.0.4-3build2_arm64.deb ... Unpacking libmnl0:arm64 (1.0.4-3build2) ... Selecting previously unselected package libxtables12:arm64. Preparing to unpack .../021-libxtables12_1.8.7-1ubuntu5_arm64.deb ... Unpacking libxtables12:arm64 (1.8.7-1ubuntu5) ... Selecting previously unselected package libcap2-bin. Preparing to unpack .../022-libcap2-bin_1%3a2.44-1build3_arm64.deb ... Unpacking libcap2-bin (1:2.44-1build3) ... Selecting previously unselected package iproute2. Preparing to unpack .../023-iproute2_5.15.0-1ubuntu2_arm64.deb ... Unpacking iproute2 (5.15.0-1ubuntu2) ... Selecting previously unselected package tzdata. Preparing to unpack .../024-tzdata_2022g-0ubuntu0.22.04.1_all.deb ... Unpacking tzdata (2022g-0ubuntu0.22.04.1) ... Selecting previously unselected package chrony. Preparing to unpack .../025-chrony_4.2-2ubuntu2_arm64.deb ... Unpacking chrony (4.2-2ubuntu2) ... Selecting previously unselected package libhavege2:arm64. Preparing to unpack .../026-libhavege2_1.9.14-1ubuntu1_arm64.deb ... Unpacking libhavege2:arm64 (1.9.14-1ubuntu1) ... Selecting previously unselected package haveged. Preparing to unpack .../027-haveged_1.9.14-1ubuntu1_arm64.deb ... Unpacking haveged (1.9.14-1ubuntu1) ... Selecting previously unselected package libsysfs2:arm64. Preparing to unpack .../028-libsysfs2_2.1.1-1build1_arm64.deb ... Unpacking libsysfs2:arm64 (2.1.1-1build1) ... Selecting previously unselected package pci.ids. Preparing to unpack .../029-pci.ids_0.0~2022.01.22-1_all.deb ... Unpacking pci.ids (0.0~2022.01.22-1) ... Selecting previously unselected package sysfsutils. Preparing to unpack .../030-sysfsutils_2.1.1-1build1_arm64.deb ... Unpacking sysfsutils (2.1.1-1build1) ... Selecting previously unselected package openssl. Preparing to unpack .../031-openssl_3.0.2-0ubuntu1.8_arm64.deb ... Unpacking openssl (3.0.2-0ubuntu1.8) ... Selecting previously unselected package ca-certificates. Preparing to unpack .../032-ca-certificates_20211016ubuntu0.22.04.1_all.deb ... Unpacking ca-certificates (20211016ubuntu0.22.04.1) ... Selecting previously unselected package dbus. Preparing to unpack .../033-dbus_1.12.20-2ubuntu4.1_arm64.deb ... Unpacking dbus (1.12.20-2ubuntu4.1) ... Selecting previously unselected package libgirepository-1.0-1:arm64. Preparing to unpack .../034-libgirepository-1.0-1_1.72.0-1_arm64.deb ... Unpacking libgirepository-1.0-1:arm64 (1.72.0-1) ... Selecting previously unselected package gir1.2-glib-2.0:arm64. Preparing to unpack .../035-gir1.2-glib-2.0_1.72.0-1_arm64.deb ... Unpacking gir1.2-glib-2.0:arm64 (1.72.0-1) ... Selecting previously unselected package libisc-export1105:arm64. Preparing to unpack .../036-libisc-export1105_1%3a9.11.19+dfsg-2.1ubuntu3_arm64.deb ... Unpacking libisc-export1105:arm64 (1:9.11.19+dfsg-2.1ubuntu3) ... Selecting previously unselected package libdns-export1110. Preparing to unpack .../037-libdns-export1110_1%3a9.11.19+dfsg-2.1ubuntu3_arm64.deb ... Unpacking libdns-export1110 (1:9.11.19+dfsg-2.1ubuntu3) ... Selecting previously unselected package isc-dhcp-client. Preparing to unpack .../038-isc-dhcp-client_4.4.1-2.3ubuntu2.4_arm64.deb ... Unpacking isc-dhcp-client (4.4.1-2.3ubuntu2.4) ... Selecting previously unselected package iso-codes. Preparing to unpack .../039-iso-codes_4.9.0-1_all.deb ... Unpacking iso-codes (4.9.0-1) ... Selecting previously unselected package less. Preparing to unpack .../040-less_590-1ubuntu0.22.04.1_arm64.deb ... Unpacking less (590-1ubuntu0.22.04.1) ... Selecting previously unselected package libestr0:arm64. Preparing to unpack .../041-libestr0_0.1.10-2.1build3_arm64.deb ... Unpacking libestr0:arm64 (0.1.10-2.1build3) ... Selecting previously unselected package libfastjson4:arm64. Preparing to unpack .../042-libfastjson4_0.99.9-1build2_arm64.deb ... Unpacking libfastjson4:arm64 (0.99.9-1build2) ... Selecting previously unselected package libyaml-0-2:arm64. Preparing to unpack .../043-libyaml-0-2_0.2.2-1build2_arm64.deb ... Unpacking libyaml-0-2:arm64 (0.2.2-1build2) ... Selecting previously unselected package libnetplan0:arm64. Preparing to unpack .../044-libnetplan0_0.105-0ubuntu2~22.04.1_arm64.deb ... Unpacking libnetplan0:arm64 (0.105-0ubuntu2~22.04.1) ... Selecting previously unselected package libslang2:arm64. Preparing to unpack .../045-libslang2_2.3.2-5build4_arm64.deb ... Unpacking libslang2:arm64 (2.3.2-5build4) ... Selecting previously unselected package libnewt0.52:arm64. Preparing to unpack .../046-libnewt0.52_0.52.21-5ubuntu2_arm64.deb ... Unpacking libnewt0.52:arm64 (0.52.21-5ubuntu2) ... Selecting previously unselected package libpam-systemd:arm64. Preparing to unpack .../047-libpam-systemd_249.11-0ubuntu3.7_arm64.deb ... Unpacking libpam-systemd:arm64 (249.11-0ubuntu3.7) ... Selecting previously unselected package logrotate. Preparing to unpack .../048-logrotate_3.19.0-1ubuntu1.1_arm64.deb ... Unpacking logrotate (3.19.0-1ubuntu1.1) ... Selecting previously unselected package netbase. Preparing to unpack .../049-netbase_6.3_all.deb ... Unpacking netbase (6.3) ... Selecting previously unselected package python3-yaml. Preparing to unpack .../050-python3-yaml_5.4.1-1ubuntu1_arm64.deb ... Unpacking python3-yaml (5.4.1-1ubuntu1) ... Selecting previously unselected package python3-netifaces:arm64. Preparing to unpack .../051-python3-netifaces_0.11.0-1build2_arm64.deb ... Unpacking python3-netifaces:arm64 (0.11.0-1build2) ... Selecting previously unselected package netplan.io. Preparing to unpack .../052-netplan.io_0.105-0ubuntu2~22.04.1_arm64.deb ... Unpacking netplan.io (0.105-0ubuntu2~22.04.1) ... Selecting previously unselected package python-apt-common. Preparing to unpack .../053-python-apt-common_2.4.0ubuntu1_all.deb ... Unpacking python-apt-common (2.4.0ubuntu1) ... Selecting previously unselected package python3-apt. Preparing to unpack .../054-python3-apt_2.4.0ubuntu1_arm64.deb ... Unpacking python3-apt (2.4.0ubuntu1) ... Selecting previously unselected package python3-dbus. Preparing to unpack .../055-python3-dbus_1.2.18-3build1_arm64.deb ... Unpacking python3-dbus (1.2.18-3build1) ... Selecting previously unselected package python3-gi. Preparing to unpack .../056-python3-gi_3.42.1-0ubuntu1_arm64.deb ... Unpacking python3-gi (3.42.1-0ubuntu1) ... Selecting previously unselected package python3-pkg-resources. Preparing to unpack .../057-python3-pkg-resources_59.6.0-1.2ubuntu0.22.04.1_all.deb ... Unpacking python3-pkg-resources (59.6.0-1.2ubuntu0.22.04.1) ... Selecting previously unselected package rsyslog. Preparing to unpack .../058-rsyslog_8.2112.0-2ubuntu2.2_arm64.deb ... Unpacking rsyslog (8.2112.0-2ubuntu2.2) ... Selecting previously unselected package sudo. Preparing to unpack .../059-sudo_1.9.9-1ubuntu2.3_arm64.deb ... Unpacking sudo (1.9.9-1ubuntu2.3) ... Selecting previously unselected package bash-completion. Preparing to unpack .../060-bash-completion_1%3a2.11-5ubuntu1_all.deb ... Unpacking bash-completion (1:2.11-5ubuntu1) ... Selecting previously unselected package bsdextrautils. Preparing to unpack .../061-bsdextrautils_2.37.2-4ubuntu3_arm64.deb ... Unpacking bsdextrautils (2.37.2-4ubuntu3) ... Selecting previously unselected package python3-gdbm:arm64. Preparing to unpack .../062-python3-gdbm_3.10.6-1~22.04_arm64.deb ... Unpacking python3-gdbm:arm64 (3.10.6-1~22.04) ... Selecting previously unselected package python3-commandnotfound. Preparing to unpack .../063-python3-commandnotfound_22.04.0_all.deb ... Unpacking python3-commandnotfound (22.04.0) ... Selecting previously unselected package command-not-found. Preparing to unpack .../064-command-not-found_22.04.0_all.deb ... Unpacking command-not-found (22.04.0) ... Selecting previously unselected package cpio. Preparing to unpack .../065-cpio_2.13+dfsg-7_arm64.deb ... Unpacking cpio (2.13+dfsg-7) ... Selecting previously unselected package dosfstools. Preparing to unpack .../066-dosfstools_4.2-1build3_arm64.deb ... Unpacking dosfstools (4.2-1build3) ... Selecting previously unselected package libmagic-mgc. Preparing to unpack .../067-libmagic-mgc_1%3a5.41-3_arm64.deb ... Unpacking libmagic-mgc (1:5.41-3) ... Selecting previously unselected package libmagic1:arm64. Preparing to unpack .../068-libmagic1_1%3a5.41-3_arm64.deb ... Unpacking libmagic1:arm64 (1:5.41-3) ... Selecting previously unselected package file. Preparing to unpack .../069-file_1%3a5.41-3_arm64.deb ... Unpacking file (1:5.41-3) ... Selecting previously unselected package libuchardet0:arm64. Preparing to unpack .../070-libuchardet0_0.0.7-1build2_arm64.deb ... Unpacking libuchardet0:arm64 (0.0.7-1build2) ... Selecting previously unselected package groff-base. Preparing to unpack .../071-groff-base_1.22.4-8build1_arm64.deb ... Unpacking groff-base (1.22.4-8build1) ... Selecting previously unselected package hdparm. Preparing to unpack .../072-hdparm_9.60+ds-1build3_arm64.deb ... Unpacking hdparm (9.60+ds-1build3) ... Selecting previously unselected package libip6tc2:arm64. Preparing to unpack .../073-libip6tc2_1.8.7-1ubuntu5_arm64.deb ... Unpacking libip6tc2:arm64 (1.8.7-1ubuntu5) ... Selecting previously unselected package libnfnetlink0:arm64. Preparing to unpack .../074-libnfnetlink0_1.0.1-3build3_arm64.deb ... Unpacking libnfnetlink0:arm64 (1.0.1-3build3) ... Selecting previously unselected package libnetfilter-conntrack3:arm64. Preparing to unpack .../075-libnetfilter-conntrack3_1.0.9-1_arm64.deb ... Unpacking libnetfilter-conntrack3:arm64 (1.0.9-1) ... Selecting previously unselected package libnftnl11:arm64. Preparing to unpack .../076-libnftnl11_1.2.1-1build1_arm64.deb ... Unpacking libnftnl11:arm64 (1.2.1-1build1) ... Selecting previously unselected package iptables. Preparing to unpack .../077-iptables_1.8.7-1ubuntu5_arm64.deb ... Unpacking iptables (1.8.7-1ubuntu5) ... Selecting previously unselected package libdrm-common. Preparing to unpack .../078-libdrm-common_2.4.113-2~ubuntu0.22.04.1_all.deb ... Unpacking libdrm-common (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously unselected package libdrm2:arm64. Preparing to unpack .../079-libdrm2_2.4.113-2~ubuntu0.22.04.1_arm64.deb ... Unpacking libdrm2:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously unselected package libjansson4:arm64. Preparing to unpack .../080-libjansson4_2.13.1-1.1build3_arm64.deb ... Unpacking libjansson4:arm64 (2.13.1-1.1build3) ... Selecting previously unselected package libnghttp2-14:arm64. Preparing to unpack .../081-libnghttp2-14_1.43.0-1build3_arm64.deb ... Unpacking libnghttp2-14:arm64 (1.43.0-1build3) ... Selecting previously unselected package libparted2:arm64. Preparing to unpack .../082-libparted2_3.4-2build1_arm64.deb ... Unpacking libparted2:arm64 (3.4-2build1) ... Selecting previously unselected package libpci3:arm64. Preparing to unpack .../083-libpci3_1%3a3.7.0-6_arm64.deb ... Unpacking libpci3:arm64 (1:3.7.0-6) ... Selecting previously unselected package libpipeline1:arm64. Preparing to unpack .../084-libpipeline1_1.5.5-1_arm64.deb ... Unpacking libpipeline1:arm64 (1.5.5-1) ... Selecting previously unselected package libplymouth5:arm64. Preparing to unpack .../085-libplymouth5_0.9.5+git20211018-1ubuntu3_arm64.deb ... Unpacking libplymouth5:arm64 (0.9.5+git20211018-1ubuntu3) ... Selecting previously unselected package libpsl5:arm64. Preparing to unpack .../086-libpsl5_0.21.0-1.2build2_arm64.deb ... Unpacking libpsl5:arm64 (0.21.0-1.2build2) ... Selecting previously unselected package libusb-1.0-0:arm64. Preparing to unpack .../087-libusb-1.0-0_2%3a1.0.25-1ubuntu2_arm64.deb ... Unpacking libusb-1.0-0:arm64 (2:1.0.25-1ubuntu2) ... Selecting previously unselected package lsof. Preparing to unpack .../088-lsof_4.93.2+dfsg-1.1build2_arm64.deb ... Unpacking lsof (4.93.2+dfsg-1.1build2) ... Selecting previously unselected package man-db. Preparing to unpack .../089-man-db_2.10.2-1_arm64.deb ... Unpacking man-db (2.10.2-1) ... Selecting previously unselected package nano. Preparing to unpack .../090-nano_6.2-1_arm64.deb ... Unpacking nano (6.2-1) ... Selecting previously unselected package parted. Preparing to unpack .../091-parted_3.4-2build1_arm64.deb ... Unpacking parted (3.4-2build1) ... Selecting previously unselected package pciutils. Preparing to unpack .../092-pciutils_1%3a3.7.0-6_arm64.deb ... Unpacking pciutils (1:3.7.0-6) ... Selecting previously unselected package plymouth. Preparing to unpack .../093-plymouth_0.9.5+git20211018-1ubuntu3_arm64.deb ... Unpacking plymouth (0.9.5+git20211018-1ubuntu3) ... Selecting previously unselected package psmisc. Preparing to unpack .../094-psmisc_23.4-2build3_arm64.deb ... Unpacking psmisc (23.4-2build3) ... Selecting previously unselected package python3-distro-info. Preparing to unpack .../095-python3-distro-info_1.1build1_all.deb ... Unpacking python3-distro-info (1.1build1) ... Selecting previously unselected package usbutils. Preparing to unpack .../096-usbutils_1%3a014-1build1_arm64.deb ... Unpacking usbutils (1:014-1build1) ... Selecting previously unselected package wget. Preparing to unpack .../097-wget_1.21.2-2ubuntu1_arm64.deb ... Unpacking wget (1.21.2-2ubuntu1) ... Selecting previously unselected package libasound2-data. Preparing to unpack .../098-libasound2-data_1.2.6.1-1ubuntu1_all.deb ... Unpacking libasound2-data (1.2.6.1-1ubuntu1) ... Selecting previously unselected package libasound2:arm64. Preparing to unpack .../099-libasound2_1.2.6.1-1ubuntu1_arm64.deb ... Unpacking libasound2:arm64 (1.2.6.1-1ubuntu1) ... Selecting previously unselected package libatopology2:arm64. Preparing to unpack .../100-libatopology2_1.2.6.1-1ubuntu1_arm64.deb ... Unpacking libatopology2:arm64 (1.2.6.1-1ubuntu1) ... Selecting previously unselected package libfftw3-single3:arm64. Preparing to unpack .../101-libfftw3-single3_3.3.8-2ubuntu8_arm64.deb ... Unpacking libfftw3-single3:arm64 (3.3.8-2ubuntu8) ... Selecting previously unselected package libsamplerate0:arm64. Preparing to unpack .../102-libsamplerate0_0.2.2-1build1_arm64.deb ... Unpacking libsamplerate0:arm64 (0.2.2-1build1) ... Selecting previously unselected package alsa-utils. Preparing to unpack .../103-alsa-utils_1.2.6-1ubuntu1_arm64.deb ... Unpacking alsa-utils (1.2.6-1ubuntu1) ... Selecting previously unselected package libapt-pkg-perl. Preparing to unpack .../104-libapt-pkg-perl_0.1.40build2_arm64.deb ... Unpacking libapt-pkg-perl (0.1.40build2) ... Selecting previously unselected package libexporter-tiny-perl. Preparing to unpack .../105-libexporter-tiny-perl_1.002002-1_all.deb ... Unpacking libexporter-tiny-perl (1.002002-1) ... Selecting previously unselected package liblist-moreutils-xs-perl. Preparing to unpack .../106-liblist-moreutils-xs-perl_0.430-2build2_arm64.deb ... Unpacking liblist-moreutils-xs-perl (0.430-2build2) ... Selecting previously unselected package liblist-moreutils-perl. Preparing to unpack .../107-liblist-moreutils-perl_0.430-2_all.deb ... Unpacking liblist-moreutils-perl (0.430-2) ... Selecting previously unselected package libregexp-assemble-perl. Preparing to unpack .../108-libregexp-assemble-perl_0.36-1.1_all.deb ... Unpacking libregexp-assemble-perl (0.36-1.1) ... Selecting previously unselected package apt-file. Preparing to unpack .../109-apt-file_3.2.2_all.deb ... Unpacking apt-file (3.2.2) ... Selecting previously unselected package aptitude-common. Preparing to unpack .../110-aptitude-common_0.8.13-3ubuntu1_all.deb ... Unpacking aptitude-common (0.8.13-3ubuntu1) ... Selecting previously unselected package libboost-iostreams1.74.0:arm64. Preparing to unpack .../111-libboost-iostreams1.74.0_1.74.0-14ubuntu3_arm64.deb ... Unpacking libboost-iostreams1.74.0:arm64 (1.74.0-14ubuntu3) ... Selecting previously unselected package libsigc++-2.0-0v5:arm64. Preparing to unpack .../112-libsigc++-2.0-0v5_2.10.4-2ubuntu3_arm64.deb ... Unpacking libsigc++-2.0-0v5:arm64 (2.10.4-2ubuntu3) ... Selecting previously unselected package libcwidget4:arm64. Preparing to unpack .../113-libcwidget4_0.5.18-5build1_arm64.deb ... Unpacking libcwidget4:arm64 (0.5.18-5build1) ... Selecting previously unselected package libxapian30:arm64. Preparing to unpack .../114-libxapian30_1.4.18-4_arm64.deb ... Unpacking libxapian30:arm64 (1.4.18-4) ... Selecting previously unselected package aptitude. Preparing to unpack .../115-aptitude_0.8.13-3ubuntu1_arm64.deb ... Unpacking aptitude (0.8.13-3ubuntu1) ... Selecting previously unselected package autoconf. Preparing to unpack .../116-autoconf_2.71-2_all.deb ... Unpacking autoconf (2.71-2) ... Selecting previously unselected package autotools-dev. Preparing to unpack .../117-autotools-dev_20220109.1_all.deb ... Unpacking autotools-dev (20220109.1) ... Selecting previously unselected package automake. Preparing to unpack .../118-automake_1%3a1.16.5-1.3_all.deb ... Unpacking automake (1:1.16.5-1.3) ... Selecting previously unselected package libdaemon0:arm64. Preparing to unpack .../119-libdaemon0_0.14-7.1ubuntu3_arm64.deb ... Unpacking libdaemon0:arm64 (0.14-7.1ubuntu3) ... Selecting previously unselected package avahi-autoipd. Preparing to unpack .../120-avahi-autoipd_0.8-5ubuntu5_arm64.deb ... Unpacking avahi-autoipd (0.8-5ubuntu5) ... Selecting previously unselected package bc. Preparing to unpack .../121-bc_1.07.1-3build1_arm64.deb ... Unpacking bc (1.07.1-3build1) ... Selecting previously unselected package bison. Preparing to unpack .../122-bison_2%3a3.8.2+dfsg-1build1_arm64.deb ... Unpacking bison (2:3.8.2+dfsg-1build1) ... Selecting previously unselected package bridge-utils. Preparing to unpack .../123-bridge-utils_1.7-1ubuntu3_arm64.deb ... Unpacking bridge-utils (1.7-1ubuntu3) ... Selecting previously unselected package liblzo2-2:arm64. Preparing to unpack .../124-liblzo2-2_2.10-2build3_arm64.deb ... Unpacking liblzo2-2:arm64 (2.10-2build3) ... Selecting previously unselected package btrfs-progs. Preparing to unpack .../125-btrfs-progs_5.16.2-1_arm64.deb ... Unpacking btrfs-progs (5.16.2-1) ... Selecting previously unselected package busybox-initramfs. Preparing to unpack .../126-busybox-initramfs_1%3a1.30.1-7ubuntu3_arm64.deb ... Unpacking busybox-initramfs (1:1.30.1-7ubuntu3) ... Selecting previously unselected package libcrack2:arm64. Preparing to unpack .../127-libcrack2_2.9.6-3.4build4_arm64.deb ... Unpacking libcrack2:arm64 (2.9.6-3.4build4) ... Selecting previously unselected package cracklib-runtime. Preparing to unpack .../128-cracklib-runtime_2.9.6-3.4build4_arm64.deb ... Unpacking cracklib-runtime (2.9.6-3.4build4) ... Selecting previously unselected package librtmp1:arm64. Preparing to unpack .../129-librtmp1_2.4+20151223.gitfa8646d.1-2build4_arm64.deb ... Unpacking librtmp1:arm64 (2.4+20151223.gitfa8646d.1-2build4) ... Selecting previously unselected package libssh-4:arm64. Preparing to unpack .../130-libssh-4_0.9.6-2build1_arm64.deb ... Unpacking libssh-4:arm64 (0.9.6-2build1) ... Selecting previously unselected package libcurl4:arm64. Preparing to unpack .../131-libcurl4_7.81.0-1ubuntu1.8_arm64.deb ... Unpacking libcurl4:arm64 (7.81.0-1ubuntu1.8) ... Selecting previously unselected package curl. Preparing to unpack .../132-curl_7.81.0-1ubuntu1.8_arm64.deb ... Unpacking curl (7.81.0-1ubuntu1.8) ... Selecting previously unselected package dbus-user-session. Preparing to unpack .../133-dbus-user-session_1.12.20-2ubuntu4.1_arm64.deb ... Unpacking dbus-user-session (1.12.20-2ubuntu4.1) ... Selecting previously unselected package debconf-utils. Preparing to unpack .../134-debconf-utils_1.5.79ubuntu1_all.deb ... Unpacking debconf-utils (1.5.79ubuntu1) ... Selecting previously unselected package libfile-fnmatch-perl. Preparing to unpack .../135-libfile-fnmatch-perl_0.02-2build8_arm64.deb ... Unpacking libfile-fnmatch-perl (0.02-2build8) ... Selecting previously unselected package debsums. Preparing to unpack .../136-debsums_3.0.2_all.deb ... Unpacking debsums (3.0.2) ... Selecting previously unselected package ethtool. Preparing to unpack .../137-ethtool_1%3a5.16-1_arm64.deb ... Unpacking ethtool (1:5.16-1) ... Selecting previously unselected package libtcl8.6:arm64. Preparing to unpack .../138-libtcl8.6_8.6.12+dfsg-1build1_arm64.deb ... Unpacking libtcl8.6:arm64 (8.6.12+dfsg-1build1) ... Selecting previously unselected package tcl8.6. Preparing to unpack .../139-tcl8.6_8.6.12+dfsg-1build1_arm64.deb ... Unpacking tcl8.6 (8.6.12+dfsg-1build1) ... Selecting previously unselected package tcl-expect:arm64. Preparing to unpack .../140-tcl-expect_5.45.4-2build1_arm64.deb ... Unpacking tcl-expect:arm64 (5.45.4-2build1) ... Selecting previously unselected package expect. Preparing to unpack .../141-expect_5.45.4-2build1_arm64.deb ... Unpacking expect (5.45.4-2build1) ... Selecting previously unselected package f2fs-tools. Preparing to unpack .../142-f2fs-tools_1.14.0-2build1_arm64.deb ... Unpacking f2fs-tools (1.14.0-2build1) ... Selecting previously unselected package f3. Preparing to unpack .../143-f3_8.0-1_arm64.deb ... Unpacking f3 (8.0-1) ... Selecting previously unselected package fbset. Preparing to unpack .../144-fbset_2.1-32build3_arm64.deb ... Unpacking fbset (2.1-32build3) ... Selecting previously unselected package libfdisk1:arm64. Preparing to unpack .../145-libfdisk1_2.37.2-4ubuntu3_arm64.deb ... Unpacking libfdisk1:arm64 (2.37.2-4ubuntu3) ... Selecting previously unselected package fdisk. Preparing to unpack .../146-fdisk_2.37.2-4ubuntu3_arm64.deb ... Unpacking fdisk (2.37.2-4ubuntu3) ... Selecting previously unselected package figlet. Preparing to unpack .../147-figlet_2.2.5-3_arm64.deb ... Unpacking figlet (2.2.5-3) ... Selecting previously unselected package fonts-ubuntu. Preparing to unpack .../148-fonts-ubuntu_0.83-6ubuntu1_all.deb ... Unpacking fonts-ubuntu (0.83-6ubuntu1) ... Selecting previously unselected package libpackagekit-glib2-18:arm64. Preparing to unpack .../149-libpackagekit-glib2-18_1.2.5-2ubuntu2_arm64.deb ... Unpacking libpackagekit-glib2-18:arm64 (1.2.5-2ubuntu2) ... Selecting previously unselected package gir1.2-packagekitglib-1.0. Preparing to unpack .../150-gir1.2-packagekitglib-1.0_1.2.5-2ubuntu2_arm64.deb ... Unpacking gir1.2-packagekitglib-1.0 (1.2.5-2ubuntu2) ... Selecting previously unselected package libcurl3-gnutls:arm64. Preparing to unpack .../151-libcurl3-gnutls_7.81.0-1ubuntu1.8_arm64.deb ... Unpacking libcurl3-gnutls:arm64 (7.81.0-1ubuntu1.8) ... Selecting previously unselected package liberror-perl. Preparing to unpack .../152-liberror-perl_0.17029-1_all.deb ... Unpacking liberror-perl (0.17029-1) ... Selecting previously unselected package git-man. Preparing to unpack .../153-git-man_1%3a2.34.1-1ubuntu1.8_all.deb ... Unpacking git-man (1:2.34.1-1ubuntu1.8) ... Selecting previously unselected package git. Preparing to unpack .../154-git_1%3a2.34.1-1ubuntu1.8_arm64.deb ... Unpacking git (1:2.34.1-1ubuntu1.8) ... Selecting previously unselected package libgpiod2:arm64. Preparing to unpack .../155-libgpiod2_1.6.3-1build1_arm64.deb ... Unpacking libgpiod2:arm64 (1.6.3-1build1) ... Selecting previously unselected package gpiod. Preparing to unpack .../156-gpiod_1.6.3-1build1_arm64.deb ... Unpacking gpiod (1.6.3-1build1) ... Selecting previously unselected package html2text. Preparing to unpack .../157-html2text_1.3.2a-28_arm64.deb ... Unpacking html2text (1.3.2a-28) ... Selecting previously unselected package libnl-3-200:arm64. Preparing to unpack .../158-libnl-3-200_3.5.0-0.1_arm64.deb ... Unpacking libnl-3-200:arm64 (3.5.0-0.1) ... Selecting previously unselected package libnl-genl-3-200:arm64. Preparing to unpack .../159-libnl-genl-3-200_3.5.0-0.1_arm64.deb ... Unpacking libnl-genl-3-200:arm64 (3.5.0-0.1) ... Selecting previously unselected package htop. Preparing to unpack .../160-htop_3.0.5-7build2_arm64.deb ... Unpacking htop (3.0.5-7build2) ... Selecting previously unselected package ifupdown. Preparing to unpack .../161-ifupdown_0.8.36+nmu1ubuntu3_arm64.deb ... Unpacking ifupdown (0.8.36+nmu1ubuntu3) ... Selecting previously unselected package ifenslave. Preparing to unpack .../162-ifenslave_2.10ubuntu3_all.deb ... Unpacking ifenslave (2.10ubuntu3) ... Selecting previously unselected package inetutils-ping. Preparing to unpack .../163-inetutils-ping_2%3a2.2-2_arm64.deb ... Unpacking inetutils-ping (2:2.2-2) ... Selecting previously unselected package initramfs-tools-bin. Preparing to unpack .../164-initramfs-tools-bin_0.140ubuntu13.1_arm64.deb ... Unpacking initramfs-tools-bin (0.140ubuntu13.1) ... Selecting previously unselected package libklibc:arm64. Preparing to unpack .../165-libklibc_2.0.10-4_arm64.deb ... Unpacking libklibc:arm64 (2.0.10-4) ... Selecting previously unselected package klibc-utils. Preparing to unpack .../166-klibc-utils_2.0.10-4_arm64.deb ... Unpacking klibc-utils (2.0.10-4) ... Selecting previously unselected package zstd. Preparing to unpack .../167-zstd_1.4.8+dfsg-3build1_arm64.deb ... Unpacking zstd (1.4.8+dfsg-3build1) ... Selecting previously unselected package initramfs-tools-core. Preparing to unpack .../168-initramfs-tools-core_0.140ubuntu13.1_all.deb ... Unpacking initramfs-tools-core (0.140ubuntu13.1) ... Selecting previously unselected package linux-base. Preparing to unpack .../169-linux-base_4.5ubuntu9_all.deb ... Unpacking linux-base (4.5ubuntu9) ... Selecting previously unselected package initramfs-tools. Preparing to unpack .../170-initramfs-tools_0.140ubuntu13.1_all.deb ... Unpacking initramfs-tools (0.140ubuntu13.1) ... Selecting previously unselected package iotop. Preparing to unpack .../171-iotop_0.6-24-g733f3f8-1.1build2_arm64.deb ... Unpacking iotop (0.6-24-g733f3f8-1.1build2) ... Selecting previously unselected package iozone3. Preparing to unpack .../172-iozone3_489-1_arm64.deb ... Unpacking iozone3 (489-1) ... Selecting previously unselected package libsctp1:arm64. Preparing to unpack .../173-libsctp1_1.0.19+dfsg-1build1_arm64.deb ... Unpacking libsctp1:arm64 (1.0.19+dfsg-1build1) ... Selecting previously unselected package libiperf0:arm64. Preparing to unpack .../174-libiperf0_3.9-1build1_arm64.deb ... Unpacking libiperf0:arm64 (3.9-1build1) ... Selecting previously unselected package iperf3. Preparing to unpack .../175-iperf3_3.9-1build1_arm64.deb ... Unpacking iperf3 (3.9-1build1) ... Selecting previously unselected package libonig5:arm64. Preparing to unpack .../176-libonig5_6.9.7.1-2build1_arm64.deb ... Unpacking libonig5:arm64 (6.9.7.1-2build1) ... Selecting previously unselected package libjq1:arm64. Preparing to unpack .../177-libjq1_1.6-2.1ubuntu3_arm64.deb ... Unpacking libjq1:arm64 (1.6-2.1ubuntu3) ... Selecting previously unselected package jq. Preparing to unpack .../178-jq_1.6-2.1ubuntu3_arm64.deb ... Unpacking jq (1.6-2.1ubuntu3) ... Selecting previously unselected package libstemmer0d:arm64. Preparing to unpack .../179-libstemmer0d_2.2.0-1build1_arm64.deb ... Unpacking libstemmer0d:arm64 (2.2.0-1build1) ... Selecting previously unselected package libxmlb2:arm64. Preparing to unpack .../180-libxmlb2_0.3.6-2build1_arm64.deb ... Unpacking libxmlb2:arm64 (0.3.6-2build1) ... Selecting previously unselected package libappstream4:arm64. Preparing to unpack .../181-libappstream4_0.15.2-2_arm64.deb ... Unpacking libappstream4:arm64 (0.15.2-2) ... Selecting previously unselected package libbluetooth3:arm64. Preparing to unpack .../182-libbluetooth3_5.64-0ubuntu1_arm64.deb ... Unpacking libbluetooth3:arm64 (5.64-0ubuntu1) ... Selecting previously unselected package libcaca0:arm64. Preparing to unpack .../183-libcaca0_0.99.beta19-2.2ubuntu4_arm64.deb ... Unpacking libcaca0:arm64 (0.99.beta19-2.2ubuntu4) ... Selecting previously unselected package libdigest-sha-perl. Preparing to unpack .../184-libdigest-sha-perl_6.02-1build4_arm64.deb ... Adding 'diversion of /usr/bin/shasum to /usr/bin/shasum.bundled by libdigest-sha-perl' Adding 'diversion of /usr/share/man/man1/shasum.1.gz to /usr/share/man/man1/shasum.bundled.1.gz by libdigest-sha-perl' Unpacking libdigest-sha-perl (6.02-1build4) ... Selecting previously unselected package libdw1:arm64. Preparing to unpack .../185-libdw1_0.186-1build1_arm64.deb ... Unpacking libdw1:arm64 (0.186-1build1) ... Selecting previously unselected package libfuse2:arm64. Preparing to unpack .../186-libfuse2_2.9.9-5ubuntu3_arm64.deb ... Unpacking libfuse2:arm64 (2.9.9-5ubuntu3) ... Selecting previously unselected package libgpm2:arm64. Preparing to unpack .../187-libgpm2_1.20.7-10build1_arm64.deb ... Unpacking libgpm2:arm64 (1.20.7-10build1) ... Selecting previously unselected package libunwind8:arm64. Preparing to unpack .../188-libunwind8_1.3.2-2build2_arm64.deb ... Unpacking libunwind8:arm64 (1.3.2-2build2) ... Selecting previously unselected package libgstreamer1.0-0:arm64. Preparing to unpack .../189-libgstreamer1.0-0_1.20.3-0ubuntu1_arm64.deb ... Unpacking libgstreamer1.0-0:arm64 (1.20.3-0ubuntu1) ... Selecting previously unselected package libi2c0:arm64. Preparing to unpack .../190-libi2c0_4.3-2build1_arm64.deb ... Unpacking libi2c0:arm64 (4.3-2build1) ... Selecting previously unselected package libiniparser1:arm64. Preparing to unpack .../191-libiniparser1_4.1-4ubuntu4_arm64.deb ... Unpacking libiniparser1:arm64 (4.1-4ubuntu4) ... Selecting previously unselected package libmm-glib0:arm64. Preparing to unpack .../192-libmm-glib0_1.20.0-1~ubuntu22.04.1_arm64.deb ... Unpacking libmm-glib0:arm64 (1.20.0-1~ubuntu22.04.1) ... Selecting previously unselected package libndp0:arm64. Preparing to unpack .../193-libndp0_1.8-0ubuntu3_arm64.deb ... Unpacking libndp0:arm64 (1.8-0ubuntu3) ... Selecting previously unselected package libnl-3-dev:arm64. Preparing to unpack .../194-libnl-3-dev_3.5.0-0.1_arm64.deb ... Unpacking libnl-3-dev:arm64 (3.5.0-0.1) ... Selecting previously unselected package libnl-genl-3-dev:arm64. Preparing to unpack .../195-libnl-genl-3-dev_3.5.0-0.1_arm64.deb ... Unpacking libnl-genl-3-dev:arm64 (3.5.0-0.1) ... Selecting previously unselected package libnl-route-3-200:arm64. Preparing to unpack .../196-libnl-route-3-200_3.5.0-0.1_arm64.deb ... Unpacking libnl-route-3-200:arm64 (3.5.0-0.1) ... Selecting previously unselected package libnm0:arm64. Preparing to unpack .../197-libnm0_1.36.6-0ubuntu2_arm64.deb ... Unpacking libnm0:arm64 (1.36.6-0ubuntu2) ... Selecting previously unselected package libpcsclite1:arm64. Preparing to unpack .../198-libpcsclite1_1.9.5-3_arm64.deb ... Unpacking libpcsclite1:arm64 (1.9.5-3) ... Selecting previously unselected package libpkcs11-helper1:arm64. Preparing to unpack .../199-libpkcs11-helper1_1.28-1ubuntu0.22.04.1_arm64.deb ... Unpacking libpkcs11-helper1:arm64 (1.28-1ubuntu0.22.04.1) ... Selecting previously unselected package libpolkit-gobject-1-0:arm64. Preparing to unpack .../200-libpolkit-gobject-1-0_0.105-33_arm64.deb ... Unpacking libpolkit-gobject-1-0:arm64 (0.105-33) ... Selecting previously unselected package libpolkit-agent-1-0:arm64. Preparing to unpack .../201-libpolkit-agent-1-0_0.105-33_arm64.deb ... Unpacking libpolkit-agent-1-0:arm64 (0.105-33) ... Selecting previously unselected package libproc-processtable-perl:arm64. Preparing to unpack .../202-libproc-processtable-perl_0.634-1build1_arm64.deb ... Unpacking libproc-processtable-perl:arm64 (0.634-1build1) ... Selecting previously unselected package libqrencode4:arm64. Preparing to unpack .../203-libqrencode4_4.1.1-1_arm64.deb ... Unpacking libqrencode4:arm64 (4.1.1-1) ... Selecting previously unselected package libsensors-config. Preparing to unpack .../204-libsensors-config_1%3a3.6.0-7ubuntu1_all.deb ... Unpacking libsensors-config (1:3.6.0-7ubuntu1) ... Selecting previously unselected package libsensors5:arm64. Preparing to unpack .../205-libsensors5_1%3a3.6.0-7ubuntu1_arm64.deb ... Unpacking libsensors5:arm64 (1:3.6.0-7ubuntu1) ... Selecting previously unselected package libssh2-1:arm64. Preparing to unpack .../206-libssh2-1_1.10.0-3_arm64.deb ... Unpacking libssh2-1:arm64 (1.10.0-3) ... Selecting previously unselected package libssl-dev:arm64. Preparing to unpack .../207-libssl-dev_3.0.2-0ubuntu1.8_arm64.deb ... Unpacking libssl-dev:arm64 (3.0.2-0ubuntu1.8) ... Selecting previously unselected package libteamdctl0:arm64. Preparing to unpack .../208-libteamdctl0_1.31-1build2_arm64.deb ... Unpacking libteamdctl0:arm64 (1.31-1build2) ... Selecting previously unselected package libutempter0:arm64. Preparing to unpack .../209-libutempter0_1.2.1-2build2_arm64.deb ... Unpacking libutempter0:arm64 (1.2.1-2build2) ... Selecting previously unselected package libwrap0-dev:arm64. Preparing to unpack .../210-libwrap0-dev_7.6.q-31build2_arm64.deb ... Unpacking libwrap0-dev:arm64 (7.6.q-31build2) ... Selecting previously unselected package mc-data. Preparing to unpack .../211-mc-data_3%3a4.8.27-1_all.deb ... Unpacking mc-data (3:4.8.27-1) ... Selecting previously unselected package mc. Preparing to unpack .../212-mc_3%3a4.8.27-1_arm64.deb ... Unpacking mc (3:4.8.27-1) ... Selecting previously unselected package mmc-utils. Preparing to unpack .../213-mmc-utils_0+git20191004.73d6c59-2_arm64.deb ... Unpacking mmc-utils (0+git20191004.73d6c59-2) ... Selecting previously unselected package ncurses-term. Preparing to unpack .../214-ncurses-term_6.3-2_all.deb ... Unpacking ncurses-term (6.3-2) ... Selecting previously unselected package polkitd. Preparing to unpack .../215-polkitd_0.105-33_arm64.deb ... Unpacking polkitd (0.105-33) ... Selecting previously unselected package pkexec. Preparing to unpack .../216-pkexec_0.105-33_arm64.deb ... Unpacking pkexec (0.105-33) ... Selecting previously unselected package policykit-1. Preparing to unpack .../217-policykit-1_0.105-33_arm64.deb ... Unpacking policykit-1 (0.105-33) ... Selecting previously unselected package network-manager. Preparing to unpack .../218-network-manager_1.36.6-0ubuntu2_arm64.deb ... Unpacking network-manager (1.36.6-0ubuntu2) ... Selecting previously unselected package openvpn. Preparing to unpack .../219-openvpn_2.5.5-1ubuntu3.1_arm64.deb ... Unpacking openvpn (2.5.5-1ubuntu3.1) ... Selecting previously unselected package network-manager-openvpn. Preparing to unpack .../220-network-manager-openvpn_1.8.18-1_arm64.deb ... Unpacking network-manager-openvpn (1.8.18-1) ... Selecting previously unselected package nocache. Preparing to unpack .../221-nocache_1.1-1_arm64.deb ... Unpacking nocache (1.1-1) ... Selecting previously unselected package plymouth-label. Preparing to unpack .../222-plymouth-label_0.9.5+git20211018-1ubuntu3_arm64.deb ... Unpacking plymouth-label (0.9.5+git20211018-1ubuntu3) ... Selecting previously unselected package plymouth-theme-spinner. Preparing to unpack .../223-plymouth-theme-spinner_0.9.5+git20211018-1ubuntu3_arm64.deb ... Unpacking plymouth-theme-spinner (0.9.5+git20211018-1ubuntu3) ... Selecting previously unselected package plymouth-themes. Preparing to unpack .../224-plymouth-themes_0.9.5+git20211018-1ubuntu3_arm64.deb ... Unpacking plymouth-themes (0.9.5+git20211018-1ubuntu3) ... Selecting previously unselected package pv. Preparing to unpack .../225-pv_1.6.6-1build2_arm64.deb ... Unpacking pv (1.6.6-1build2) ... Selecting previously unselected package python3-blinker. Preparing to unpack .../226-python3-blinker_1.4+dfsg1-0.4_all.deb ... Unpacking python3-blinker (1.4+dfsg1-0.4) ... Selecting previously unselected package python3-cffi-backend:arm64. Preparing to unpack .../227-python3-cffi-backend_1.15.0-1build2_arm64.deb ... Unpacking python3-cffi-backend:arm64 (1.15.0-1build2) ... Selecting previously unselected package python3-cryptography. Preparing to unpack .../228-python3-cryptography_3.4.8-1ubuntu2_arm64.deb ... Unpacking python3-cryptography (3.4.8-1ubuntu2) ... Selecting previously unselected package python3-pyparsing. Preparing to unpack .../229-python3-pyparsing_2.4.7-1_all.deb ... Unpacking python3-pyparsing (2.4.7-1) ... Selecting previously unselected package python3-httplib2. Preparing to unpack .../230-python3-httplib2_0.20.2-2_all.deb ... Unpacking python3-httplib2 (0.20.2-2) ... Selecting previously unselected package python3-more-itertools. Preparing to unpack .../231-python3-more-itertools_8.10.0-2_all.deb ... Unpacking python3-more-itertools (8.10.0-2) ... Selecting previously unselected package python3-zipp. Preparing to unpack .../232-python3-zipp_1.0.0-3_all.deb ... Unpacking python3-zipp (1.0.0-3) ... Selecting previously unselected package python3-importlib-metadata. Preparing to unpack .../233-python3-importlib-metadata_4.6.4-1_all.deb ... Unpacking python3-importlib-metadata (4.6.4-1) ... Selecting previously unselected package python3-jeepney. Preparing to unpack .../234-python3-jeepney_0.7.1-3_all.deb ... Unpacking python3-jeepney (0.7.1-3) ... Selecting previously unselected package python3-jwt. Preparing to unpack .../235-python3-jwt_2.3.0-1ubuntu0.2_all.deb ... Unpacking python3-jwt (2.3.0-1ubuntu0.2) ... Selecting previously unselected package python3-secretstorage. Preparing to unpack .../236-python3-secretstorage_3.3.1-1_all.deb ... Unpacking python3-secretstorage (3.3.1-1) ... Selecting previously unselected package python3-keyring. Preparing to unpack .../237-python3-keyring_23.5.0-1_all.deb ... Unpacking python3-keyring (23.5.0-1) ... Selecting previously unselected package python3-lazr.uri. Preparing to unpack .../238-python3-lazr.uri_1.0.6-2_all.deb ... Unpacking python3-lazr.uri (1.0.6-2) ... Selecting previously unselected package python3-wadllib. Preparing to unpack .../239-python3-wadllib_1.3.6-1_all.deb ... Unpacking python3-wadllib (1.3.6-1) ... Selecting previously unselected package python3-distro. Preparing to unpack .../240-python3-distro_1.7.0-1_all.deb ... Unpacking python3-distro (1.7.0-1) ... Selecting previously unselected package python3-oauthlib. Preparing to unpack .../241-python3-oauthlib_3.2.0-1ubuntu0.1_all.deb ... Unpacking python3-oauthlib (3.2.0-1ubuntu0.1) ... Selecting previously unselected package python3-six. Preparing to unpack .../242-python3-six_1.16.0-3ubuntu1_all.deb ... Unpacking python3-six (1.16.0-3ubuntu1) ... Selecting previously unselected package python3-lazr.restfulclient. Preparing to unpack .../243-python3-lazr.restfulclient_0.14.4-1_all.deb ... Unpacking python3-lazr.restfulclient (0.14.4-1) ... Selecting previously unselected package python3-launchpadlib. Preparing to unpack .../244-python3-launchpadlib_1.10.16-1_all.deb ... Unpacking python3-launchpadlib (1.10.16-1) ... Selecting previously unselected package python3-software-properties. Preparing to unpack .../245-python3-software-properties_0.99.22.6_all.deb ... Unpacking python3-software-properties (0.99.22.6) ... Selecting previously unselected package qrencode. Preparing to unpack .../246-qrencode_4.1.1-1_arm64.deb ... Unpacking qrencode (4.1.1-1) ... Selecting previously unselected package rfkill. Preparing to unpack .../247-rfkill_2.37.2-4ubuntu3_arm64.deb ... Unpacking rfkill (2.37.2-4ubuntu3) ... Selecting previously unselected package screen. Preparing to unpack .../248-screen_4.9.0-1_arm64.deb ... Unpacking screen (4.9.0-1) ... Selecting previously unselected package smartmontools. Preparing to unpack .../249-smartmontools_7.2-1build2_arm64.deb ... Unpacking smartmontools (7.2-1build2) ... Selecting previously unselected package packagekit. Preparing to unpack .../250-packagekit_1.2.5-2ubuntu2_arm64.deb ... Unpacking packagekit (1.2.5-2ubuntu2) ... Selecting previously unselected package software-properties-common. Preparing to unpack .../251-software-properties-common_0.99.22.6_all.deb ... Unpacking software-properties-common (0.99.22.6) ... Selecting previously unselected package stress. Preparing to unpack .../252-stress_1.0.5-1_arm64.deb ... Unpacking stress (1.0.5-1) ... Selecting previously unselected package sysstat. Preparing to unpack .../253-sysstat_12.5.2-2ubuntu0.1_arm64.deb ... Unpacking sysstat (12.5.2-2ubuntu0.1) ... Selecting previously unselected package toilet-fonts. Preparing to unpack .../254-toilet-fonts_0.3-1.4_all.deb ... Unpacking toilet-fonts (0.3-1.4) ... Selecting previously unselected package toilet. Preparing to unpack .../255-toilet_0.3-1.4_arm64.deb ... Unpacking toilet (0.3-1.4) ... Selecting previously unselected package u-boot-tools. Preparing to unpack .../256-u-boot-tools_2022.01+dfsg-2ubuntu2.3_arm64.deb ... Unpacking u-boot-tools (2022.01+dfsg-2ubuntu2.3) ... Selecting previously unselected package unattended-upgrades. Preparing to unpack .../257-unattended-upgrades_2.8ubuntu1_all.deb ... Unpacking unattended-upgrades (2.8ubuntu1) ... Selecting previously unselected package unicode-data. Preparing to unpack .../258-unicode-data_14.0.0-1.1_all.deb ... Unpacking unicode-data (14.0.0-1.1) ... Selecting previously unselected package unzip. Preparing to unpack .../259-unzip_6.0-26ubuntu3.1_arm64.deb ... Unpacking unzip (6.0-26ubuntu3.1) ... Selecting previously unselected package wireless-regdb. Preparing to unpack .../260-wireless-regdb_2022.06.06-0ubuntu1~22.04.1_all.deb ... Unpacking wireless-regdb (2022.06.06-0ubuntu1~22.04.1) ... Selecting previously unselected package libiw30:arm64. Preparing to unpack .../261-libiw30_30~pre9-13.1ubuntu4_arm64.deb ... Unpacking libiw30:arm64 (30~pre9-13.1ubuntu4) ... Selecting previously unselected package wireless-tools. Preparing to unpack .../262-wireless-tools_30~pre9-13.1ubuntu4_arm64.deb ... Unpacking wireless-tools (30~pre9-13.1ubuntu4) ... Selecting previously unselected package wpasupplicant. Preparing to unpack .../263-wpasupplicant_2%3a2.10-6ubuntu2_arm64.deb ... Unpacking wpasupplicant (2:2.10-6ubuntu2) ... Selecting previously unselected package libfdt1:arm64. Preparing to unpack .../264-libfdt1_1.6.1-1_arm64.deb ... Unpacking libfdt1:arm64 (1.6.1-1) ... Selecting previously unselected package device-tree-compiler. Preparing to unpack .../265-device-tree-compiler_1.6.1-1_arm64.deb ... Unpacking device-tree-compiler (1.6.1-1) ... Selecting previously unselected package evtest. Preparing to unpack .../266-evtest_1%3a1.34-1_arm64.deb ... Unpacking evtest (1:1.34-1) ... Selecting previously unselected package fake-hwclock. Preparing to unpack .../267-fake-hwclock_0.12_all.deb ... Unpacking fake-hwclock (0.12) ... Selecting previously unselected package i2c-tools. Preparing to unpack .../268-i2c-tools_4.3-2build1_arm64.deb ... Unpacking i2c-tools (4.3-2build1) ... Selecting previously unselected package libnss-myhostname:arm64. Preparing to unpack .../269-libnss-myhostname_249.11-0ubuntu3.7_arm64.deb ... Unpacking libnss-myhostname:arm64 (249.11-0ubuntu3.7) ... Selecting previously unselected package mtd-utils. Preparing to unpack .../270-mtd-utils_1%3a2.1.4-1_arm64.deb ... Unpacking mtd-utils (1:2.1.4-1) ... Selecting previously unselected package vlan. Preparing to unpack .../271-vlan_2.0.5ubuntu5_all.deb ... Unpacking vlan (2.0.5ubuntu5) ... Setting up python3-pkg-resources (59.6.0-1.2ubuntu0.22.04.1) ... Setting up smartmontools (7.2-1build2) ... Created symlink /etc/systemd/system/smartd.service → /lib/systemd/system/smartmontools.service. Created symlink /etc/systemd/system/multi-user.target.wants/smartmontools.service → /lib/systemd/system/smartmontools.service. Setting up libapt-pkg-perl (0.1.40build2) ... Setting up cpio (2.13+dfsg-7) ... update-alternatives: using /bin/mt-gnu to provide /bin/mt (mt) in auto mode Setting up libpipeline1:arm64 (1.5.5-1) ... Setting up python3-more-itertools (8.10.0-2) ... Setting up fake-hwclock (0.12) ... Created symlink /etc/systemd/system/sysinit.target.wants/fake-hwclock.service → /lib/systemd/system/fake-hwclock.service. update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults Setting up libxapian30:arm64 (1.4.18-4) ... Setting up gcc-11-base:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up libdw1:arm64 (0.186-1build1) ... Setting up python3-dbus (1.2.18-3build1) ... Setting up lto-disabled-list (24) ... Setting up libnfsidmap1:arm64 (1:2.6.1-1ubuntu1.2) ... Setting up libiniparser1:arm64 (4.1-4ubuntu4) ... Setting up pci.ids (0.0~2022.01.22-1) ... Setting up libpsl5:arm64 (0.21.0-1.2build2) ... Setting up toilet-fonts (0.3-1.4) ... Setting up libgpm2:arm64 (1.20.7-10build1) ... Setting up linux-base (4.5ubuntu9) ... Setting up bsdextrautils (2.37.2-4ubuntu3) ... update-alternatives: using /usr/bin/write.ul to provide /usr/bin/write (write) in auto mode Setting up python3-distro (1.7.0-1) ... Setting up wget (1.21.2-2ubuntu1) ... Setting up libsysfs2:arm64 (2.1.1-1build1) ... Setting up init (1.62) ... Setting up libqrencode4:arm64 (4.1.1-1) ... Setting up iozone3 (489-1) ... Setting up sysfsutils (2.1.1-1build1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up libdigest-sha-perl (6.02-1build4) ... Setting up python3-jwt (2.3.0-1ubuntu0.2) ... Setting up libmagic-mgc (1:5.41-3) ... Setting up python3-gdbm:arm64 (3.10.6-1~22.04) ... Setting up psmisc (23.4-2build3) ... Setting up qrencode (4.1.1-1) ... Setting up libyaml-0-2:arm64 (0.2.2-1build2) ... Setting up libip6tc2:arm64 (1.8.7-1ubuntu5) ... Setting up libboost-iostreams1.74.0:arm64 (1.74.0-14ubuntu3) ... Setting up f2fs-tools (1.14.0-2build1) ... Setting up libestr0:arm64 (0.1.10-2.1build3) ... Setting up libi2c0:arm64 (4.3-2build1) ... Setting up libfastjson4:arm64 (0.99.9-1build2) ... Setting up fonts-ubuntu (0.83-6ubuntu1) ... Setting up libxmlb2:arm64 (0.3.6-2build1) ... Setting up stress (1.0.5-1) ... Setting up unzip (6.0-26ubuntu3.1) ... Setting up libcbor0.8:arm64 (0.8.0-2ubuntu1) ... Setting up libedit2:arm64 (3.1-20210910-1build1) ... Setting up wireless-regdb (2022.06.06-0ubuntu1~22.04.1) ... Setting up cron (3.0pl1-137ubuntu3) ... Adding group `crontab' (GID 104) ... Done. Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/multi-user.target.wants/cron.service → /lib/systemd/system/cron.service. Setting up dosfstools (4.2-1build3) ... Setting up rsyslog (8.2112.0-2ubuntu2.2) ... Adding user `syslog' to group `adm' ... Adding user syslog to group adm Done. Creating config file /etc/rsyslog.d/50-default.conf with new version Created symlink /etc/systemd/system/multi-user.target.wants/dmesg.service → /lib/systemd/system/dmesg.service. Created symlink /etc/systemd/system/syslog.service → /lib/systemd/system/rsyslog.service. Created symlink /etc/systemd/system/multi-user.target.wants/rsyslog.service → /lib/systemd/system/rsyslog.service. Setting up binutils-common:arm64 (2.38-4ubuntu2.1) ... Setting up libsensors-config (1:3.6.0-7ubuntu1) ... Setting up libnghttp2-14:arm64 (1.43.0-1build3) ... Setting up libmagic1:arm64 (1:5.41-3) ... Setting up less (590-1ubuntu0.22.04.1) ... Setting up bc (1.07.1-3build1) ... Setting up libctf-nobfd0:arm64 (2.38-4ubuntu2.1) ... Setting up libnetplan0:arm64 (0.105-0ubuntu2~22.04.1) ... Setting up libpackagekit-glib2-18:arm64 (1.2.5-2ubuntu2) ... Setting up python3-yaml (5.4.1-1ubuntu1) ... Setting up liblzo2-2:arm64 (2.10-2build3) ... Setting up hdparm (9.60+ds-1build3) ... Setting up python3-lazr.uri (1.0.6-2) ... Setting up libntfs-3g89 (1:2021.8.22-3ubuntu1.2) ... Setting up file (1:5.41-3) ... Setting up kmod (29-1ubuntu1) ... Setting up python3-zipp (1.0.0-3) ... Setting up libgomp1:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up libfuse2:arm64 (2.9.9-5ubuntu3) ... Setting up libfdt1:arm64 (1.6.1-1) ... Setting up bzip2 (1.0.8-5build1) ... Setting up libunwind8:arm64 (1.3.2-2build2) ... Setting up mtd-utils (1:2.1.4-1) ... Setting up libpkcs11-helper1:arm64 (1.28-1ubuntu0.22.04.1) ... Setting up ntfs-3g (1:2021.8.22-3ubuntu1.2) ... Setting up libasan6:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up libjansson4:arm64 (2.13.1-1.1build3) ... Setting up tzdata (2022g-0ubuntu0.22.04.1) ... Current default time zone: 'Etc/UTC' Local time is now: Wed Mar 15 08:49:28 UTC 2023. Universal Time is now: Wed Mar 15 08:49:28 UTC 2023. Run 'dpkg-reconfigure tzdata' if you wish to change it. Setting up libcap2-bin (1:2.44-1build3) ... Setting up libhavege2:arm64 (1.9.14-1ubuntu1) ... Setting up liberror-perl (0.17029-1) ... Setting up unicode-data (14.0.0-1.1) ... Setting up python3-six (1.16.0-3ubuntu1) ... Setting up libasound2-data (1.2.6.1-1ubuntu1) ... Setting up libklibc:arm64 (2.0.10-4) ... Setting up iotop (0.6-24-g733f3f8-1.1build2) ... update-alternatives: using /usr/sbin/iotop-py to provide /usr/sbin/iotop (iotop) in auto mode Setting up autotools-dev (20220109.1) ... Setting up libisc-export1105:arm64 (1:9.11.19+dfsg-2.1ubuntu3) ... Setting up nocache (1.1-1) ... Setting up libslang2:arm64 (2.3.2-5build4) ... Setting up python3-pyparsing (2.4.7-1) ... Setting up libwrap0:arm64 (7.6.q-31build2) ... Setting up make (4.3-4.1build1) ... Setting up libmpfr6:arm64 (4.1.0-3build3) ... Setting up librtmp1:arm64 (2.4+20151223.gitfa8646d.1-2build4) ... Setting up html2text (1.3.2a-28) ... Setting up libsigc++-2.0-0v5:arm64 (2.10.4-2ubuntu3) ... Setting up aptitude-common (0.8.13-3ubuntu1) ... Setting up bash-completion (1:2.11-5ubuntu1) ... Setting up libteamdctl0:arm64 (1.31-1build2) ... Setting up python3-wadllib (1.3.6-1) ... Setting up dbus (1.12.20-2ubuntu4.1) ... Setting up libsigsegv2:arm64 (2.13-1ubuntu3) ... Setting up xz-utils (5.2.5-2ubuntu1) ... update-alternatives: using /usr/bin/xz to provide /usr/bin/lzma (lzma) in auto mode Setting up debconf-utils (1.5.79ubuntu1) ... Setting up rfkill (2.37.2-4ubuntu3) ... Setting up figlet (2.2.5-3) ... update-alternatives: using /usr/bin/figlet-figlet to provide /usr/bin/figlet (figlet) in auto mode Setting up libssl-dev:arm64 (3.0.2-0ubuntu1.8) ... Setting up libmpc3:arm64 (1.2.1-2build1) ... Setting up libmnl0:arm64 (1.0.4-3build2) ... Setting up libevent-core-2.1-7:arm64 (2.1.12-stable-1build3) ... Setting up libatomic1:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up udev (249.11-0ubuntu3.7) ... A chroot environment has been detected, udev not started. Setting up patch (2.7.6-7build2) ... Setting up libtcl8.6:arm64 (8.6.12+dfsg-1build1) ... Setting up libnss-myhostname:arm64 (249.11-0ubuntu3.7) ... First installation detected... Checking NSS setup... Setting up sudo (1.9.9-1ubuntu2.3) ... Setting up device-tree-compiler (1.6.1-1) ... Setting up liblist-moreutils-xs-perl (0.430-2build2) ... Setting up libpcsclite1:arm64 (1.9.5-3) ... Setting up libsensors5:arm64 (1:3.6.0-7ubuntu1) ... Setting up busybox-initramfs (1:1.30.1-7ubuntu3) ... Setting up libxtables12:arm64 (1.8.7-1ubuntu5) ... Setting up mc-data (3:4.8.27-1) ... Setting up bridge-utils (1.7-1ubuntu3) ... Setting up libnm0:arm64 (1.36.6-0ubuntu2) ... Setting up libssh-4:arm64 (0.9.6-2build1) ... Setting up python3-jeepney (0.7.1-3) ... Setting up lsof (4.93.2+dfsg-1.1build2) ... Setting up libcrack2:arm64 (2.9.6-3.4build4) ... Setting up libfile-fnmatch-perl (0.02-2build8) ... Setting up libfdisk1:arm64 (2.37.2-4ubuntu3) ... Setting up python3-netifaces:arm64 (0.11.0-1build2) ... Setting up libutempter0:arm64 (1.2.1-2build2) ... Setting up libubsan1:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up nano (6.2-1) ... update-alternatives: using /bin/nano to provide /usr/bin/editor (editor) in auto mode update-alternatives: using /bin/nano to provide /usr/bin/pico (pico) in auto mode Setting up libpci3:arm64 (1:3.7.0-6) ... Setting up libparted2:arm64 (3.4-2build1) ... Setting up f3 (8.0-1) ... Setting up keyutils (1.6.1-2ubuntu3) ... Setting up libproc-processtable-perl:arm64 (0.634-1build1) ... Setting up libsctp1:arm64 (1.0.19+dfsg-1build1) ... Setting up u-boot-tools (2022.01+dfsg-2ubuntu2.3) ... Setting up python-apt-common (2.4.0ubuntu1) ... Setting up libcpufreq0 (008-2build1) ... Setting up pv (1.6.6-1build2) ... Setting up libmm-glib0:arm64 (1.20.0-1~ubuntu22.04.1) ... Setting up libhwasan0:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up libbluetooth3:arm64 (5.64-0ubuntu1) ... Setting up libnfnetlink0:arm64 (1.0.1-3build3) ... Setting up libplymouth5:arm64 (0.9.5+git20211018-1ubuntu3) ... Setting up libwrap0-dev:arm64 (7.6.q-31build2) ... Setting up libasan8:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up libuchardet0:arm64 (0.0.7-1build2) ... Setting up libasound2:arm64 (1.2.6.1-1ubuntu1) ... Setting up libnl-3-200:arm64 (3.5.0-0.1) ... Setting up mmc-utils (0+git20191004.73d6c59-2) ... Setting up libpam-systemd:arm64 (249.11-0ubuntu3.7) ... Setting up libcurl4:arm64 (7.81.0-1ubuntu1.8) ... Setting up git-man (1:2.34.1-1ubuntu1.8) ... Setting up libgirepository-1.0-1:arm64 (1.72.0-1) ... Setting up libssh2-1:arm64 (1.10.0-3) ... Setting up netbase (6.3) ... Setting up curl (7.81.0-1ubuntu1.8) ... Setting up debsums (3.0.2) ... Setting up libusb-1.0-0:arm64 (2:1.0.25-1ubuntu2) ... Setting up libstemmer0d:arm64 (2.2.0-1build1) ... Setting up libndp0:arm64 (1.8-0ubuntu3) ... Setting up libgpiod2:arm64 (1.6.3-1build1) ... Setting up libtsan2:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up libexporter-tiny-perl (1.002002-1) ... Setting up libbinutils:arm64 (2.38-4ubuntu2.1) ... Setting up libfido2-1:arm64 (1.10.0-1) ... Setting up libisl23:arm64 (0.24-2build1) ... Setting up libbpf0:arm64 (1:0.5.0-1ubuntu22.04.1) ... Setting up evtest (1:1.34-1) ... Setting up libdaemon0:arm64 (0.14-7.1ubuntu3) ... Setting up klibc-utils (2.0.10-4) ... No diversion 'diversion of /usr/share/initramfs-tools/hooks/klibc to /usr/share/initramfs-tools/hooks/klibc^i-t by klibc-utils', none removed. Setting up libregexp-assemble-perl (0.36-1.1) ... Setting up libsamplerate0:arm64 (0.2.2-1build1) ... Setting up openssl (3.0.2-0ubuntu1.8) ... Setting up libatopology2:arm64 (1.2.6.1-1ubuntu1) ... Setting up libdrm-common (2.4.113-2~ubuntu0.22.04.1) ... Setting up python3-distro-info (1.1build1) ... Setting up vnstat (2.9-1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of restart. Created symlink /etc/systemd/system/multi-user.target.wants/vnstat.service → /lib/systemd/system/vnstat.service. Setting up sysstat (12.5.2-2ubuntu0.1) ... Creating config file /etc/default/sysstat with new version update-alternatives: using /usr/bin/sar.sysstat to provide /usr/bin/sar (sar) in auto mode Created symlink /etc/systemd/system/sysstat.service.wants/sysstat-collect.timer → /lib/systemd/system/sysstat-collect.timer. Created symlink /etc/systemd/system/sysstat.service.wants/sysstat-summary.timer → /lib/systemd/system/sysstat-summary.timer. Created symlink /etc/systemd/system/multi-user.target.wants/sysstat.service → /lib/systemd/system/sysstat.service. Setting up zstd (1.4.8+dfsg-3build1) ... Setting up libcc1-0:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up iso-codes (4.9.0-1) ... Setting up libonig5:arm64 (6.9.7.1-2build1) ... Setting up libiw30:arm64 (30~pre9-13.1ubuntu4) ... Setting up libpolkit-gobject-1-0:arm64 (0.105-33) ... Setting up liblsan0:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up libgstreamer1.0-0:arm64 (1.20.3-0ubuntu1) ... Setcap worked! gst-ptp-helper is not suid! Setting up dctrl-tools (2.24-3build2) ... Setting up libitm1:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up python3-cffi-backend:arm64 (1.15.0-1build2) ... Setting up libpopt0:arm64 (1.18-3build1) ... Setting up ethtool (1:5.16-1) ... Setting up initramfs-tools-bin (0.140ubuntu13.1) ... Setting up ncurses-term (6.3-2) ... Setting up libtsan0:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up python3-blinker (1.4+dfsg1-0.4) ... Setting up libctf0:arm64 (2.38-4ubuntu2.1) ... Setting up logrotate (3.19.0-1ubuntu1.1) ... Created symlink /etc/systemd/system/timers.target.wants/logrotate.timer → /lib/systemd/system/logrotate.timer. Setting up cpp-11 (11.3.0-1ubuntu1~22.04) ... Setting up haveged (1.9.14-1ubuntu1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/sysinit.target.wants/haveged.service → /lib/systemd/system/haveged.service. Setting up tcl8.6 (8.6.12+dfsg-1build1) ... Setting up cpp-12 (12.1.0-2ubuntu1~22.04) ... Setting up libnewt0.52:arm64 (0.52.21-5ubuntu2) ... update-alternatives: using /etc/newt/palette.ubuntu to provide /etc/newt/palette (newt-palette) in auto mode Setting up libfftw3-single3:arm64 (3.3.8-2ubuntu8) ... Setting up fbset (2.1-32build3) ... Setting up python3-importlib-metadata (4.6.4-1) ... Setting up libcaca0:arm64 (0.99.beta19-2.2ubuntu4) ... Setting up toilet (0.3-1.4) ... Setting up mc (3:4.8.27-1) ... update-alternatives: using /usr/bin/mcview to provide /usr/bin/view (view) in auto mode Setting up libjq1:arm64 (1.6-2.1ubuntu3) ... Setting up python3-apt (2.4.0ubuntu1) ... Setting up iproute2 (5.15.0-1ubuntu2) ... Setting up openssh-client (1:8.9p1-3ubuntu0.1) ... update-alternatives: using /usr/bin/ssh to provide /usr/bin/rsh (rsh) in auto mode update-alternatives: using /usr/bin/slogin to provide /usr/bin/rlogin (rlogin) in auto mode update-alternatives: using /usr/bin/scp to provide /usr/bin/rcp (rcp) in auto mode Setting up liblist-moreutils-perl (0.430-2) ... Setting up chrony (4.2-2ubuntu2) ... Creating config file /etc/chrony/chrony.conf with new version Creating config file /etc/chrony/chrony.keys with new version dpkg-statoverride: warning: --update given but /var/log/chrony does not exist Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of restart. Created symlink /etc/systemd/system/chronyd.service → /lib/systemd/system/chrony.service. Created symlink /etc/systemd/system/multi-user.target.wants/chrony.service → /lib/systemd/system/chrony.service. Setting up btrfs-progs (5.16.2-1) ... Setting up wireless-tools (30~pre9-13.1ubuntu4) ... Setting up tcl-expect:arm64 (5.45.4-2build1) ... Setting up libdns-export1110 (1:9.11.19+dfsg-2.1ubuntu3) ... Setting up isc-dhcp-client (4.4.1-2.3ubuntu2.4) ... Setting up m4 (1.4.18-5ubuntu2) ... Setting up parted (3.4-2build1) ... Setting up binutils-aarch64-linux-gnu (2.38-4ubuntu2.1) ... Setting up screen (4.9.0-1) ... Setting up libnftnl11:arm64 (1.2.1-1build1) ... Setting up libcurl3-gnutls:arm64 (7.81.0-1ubuntu1.8) ... Setting up rpcbind (1.2.6-2build1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/multi-user.target.wants/rpcbind.service → /lib/systemd/system/rpcbind.service. Created symlink /etc/systemd/system/sockets.target.wants/rpcbind.socket → /lib/systemd/system/rpcbind.socket. Setting up apt-file (3.2.2) ... The system-wide cache is empty. You may want to run 'apt-file update' as root to update the cache. Setting up binutils (2.38-4ubuntu2.1) ... Setting up libappstream4:arm64 (0.15.2-2) ... Setting up usbutils (1:014-1build1) ... Setting up fdisk (2.37.2-4ubuntu3) ... Setting up dpkg-dev (1.21.1ubuntu2.1) ... Setting up netplan.io (0.105-0ubuntu2~22.04.1) ... Setting up libnl-route-3-200:arm64 (3.5.0-0.1) ... Setting up nfs-common (1:2.6.1-1ubuntu1.2) ... Creating config file /etc/idmapd.conf with new version Creating config file /etc/nfs.conf with new version Adding system user `statd' (UID 108) ... Adding new user `statd' (UID 108) with group `nogroup' ... Not creating home directory `/var/lib/nfs'. Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/multi-user.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target. Created symlink /etc/systemd/system/remote-fs.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target. Setting up ca-certificates (20211016ubuntu0.22.04.1) ... Updating certificates in /etc/ssl/certs... 124 added, 0 removed; done. Setting up alsa-utils (1.2.6-1ubuntu1) ... Setting up cracklib-runtime (2.9.6-3.4build4) ... Setting up dbus-user-session (1.12.20-2ubuntu4.1) ... Setting up unattended-upgrades (2.8ubuntu1) ... Creating config file /etc/apt/apt.conf.d/20auto-upgrades with new version Creating config file /etc/apt/apt.conf.d/50unattended-upgrades with new version Created symlink /etc/systemd/system/multi-user.target.wants/unattended-upgrades.service → /lib/systemd/system/unattended-upgrades.service. Setting up libcwidget4:arm64 (0.5.18-5build1) ... Setting up ifupdown (0.8.36+nmu1ubuntu3) ... Creating /etc/network/interfaces. Created symlink /etc/systemd/system/multi-user.target.wants/networking.service → /lib/systemd/system/networking.service. Created symlink /etc/systemd/system/network-online.target.wants/networking.service → /lib/systemd/system/networking.service. Setting up python3-cryptography (3.4.8-1ubuntu2) ... Setting up rng-tools-debian (2.3) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up libgcc-12-dev:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up python3-commandnotfound (22.04.0) ... Setting up cpufrequtils (008-2build1) ... update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up i2c-tools (4.3-2build1) ... Running in chroot, ignoring request. Running in chroot, ignoring request. Setting up libiperf0:arm64 (3.9-1build1) ... Setting up avahi-autoipd (0.8-5ubuntu5) ... Setting up git (1:2.34.1-1ubuntu1.8) ... Setting up gir1.2-glib-2.0:arm64 (1.72.0-1) ... Setting up pciutils (1:3.7.0-6) ... Setting up autoconf (2.71-2) ... Setting up aptitude (0.8.13-3ubuntu1) ... update-alternatives: using /usr/bin/aptitude-curses to provide /usr/bin/aptitude (aptitude) in auto mode Setting up inetutils-ping (2:2.2-2) ... Setting up libgcc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up libdrm2:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Setting up libnl-3-dev:arm64 (3.5.0-0.1) ... Setting up gcc-11 (11.3.0-1ubuntu1~22.04) ... Setting up vlan (2.0.5ubuntu5) ... Setting up libnetfilter-conntrack3:arm64 (1.0.9-1) ... Setting up groff-base (1.22.4-8build1) ... Setting up cpp (4:11.2.0-1ubuntu1) ... Setting up jq (1.6-2.1ubuntu3) ... Setting up libnl-genl-3-200:arm64 (3.5.0-0.1) ... Setting up bison (2:3.8.2+dfsg-1build1) ... update-alternatives: using /usr/bin/bison.yacc to provide /usr/bin/yacc (yacc) in auto mode Setting up gpiod (1.6.3-1build1) ... Setting up python3-httplib2 (0.20.2-2) ... Setting up libpolkit-agent-1-0:arm64 (0.105-33) ... Setting up initramfs-tools-core (0.140ubuntu13.1) ... Setting up ifenslave (2.10ubuntu3) ... Setting up polkitd (0.105-33) ... Setting up rsync (3.2.7-0ubuntu0.22.04.2) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up automake (1:1.16.5-1.3) ... update-alternatives: using /usr/bin/automake-1.16 to provide /usr/bin/automake (automake) in auto mode Setting up openssh-sftp-server (1:8.9p1-3ubuntu0.1) ... Setting up flex (2.6.4-8build2) ... Setting up openvpn (2.5.5-1ubuntu3.1) ... Created symlink /etc/systemd/system/multi-user.target.wants/openvpn.service → /lib/systemd/system/openvpn.service. Setting up initramfs-tools (0.140ubuntu13.1) ... update-initramfs: deferring update (trigger activated) Setting up openssh-server (1:8.9p1-3ubuntu0.1) ... Creating config file /etc/ssh/sshd_config with new version Creating SSH2 RSA key; this may take some time ... 3072 SHA256:mBwVA2MIzzRnP+xIblJBoBsS4wMSp3GJG7iY5V5Gioo root@a12a13pctsp (RSA) Creating SSH2 ECDSA key; this may take some time ... 256 SHA256:wAQdk9ICB4KStzst3P91crjL9OgjStPie1PY9Xnp/Lg root@a12a13pctsp (ECDSA) Creating SSH2 ED25519 key; this may take some time ... 256 SHA256:1AMdF89rdHY4qxKQdU9rsv/N/WJABVdd7sM4C2QOvj8 root@a12a13pctsp (ED25519) Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/sshd.service → /lib/systemd/system/ssh.service. Created symlink /etc/systemd/system/multi-user.target.wants/ssh.service → /lib/systemd/system/ssh.service. Setting up iperf3 (3.9-1build1) ... Setting up plymouth (0.9.5+git20211018-1ubuntu3) ... update-initramfs: deferring update (trigger activated) update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults Setting up iptables (1.8.7-1ubuntu5) ... update-alternatives: using /usr/sbin/iptables-legacy to provide /usr/sbin/iptables (iptables) in auto mode update-alternatives: using /usr/sbin/ip6tables-legacy to provide /usr/sbin/ip6tables (ip6tables) in auto mode update-alternatives: using /usr/sbin/iptables-nft to provide /usr/sbin/iptables (iptables) in auto mode update-alternatives: using /usr/sbin/ip6tables-nft to provide /usr/sbin/ip6tables (ip6tables) in auto mode update-alternatives: using /usr/sbin/arptables-nft to provide /usr/sbin/arptables (arptables) in auto mode update-alternatives: using /usr/sbin/ebtables-nft to provide /usr/sbin/ebtables (ebtables) in auto mode Setting up htop (3.0.5-7build2) ... Setting up expect (5.45.4-2build1) ... Setting up pkexec (0.105-33) ... Setting up man-db (2.10.2-1) ... Building database of manual pages ... Created symlink /etc/systemd/system/timers.target.wants/man-db.timer → /lib/systemd/system/man-db.timer. Setting up libnl-genl-3-dev:arm64 (3.5.0-0.1) ... Setting up gcc (4:11.2.0-1ubuntu1) ... Setting up wpasupplicant (2:2.10-6ubuntu2) ... Created symlink /etc/systemd/system/dbus-fi.w1.wpa_supplicant1.service → /lib/systemd/system/wpa_supplicant.service. Created symlink /etc/systemd/system/multi-user.target.wants/wpa_supplicant.service → /lib/systemd/system/wpa_supplicant.service. Setting up gir1.2-packagekitglib-1.0 (1.2.5-2ubuntu2) ... Setting up python3-oauthlib (3.2.0-1ubuntu0.1) ... Setting up python3-secretstorage (3.3.1-1) ... Setting up gcc-12 (12.1.0-2ubuntu1~22.04) ... Setting up command-not-found (22.04.0) ... Setting up python3-gi (3.42.1-0ubuntu1) ... Setting up libstdc++-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up python3-keyring (23.5.0-1) ... Setting up python3-lazr.restfulclient (0.14.4-1) ... Setting up policykit-1 (0.105-33) ... Setting up plymouth-label (0.9.5+git20211018-1ubuntu3) ... Setting up g++-11 (11.3.0-1ubuntu1~22.04) ... Setting up python3-launchpadlib (1.10.16-1) ... Setting up network-manager (1.36.6-0ubuntu2) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of force-reload. Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service → /lib/systemd/system/NetworkManager-dispatcher.service. Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service → /lib/systemd/system/NetworkManager-wait-online.service. Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service → /lib/systemd/system/NetworkManager.service. Setting up dkms (2.8.7-2ubuntu2.1) ... Setting up python3-software-properties (0.99.22.6) ... Setting up g++ (4:11.2.0-1ubuntu1) ... update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode Setting up build-essential (12.9ubuntu3) ... Setting up packagekit (1.2.5-2ubuntu2) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of force-reload. Failed to open connection to "system" message bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory Created symlink /etc/systemd/user/sockets.target.wants/pk-debconf-helper.socket → /usr/lib/systemd/user/pk-debconf-helper.socket. Setting up plymouth-theme-spinner (0.9.5+git20211018-1ubuntu3) ... update-alternatives: using /usr/share/plymouth/themes/bgrt/bgrt.plymouth to provide /usr/share/plymouth/themes/default.plymouth (default.plymouth) in auto mode update-initramfs: deferring update (trigger activated) Setting up network-manager-openvpn (1.8.18-1) ... Setting up software-properties-common (0.99.22.6) ... Setting up plymouth-themes (0.9.5+git20211018-1ubuntu3) ... update-alternatives: using /usr/share/plymouth/themes/text/text.plymouth to provide /usr/share/plymouth/themes/text.plymouth (text.plymouth) in auto mode update-initramfs: deferring update (trigger activated) Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for libc-bin (2.35-0ubuntu3.1) ... Processing triggers for fontconfig (2.13.1-4.2ubuntu5) ... Processing triggers for ca-certificates (20211016ubuntu0.22.04.1) ... Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done. Running hooks in /etc/ca-certificates/update.d... done. Processing triggers for initramfs-tools (0.140ubuntu13.1) ... Processing triggers for dbus (1.12.20-2ubuntu4.1) ... --> (871) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (871) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (871) INFO: Installing 150 desktop packages [ jammy xfce ] --> (871) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (871) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (871) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (871) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --dry-run install anacron apt-xapian-index blueman bluez bluez-cups bluez-tools brltty brltty-x11 cifs-utils colord cups cups-bsd cups-client cups-filters dbus-x11 dmz-cursor-theme evince evince-common fontconfig fontconfig-config fonts-noto-cjk fonts-ubuntu fonts-ubuntu-console foomatic-db-compressed-ppds gdebi ghostscript-x gnome-font-viewer gnome-disk-utility gnome-screenshot gnome-system-monitor gstreamer1.0-packagekit gstreamer1.0-plugins-base-apps gstreamer1.0-pulseaudio gtk2-engines gtk2-engines-murrine gtk2-engines-pixbuf gvfs-backends hplip indicator-printers inputattach inxi keyutils laptop-detect libatk-adaptor libfontconfig1 libfontembed1 libfontenc1 libgail-common libgl1-mesa-dri libgsettings-qt1 libgtk2.0-bin libnotify-bin libpam-gnome-keyring libproxy1-plugin-gsettings libproxy1-plugin-networkmanager libu2f-udev libwmf0.2-7-gtk libxcursor1 lightdm lm-sensors lxtask mesa-utils mousepad mousetweaks network-manager-gnome network-manager-openvpn network-manager-ssh network-manager-vpnc numix-gtk-theme numix-icon-theme numix-icon-theme-circle openprinting-ppds orca p7zip-full pamix pasystray pavucontrol pavumeter policykit-1 policykit-desktop-privileges printer-driver-all profile-sync-daemon pulseaudio pulseaudio-module-bluetooth qalculate-gtk redshift slick-greeter smbclient software-properties-gtk spice-vdagent synaptic system-config-printer system-config-printer-common terminator thunar-volman update-inetd update-manager update-manager-core viewnior x11-apps x11-utils x11-xserver-utils xapps-common xarchiver xbacklight xcursor-themes xdg-user-dirs xdg-user-dirs-gtk xfce4 xfce4-notifyd xfce4-power-manager xfce4-screenshooter xfce4-terminal xfonts-100dpi xfonts-75dpi xfonts-base xfonts-encodings xfonts-scalable xfonts-utils xorg-docs-core xscreensaver xsensors xserver-xorg xserver-xorg-video-fbdev xwallpaper gh glmark2 chromium-browser firefox-esr bleachbit fbi gparted system-monitoring-center emacs notepadqq vim filezilla putty transmission transmission-remote-gtk build-essential clang geany meld regexxer remmina remmina-plugin-vnc remmina-plugin-rdp gnome-builder codium 2>&1 | { grep --line-buffered -v -e '^Conf ' -e '^Inst ' || true; } --> (886) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (886) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (886) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (886) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (886) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (886) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --download-only install anacron apt-xapian-index blueman bluez bluez-cups bluez-tools brltty brltty-x11 cifs-utils colord cups cups-bsd cups-client cups-filters dbus-x11 dmz-cursor-theme evince evince-common fontconfig fontconfig-config fonts-noto-cjk fonts-ubuntu fonts-ubuntu-console foomatic-db-compressed-ppds gdebi ghostscript-x gnome-font-viewer gnome-disk-utility gnome-screenshot gnome-system-monitor gstreamer1.0-packagekit gstreamer1.0-plugins-base-apps gstreamer1.0-pulseaudio gtk2-engines gtk2-engines-murrine gtk2-engines-pixbuf gvfs-backends hplip indicator-printers inputattach inxi keyutils laptop-detect libatk-adaptor libfontconfig1 libfontembed1 libfontenc1 libgail-common libgl1-mesa-dri libgsettings-qt1 libgtk2.0-bin libnotify-bin libpam-gnome-keyring libproxy1-plugin-gsettings libproxy1-plugin-networkmanager libu2f-udev libwmf0.2-7-gtk libxcursor1 lightdm lm-sensors lxtask mesa-utils mousepad mousetweaks network-manager-gnome network-manager-openvpn network-manager-ssh network-manager-vpnc numix-gtk-theme numix-icon-theme numix-icon-theme-circle openprinting-ppds orca p7zip-full pamix pasystray pavucontrol pavumeter policykit-1 policykit-desktop-privileges printer-driver-all profile-sync-daemon pulseaudio pulseaudio-module-bluetooth qalculate-gtk redshift slick-greeter smbclient software-properties-gtk spice-vdagent synaptic system-config-printer system-config-printer-common terminator thunar-volman update-inetd update-manager update-manager-core viewnior x11-apps x11-utils x11-xserver-utils xapps-common xarchiver xbacklight xcursor-themes xdg-user-dirs xdg-user-dirs-gtk xfce4 xfce4-notifyd xfce4-power-manager xfce4-screenshooter xfce4-terminal xfonts-100dpi xfonts-75dpi xfonts-base xfonts-encodings xfonts-scalable xfonts-utils xorg-docs-core xscreensaver xsensors xserver-xorg xserver-xorg-video-fbdev xwallpaper gh glmark2 chromium-browser firefox-esr bleachbit fbi gparted system-monitoring-center emacs notepadqq vim filezilla putty transmission transmission-remote-gtk build-essential clang geany meld regexxer remmina remmina-plugin-vnc remmina-plugin-rdp gnome-builder codium --> (927) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (927) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (927) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (927) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (927) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (927) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends install anacron apt-xapian-index blueman bluez bluez-cups bluez-tools brltty brltty-x11 cifs-utils colord cups cups-bsd cups-client cups-filters dbus-x11 dmz-cursor-theme evince evince-common fontconfig fontconfig-config fonts-noto-cjk fonts-ubuntu fonts-ubuntu-console foomatic-db-compressed-ppds gdebi ghostscript-x gnome-font-viewer gnome-disk-utility gnome-screenshot gnome-system-monitor gstreamer1.0-packagekit gstreamer1.0-plugins-base-apps gstreamer1.0-pulseaudio gtk2-engines gtk2-engines-murrine gtk2-engines-pixbuf gvfs-backends hplip indicator-printers inputattach inxi keyutils laptop-detect libatk-adaptor libfontconfig1 libfontembed1 libfontenc1 libgail-common libgl1-mesa-dri libgsettings-qt1 libgtk2.0-bin libnotify-bin libpam-gnome-keyring libproxy1-plugin-gsettings libproxy1-plugin-networkmanager libu2f-udev libwmf0.2-7-gtk libxcursor1 lightdm lm-sensors lxtask mesa-utils mousepad mousetweaks network-manager-gnome network-manager-openvpn network-manager-ssh network-manager-vpnc numix-gtk-theme numix-icon-theme numix-icon-theme-circle openprinting-ppds orca p7zip-full pamix pasystray pavucontrol pavumeter policykit-1 policykit-desktop-privileges printer-driver-all profile-sync-daemon pulseaudio pulseaudio-module-bluetooth qalculate-gtk redshift slick-greeter smbclient software-properties-gtk spice-vdagent synaptic system-config-printer system-config-printer-common terminator thunar-volman update-inetd update-manager update-manager-core viewnior x11-apps x11-utils x11-xserver-utils xapps-common xarchiver xbacklight xcursor-themes xdg-user-dirs xdg-user-dirs-gtk xfce4 xfce4-notifyd xfce4-power-manager xfce4-screenshooter xfce4-terminal xfonts-100dpi xfonts-75dpi xfonts-base xfonts-encodings xfonts-scalable xfonts-utils xorg-docs-core xscreensaver xsensors xserver-xorg xserver-xorg-video-fbdev xwallpaper gh glmark2 chromium-browser firefox-esr bleachbit fbi gparted system-monitoring-center emacs notepadqq vim filezilla putty transmission transmission-remote-gtk build-essential clang geany meld regexxer remmina remmina-plugin-vnc remmina-plugin-rdp gnome-builder codium Preconfiguring packages ... Selecting previously unselected package install-info. (Reading database ... 45731 files and directories currently installed.) Preparing to unpack .../install-info_6.8-4build1_arm64.deb ... Unpacking install-info (6.8-4build1) ... Setting up install-info (6.8-4build1) ... Selecting previously unselected package libatspi2.0-0:arm64. (Reading database ... 45744 files and directories currently installed.) Preparing to unpack .../000-libatspi2.0-0_2.44.0-3_arm64.deb ... Unpacking libatspi2.0-0:arm64 (2.44.0-3) ... Selecting previously unselected package libatk-bridge2.0-0:arm64. Preparing to unpack .../001-libatk-bridge2.0-0_2.38.0-3_arm64.deb ... Unpacking libatk-bridge2.0-0:arm64 (2.38.0-3) ... Selecting previously unselected package libwayland-server0:arm64. Preparing to unpack .../002-libwayland-server0_1.20.0-1ubuntu0.1_arm64.deb ... Unpacking libwayland-server0:arm64 (1.20.0-1ubuntu0.1) ... Selecting previously unselected package libgbm1:arm64. Preparing to unpack .../003-libgbm1_22.2.5-0ubuntu0.1~22.04.1_arm64.deb ... Unpacking libgbm1:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Selecting previously unselected package libnspr4:arm64. Preparing to unpack .../004-libnspr4_2%3a4.32-3build1_arm64.deb ... Unpacking libnspr4:arm64 (2:4.32-3build1) ... Selecting previously unselected package libnss3:arm64. Preparing to unpack .../005-libnss3_2%3a3.68.2-0ubuntu1.2_arm64.deb ... Unpacking libnss3:arm64 (2:3.68.2-0ubuntu1.2) ... Selecting previously unselected package libasyncns0:arm64. Preparing to unpack .../006-libasyncns0_0.8-6build2_arm64.deb ... Unpacking libasyncns0:arm64 (0.8-6build2) ... Selecting previously unselected package libogg0:arm64. Preparing to unpack .../007-libogg0_1.3.5-0ubuntu3_arm64.deb ... Unpacking libogg0:arm64 (1.3.5-0ubuntu3) ... Selecting previously unselected package libflac8:arm64. Preparing to unpack .../008-libflac8_1.3.3-2ubuntu0.1_arm64.deb ... Unpacking libflac8:arm64 (1.3.3-2ubuntu0.1) ... Selecting previously unselected package libopus0:arm64. Preparing to unpack .../009-libopus0_1.3.1-0.1build2_arm64.deb ... Unpacking libopus0:arm64 (1.3.1-0.1build2) ... Selecting previously unselected package libvorbis0a:arm64. Preparing to unpack .../010-libvorbis0a_1.3.7-1build2_arm64.deb ... Unpacking libvorbis0a:arm64 (1.3.7-1build2) ... Selecting previously unselected package libvorbisenc2:arm64. Preparing to unpack .../011-libvorbisenc2_1.3.7-1build2_arm64.deb ... Unpacking libvorbisenc2:arm64 (1.3.7-1build2) ... Selecting previously unselected package libsndfile1:arm64. Preparing to unpack .../012-libsndfile1_1.0.31-2build1_arm64.deb ... Unpacking libsndfile1:arm64 (1.0.31-2build1) ... Selecting previously unselected package libx11-xcb1:arm64. Preparing to unpack .../013-libx11-xcb1_2%3a1.7.5-1_arm64.deb ... Unpacking libx11-xcb1:arm64 (2:1.7.5-1) ... Selecting previously unselected package libpulse0:arm64. Preparing to unpack .../014-libpulse0_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking libpulse0:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package libdouble-conversion3:arm64. Preparing to unpack .../015-libdouble-conversion3_3.1.7-4_arm64.deb ... Unpacking libdouble-conversion3:arm64 (3.1.7-4) ... Selecting previously unselected package libqt5core5a:arm64. Preparing to unpack .../016-libqt5core5a_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5core5a:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libglvnd0:arm64. Preparing to unpack .../017-libglvnd0_1.4.0-1_arm64.deb ... Unpacking libglvnd0:arm64 (1.4.0-1) ... Selecting previously unselected package libglapi-mesa:arm64. Preparing to unpack .../018-libglapi-mesa_22.2.5-0ubuntu0.1~22.04.1_arm64.deb ... Unpacking libglapi-mesa:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Selecting previously unselected package libwayland-client0:arm64. Preparing to unpack .../019-libwayland-client0_1.20.0-1ubuntu0.1_arm64.deb ... Unpacking libwayland-client0:arm64 (1.20.0-1ubuntu0.1) ... Selecting previously unselected package libxcb-dri2-0:arm64. Preparing to unpack .../020-libxcb-dri2-0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-dri2-0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-dri3-0:arm64. Preparing to unpack .../021-libxcb-dri3-0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-dri3-0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-present0:arm64. Preparing to unpack .../022-libxcb-present0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-present0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-sync1:arm64. Preparing to unpack .../023-libxcb-sync1_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-sync1:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-xfixes0:arm64. Preparing to unpack .../024-libxcb-xfixes0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-xfixes0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxshmfence1:arm64. Preparing to unpack .../025-libxshmfence1_1.3-1build4_arm64.deb ... Unpacking libxshmfence1:arm64 (1.3-1build4) ... Selecting previously unselected package libegl-mesa0:arm64. Preparing to unpack .../026-libegl-mesa0_22.2.5-0ubuntu0.1~22.04.1_arm64.deb ... Unpacking libegl-mesa0:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Selecting previously unselected package libegl1:arm64. Preparing to unpack .../027-libegl1_1.4.0-1_arm64.deb ... Unpacking libegl1:arm64 (1.4.0-1) ... Selecting previously unselected package libxcb-glx0:arm64. Preparing to unpack .../028-libxcb-glx0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-glx0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxxf86vm1:arm64. Preparing to unpack .../029-libxxf86vm1_1%3a1.1.4-1build3_arm64.deb ... Unpacking libxxf86vm1:arm64 (1:1.1.4-1build3) ... Selecting previously unselected package libdrm-amdgpu1:arm64. Preparing to unpack .../030-libdrm-amdgpu1_2.4.113-2~ubuntu0.22.04.1_arm64.deb ... Unpacking libdrm-amdgpu1:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously unselected package libdrm-nouveau2:arm64. Preparing to unpack .../031-libdrm-nouveau2_2.4.113-2~ubuntu0.22.04.1_arm64.deb ... Unpacking libdrm-nouveau2:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously unselected package libdrm-radeon1:arm64. Preparing to unpack .../032-libdrm-radeon1_2.4.113-2~ubuntu0.22.04.1_arm64.deb ... Unpacking libdrm-radeon1:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Selecting previously unselected package libllvm15:arm64. Preparing to unpack .../033-libllvm15_1%3a15.0.6-3~ubuntu0.22.04.2_arm64.deb ... Unpacking libllvm15:arm64 (1:15.0.6-3~ubuntu0.22.04.2) ... Selecting previously unselected package libgl1-mesa-dri:arm64. Preparing to unpack .../034-libgl1-mesa-dri_22.2.5-0ubuntu0.1~22.04.1_arm64.deb ... Unpacking libgl1-mesa-dri:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Selecting previously unselected package libglx-mesa0:arm64. Preparing to unpack .../035-libglx-mesa0_22.2.5-0ubuntu0.1~22.04.1_arm64.deb ... Unpacking libglx-mesa0:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Selecting previously unselected package libglx0:arm64. Preparing to unpack .../036-libglx0_1.4.0-1_arm64.deb ... Unpacking libglx0:arm64 (1.4.0-1) ... Selecting previously unselected package libgl1:arm64. Preparing to unpack .../037-libgl1_1.4.0-1_arm64.deb ... Unpacking libgl1:arm64 (1.4.0-1) ... Selecting previously unselected package x11-common. Preparing to unpack .../038-x11-common_1%3a7.7+23ubuntu2_all.deb ... Unpacking x11-common (1:7.7+23ubuntu2) ... Selecting previously unselected package libice6:arm64. Preparing to unpack .../039-libice6_2%3a1.0.10-1build2_arm64.deb ... Unpacking libice6:arm64 (2:1.0.10-1build2) ... Selecting previously unselected package libevdev2:arm64. Preparing to unpack .../040-libevdev2_1.12.1+dfsg-1_arm64.deb ... Unpacking libevdev2:arm64 (1.12.1+dfsg-1) ... Selecting previously unselected package libmtdev1:arm64. Preparing to unpack .../041-libmtdev1_1.1.6-1build4_arm64.deb ... Unpacking libmtdev1:arm64 (1.1.6-1build4) ... Selecting previously unselected package libgudev-1.0-0:arm64. Preparing to unpack .../042-libgudev-1.0-0_1%3a237-2build1_arm64.deb ... Unpacking libgudev-1.0-0:arm64 (1:237-2build1) ... Selecting previously unselected package libwacom-common. Preparing to unpack .../043-libwacom-common_2.2.0-1_all.deb ... Unpacking libwacom-common (2.2.0-1) ... Selecting previously unselected package libwacom9:arm64. Preparing to unpack .../044-libwacom9_2.2.0-1_arm64.deb ... Unpacking libwacom9:arm64 (2.2.0-1) ... Selecting previously unselected package libinput-bin. Preparing to unpack .../045-libinput-bin_1.20.0-1ubuntu0.2_arm64.deb ... Unpacking libinput-bin (1.20.0-1ubuntu0.2) ... Selecting previously unselected package libinput10:arm64. Preparing to unpack .../046-libinput10_1.20.0-1ubuntu0.2_arm64.deb ... Unpacking libinput10:arm64 (1.20.0-1ubuntu0.2) ... Selecting previously unselected package libmd4c0:arm64. Preparing to unpack .../047-libmd4c0_0.4.8-1_arm64.deb ... Unpacking libmd4c0:arm64 (0.4.8-1) ... Selecting previously unselected package libqt5dbus5:arm64. Preparing to unpack .../048-libqt5dbus5_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5dbus5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libqt5network5:arm64. Preparing to unpack .../049-libqt5network5_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5network5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libsm6:arm64. Preparing to unpack .../050-libsm6_2%3a1.2.3-1build2_arm64.deb ... Unpacking libsm6:arm64 (2:1.2.3-1build2) ... Selecting previously unselected package libxcb-icccm4:arm64. Preparing to unpack .../051-libxcb-icccm4_0.4.1-1.1build2_arm64.deb ... Unpacking libxcb-icccm4:arm64 (0.4.1-1.1build2) ... Selecting previously unselected package libxcb-util1:arm64. Preparing to unpack .../052-libxcb-util1_0.4.0-1build2_arm64.deb ... Unpacking libxcb-util1:arm64 (0.4.0-1build2) ... Selecting previously unselected package libxcb-image0:arm64. Preparing to unpack .../053-libxcb-image0_0.4.0-2_arm64.deb ... Unpacking libxcb-image0:arm64 (0.4.0-2) ... Selecting previously unselected package libxcb-keysyms1:arm64. Preparing to unpack .../054-libxcb-keysyms1_0.4.0-1build3_arm64.deb ... Unpacking libxcb-keysyms1:arm64 (0.4.0-1build3) ... Selecting previously unselected package libxcb-randr0:arm64. Preparing to unpack .../055-libxcb-randr0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-randr0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-render-util0:arm64. Preparing to unpack .../056-libxcb-render-util0_0.3.9-1build3_arm64.deb ... Unpacking libxcb-render-util0:arm64 (0.3.9-1build3) ... Selecting previously unselected package libxcb-shape0:arm64. Preparing to unpack .../057-libxcb-shape0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-shape0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-xinerama0:arm64. Preparing to unpack .../058-libxcb-xinerama0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-xinerama0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-xinput0:arm64. Preparing to unpack .../059-libxcb-xinput0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-xinput0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxcb-xkb1:arm64. Preparing to unpack .../060-libxcb-xkb1_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-xkb1:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxkbcommon0:arm64. Preparing to unpack .../061-libxkbcommon0_1.4.0-1_arm64.deb ... Unpacking libxkbcommon0:arm64 (1.4.0-1) ... Selecting previously unselected package libxkbcommon-x11-0:arm64. Preparing to unpack .../062-libxkbcommon-x11-0_1.4.0-1_arm64.deb ... Unpacking libxkbcommon-x11-0:arm64 (1.4.0-1) ... Selecting previously unselected package libqt5gui5:arm64. Preparing to unpack .../063-libqt5gui5_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5gui5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libqt5widgets5:arm64. Preparing to unpack .../064-libqt5widgets5_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5widgets5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libxtst6:arm64. Preparing to unpack .../065-libxtst6_2%3a1.2.3-1build4_arm64.deb ... Unpacking libxtst6:arm64 (2:1.2.3-1build4) ... Selecting previously unselected package xdg-utils. Preparing to unpack .../066-xdg-utils_1.1.3-4.1ubuntu3~22.04.1_all.deb ... Unpacking xdg-utils (1.1.3-4.1ubuntu3~22.04.1) ... Selecting previously unselected package chromium-codecs-ffmpeg-extra. Preparing to unpack .../067-chromium-codecs-ffmpeg-extra_1%3a107.0.5304.62-0ubuntu1~ppa1~22.04.1_arm64.deb ... Unpacking chromium-codecs-ffmpeg-extra (1:107.0.5304.62-0ubuntu1~ppa1~22.04.1) ... Selecting previously unselected package chromium-browser. Preparing to unpack .../068-chromium-browser_1%3a107.0.5304.62-0ubuntu1~ppa1~22.04.1_arm64.deb ... Unpacking chromium-browser (1:107.0.5304.62-0ubuntu1~ppa1~22.04.1) ... Selecting previously unselected package ssl-cert. Preparing to unpack .../069-ssl-cert_1.1.2_all.deb ... Unpacking ssl-cert (1.1.2) ... Selecting previously unselected package libpaper1:arm64. Preparing to unpack .../070-libpaper1_1.1.28build2_arm64.deb ... Unpacking libpaper1:arm64 (1.1.28build2) ... Selecting previously unselected package libjson-glib-1.0-common. Preparing to unpack .../071-libjson-glib-1.0-common_1.6.6-1build1_all.deb ... Unpacking libjson-glib-1.0-common (1.6.6-1build1) ... Selecting previously unselected package libjson-glib-1.0-0:arm64. Preparing to unpack .../072-libjson-glib-1.0-0_1.6.6-1build1_arm64.deb ... Unpacking libjson-glib-1.0-0:arm64 (1.6.6-1build1) ... Selecting previously unselected package libproxy1v5:arm64. Preparing to unpack .../073-libproxy1v5_0.4.17-2_arm64.deb ... Unpacking libproxy1v5:arm64 (0.4.17-2) ... Selecting previously unselected package glib-networking-common. Preparing to unpack .../074-glib-networking-common_2.72.0-1_all.deb ... Unpacking glib-networking-common (2.72.0-1) ... Selecting previously unselected package glib-networking-services. Preparing to unpack .../075-glib-networking-services_2.72.0-1_arm64.deb ... Unpacking glib-networking-services (2.72.0-1) ... Selecting previously unselected package dbus-x11. Preparing to unpack .../076-dbus-x11_1.12.20-2ubuntu4.1_arm64.deb ... Unpacking dbus-x11 (1.12.20-2ubuntu4.1) ... Selecting previously unselected package dconf-service. Preparing to unpack .../077-dconf-service_0.40.0-3_arm64.deb ... Unpacking dconf-service (0.40.0-3) ... Selecting previously unselected package dconf-gsettings-backend:arm64. Preparing to unpack .../078-dconf-gsettings-backend_0.40.0-3_arm64.deb ... Unpacking dconf-gsettings-backend:arm64 (0.40.0-3) ... Selecting previously unselected package session-migration. Preparing to unpack .../079-session-migration_0.3.6_arm64.deb ... Unpacking session-migration (0.3.6) ... Selecting previously unselected package gsettings-desktop-schemas. Preparing to unpack .../080-gsettings-desktop-schemas_42.0-1ubuntu1_all.deb ... Unpacking gsettings-desktop-schemas (42.0-1ubuntu1) ... Selecting previously unselected package glib-networking:arm64. Preparing to unpack .../081-glib-networking_2.72.0-1_arm64.deb ... Unpacking glib-networking:arm64 (2.72.0-1) ... Selecting previously unselected package libsoup2.4-common. Preparing to unpack .../082-libsoup2.4-common_2.74.2-3_all.deb ... Unpacking libsoup2.4-common (2.74.2-3) ... Selecting previously unselected package libsoup2.4-1:arm64. Preparing to unpack .../083-libsoup2.4-1_2.74.2-3_arm64.deb ... Unpacking libsoup2.4-1:arm64 (2.74.2-3) ... Selecting previously unselected package libsnapd-glib1:arm64. Preparing to unpack .../084-libsnapd-glib1_1.60-0ubuntu1_arm64.deb ... Unpacking libsnapd-glib1:arm64 (1.60-0ubuntu1) ... Selecting previously unselected package cups-daemon. Preparing to unpack .../085-cups-daemon_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-daemon (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package libqt5svg5:arm64. Preparing to unpack .../086-libqt5svg5_5.15.3-1_arm64.deb ... Unpacking libqt5svg5:arm64 (5.15.3-1) ... Selecting previously unselected package libsane-common. Preparing to unpack .../087-libsane-common_1.1.1-5_all.deb ... Unpacking libsane-common (1.1.1-5) ... Selecting previously unselected package libtalloc2:arm64. Preparing to unpack .../088-libtalloc2_2.3.3-2build1_arm64.deb ... Unpacking libtalloc2:arm64 (2.3.3-2build1) ... Selecting previously unselected package libtevent0:arm64. Preparing to unpack .../089-libtevent0_0.11.0-1build1_arm64.deb ... Unpacking libtevent0:arm64 (0.11.0-1build1) ... Selecting previously unselected package libwbclient0:arm64. Preparing to unpack .../090-libwbclient0_2%3a4.15.13+dfsg-0ubuntu1_arm64.deb ... Unpacking libwbclient0:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Selecting previously unselected package lightdm. Preparing to unpack .../091-lightdm_1.30.0-0ubuntu5_arm64.deb ... Unpacking lightdm (1.30.0-0ubuntu5) ... Selecting previously unselected package poppler-data. Preparing to unpack .../092-poppler-data_0.4.11-1_all.deb ... Unpacking poppler-data (0.4.11-1) ... Selecting previously unselected package liborc-0.4-0:arm64. Preparing to unpack .../093-liborc-0.4-0_1%3a0.4.32-2_arm64.deb ... Unpacking liborc-0.4-0:arm64 (1:0.4.32-2) ... Selecting previously unselected package libgstreamer-plugins-base1.0-0:arm64. Preparing to unpack .../094-libgstreamer-plugins-base1.0-0_1.20.1-1_arm64.deb ... Unpacking libgstreamer-plugins-base1.0-0:arm64 (1.20.1-1) ... Selecting previously unselected package libltdl7:arm64. Preparing to unpack .../095-libltdl7_2.4.6-15build2_arm64.deb ... Unpacking libltdl7:arm64 (2.4.6-15build2) ... Selecting previously unselected package libsoxr0:arm64. Preparing to unpack .../096-libsoxr0_0.1.3-4build2_arm64.deb ... Unpacking libsoxr0:arm64 (0.1.3-4build2) ... Selecting previously unselected package libspeexdsp1:arm64. Preparing to unpack .../097-libspeexdsp1_1.2~rc1.2-1.1ubuntu3_arm64.deb ... Unpacking libspeexdsp1:arm64 (1.2~rc1.2-1.1ubuntu3) ... Selecting previously unselected package libtdb1:arm64. Preparing to unpack .../098-libtdb1_1.4.5-2build1_arm64.deb ... Unpacking libtdb1:arm64 (1.4.5-2build1) ... Selecting previously unselected package libwebrtc-audio-processing1:arm64. Preparing to unpack .../099-libwebrtc-audio-processing1_0.3.1-0ubuntu5_arm64.deb ... Unpacking libwebrtc-audio-processing1:arm64 (0.3.1-0ubuntu5) ... Selecting previously unselected package libjack-jackd2-0:arm64. Preparing to unpack .../100-libjack-jackd2-0_1.9.20~dfsg-1_arm64.deb ... Unpacking libjack-jackd2-0:arm64 (1.9.20~dfsg-1) ... Selecting previously unselected package libasound2-plugins:arm64. Preparing to unpack .../101-libasound2-plugins_1.2.6-1_arm64.deb ... Unpacking libasound2-plugins:arm64 (1.2.6-1) ... Selecting previously unselected package libpulsedsp:arm64. Preparing to unpack .../102-libpulsedsp_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking libpulsedsp:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package pulseaudio-utils. Preparing to unpack .../103-pulseaudio-utils_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking pulseaudio-utils (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package pulseaudio. Preparing to unpack .../104-pulseaudio_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking pulseaudio (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package samba-common. Preparing to unpack .../105-samba-common_2%3a4.15.13+dfsg-0ubuntu1_all.deb ... Unpacking samba-common (2:4.15.13+dfsg-0ubuntu1) ... Selecting previously unselected package liblmdb0:arm64. Preparing to unpack .../106-liblmdb0_0.9.24-1build2_arm64.deb ... Unpacking liblmdb0:arm64 (0.9.24-1build2) ... Selecting previously unselected package libldb2:arm64. Preparing to unpack .../107-libldb2_2%3a2.4.4-0ubuntu0.22.04.1_arm64.deb ... Unpacking libldb2:arm64 (2:2.4.4-0ubuntu0.22.04.1) ... Selecting previously unselected package libpython3.10:arm64. Preparing to unpack .../108-libpython3.10_3.10.6-1~22.04.2_arm64.deb ... Unpacking libpython3.10:arm64 (3.10.6-1~22.04.2) ... Selecting previously unselected package python3-ldb. Preparing to unpack .../109-python3-ldb_2%3a2.4.4-0ubuntu0.22.04.1_arm64.deb ... Unpacking python3-ldb (2:2.4.4-0ubuntu0.22.04.1) ... Selecting previously unselected package python3-talloc:arm64. Preparing to unpack .../110-python3-talloc_2.3.3-2build1_arm64.deb ... Unpacking python3-talloc:arm64 (2.3.3-2build1) ... Selecting previously unselected package samba-libs:arm64. Preparing to unpack .../111-samba-libs_2%3a4.15.13+dfsg-0ubuntu1_arm64.deb ... Unpacking samba-libs:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Selecting previously unselected package libarchive13:arm64. Preparing to unpack .../112-libarchive13_3.6.0-1ubuntu1_arm64.deb ... Unpacking libarchive13:arm64 (3.6.0-1ubuntu1) ... Selecting previously unselected package libsmbclient:arm64. Preparing to unpack .../113-libsmbclient_2%3a4.15.13+dfsg-0ubuntu1_arm64.deb ... Unpacking libsmbclient:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Selecting previously unselected package smbclient. Preparing to unpack .../114-smbclient_2%3a4.15.13+dfsg-0ubuntu1_arm64.deb ... Unpacking smbclient (2:4.15.13+dfsg-0ubuntu1) ... Selecting previously unselected package libcairo-gobject2:arm64. Preparing to unpack .../115-libcairo-gobject2_1.16.0-5ubuntu2_arm64.deb ... Unpacking libcairo-gobject2:arm64 (1.16.0-5ubuntu2) ... Selecting previously unselected package liblcms2-2:arm64. Preparing to unpack .../116-liblcms2-2_2.12~rc1-2build2_arm64.deb ... Unpacking liblcms2-2:arm64 (2.12~rc1-2build2) ... Selecting previously unselected package libcolord2:arm64. Preparing to unpack .../117-libcolord2_1.4.6-1_arm64.deb ... Unpacking libcolord2:arm64 (1.4.6-1) ... Selecting previously unselected package libepoxy0:arm64. Preparing to unpack .../118-libepoxy0_1.5.10-1_arm64.deb ... Unpacking libepoxy0:arm64 (1.5.10-1) ... Selecting previously unselected package libwayland-cursor0:arm64. Preparing to unpack .../119-libwayland-cursor0_1.20.0-1ubuntu0.1_arm64.deb ... Unpacking libwayland-cursor0:arm64 (1.20.0-1ubuntu0.1) ... Selecting previously unselected package libwayland-egl1:arm64. Preparing to unpack .../120-libwayland-egl1_1.20.0-1ubuntu0.1_arm64.deb ... Unpacking libwayland-egl1:arm64 (1.20.0-1ubuntu0.1) ... Selecting previously unselected package libgtk-3-common. Preparing to unpack .../121-libgtk-3-common_3.24.33-1ubuntu2_all.deb ... Unpacking libgtk-3-common (3.24.33-1ubuntu2) ... Selecting previously unselected package libgtk-3-0:arm64. Preparing to unpack .../122-libgtk-3-0_3.24.33-1ubuntu2_arm64.deb ... Unpacking libgtk-3-0:arm64 (3.24.33-1ubuntu2) ... Selecting previously unselected package libpciaccess0:arm64. Preparing to unpack .../123-libpciaccess0_0.16-3_arm64.deb ... Unpacking libpciaccess0:arm64 (0.16-3) ... Selecting previously unselected package spice-vdagent. Preparing to unpack .../124-spice-vdagent_0.22.1-1_arm64.deb ... Unpacking spice-vdagent (0.22.1-1) ... Selecting previously unselected package python3-xkit. Preparing to unpack .../125-python3-xkit_0.5.0ubuntu5_all.deb ... Unpacking python3-xkit (0.5.0ubuntu5) ... Selecting previously unselected package python3-colorama. Preparing to unpack .../126-python3-colorama_0.4.4-1_all.deb ... Unpacking python3-colorama (0.4.4-1) ... Selecting previously unselected package python3-click. Preparing to unpack .../127-python3-click_8.0.3-1_all.deb ... Unpacking python3-click (8.0.3-1) ... Selecting previously unselected package ubuntu-drivers-common. Preparing to unpack .../128-ubuntu-drivers-common_1%3a0.9.6.1_arm64.deb ... Unpacking ubuntu-drivers-common (1:0.9.6.1) ... Selecting previously unselected package python3-chardet. Preparing to unpack .../129-python3-chardet_4.0.0-1_all.deb ... Unpacking python3-chardet (4.0.0-1) ... Selecting previously unselected package python3-debian. Preparing to unpack .../130-python3-debian_0.1.43ubuntu1_all.deb ... Unpacking python3-debian (0.1.43ubuntu1) ... Selecting previously unselected package python3-debconf. Preparing to unpack .../131-python3-debconf_1.5.79ubuntu1_all.deb ... Unpacking python3-debconf (1.5.79ubuntu1) ... Selecting previously unselected package python3-distupgrade. Preparing to unpack .../132-python3-distupgrade_1%3a22.04.16_all.deb ... Unpacking python3-distupgrade (1:22.04.16) ... Selecting previously unselected package python3-update-manager. Preparing to unpack .../133-python3-update-manager_1%3a22.04.10_all.deb ... Unpacking python3-update-manager (1:22.04.10) ... Selecting previously unselected package ubuntu-release-upgrader-core. Preparing to unpack .../134-ubuntu-release-upgrader-core_1%3a22.04.16_all.deb ... Unpacking ubuntu-release-upgrader-core (1:22.04.16) ... Selecting previously unselected package distro-info. Preparing to unpack .../135-distro-info_1.1build1_arm64.deb ... Unpacking distro-info (1.1build1) ... Selecting previously unselected package ubuntu-advantage-tools. Preparing to unpack .../136-ubuntu-advantage-tools_27.13.6~22.04.1_arm64.deb ... Unpacking ubuntu-advantage-tools (27.13.6~22.04.1) ... Selecting previously unselected package update-manager-core. Preparing to unpack .../137-update-manager-core_1%3a22.04.10_all.deb ... Unpacking update-manager-core (1:22.04.10) ... Selecting previously unselected package update-notifier-common. Preparing to unpack .../138-update-notifier-common_3.192.54.5_all.deb ... Unpacking update-notifier-common (3.192.54.5) ... Selecting previously unselected package libtext-iconv-perl. Preparing to unpack .../139-libtext-iconv-perl_1.7-7build3_arm64.deb ... Unpacking libtext-iconv-perl (1.7-7build3) ... Selecting previously unselected package xxd. Preparing to unpack .../140-xxd_2%3a8.2.3995-1ubuntu2.3_arm64.deb ... Unpacking xxd (2:8.2.3995-1ubuntu2.3) ... Selecting previously unselected package vim-common. Preparing to unpack .../141-vim-common_2%3a8.2.3995-1ubuntu2.3_all.deb ... Unpacking vim-common (2:8.2.3995-1ubuntu2.3) ... Selecting previously unselected package xdg-user-dirs. Preparing to unpack .../142-xdg-user-dirs_0.17-2ubuntu4_arm64.deb ... Unpacking xdg-user-dirs (0.17-2ubuntu4) ... Selecting previously unselected package dmidecode. Preparing to unpack .../143-dmidecode_3.3-3ubuntu0.1_arm64.deb ... Unpacking dmidecode (3.3-3ubuntu0.1) ... Selecting previously unselected package libnuma1:arm64. Preparing to unpack .../144-libnuma1_2.0.14-3ubuntu2_arm64.deb ... Unpacking libnuma1:arm64 (2.0.14-3ubuntu2) ... Selecting previously unselected package libxmuu1:arm64. Preparing to unpack .../145-libxmuu1_2%3a1.1.3-3_arm64.deb ... Unpacking libxmuu1:arm64 (2:1.1.3-3) ... Selecting previously unselected package usb.ids. Preparing to unpack .../146-usb.ids_2022.04.02-1_all.deb ... Unpacking usb.ids (2022.04.02-1) ... Selecting previously unselected package acl. Preparing to unpack .../147-acl_2.3.1-1_arm64.deb ... Unpacking acl (2.3.1-1) ... Selecting previously unselected package anacron. Preparing to unpack .../148-anacron_2.3-31ubuntu2_arm64.deb ... Unpacking anacron (2.3-31ubuntu2) ... Selecting previously unselected package python3-xapian. Preparing to unpack .../149-python3-xapian_1.4.18-2build3_arm64.deb ... Unpacking python3-xapian (1.4.18-2build3) ... Selecting previously unselected package apt-xapian-index. Preparing to unpack .../150-apt-xapian-index_0.51ubuntu1_all.deb ... Unpacking apt-xapian-index (0.51ubuntu1) ... Selecting previously unselected package at-spi2-core. Preparing to unpack .../151-at-spi2-core_2.44.0-3_arm64.deb ... Unpacking at-spi2-core (2.44.0-3) ... Selecting previously unselected package gir1.2-atk-1.0:arm64. Preparing to unpack .../152-gir1.2-atk-1.0_2.36.0-3build1_arm64.deb ... Unpacking gir1.2-atk-1.0:arm64 (2.36.0-3build1) ... Selecting previously unselected package gir1.2-freedesktop:arm64. Preparing to unpack .../153-gir1.2-freedesktop_1.72.0-1_arm64.deb ... Unpacking gir1.2-freedesktop:arm64 (1.72.0-1) ... Selecting previously unselected package gir1.2-gdkpixbuf-2.0:arm64. Preparing to unpack .../154-gir1.2-gdkpixbuf-2.0_2.42.8+dfsg-1ubuntu0.2_arm64.deb ... Unpacking gir1.2-gdkpixbuf-2.0:arm64 (2.42.8+dfsg-1ubuntu0.2) ... Selecting previously unselected package gir1.2-harfbuzz-0.0:arm64. Preparing to unpack .../155-gir1.2-harfbuzz-0.0_2.7.4-1ubuntu3.1_arm64.deb ... Unpacking gir1.2-harfbuzz-0.0:arm64 (2.7.4-1ubuntu3.1) ... Selecting previously unselected package libxft2:arm64. Preparing to unpack .../156-libxft2_2.3.4-1_arm64.deb ... Unpacking libxft2:arm64 (2.3.4-1) ... Selecting previously unselected package libpangoxft-1.0-0:arm64. Preparing to unpack .../157-libpangoxft-1.0-0_1.50.6+ds-2ubuntu1_arm64.deb ... Unpacking libpangoxft-1.0-0:arm64 (1.50.6+ds-2ubuntu1) ... Selecting previously unselected package gir1.2-pango-1.0:arm64. Preparing to unpack .../158-gir1.2-pango-1.0_1.50.6+ds-2ubuntu1_arm64.deb ... Unpacking gir1.2-pango-1.0:arm64 (1.50.6+ds-2ubuntu1) ... Selecting previously unselected package gir1.2-gtk-3.0:arm64. Preparing to unpack .../159-gir1.2-gtk-3.0_3.24.33-1ubuntu2_arm64.deb ... Unpacking gir1.2-gtk-3.0:arm64 (3.24.33-1ubuntu2) ... Selecting previously unselected package libnotify4:arm64. Preparing to unpack .../160-libnotify4_0.7.9-3ubuntu5.22.04.1_arm64.deb ... Unpacking libnotify4:arm64 (0.7.9-3ubuntu5.22.04.1) ... Selecting previously unselected package gir1.2-notify-0.7:arm64. Preparing to unpack .../161-gir1.2-notify-0.7_0.7.9-3ubuntu5.22.04.1_arm64.deb ... Unpacking gir1.2-notify-0.7:arm64 (0.7.9-3ubuntu5.22.04.1) ... Selecting previously unselected package python3-certifi. Preparing to unpack .../162-python3-certifi_2020.6.20-1_all.deb ... Unpacking python3-certifi (2020.6.20-1) ... Selecting previously unselected package python3-idna. Preparing to unpack .../163-python3-idna_3.3-1_all.deb ... Unpacking python3-idna (3.3-1) ... Selecting previously unselected package python3-urllib3. Preparing to unpack .../164-python3-urllib3_1.26.5-1~exp1_all.deb ... Unpacking python3-urllib3 (1.26.5-1~exp1) ... Selecting previously unselected package python3-requests. Preparing to unpack .../165-python3-requests_2.25.1+dfsg-2_all.deb ... Unpacking python3-requests (2.25.1+dfsg-2) ... Selecting previously unselected package bleachbit. Preparing to unpack .../166-bleachbit_4.4.2-1_all.deb ... Unpacking bleachbit (4.4.2-1) ... Selecting previously unselected package bluez. Preparing to unpack .../167-bluez_5.64-0ubuntu1_arm64.deb ... Unpacking bluez (5.64-0ubuntu1) ... Selecting previously unselected package libical3:arm64. Preparing to unpack .../168-libical3_3.0.14-1build1_arm64.deb ... Unpacking libical3:arm64 (3.0.14-1build1) ... Selecting previously unselected package bluez-obexd. Preparing to unpack .../169-bluez-obexd_5.64-0ubuntu1_arm64.deb ... Unpacking bluez-obexd (5.64-0ubuntu1) ... Selecting previously unselected package libcamel-1.2-63:arm64. Preparing to unpack .../170-libcamel-1.2-63_3.44.4-0ubuntu1_arm64.deb ... Unpacking libcamel-1.2-63:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libvorbisfile3:arm64. Preparing to unpack .../171-libvorbisfile3_1.3.7-1build2_arm64.deb ... Unpacking libvorbisfile3:arm64 (1.3.7-1build2) ... Selecting previously unselected package sound-theme-freedesktop. Preparing to unpack .../172-sound-theme-freedesktop_0.8-2ubuntu1_all.deb ... Unpacking sound-theme-freedesktop (0.8-2ubuntu1) ... Selecting previously unselected package libcanberra0:arm64. Preparing to unpack .../173-libcanberra0_0.30-10ubuntu1_arm64.deb ... Unpacking libcanberra0:arm64 (0.30-10ubuntu1) ... Selecting previously unselected package libcanberra-gtk3-0:arm64. Preparing to unpack .../174-libcanberra-gtk3-0_0.30-10ubuntu1_arm64.deb ... Unpacking libcanberra-gtk3-0:arm64 (0.30-10ubuntu1) ... Selecting previously unselected package libgck-1-0:arm64. Preparing to unpack .../175-libgck-1-0_3.40.0-4_arm64.deb ... Unpacking libgck-1-0:arm64 (3.40.0-4) ... Selecting previously unselected package libgcr-base-3-1:arm64. Preparing to unpack .../176-libgcr-base-3-1_3.40.0-4_arm64.deb ... Unpacking libgcr-base-3-1:arm64 (3.40.0-4) ... Selecting previously unselected package libgoa-1.0-common. Preparing to unpack .../177-libgoa-1.0-common_3.44.0-1ubuntu1_all.deb ... Unpacking libgoa-1.0-common (3.44.0-1ubuntu1) ... Selecting previously unselected package libgoa-1.0-0b:arm64. Preparing to unpack .../178-libgoa-1.0-0b_3.44.0-1ubuntu1_arm64.deb ... Unpacking libgoa-1.0-0b:arm64 (3.44.0-1ubuntu1) ... Selecting previously unselected package libgdata-common. Preparing to unpack .../179-libgdata-common_0.18.1-2build1_all.deb ... Unpacking libgdata-common (0.18.1-2build1) ... Selecting previously unselected package libgdata22:arm64. Preparing to unpack .../180-libgdata22_0.18.1-2build1_arm64.deb ... Unpacking libgdata22:arm64 (0.18.1-2build1) ... Selecting previously unselected package libsecret-common. Preparing to unpack .../181-libsecret-common_0.20.5-2_all.deb ... Unpacking libsecret-common (0.20.5-2) ... Selecting previously unselected package libsecret-1-0:arm64. Preparing to unpack .../182-libsecret-1-0_0.20.5-2_arm64.deb ... Unpacking libsecret-1-0:arm64 (0.20.5-2) ... Selecting previously unselected package evolution-data-server-common. Preparing to unpack .../183-evolution-data-server-common_3.44.4-0ubuntu1_all.deb ... Unpacking evolution-data-server-common (3.44.4-0ubuntu1) ... Selecting previously unselected package libedataserver-1.2-26:arm64. Preparing to unpack .../184-libedataserver-1.2-26_3.44.4-0ubuntu1_arm64.deb ... Unpacking libedataserver-1.2-26:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libebackend-1.2-10:arm64. Preparing to unpack .../185-libebackend-1.2-10_3.44.4-0ubuntu1_arm64.deb ... Unpacking libebackend-1.2-10:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libabsl20210324:arm64. Preparing to unpack .../186-libabsl20210324_0~20210324.2-2_arm64.deb ... Unpacking libabsl20210324:arm64 (0~20210324.2-2) ... Selecting previously unselected package libprotobuf23:arm64. Preparing to unpack .../187-libprotobuf23_3.12.4-1ubuntu7.22.04.1_arm64.deb ... Unpacking libprotobuf23:arm64 (3.12.4-1ubuntu7.22.04.1) ... Selecting previously unselected package libphonenumber8:arm64. Preparing to unpack .../188-libphonenumber8_8.12.44-1_arm64.deb ... Unpacking libphonenumber8:arm64 (8.12.44-1) ... Selecting previously unselected package libebook-contacts-1.2-3:arm64. Preparing to unpack .../189-libebook-contacts-1.2-3_3.44.4-0ubuntu1_arm64.deb ... Unpacking libebook-contacts-1.2-3:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libedata-book-1.2-26:arm64. Preparing to unpack .../190-libedata-book-1.2-26_3.44.4-0ubuntu1_arm64.deb ... Unpacking libedata-book-1.2-26:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libebook-1.2-20:arm64. Preparing to unpack .../191-libebook-1.2-20_3.44.4-0ubuntu1_arm64.deb ... Unpacking libebook-1.2-20:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libecal-2.0-1:arm64. Preparing to unpack .../192-libecal-2.0-1_3.44.4-0ubuntu1_arm64.deb ... Unpacking libecal-2.0-1:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libedata-cal-2.0-1:arm64. Preparing to unpack .../193-libedata-cal-2.0-1_3.44.4-0ubuntu1_arm64.deb ... Unpacking libedata-cal-2.0-1:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libgcr-ui-3-1:arm64. Preparing to unpack .../194-libgcr-ui-3-1_3.40.0-4_arm64.deb ... Unpacking libgcr-ui-3-1:arm64 (3.40.0-4) ... Selecting previously unselected package libjavascriptcoregtk-4.0-18:arm64. Preparing to unpack .../195-libjavascriptcoregtk-4.0-18_2.38.5-0ubuntu0.22.04.1_arm64.deb ... Unpacking libjavascriptcoregtk-4.0-18:arm64 (2.38.5-0ubuntu0.22.04.1) ... Selecting previously unselected package libcdparanoia0:arm64. Preparing to unpack .../196-libcdparanoia0_3.10.2+debian-14build2_arm64.deb ... Unpacking libcdparanoia0:arm64 (3.10.2+debian-14build2) ... Selecting previously unselected package libtheora0:arm64. Preparing to unpack .../197-libtheora0_1.1.1+dfsg.1-15ubuntu4_arm64.deb ... Unpacking libtheora0:arm64 (1.1.1+dfsg.1-15ubuntu4) ... Selecting previously unselected package libvisual-0.4-0:arm64. Preparing to unpack .../198-libvisual-0.4-0_0.4.0-17build2_arm64.deb ... Unpacking libvisual-0.4-0:arm64 (0.4.0-17build2) ... Selecting previously unselected package gstreamer1.0-plugins-base:arm64. Preparing to unpack .../199-gstreamer1.0-plugins-base_1.20.1-1_arm64.deb ... Unpacking gstreamer1.0-plugins-base:arm64 (1.20.1-1) ... Selecting previously unselected package libaa1:arm64. Preparing to unpack .../200-libaa1_1.4p5-50build1_arm64.deb ... Unpacking libaa1:arm64 (1.4p5-50build1) ... Selecting previously unselected package libraw1394-11:arm64. Preparing to unpack .../201-libraw1394-11_2.1.2-2build2_arm64.deb ... Unpacking libraw1394-11:arm64 (2.1.2-2build2) ... Selecting previously unselected package libavc1394-0:arm64. Preparing to unpack .../202-libavc1394-0_0.5.4-5build2_arm64.deb ... Unpacking libavc1394-0:arm64 (0.5.4-5build2) ... Selecting previously unselected package libdv4:arm64. Preparing to unpack .../203-libdv4_1.0.0-14build1_arm64.deb ... Unpacking libdv4:arm64 (1.0.0-14build1) ... Selecting previously unselected package libgstreamer-plugins-good1.0-0:arm64. Preparing to unpack .../204-libgstreamer-plugins-good1.0-0_1.20.3-0ubuntu1_arm64.deb ... Unpacking libgstreamer-plugins-good1.0-0:arm64 (1.20.3-0ubuntu1) ... Selecting previously unselected package libiec61883-0:arm64. Preparing to unpack .../205-libiec61883-0_1.2.0-4build3_arm64.deb ... Unpacking libiec61883-0:arm64 (1.2.0-4build3) ... Selecting previously unselected package libmp3lame0:arm64. Preparing to unpack .../206-libmp3lame0_3.100-3build2_arm64.deb ... Unpacking libmp3lame0:arm64 (3.100-3build2) ... Selecting previously unselected package libmpg123-0:arm64. Preparing to unpack .../207-libmpg123-0_1.29.3-1build1_arm64.deb ... Unpacking libmpg123-0:arm64 (1.29.3-1build1) ... Selecting previously unselected package libspeex1:arm64. Preparing to unpack .../208-libspeex1_1.2~rc1.2-1.1ubuntu3_arm64.deb ... Unpacking libspeex1:arm64 (1.2~rc1.2-1.1ubuntu3) ... Selecting previously unselected package libshout3:arm64. Preparing to unpack .../209-libshout3_2.4.5-1build3_arm64.deb ... Unpacking libshout3:arm64 (2.4.5-1build3) ... Selecting previously unselected package libtag1v5-vanilla:arm64. Preparing to unpack .../210-libtag1v5-vanilla_1.11.1+dfsg.1-3ubuntu3_arm64.deb ... Unpacking libtag1v5-vanilla:arm64 (1.11.1+dfsg.1-3ubuntu3) ... Selecting previously unselected package libtag1v5:arm64. Preparing to unpack .../211-libtag1v5_1.11.1+dfsg.1-3ubuntu3_arm64.deb ... Unpacking libtag1v5:arm64 (1.11.1+dfsg.1-3ubuntu3) ... Selecting previously unselected package libtwolame0:arm64. Preparing to unpack .../212-libtwolame0_0.4.0-2build2_arm64.deb ... Unpacking libtwolame0:arm64 (0.4.0-2build2) ... Selecting previously unselected package libv4lconvert0:arm64. Preparing to unpack .../213-libv4lconvert0_1.22.1-2build1_arm64.deb ... Unpacking libv4lconvert0:arm64 (1.22.1-2build1) ... Selecting previously unselected package libv4l-0:arm64. Preparing to unpack .../214-libv4l-0_1.22.1-2build1_arm64.deb ... Unpacking libv4l-0:arm64 (1.22.1-2build1) ... Selecting previously unselected package libvpx7:arm64. Preparing to unpack .../215-libvpx7_1.11.0-2ubuntu2_arm64.deb ... Unpacking libvpx7:arm64 (1.11.0-2ubuntu2) ... Selecting previously unselected package libwavpack1:arm64. Preparing to unpack .../216-libwavpack1_5.4.0-1build2_arm64.deb ... Unpacking libwavpack1:arm64 (5.4.0-1build2) ... Selecting previously unselected package gstreamer1.0-plugins-good:arm64. Preparing to unpack .../217-gstreamer1.0-plugins-good_1.20.3-0ubuntu1_arm64.deb ... Unpacking gstreamer1.0-plugins-good:arm64 (1.20.3-0ubuntu1) ... Selecting previously unselected package bubblewrap. Preparing to unpack .../218-bubblewrap_0.6.1-1_arm64.deb ... Unpacking bubblewrap (0.6.1-1) ... Selecting previously unselected package xdg-dbus-proxy. Preparing to unpack .../219-xdg-dbus-proxy_0.1.3-1_arm64.deb ... Unpacking xdg-dbus-proxy (0.1.3-1) ... Selecting previously unselected package emacsen-common. Preparing to unpack .../220-emacsen-common_3.0.4_all.deb ... Unpacking emacsen-common (3.0.4) ... Selecting previously unselected package dictionaries-common. Preparing to unpack .../221-dictionaries-common_1.28.14_all.deb ... Adding 'diversion of /usr/share/dict/words to /usr/share/dict/words.pre-dictionaries-common by dictionaries-common' Unpacking dictionaries-common (1.28.14) ... Selecting previously unselected package hunspell-en-us. Preparing to unpack .../222-hunspell-en-us_1%3a2020.12.07-2_all.deb ... Unpacking hunspell-en-us (1:2020.12.07-2) ... Selecting previously unselected package libaspell15:arm64. Preparing to unpack .../223-libaspell15_0.60.8-4build1_arm64.deb ... Unpacking libaspell15:arm64 (0.60.8-4build1) ... Selecting previously unselected package libhunspell-1.7-0:arm64. Preparing to unpack .../224-libhunspell-1.7-0_1.7.0-4build1_arm64.deb ... Unpacking libhunspell-1.7-0:arm64 (1.7.0-4build1) ... Selecting previously unselected package libenchant-2-2:arm64. Preparing to unpack .../225-libenchant-2-2_2.3.2-1ubuntu2_arm64.deb ... Unpacking libenchant-2-2:arm64 (2.3.2-1ubuntu2) ... Selecting previously unselected package libgles2:arm64. Preparing to unpack .../226-libgles2_1.4.0-1_arm64.deb ... Unpacking libgles2:arm64 (1.4.0-1) ... Selecting previously unselected package libgstreamer-gl1.0-0:arm64. Preparing to unpack .../227-libgstreamer-gl1.0-0_1.20.1-1_arm64.deb ... Unpacking libgstreamer-gl1.0-0:arm64 (1.20.1-1) ... Selecting previously unselected package libharfbuzz-icu0:arm64. Preparing to unpack .../228-libharfbuzz-icu0_2.7.4-1ubuntu3.1_arm64.deb ... Unpacking libharfbuzz-icu0:arm64 (2.7.4-1ubuntu3.1) ... Selecting previously unselected package libhyphen0:arm64. Preparing to unpack .../229-libhyphen0_2.8.8-7build2_arm64.deb ... Unpacking libhyphen0:arm64 (2.8.8-7build2) ... Selecting previously unselected package libmanette-0.2-0:arm64. Preparing to unpack .../230-libmanette-0.2-0_0.2.6-3build1_arm64.deb ... Unpacking libmanette-0.2-0:arm64 (0.2.6-3build1) ... Selecting previously unselected package libopenjp2-7:arm64. Preparing to unpack .../231-libopenjp2-7_2.4.0-6_arm64.deb ... Unpacking libopenjp2-7:arm64 (2.4.0-6) ... Selecting previously unselected package libwebpdemux2:arm64. Preparing to unpack .../232-libwebpdemux2_1.2.2-2_arm64.deb ... Unpacking libwebpdemux2:arm64 (1.2.2-2) ... Selecting previously unselected package libwoff1:arm64. Preparing to unpack .../233-libwoff1_1.0.2-1build4_arm64.deb ... Unpacking libwoff1:arm64 (1.0.2-1build4) ... Selecting previously unselected package libxslt1.1:arm64. Preparing to unpack .../234-libxslt1.1_1.1.34-4ubuntu0.22.04.1_arm64.deb ... Unpacking libxslt1.1:arm64 (1.1.34-4ubuntu0.22.04.1) ... Selecting previously unselected package libwebkit2gtk-4.0-37:arm64. Preparing to unpack .../235-libwebkit2gtk-4.0-37_2.38.5-0ubuntu0.22.04.1_arm64.deb ... Unpacking libwebkit2gtk-4.0-37:arm64 (2.38.5-0ubuntu0.22.04.1) ... Selecting previously unselected package libedataserverui-1.2-3:arm64. Preparing to unpack .../236-libedataserverui-1.2-3_3.44.4-0ubuntu1_arm64.deb ... Unpacking libedataserverui-1.2-3:arm64 (3.44.4-0ubuntu1) ... Selecting previously unselected package libgeocode-glib0:arm64. Preparing to unpack .../237-libgeocode-glib0_3.26.2-2build2_arm64.deb ... Unpacking libgeocode-glib0:arm64 (3.26.2-2build2) ... Selecting previously unselected package libgweather-common. Preparing to unpack .../238-libgweather-common_40.0-5build1_all.deb ... Unpacking libgweather-common (40.0-5build1) ... Selecting previously unselected package libgweather-3-16:arm64. Preparing to unpack .../239-libgweather-3-16_40.0-5build1_arm64.deb ... Unpacking libgweather-3-16:arm64 (40.0-5build1) ... Selecting previously unselected package gcr. Preparing to unpack .../240-gcr_3.40.0-4_arm64.deb ... Unpacking gcr (3.40.0-4) ... Selecting previously unselected package p11-kit-modules:arm64. Preparing to unpack .../241-p11-kit-modules_0.24.0-6build1_arm64.deb ... Unpacking p11-kit-modules:arm64 (0.24.0-6build1) ... Selecting previously unselected package p11-kit. Preparing to unpack .../242-p11-kit_0.24.0-6build1_arm64.deb ... Unpacking p11-kit (0.24.0-6build1) ... Selecting previously unselected package pinentry-gnome3. Preparing to unpack .../243-pinentry-gnome3_1.1.1-1build2_arm64.deb ... Unpacking pinentry-gnome3 (1.1.1-1build2) ... Selecting previously unselected package gnome-keyring. Preparing to unpack .../244-gnome-keyring_40.0-3ubuntu3_arm64.deb ... Unpacking gnome-keyring (40.0-3ubuntu3) ... Selecting previously unselected package evolution-data-server. Preparing to unpack .../245-evolution-data-server_3.44.4-0ubuntu1_arm64.deb ... Unpacking evolution-data-server (3.44.4-0ubuntu1) ... Selecting previously unselected package libaccountsservice0:arm64. Preparing to unpack .../246-libaccountsservice0_22.07.5-2ubuntu1.3_arm64.deb ... Unpacking libaccountsservice0:arm64 (22.07.5-2ubuntu1.3) ... Selecting previously unselected package gir1.2-accountsservice-1.0:arm64. Preparing to unpack .../247-gir1.2-accountsservice-1.0_22.07.5-2ubuntu1.3_arm64.deb ... Unpacking gir1.2-accountsservice-1.0:arm64 (22.07.5-2ubuntu1.3) ... Selecting previously unselected package libgraphene-1.0-0:arm64. Preparing to unpack .../248-libgraphene-1.0-0_1.10.8-1_arm64.deb ... Unpacking libgraphene-1.0-0:arm64 (1.10.8-1) ... Selecting previously unselected package gir1.2-graphene-1.0:arm64. Preparing to unpack .../249-gir1.2-graphene-1.0_1.10.8-1_arm64.deb ... Unpacking gir1.2-graphene-1.0:arm64 (1.10.8-1) ... Selecting previously unselected package libcairo-script-interpreter2:arm64. Preparing to unpack .../250-libcairo-script-interpreter2_1.16.0-5ubuntu2_arm64.deb ... Unpacking libcairo-script-interpreter2:arm64 (1.16.0-5ubuntu2) ... Selecting previously unselected package libgtk-4-common. Preparing to unpack .../251-libgtk-4-common_4.6.6+ds-0ubuntu1_all.deb ... Unpacking libgtk-4-common (4.6.6+ds-0ubuntu1) ... Selecting previously unselected package libgtk-4-1:arm64. Preparing to unpack .../252-libgtk-4-1_4.6.6+ds-0ubuntu1_arm64.deb ... Unpacking libgtk-4-1:arm64 (4.6.6+ds-0ubuntu1) ... Selecting previously unselected package gir1.2-gtk-4.0:arm64. Preparing to unpack .../253-gir1.2-gtk-4.0_4.6.6+ds-0ubuntu1_arm64.deb ... Unpacking gir1.2-gtk-4.0:arm64 (4.6.6+ds-0ubuntu1) ... Selecting previously unselected package libadwaita-1-0:arm64. Preparing to unpack .../254-libadwaita-1-0_1.1.0-1ubuntu2_arm64.deb ... Unpacking libadwaita-1-0:arm64 (1.1.0-1ubuntu2) ... Selecting previously unselected package gir1.2-adw-1:arm64. Preparing to unpack .../255-gir1.2-adw-1_1.1.0-1ubuntu2_arm64.deb ... Unpacking gir1.2-adw-1:arm64 (1.1.0-1ubuntu2) ... Selecting previously unselected package gir1.2-atspi-2.0:arm64. Preparing to unpack .../256-gir1.2-atspi-2.0_2.44.0-3_arm64.deb ... Unpacking gir1.2-atspi-2.0:arm64 (2.44.0-3) ... Selecting previously unselected package gir1.2-gck-1:arm64. Preparing to unpack .../257-gir1.2-gck-1_3.40.0-4_arm64.deb ... Unpacking gir1.2-gck-1:arm64 (3.40.0-4) ... Selecting previously unselected package gir1.2-gcr-3:arm64. Preparing to unpack .../258-gir1.2-gcr-3_3.40.0-4_arm64.deb ... Unpacking gir1.2-gcr-3:arm64 (3.40.0-4) ... Selecting previously unselected package gir1.2-gdesktopenums-3.0:arm64. Preparing to unpack .../259-gir1.2-gdesktopenums-3.0_42.0-1ubuntu1_arm64.deb ... Unpacking gir1.2-gdesktopenums-3.0:arm64 (42.0-1ubuntu1) ... Selecting previously unselected package libgdm1. Preparing to unpack .../260-libgdm1_42.0-1ubuntu7_arm64.deb ... Unpacking libgdm1 (42.0-1ubuntu7) ... Selecting previously unselected package gir1.2-gdm-1.0:arm64. Preparing to unpack .../261-gir1.2-gdm-1.0_42.0-1ubuntu7_arm64.deb ... Unpacking gir1.2-gdm-1.0:arm64 (42.0-1ubuntu7) ... Selecting previously unselected package libavahi-glib1:arm64. Preparing to unpack .../262-libavahi-glib1_0.8-5ubuntu5_arm64.deb ... Unpacking libavahi-glib1:arm64 (0.8-5ubuntu5) ... Selecting previously unselected package geoclue-2.0. Preparing to unpack .../263-geoclue-2.0_2.5.7-3ubuntu3_arm64.deb ... Unpacking geoclue-2.0 (2.5.7-3ubuntu3) ... Selecting previously unselected package libgeoclue-2-0:arm64. Preparing to unpack .../264-libgeoclue-2-0_2.5.7-3ubuntu3_arm64.deb ... Unpacking libgeoclue-2-0:arm64 (2.5.7-3ubuntu3) ... Selecting previously unselected package gir1.2-geoclue-2.0:arm64. Preparing to unpack .../265-gir1.2-geoclue-2.0_2.5.7-3ubuntu3_arm64.deb ... Unpacking gir1.2-geoclue-2.0:arm64 (2.5.7-3ubuntu3) ... Selecting previously unselected package libupower-glib3:arm64. Preparing to unpack .../266-libupower-glib3_0.99.17-1_arm64.deb ... Unpacking libupower-glib3:arm64 (0.99.17-1) ... Selecting previously unselected package gnome-bluetooth-3-common. Preparing to unpack .../267-gnome-bluetooth-3-common_42.0-5_all.deb ... Unpacking gnome-bluetooth-3-common (42.0-5) ... Selecting previously unselected package libgnome-bluetooth-3.0-13:arm64. Preparing to unpack .../268-libgnome-bluetooth-3.0-13_42.0-5_arm64.deb ... Unpacking libgnome-bluetooth-3.0-13:arm64 (42.0-5) ... Selecting previously unselected package gir1.2-gnomebluetooth-3.0:arm64. Preparing to unpack .../269-gir1.2-gnomebluetooth-3.0_42.0-5_arm64.deb ... Unpacking gir1.2-gnomebluetooth-3.0:arm64 (42.0-5) ... Selecting previously unselected package gnome-desktop3-data. Preparing to unpack .../270-gnome-desktop3-data_42.5-0ubuntu1_all.deb ... Unpacking gnome-desktop3-data (42.5-0ubuntu1) ... Selecting previously unselected package libxkbregistry0:arm64. Preparing to unpack .../271-libxkbregistry0_1.4.0-1_arm64.deb ... Unpacking libxkbregistry0:arm64 (1.4.0-1) ... Selecting previously unselected package libgnome-desktop-3-19:arm64. Preparing to unpack .../272-libgnome-desktop-3-19_42.5-0ubuntu1_arm64.deb ... Unpacking libgnome-desktop-3-19:arm64 (42.5-0ubuntu1) ... Selecting previously unselected package gir1.2-gnomedesktop-3.0:arm64. Preparing to unpack .../273-gir1.2-gnomedesktop-3.0_42.5-0ubuntu1_arm64.deb ... Unpacking gir1.2-gnomedesktop-3.0:arm64 (42.5-0ubuntu1) ... Selecting previously unselected package gir1.2-gstreamer-1.0:arm64. Preparing to unpack .../274-gir1.2-gstreamer-1.0_1.20.3-0ubuntu1_arm64.deb ... Unpacking gir1.2-gstreamer-1.0:arm64 (1.20.3-0ubuntu1) ... Selecting previously unselected package gir1.2-gweather-3.0:arm64. Preparing to unpack .../275-gir1.2-gweather-3.0_40.0-5build1_arm64.deb ... Unpacking gir1.2-gweather-3.0:arm64 (40.0-5build1) ... Selecting previously unselected package libibus-1.0-5:arm64. Preparing to unpack .../276-libibus-1.0-5_1.5.26-4_arm64.deb ... Unpacking libibus-1.0-5:arm64 (1.5.26-4) ... Selecting previously unselected package gir1.2-ibus-1.0:arm64. Preparing to unpack .../277-gir1.2-ibus-1.0_1.5.26-4_arm64.deb ... Unpacking gir1.2-ibus-1.0:arm64 (1.5.26-4) ... Selecting previously unselected package mutter-common. Preparing to unpack .../278-mutter-common_42.5-0ubuntu1_all.deb ... Unpacking mutter-common (42.5-0ubuntu1) ... Selecting previously unselected package libspa-0.2-modules:arm64. Preparing to unpack .../279-libspa-0.2-modules_0.3.48-1ubuntu3_arm64.deb ... Unpacking libspa-0.2-modules:arm64 (0.3.48-1ubuntu3) ... Selecting previously unselected package libpipewire-0.3-0:arm64. Preparing to unpack .../280-libpipewire-0.3-0_0.3.48-1ubuntu3_arm64.deb ... Unpacking libpipewire-0.3-0:arm64 (0.3.48-1ubuntu3) ... Selecting previously unselected package libstartup-notification0:arm64. Preparing to unpack .../281-libstartup-notification0_0.12-6build2_arm64.deb ... Unpacking libstartup-notification0:arm64 (0.12-6build2) ... Selecting previously unselected package libxcb-res0:arm64. Preparing to unpack .../282-libxcb-res0_1.14-3ubuntu3_arm64.deb ... Unpacking libxcb-res0:arm64 (1.14-3ubuntu3) ... Selecting previously unselected package libxkbfile1:arm64. Preparing to unpack .../283-libxkbfile1_1%3a1.1.0-1build3_arm64.deb ... Unpacking libxkbfile1:arm64 (1:1.1.0-1build3) ... Selecting previously unselected package libmutter-10-0:arm64. Preparing to unpack .../284-libmutter-10-0_42.5-0ubuntu1_arm64.deb ... Unpacking libmutter-10-0:arm64 (42.5-0ubuntu1) ... Selecting previously unselected package gir1.2-json-1.0:arm64. Preparing to unpack .../285-gir1.2-json-1.0_1.6.6-1build1_arm64.deb ... Unpacking gir1.2-json-1.0:arm64 (1.6.6-1build1) ... Selecting previously unselected package gir1.2-mutter-10:arm64. Preparing to unpack .../286-gir1.2-mutter-10_42.5-0ubuntu1_arm64.deb ... Unpacking gir1.2-mutter-10:arm64 (42.5-0ubuntu1) ... Selecting previously unselected package gir1.2-nm-1.0:arm64. Preparing to unpack .../287-gir1.2-nm-1.0_1.36.6-0ubuntu2_arm64.deb ... Unpacking gir1.2-nm-1.0:arm64 (1.36.6-0ubuntu2) ... Selecting previously unselected package libnma-common. Preparing to unpack .../288-libnma-common_1.8.34-1ubuntu1_all.deb ... Unpacking libnma-common (1.8.34-1ubuntu1) ... Selecting previously unselected package libnma0:arm64. Preparing to unpack .../289-libnma0_1.8.34-1ubuntu1_arm64.deb ... Unpacking libnma0:arm64 (1.8.34-1ubuntu1) ... Selecting previously unselected package gir1.2-nma-1.0:arm64. Preparing to unpack .../290-gir1.2-nma-1.0_1.8.34-1ubuntu1_arm64.deb ... Unpacking gir1.2-nma-1.0:arm64 (1.8.34-1ubuntu1) ... Selecting previously unselected package gir1.2-polkit-1.0. Preparing to unpack .../291-gir1.2-polkit-1.0_0.105-33_arm64.deb ... Unpacking gir1.2-polkit-1.0 (0.105-33) ... Selecting previously unselected package librsvg2-2:arm64. Preparing to unpack .../292-librsvg2-2_2.52.5+dfsg-3_arm64.deb ... Unpacking librsvg2-2:arm64 (2.52.5+dfsg-3) ... Selecting previously unselected package gir1.2-rsvg-2.0:arm64. Preparing to unpack .../293-gir1.2-rsvg-2.0_2.52.5+dfsg-3_arm64.deb ... Unpacking gir1.2-rsvg-2.0:arm64 (2.52.5+dfsg-3) ... Selecting previously unselected package libsoup-gnome2.4-1:arm64. Preparing to unpack .../294-libsoup-gnome2.4-1_2.74.2-3_arm64.deb ... Unpacking libsoup-gnome2.4-1:arm64 (2.74.2-3) ... Selecting previously unselected package gir1.2-soup-2.4:arm64. Preparing to unpack .../295-gir1.2-soup-2.4_2.74.2-3_arm64.deb ... Unpacking gir1.2-soup-2.4:arm64 (2.74.2-3) ... Selecting previously unselected package gir1.2-upowerglib-1.0:arm64. Preparing to unpack .../296-gir1.2-upowerglib-1.0_0.99.17-1_arm64.deb ... Unpacking gir1.2-upowerglib-1.0:arm64 (0.99.17-1) ... Selecting previously unselected package gir1.2-javascriptcoregtk-4.0:arm64. Preparing to unpack .../297-gir1.2-javascriptcoregtk-4.0_2.38.5-0ubuntu0.22.04.1_arm64.deb ... Unpacking gir1.2-javascriptcoregtk-4.0:arm64 (2.38.5-0ubuntu0.22.04.1) ... Selecting previously unselected package gir1.2-webkit2-4.0:arm64. Preparing to unpack .../298-gir1.2-webkit2-4.0_2.38.5-0ubuntu0.22.04.1_arm64.deb ... Unpacking gir1.2-webkit2-4.0:arm64 (2.38.5-0ubuntu0.22.04.1) ... Selecting previously unselected package gnome-settings-daemon-common. Preparing to unpack .../299-gnome-settings-daemon-common_42.1-1ubuntu2.1_all.deb ... Unpacking gnome-settings-daemon-common (42.1-1ubuntu2.1) ... Selecting previously unselected package libpulse-mainloop-glib0:arm64. Preparing to unpack .../300-libpulse-mainloop-glib0_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking libpulse-mainloop-glib0:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package gnome-settings-daemon. Preparing to unpack .../301-gnome-settings-daemon_42.1-1ubuntu2.1_arm64.deb ... Unpacking gnome-settings-daemon (42.1-1ubuntu2.1) ... Selecting previously unselected package gnome-shell-common. Preparing to unpack .../302-gnome-shell-common_42.5-0ubuntu1_all.deb ... Unpacking gnome-shell-common (42.5-0ubuntu1) ... Selecting previously unselected package libpipewire-0.3-modules:arm64. Preparing to unpack .../303-libpipewire-0.3-modules_0.3.48-1ubuntu3_arm64.deb ... Unpacking libpipewire-0.3-modules:arm64 (0.3.48-1ubuntu3) ... Selecting previously unselected package pipewire-bin. Preparing to unpack .../304-pipewire-bin_0.3.48-1ubuntu3_arm64.deb ... Unpacking pipewire-bin (0.3.48-1ubuntu3) ... Selecting previously unselected package pipewire:arm64. Preparing to unpack .../305-pipewire_0.3.48-1ubuntu3_arm64.deb ... Unpacking pipewire:arm64 (0.3.48-1ubuntu3) ... Selecting previously unselected package gstreamer1.0-pipewire:arm64. Preparing to unpack .../306-gstreamer1.0-pipewire_0.3.48-1ubuntu3_arm64.deb ... Unpacking gstreamer1.0-pipewire:arm64 (0.3.48-1ubuntu3) ... Selecting previously unselected package ubuntu-wallpapers-jammy. Preparing to unpack .../307-ubuntu-wallpapers-jammy_22.04.4-0ubuntu1_all.deb ... Unpacking ubuntu-wallpapers-jammy (22.04.4-0ubuntu1) ... Selecting previously unselected package ubuntu-wallpapers. Preparing to unpack .../308-ubuntu-wallpapers_22.04.4-0ubuntu1_all.deb ... Unpacking ubuntu-wallpapers (22.04.4-0ubuntu1) ... Selecting previously unselected package libmozjs-91-0:arm64. Preparing to unpack .../309-libmozjs-91-0_91.10.0-0ubuntu1_arm64.deb ... Unpacking libmozjs-91-0:arm64 (91.10.0-0ubuntu1) ... Selecting previously unselected package libgjs0g:arm64. Preparing to unpack .../310-libgjs0g_1.72.2-0ubuntu1_arm64.deb ... Unpacking libgjs0g:arm64 (1.72.2-0ubuntu1) ... Selecting previously unselected package libgnome-autoar-0-0:arm64. Preparing to unpack .../311-libgnome-autoar-0-0_0.4.3-1_arm64.deb ... Unpacking libgnome-autoar-0-0:arm64 (0.4.3-1) ... Selecting previously unselected package gnome-shell. Preparing to unpack .../312-gnome-shell_42.5-0ubuntu1_arm64.deb ... Unpacking gnome-shell (42.5-0ubuntu1) ... Selecting previously unselected package libxfce4util-common. Preparing to unpack .../313-libxfce4util-common_4.16.0-1_all.deb ... Unpacking libxfce4util-common (4.16.0-1) ... Selecting previously unselected package libxfce4util7:arm64. Preparing to unpack .../314-libxfce4util7_4.16.0-1_arm64.deb ... Unpacking libxfce4util7:arm64 (4.16.0-1) ... Selecting previously unselected package libxfce4panel-2.0-4. Preparing to unpack .../315-libxfce4panel-2.0-4_4.16.3-1_arm64.deb ... Unpacking libxfce4panel-2.0-4 (4.16.3-1) ... Selecting previously unselected package libxfce4ui-common. Preparing to unpack .../316-libxfce4ui-common_4.16.1-1_all.deb ... Unpacking libxfce4ui-common (4.16.1-1) ... Selecting previously unselected package xfconf. Preparing to unpack .../317-xfconf_4.16.0-2_arm64.deb ... Unpacking xfconf (4.16.0-2) ... Selecting previously unselected package libxfconf-0-3:arm64. Preparing to unpack .../318-libxfconf-0-3_4.16.0-2_arm64.deb ... Unpacking libxfconf-0-3:arm64 (4.16.0-2) ... Selecting previously unselected package libxfce4ui-2-0:arm64. Preparing to unpack .../319-libxfce4ui-2-0_4.16.1-1_arm64.deb ... Unpacking libxfce4ui-2-0:arm64 (4.16.1-1) ... Selecting previously unselected package xfce4-notifyd. Preparing to unpack .../320-xfce4-notifyd_0.6.3-1_arm64.deb ... Unpacking xfce4-notifyd (0.6.3-1) ... Selecting previously unselected package librsvg2-common:arm64. Preparing to unpack .../321-librsvg2-common_2.52.5+dfsg-3_arm64.deb ... Unpacking librsvg2-common:arm64 (2.52.5+dfsg-3) ... Selecting previously unselected package gnome-icon-theme. Preparing to unpack .../322-gnome-icon-theme_3.12.0-4_all.deb ... Unpacking gnome-icon-theme (3.12.0-4) ... Selecting previously unselected package python3-cairo:arm64. Preparing to unpack .../323-python3-cairo_1.20.1-3build1_arm64.deb ... Unpacking python3-cairo:arm64 (1.20.1-3build1) ... Selecting previously unselected package python3-gi-cairo. Preparing to unpack .../324-python3-gi-cairo_3.42.1-0ubuntu1_arm64.deb ... Unpacking python3-gi-cairo (3.42.1-0ubuntu1) ... Selecting previously unselected package libayatana-ido3-0.4-0:arm64. Preparing to unpack .../325-libayatana-ido3-0.4-0_0.9.1-1_arm64.deb ... Unpacking libayatana-ido3-0.4-0:arm64 (0.9.1-1) ... Selecting previously unselected package libayatana-indicator3-7:arm64. Preparing to unpack .../326-libayatana-indicator3-7_0.9.1-1_arm64.deb ... Unpacking libayatana-indicator3-7:arm64 (0.9.1-1) ... Selecting previously unselected package libdbusmenu-glib4:arm64. Preparing to unpack .../327-libdbusmenu-glib4_16.04.1+18.10.20180917-0ubuntu8_arm64.deb ... Unpacking libdbusmenu-glib4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Selecting previously unselected package libdbusmenu-gtk3-4:arm64. Preparing to unpack .../328-libdbusmenu-gtk3-4_16.04.1+18.10.20180917-0ubuntu8_arm64.deb ... Unpacking libdbusmenu-gtk3-4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Selecting previously unselected package libayatana-appindicator3-1. Preparing to unpack .../329-libayatana-appindicator3-1_0.5.90-7ubuntu2_arm64.deb ... Unpacking libayatana-appindicator3-1 (0.5.90-7ubuntu2) ... Selecting previously unselected package gir1.2-ayatanaappindicator3-0.1. Preparing to unpack .../330-gir1.2-ayatanaappindicator3-0.1_0.5.90-7ubuntu2_arm64.deb ... Unpacking gir1.2-ayatanaappindicator3-0.1 (0.5.90-7ubuntu2) ... Selecting previously unselected package blueman. Preparing to unpack .../331-blueman_2.2.4-1_arm64.deb ... Unpacking blueman (2.2.4-1) ... Selecting previously unselected package cups-common. Preparing to unpack .../332-cups-common_2.4.1op1-1ubuntu4.1_all.deb ... Unpacking cups-common (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package cups-client. Preparing to unpack .../333-cups-client_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-client (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package cups-ipp-utils. Preparing to unpack .../334-cups-ipp-utils_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-ipp-utils (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package libpoppler118:arm64. Preparing to unpack .../335-libpoppler118_22.02.0-2ubuntu0.1_arm64.deb ... Unpacking libpoppler118:arm64 (22.02.0-2ubuntu0.1) ... Selecting previously unselected package poppler-utils. Preparing to unpack .../336-poppler-utils_22.02.0-2ubuntu0.1_arm64.deb ... Unpacking poppler-utils (22.02.0-2ubuntu0.1) ... Selecting previously unselected package libcupsfilters1:arm64. Preparing to unpack .../337-libcupsfilters1_1.28.15-0ubuntu1_arm64.deb ... Unpacking libcupsfilters1:arm64 (1.28.15-0ubuntu1) ... Selecting previously unselected package libpoppler-cpp0v5:arm64. Preparing to unpack .../338-libpoppler-cpp0v5_22.02.0-2ubuntu0.1_arm64.deb ... Unpacking libpoppler-cpp0v5:arm64 (22.02.0-2ubuntu0.1) ... Selecting previously unselected package libqpdf28:arm64. Preparing to unpack .../339-libqpdf28_10.6.3-1_arm64.deb ... Unpacking libqpdf28:arm64 (10.6.3-1) ... Selecting previously unselected package cups-filters-core-drivers. Preparing to unpack .../340-cups-filters-core-drivers_1.28.15-0ubuntu1_arm64.deb ... Unpacking cups-filters-core-drivers (1.28.15-0ubuntu1) ... Selecting previously unselected package cups-core-drivers. Preparing to unpack .../341-cups-core-drivers_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-core-drivers (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package fonts-urw-base35. Preparing to unpack .../342-fonts-urw-base35_20200910-1_all.deb ... Unpacking fonts-urw-base35 (20200910-1) ... Selecting previously unselected package libgs9-common. Preparing to unpack .../343-libgs9-common_9.55.0~dfsg1-0ubuntu5.1_all.deb ... Unpacking libgs9-common (9.55.0~dfsg1-0ubuntu5.1) ... Selecting previously unselected package libidn12:arm64. Preparing to unpack .../344-libidn12_1.38-4build1_arm64.deb ... Unpacking libidn12:arm64 (1.38-4build1) ... Selecting previously unselected package libijs-0.35:arm64. Preparing to unpack .../345-libijs-0.35_0.35-15build2_arm64.deb ... Unpacking libijs-0.35:arm64 (0.35-15build2) ... Selecting previously unselected package libjbig2dec0:arm64. Preparing to unpack .../346-libjbig2dec0_0.19-3build2_arm64.deb ... Unpacking libjbig2dec0:arm64 (0.19-3build2) ... Selecting previously unselected package libgs9:arm64. Preparing to unpack .../347-libgs9_9.55.0~dfsg1-0ubuntu5.1_arm64.deb ... Unpacking libgs9:arm64 (9.55.0~dfsg1-0ubuntu5.1) ... Selecting previously unselected package ghostscript. Preparing to unpack .../348-ghostscript_9.55.0~dfsg1-0ubuntu5.1_arm64.deb ... Unpacking ghostscript (9.55.0~dfsg1-0ubuntu5.1) ... Selecting previously unselected package libfontembed1:arm64. Preparing to unpack .../349-libfontembed1_1.28.15-0ubuntu1_arm64.deb ... Unpacking libfontembed1:arm64 (1.28.15-0ubuntu1) ... Selecting previously unselected package cups-filters. Preparing to unpack .../350-cups-filters_1.28.15-0ubuntu1_arm64.deb ... Unpacking cups-filters (1.28.15-0ubuntu1) ... Selecting previously unselected package cups-ppdc. Preparing to unpack .../351-cups-ppdc_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-ppdc (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package cups-server-common. Preparing to unpack .../352-cups-server-common_2.4.1op1-1ubuntu4.1_all.deb ... Unpacking cups-server-common (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package cups. Preparing to unpack .../353-cups_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package bluez-cups. Preparing to unpack .../354-bluez-cups_5.64-0ubuntu1_arm64.deb ... Unpacking bluez-cups (5.64-0ubuntu1) ... Selecting previously unselected package bluez-tools. Preparing to unpack .../355-bluez-tools_2.0~20170911.0.7cb788c-4_arm64.deb ... Unpacking bluez-tools (2.0~20170911.0.7cb788c-4) ... Selecting previously unselected package cifs-utils. Preparing to unpack .../356-cifs-utils_2%3a6.14-1ubuntu0.1_arm64.deb ... Unpacking cifs-utils (2:6.14-1ubuntu0.1) ... Selecting previously unselected package libllvm14:arm64. Preparing to unpack .../357-libllvm14_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking libllvm14:arm64 (1:14.0.0-1ubuntu1) ... Selecting previously unselected package libclang-cpp14. Preparing to unpack .../358-libclang-cpp14_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking libclang-cpp14 (1:14.0.0-1ubuntu1) ... Selecting previously unselected package libgc1:arm64. Preparing to unpack .../359-libgc1_1%3a8.0.6-1.1build1_arm64.deb ... Unpacking libgc1:arm64 (1:8.0.6-1.1build1) ... Selecting previously unselected package libobjc4:arm64. Preparing to unpack .../360-libobjc4_12.1.0-2ubuntu1~22.04_arm64.deb ... Unpacking libobjc4:arm64 (12.1.0-2ubuntu1~22.04) ... Selecting previously unselected package libobjc-11-dev:arm64. Preparing to unpack .../361-libobjc-11-dev_11.3.0-1ubuntu1~22.04_arm64.deb ... Unpacking libobjc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Selecting previously unselected package libclang-common-14-dev. Preparing to unpack .../362-libclang-common-14-dev_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking libclang-common-14-dev (1:14.0.0-1ubuntu1) ... Selecting previously unselected package llvm-14-linker-tools. Preparing to unpack .../363-llvm-14-linker-tools_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking llvm-14-linker-tools (1:14.0.0-1ubuntu1) ... Selecting previously unselected package libclang1-14. Preparing to unpack .../364-libclang1-14_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking libclang1-14 (1:14.0.0-1ubuntu1) ... Selecting previously unselected package clang-14. Preparing to unpack .../365-clang-14_1%3a14.0.0-1ubuntu1_arm64.deb ... Unpacking clang-14 (1:14.0.0-1ubuntu1) ... Selecting previously unselected package clang. Preparing to unpack .../366-clang_1%3a14.0-55~exp2_arm64.deb ... Unpacking clang (1:14.0-55~exp2) ... Selecting previously unselected package codium. Preparing to unpack .../367-codium_1.75.1.23040_arm64.deb ... Unpacking codium (1.75.1.23040) ... Selecting previously unselected package colord-data. Preparing to unpack .../368-colord-data_1.4.6-1_all.deb ... Unpacking colord-data (1.4.6-1) ... Selecting previously unselected package libgusb2:arm64. Preparing to unpack .../369-libgusb2_0.3.10-1_arm64.deb ... Unpacking libgusb2:arm64 (0.3.10-1) ... Selecting previously unselected package libcolorhug2:arm64. Preparing to unpack .../370-libcolorhug2_1.4.6-1_arm64.deb ... Unpacking libcolorhug2:arm64 (1.4.6-1) ... Selecting previously unselected package libexif12:arm64. Preparing to unpack .../371-libexif12_0.6.24-1build1_arm64.deb ... Unpacking libexif12:arm64 (0.6.24-1build1) ... Selecting previously unselected package libxpm4:arm64. Preparing to unpack .../372-libxpm4_1%3a3.5.12-1ubuntu0.22.04.1_arm64.deb ... Unpacking libxpm4:arm64 (1:3.5.12-1ubuntu0.22.04.1) ... Selecting previously unselected package libgd3:arm64. Preparing to unpack .../373-libgd3_2.3.0-2ubuntu2_arm64.deb ... Unpacking libgd3:arm64 (2.3.0-2ubuntu2) ... Selecting previously unselected package libgphoto2-port12:arm64. Preparing to unpack .../374-libgphoto2-port12_2.5.27-1build2_arm64.deb ... Unpacking libgphoto2-port12:arm64 (2.5.27-1build2) ... Selecting previously unselected package libgphoto2-6:arm64. Preparing to unpack .../375-libgphoto2-6_2.5.27-1build2_arm64.deb ... Unpacking libgphoto2-6:arm64 (2.5.27-1build2) ... Selecting previously unselected package libieee1284-3:arm64. Preparing to unpack .../376-libieee1284-3_0.2.11-14build2_arm64.deb ... Unpacking libieee1284-3:arm64 (0.2.11-14build2) ... Selecting previously unselected package libpoppler-glib8:arm64. Preparing to unpack .../377-libpoppler-glib8_22.02.0-2ubuntu0.1_arm64.deb ... Unpacking libpoppler-glib8:arm64 (22.02.0-2ubuntu0.1) ... Selecting previously unselected package libsnmp-base. Preparing to unpack .../378-libsnmp-base_5.9.1+dfsg-1ubuntu2.5_all.deb ... Unpacking libsnmp-base (5.9.1+dfsg-1ubuntu2.5) ... Selecting previously unselected package libsnmp40:arm64. Preparing to unpack .../379-libsnmp40_5.9.1+dfsg-1ubuntu2.5_arm64.deb ... Unpacking libsnmp40:arm64 (5.9.1+dfsg-1ubuntu2.5) ... Selecting previously unselected package libsane1:arm64. Preparing to unpack .../380-libsane1_1.1.1-5_arm64.deb ... Unpacking libsane1:arm64 (1.1.1-5) ... Selecting previously unselected package colord. Preparing to unpack .../381-colord_1.4.6-1_arm64.deb ... Unpacking colord (1.4.6-1) ... Selecting previously unselected package desktop-file-utils. Preparing to unpack .../382-desktop-file-utils_0.26-1ubuntu3_arm64.deb ... Unpacking desktop-file-utils (0.26-1ubuntu3) ... Selecting previously unselected package devhelp-common. Preparing to unpack .../383-devhelp-common_41.2-2_all.deb ... Unpacking devhelp-common (41.2-2) ... Selecting previously unselected package dmz-cursor-theme. Preparing to unpack .../384-dmz-cursor-theme_0.4.5ubuntu1_all.deb ... Unpacking dmz-cursor-theme (0.4.5ubuntu1) ... Selecting previously unselected package emacs-common. Preparing to unpack .../385-emacs-common_1%3a27.1+1-3ubuntu5_all.deb ... Unpacking emacs-common (1:27.1+1-3ubuntu5) ... Selecting previously unselected package emacs-bin-common. Preparing to unpack .../386-emacs-bin-common_1%3a27.1+1-3ubuntu5_arm64.deb ... Unpacking emacs-bin-common (1:27.1+1-3ubuntu5) ... Selecting previously unselected package libgif7:arm64. Preparing to unpack .../387-libgif7_5.1.9-2build2_arm64.deb ... Unpacking libgif7:arm64 (5.1.9-2build2) ... Selecting previously unselected package m17n-db. Preparing to unpack .../388-m17n-db_1.8.0-3_all.deb ... Unpacking m17n-db (1.8.0-3) ... Selecting previously unselected package libotf1:arm64. Preparing to unpack .../389-libotf1_0.9.16-3build1_arm64.deb ... Unpacking libotf1:arm64 (0.9.16-3build1) ... Selecting previously unselected package libxt6:arm64. Preparing to unpack .../390-libxt6_1%3a1.2.1-1_arm64.deb ... Unpacking libxt6:arm64 (1:1.2.1-1) ... Selecting previously unselected package libm17n-0:arm64. Preparing to unpack .../391-libm17n-0_1.8.0-4_arm64.deb ... Unpacking libm17n-0:arm64 (1.8.0-4) ... Selecting previously unselected package emacs-gtk. Preparing to unpack .../392-emacs-gtk_1%3a27.1+1-3ubuntu5_arm64.deb ... Unpacking emacs-gtk (1:27.1+1-3ubuntu5) ... Selecting previously unselected package emacs. Preparing to unpack .../393-emacs_1%3a27.1+1-3ubuntu5_all.deb ... Unpacking emacs (1:27.1+1-3ubuntu5) ... Selecting previously unselected package evince-common. Preparing to unpack .../394-evince-common_42.3-0ubuntu3_all.deb ... Unpacking evince-common (42.3-0ubuntu3) ... Selecting previously unselected package libdjvulibre-text. Preparing to unpack .../395-libdjvulibre-text_3.5.28-2build2_all.deb ... Unpacking libdjvulibre-text (3.5.28-2build2) ... Selecting previously unselected package libdjvulibre21:arm64. Preparing to unpack .../396-libdjvulibre21_3.5.28-2build2_arm64.deb ... Unpacking libdjvulibre21:arm64 (3.5.28-2build2) ... Selecting previously unselected package libgxps2:arm64. Preparing to unpack .../397-libgxps2_0.3.2-2_arm64.deb ... Unpacking libgxps2:arm64 (0.3.2-2) ... Selecting previously unselected package libkpathsea6:arm64. Preparing to unpack .../398-libkpathsea6_2021.20210626.59705-1build1_arm64.deb ... Unpacking libkpathsea6:arm64 (2021.20210626.59705-1build1) ... Selecting previously unselected package libspectre1:arm64. Preparing to unpack .../399-libspectre1_0.2.10-1_arm64.deb ... Unpacking libspectre1:arm64 (0.2.10-1) ... Selecting previously unselected package libsynctex2:arm64. Preparing to unpack .../400-libsynctex2_2021.20210626.59705-1build1_arm64.deb ... Unpacking libsynctex2:arm64 (2021.20210626.59705-1build1) ... Selecting previously unselected package libevdocument3-4:arm64. Preparing to unpack .../401-libevdocument3-4_42.3-0ubuntu3_arm64.deb ... Unpacking libevdocument3-4:arm64 (42.3-0ubuntu3) ... Selecting previously unselected package libgspell-1-common. Preparing to unpack .../402-libgspell-1-common_1.9.1-4_all.deb ... Unpacking libgspell-1-common (1.9.1-4) ... Selecting previously unselected package libgspell-1-2:arm64. Preparing to unpack .../403-libgspell-1-2_1.9.1-4_arm64.deb ... Unpacking libgspell-1-2:arm64 (1.9.1-4) ... Selecting previously unselected package libevview3-3:arm64. Preparing to unpack .../404-libevview3-3_42.3-0ubuntu3_arm64.deb ... Unpacking libevview3-3:arm64 (42.3-0ubuntu3) ... Selecting previously unselected package libhandy-1-0:arm64. Preparing to unpack .../405-libhandy-1-0_1.6.1-1_arm64.deb ... Unpacking libhandy-1-0:arm64 (1.6.1-1) ... Selecting previously unselected package libnautilus-extension1a:arm64. Preparing to unpack .../406-libnautilus-extension1a_1%3a42.2-0ubuntu2.1_arm64.deb ... Unpacking libnautilus-extension1a:arm64 (1:42.2-0ubuntu2.1) ... Selecting previously unselected package evince. Preparing to unpack .../407-evince_42.3-0ubuntu3_arm64.deb ... Unpacking evince (42.3-0ubuntu3) ... Selecting previously unselected package libexo-common. Preparing to unpack .../408-libexo-common_4.16.3-1_all.deb ... Unpacking libexo-common (4.16.3-1) ... Selecting previously unselected package libexo-2-0:arm64. Preparing to unpack .../409-libexo-2-0_4.16.3-1_arm64.deb ... Unpacking libexo-2-0:arm64 (4.16.3-1) ... Selecting previously unselected package exo-utils. Preparing to unpack .../410-exo-utils_4.16.3-1_arm64.deb ... Unpacking exo-utils (4.16.3-1) ... Selecting previously unselected package exuberant-ctags. Preparing to unpack .../411-exuberant-ctags_1%3a5.9~svn20110310-16ubuntu0.22.04.1_arm64.deb ... Unpacking exuberant-ctags (1:5.9~svn20110310-16ubuntu0.22.04.1) ... Selecting previously unselected package fbi. Preparing to unpack .../412-fbi_2.10-4ubuntu1_arm64.deb ... Unpacking fbi (2.10-4ubuntu1) ... Selecting previously unselected package filezilla-common. Preparing to unpack .../413-filezilla-common_3.58.0-1_all.deb ... Unpacking filezilla-common (3.58.0-1) ... Selecting previously unselected package libfilezilla-common. Preparing to unpack .../414-libfilezilla-common_0.36.0-2_all.deb ... Unpacking libfilezilla-common (0.36.0-2) ... Selecting previously unselected package libfilezilla24:arm64. Preparing to unpack .../415-libfilezilla24_0.36.0-2_arm64.deb ... Unpacking libfilezilla24:arm64 (0.36.0-2) ... Selecting previously unselected package libpugixml1v5:arm64. Preparing to unpack .../416-libpugixml1v5_1.12.1-1_arm64.deb ... Unpacking libpugixml1v5:arm64 (1.12.1-1) ... Selecting previously unselected package libwxbase3.0-0v5:arm64. Preparing to unpack .../417-libwxbase3.0-0v5_3.0.5.1+dfsg-4_arm64.deb ... Unpacking libwxbase3.0-0v5:arm64 (3.0.5.1+dfsg-4) ... Selecting previously unselected package libwxgtk3.0-gtk3-0v5:arm64. Preparing to unpack .../418-libwxgtk3.0-gtk3-0v5_3.0.5.1+dfsg-4_arm64.deb ... Unpacking libwxgtk3.0-gtk3-0v5:arm64 (3.0.5.1+dfsg-4) ... Selecting previously unselected package filezilla. Preparing to unpack .../419-filezilla_3.58.0-1_arm64.deb ... Unpacking filezilla (3.58.0-1) ... Selecting previously unselected package libdbus-glib-1-2:arm64. Preparing to unpack .../420-libdbus-glib-1-2_0.112-2build1_arm64.deb ... Unpacking libdbus-glib-1-2:arm64 (0.112-2build1) ... Selecting previously unselected package firefox-esr. Preparing to unpack .../421-firefox-esr_102.8.0esr+build2-0ubuntu0.22.04.1_arm64.deb ... Unpacking firefox-esr (102.8.0esr+build2-0ubuntu0.22.04.1) ... Selecting previously unselected package fonts-mathjax. Preparing to unpack .../422-fonts-mathjax_2.7.9+dfsg-1_all.deb ... Unpacking fonts-mathjax (2.7.9+dfsg-1) ... Selecting previously unselected package fonts-noto-cjk. Preparing to unpack .../423-fonts-noto-cjk_1%3a20220127+repack1-1_all.deb ... Unpacking fonts-noto-cjk (1:20220127+repack1-1) ... Selecting previously unselected package fonts-ubuntu-console. Preparing to unpack .../424-fonts-ubuntu-console_0.83-6ubuntu1_all.deb ... Unpacking fonts-ubuntu-console (0.83-6ubuntu1) ... Selecting previously unselected package foomatic-db-compressed-ppds. Preparing to unpack .../425-foomatic-db-compressed-ppds_20220223-0ubuntu1_all.deb ... Unpacking foomatic-db-compressed-ppds (20220223-0ubuntu1) ... Selecting previously unselected package gdebi-core. Preparing to unpack .../426-gdebi-core_0.9.5.7+nmu6_all.deb ... Unpacking gdebi-core (0.9.5.7+nmu6) ... Selecting previously unselected package libvte-2.91-common. Preparing to unpack .../427-libvte-2.91-common_0.68.0-1_arm64.deb ... Unpacking libvte-2.91-common (0.68.0-1) ... Selecting previously unselected package libvte-2.91-0:arm64. Preparing to unpack .../428-libvte-2.91-0_0.68.0-1_arm64.deb ... Unpacking libvte-2.91-0:arm64 (0.68.0-1) ... Selecting previously unselected package gir1.2-vte-2.91:arm64. Preparing to unpack .../429-gir1.2-vte-2.91_0.68.0-1_arm64.deb ... Unpacking gir1.2-vte-2.91:arm64 (0.68.0-1) ... Selecting previously unselected package gdebi. Preparing to unpack .../430-gdebi_0.9.5.7+nmu6_all.deb ... Unpacking gdebi (0.9.5.7+nmu6) ... Selecting previously unselected package geany-common. Preparing to unpack .../431-geany-common_1.38-1_all.deb ... Unpacking geany-common (1.38-1) ... Selecting previously unselected package geany. Preparing to unpack .../432-geany_1.38-1_arm64.deb ... Unpacking geany (1.38-1) ... Selecting previously unselected package gh. Preparing to unpack .../433-gh_2.23.0_arm64.deb ... Unpacking gh (2.23.0) ... Selecting previously unselected package ghostscript-x. Preparing to unpack .../434-ghostscript-x_9.55.0~dfsg1-0ubuntu5.1_arm64.deb ... Unpacking ghostscript-x (9.55.0~dfsg1-0ubuntu5.1) ... Selecting previously unselected package libdazzle-common. Preparing to unpack .../435-libdazzle-common_3.44.0-1_all.deb ... Unpacking libdazzle-common (3.44.0-1) ... Selecting previously unselected package libdazzle-1.0-0:arm64. Preparing to unpack .../436-libdazzle-1.0-0_3.44.0-1_arm64.deb ... Unpacking libdazzle-1.0-0:arm64 (3.44.0-1) ... Selecting previously unselected package gir1.2-dazzle-1.0:arm64. Preparing to unpack .../437-gir1.2-dazzle-1.0_3.44.0-1_arm64.deb ... Unpacking gir1.2-dazzle-1.0:arm64 (3.44.0-1) ... Selecting previously unselected package libhttp-parser2.9:arm64. Preparing to unpack .../438-libhttp-parser2.9_2.9.4-4_arm64.deb ... Unpacking libhttp-parser2.9:arm64 (2.9.4-4) ... Selecting previously unselected package libmbedcrypto7:arm64. Preparing to unpack .../439-libmbedcrypto7_2.28.0-1build1_arm64.deb ... Unpacking libmbedcrypto7:arm64 (2.28.0-1build1) ... Selecting previously unselected package libmbedx509-1:arm64. Preparing to unpack .../440-libmbedx509-1_2.28.0-1build1_arm64.deb ... Unpacking libmbedx509-1:arm64 (2.28.0-1build1) ... Selecting previously unselected package libmbedtls14:arm64. Preparing to unpack .../441-libmbedtls14_2.28.0-1build1_arm64.deb ... Unpacking libmbedtls14:arm64 (2.28.0-1build1) ... Selecting previously unselected package libgit2-1.1:arm64. Preparing to unpack .../442-libgit2-1.1_1.1.0+dfsg.1-4.1build1_arm64.deb ... Unpacking libgit2-1.1:arm64 (1.1.0+dfsg.1-4.1build1) ... Selecting previously unselected package libgit2-glib-1.0-0:arm64. Preparing to unpack .../443-libgit2-glib-1.0-0_1.0.0.1-1_arm64.deb ... Unpacking libgit2-glib-1.0-0:arm64 (1.0.0.1-1) ... Selecting previously unselected package gir1.2-ggit-1.0:arm64. Preparing to unpack .../444-gir1.2-ggit-1.0_1.0.0.1-1_arm64.deb ... Unpacking gir1.2-ggit-1.0:arm64 (1.0.0.1-1) ... Selecting previously unselected package gir1.2-goa-1.0:arm64. Preparing to unpack .../445-gir1.2-goa-1.0_3.44.0-1ubuntu1_arm64.deb ... Unpacking gir1.2-goa-1.0:arm64 (3.44.0-1ubuntu1) ... Selecting previously unselected package libgtksourceview-3.0-common. Preparing to unpack .../446-libgtksourceview-3.0-common_3.24.11-2build1_all.deb ... Unpacking libgtksourceview-3.0-common (3.24.11-2build1) ... Selecting previously unselected package libgtksourceview-3.0-1:arm64. Preparing to unpack .../447-libgtksourceview-3.0-1_3.24.11-2build1_arm64.deb ... Unpacking libgtksourceview-3.0-1:arm64 (3.24.11-2build1) ... Selecting previously unselected package gir1.2-gtksource-3.0:arm64. Preparing to unpack .../448-gir1.2-gtksource-3.0_3.24.11-2build1_arm64.deb ... Unpacking gir1.2-gtksource-3.0:arm64 (3.24.11-2build1) ... Selecting previously unselected package libgtksourceview-4-common. Preparing to unpack .../449-libgtksourceview-4-common_4.8.3-1_all.deb ... Unpacking libgtksourceview-4-common (4.8.3-1) ... Selecting previously unselected package libgtksourceview-4-0:arm64. Preparing to unpack .../450-libgtksourceview-4-0_4.8.3-1_arm64.deb ... Unpacking libgtksourceview-4-0:arm64 (4.8.3-1) ... Selecting previously unselected package gir1.2-gtksource-4:arm64. Preparing to unpack .../451-gir1.2-gtksource-4_4.8.3-1_arm64.deb ... Unpacking gir1.2-gtksource-4:arm64 (4.8.3-1) ... Selecting previously unselected package gir1.2-handy-1:arm64. Preparing to unpack .../452-gir1.2-handy-1_1.6.1-1_arm64.deb ... Unpacking gir1.2-handy-1:arm64 (1.6.1-1) ... Selecting previously unselected package libjsonrpc-glib-1.0-1:arm64. Preparing to unpack .../453-libjsonrpc-glib-1.0-1_3.42.0-1_arm64.deb ... Unpacking libjsonrpc-glib-1.0-1:arm64 (3.42.0-1) ... Selecting previously unselected package gir1.2-jsonrpc-1.0:arm64. Preparing to unpack .../454-gir1.2-jsonrpc-1.0_3.42.0-1_arm64.deb ... Unpacking gir1.2-jsonrpc-1.0:arm64 (3.42.0-1) ... Selecting previously unselected package gir1.2-snapd-1:arm64. Preparing to unpack .../455-gir1.2-snapd-1_1.60-0ubuntu1_arm64.deb ... Unpacking gir1.2-snapd-1:arm64 (1.60-0ubuntu1) ... Selecting previously unselected package libtemplate-glib-common. Preparing to unpack .../456-libtemplate-glib-common_3.34.1-1_all.deb ... Unpacking libtemplate-glib-common (3.34.1-1) ... Selecting previously unselected package libtemplate-glib-1.0-0:arm64. Preparing to unpack .../457-libtemplate-glib-1.0-0_3.34.1-1_arm64.deb ... Unpacking libtemplate-glib-1.0-0:arm64 (3.34.1-1) ... Selecting previously unselected package gir1.2-template-1.0:arm64. Preparing to unpack .../458-gir1.2-template-1.0_3.34.1-1_arm64.deb ... Unpacking gir1.2-template-1.0:arm64 (3.34.1-1) ... Selecting previously unselected package libxres1:arm64. Preparing to unpack .../459-libxres1_2%3a1.2.1-1_arm64.deb ... Unpacking libxres1:arm64 (2:1.2.1-1) ... Selecting previously unselected package libwnck-3-common. Preparing to unpack .../460-libwnck-3-common_40.1-1_all.deb ... Unpacking libwnck-3-common (40.1-1) ... Selecting previously unselected package libwnck-3-0:arm64. Preparing to unpack .../461-libwnck-3-0_40.1-1_arm64.deb ... Unpacking libwnck-3-0:arm64 (40.1-1) ... Selecting previously unselected package gir1.2-wnck-3.0:arm64. Preparing to unpack .../462-gir1.2-wnck-3.0_40.1-1_arm64.deb ... Unpacking gir1.2-wnck-3.0:arm64 (40.1-1) ... Selecting previously unselected package glmark2-data. Preparing to unpack .../463-glmark2-data_2021.02-0ubuntu1_all.deb ... Unpacking glmark2-data (2021.02-0ubuntu1) ... Selecting previously unselected package glmark2. Preparing to unpack .../464-glmark2_2021.02-0ubuntu1_arm64.deb ... Unpacking glmark2 (2021.02-0ubuntu1) ... Selecting previously unselected package libpeas-common. Preparing to unpack .../465-libpeas-common_1.32.0-1_all.deb ... Unpacking libpeas-common (1.32.0-1) ... Selecting previously unselected package libpeas-1.0-0:arm64. Preparing to unpack .../466-libpeas-1.0-0_1.32.0-1_arm64.deb ... Unpacking libpeas-1.0-0:arm64 (1.32.0-1) ... Selecting previously unselected package gir1.2-peas-1.0:arm64. Preparing to unpack .../467-gir1.2-peas-1.0_1.32.0-1_arm64.deb ... Unpacking gir1.2-peas-1.0:arm64 (1.32.0-1) ... Selecting previously unselected package libvala-0.56-0:arm64. Preparing to unpack .../468-libvala-0.56-0_0.56.0-1_arm64.deb ... Unpacking libvala-0.56-0:arm64 (0.56.0-1) ... Selecting previously unselected package libvala-0.56-dev:arm64. Preparing to unpack .../469-libvala-0.56-dev_0.56.0-1_arm64.deb ... Unpacking libvala-0.56-dev:arm64 (0.56.0-1) ... Selecting previously unselected package libcmark0.30.2:arm64. Preparing to unpack .../470-libcmark0.30.2_0.30.2-5_arm64.deb ... Unpacking libcmark0.30.2:arm64 (0.30.2-5) ... Selecting previously unselected package libdevhelp-3-6:arm64. Preparing to unpack .../471-libdevhelp-3-6_41.2-2_arm64.deb ... Unpacking libdevhelp-3-6:arm64 (41.2-2) ... Selecting previously unselected package libmalcontent-0-0:arm64. Preparing to unpack .../472-libmalcontent-0-0_0.10.4-1_arm64.deb ... Unpacking libmalcontent-0-0:arm64 (0.10.4-1) ... Selecting previously unselected package libgpgme11:arm64. Preparing to unpack .../473-libgpgme11_1.16.0-1.2ubuntu4_arm64.deb ... Unpacking libgpgme11:arm64 (1.16.0-1.2ubuntu4) ... Selecting previously unselected package libostree-1-1:arm64. Preparing to unpack .../474-libostree-1-1_2022.2-3_arm64.deb ... Unpacking libostree-1-1:arm64 (2022.2-3) ... Selecting previously unselected package libflatpak0:arm64. Preparing to unpack .../475-libflatpak0_1.12.7-1_arm64.deb ... Unpacking libflatpak0:arm64 (1.12.7-1) ... Selecting previously unselected package libgladeui-common. Preparing to unpack .../476-libgladeui-common_3.38.2-7_all.deb ... Unpacking libgladeui-common (3.38.2-7) ... Selecting previously unselected package libgladeui-2-13:arm64. Preparing to unpack .../477-libgladeui-2-13_3.38.2-7_arm64.deb ... Unpacking libgladeui-2-13:arm64 (3.38.2-7) ... Selecting previously unselected package libportal-gtk3-1:arm64. Preparing to unpack .../478-libportal-gtk3-1_0.6-2_arm64.deb ... Unpacking libportal-gtk3-1:arm64 (0.6-2) ... Selecting previously unselected package libportal1:arm64. Preparing to unpack .../479-libportal1_0.6-2_arm64.deb ... Unpacking libportal1:arm64 (0.6-2) ... Selecting previously unselected package libsysprof-4:arm64. Preparing to unpack .../480-libsysprof-4_3.44.0-1_arm64.deb ... Unpacking libsysprof-4:arm64 (3.44.0-1) ... Selecting previously unselected package libsysprof-ui-4:arm64. Preparing to unpack .../481-libsysprof-ui-4_3.44.0-1_arm64.deb ... Unpacking libsysprof-ui-4:arm64 (3.44.0-1) ... Selecting previously unselected package gnome-builder. Preparing to unpack .../482-gnome-builder_42.0-1_arm64.deb ... Unpacking gnome-builder (42.0-1) ... Selecting previously unselected package libblockdev-part-err2:arm64. Preparing to unpack .../483-libblockdev-part-err2_2.26-1_arm64.deb ... Unpacking libblockdev-part-err2:arm64 (2.26-1) ... Selecting previously unselected package libblockdev-utils2:arm64. Preparing to unpack .../484-libblockdev-utils2_2.26-1_arm64.deb ... Unpacking libblockdev-utils2:arm64 (2.26-1) ... Selecting previously unselected package libparted-fs-resize0:arm64. Preparing to unpack .../485-libparted-fs-resize0_3.4-2build1_arm64.deb ... Unpacking libparted-fs-resize0:arm64 (3.4-2build1) ... Selecting previously unselected package libblockdev-fs2:arm64. Preparing to unpack .../486-libblockdev-fs2_2.26-1_arm64.deb ... Unpacking libblockdev-fs2:arm64 (2.26-1) ... Selecting previously unselected package libblockdev-loop2:arm64. Preparing to unpack .../487-libblockdev-loop2_2.26-1_arm64.deb ... Unpacking libblockdev-loop2:arm64 (2.26-1) ... Selecting previously unselected package gdisk. Preparing to unpack .../488-gdisk_1.0.8-4build1_arm64.deb ... Unpacking gdisk (1.0.8-4build1) ... Selecting previously unselected package libblockdev-part2:arm64. Preparing to unpack .../489-libblockdev-part2_2.26-1_arm64.deb ... Unpacking libblockdev-part2:arm64 (2.26-1) ... Selecting previously unselected package libblockdev-swap2:arm64. Preparing to unpack .../490-libblockdev-swap2_2.26-1_arm64.deb ... Unpacking libblockdev-swap2:arm64 (2.26-1) ... Selecting previously unselected package libatasmart4:arm64. Preparing to unpack .../491-libatasmart4_0.19-5build2_arm64.deb ... Unpacking libatasmart4:arm64 (0.19-5build2) ... Selecting previously unselected package libblockdev2:arm64. Preparing to unpack .../492-libblockdev2_2.26-1_arm64.deb ... Unpacking libblockdev2:arm64 (2.26-1) ... Selecting previously unselected package libudisks2-0:arm64. Preparing to unpack .../493-libudisks2-0_2.9.4-1ubuntu2_arm64.deb ... Unpacking libudisks2-0:arm64 (2.9.4-1ubuntu2) ... Selecting previously unselected package udisks2. Preparing to unpack .../494-udisks2_2.9.4-1ubuntu2_arm64.deb ... Unpacking udisks2 (2.9.4-1ubuntu2) ... Selecting previously unselected package libpwquality-common. Preparing to unpack .../495-libpwquality-common_1.4.4-1build2_all.deb ... Unpacking libpwquality-common (1.4.4-1build2) ... Selecting previously unselected package libpwquality1:arm64. Preparing to unpack .../496-libpwquality1_1.4.4-1build2_arm64.deb ... Unpacking libpwquality1:arm64 (1.4.4-1build2) ... Selecting previously unselected package gnome-disk-utility. Preparing to unpack .../497-gnome-disk-utility_42.0-1ubuntu1_arm64.deb ... Unpacking gnome-disk-utility (42.0-1ubuntu1) ... Selecting previously unselected package gnome-font-viewer. Preparing to unpack .../498-gnome-font-viewer_41.0-2_arm64.deb ... Unpacking gnome-font-viewer (41.0-2) ... Selecting previously unselected package gnome-screenshot. Preparing to unpack .../499-gnome-screenshot_41.0-2_arm64.deb ... Unpacking gnome-screenshot (41.0-2) ... Selecting previously unselected package libglibmm-2.4-1v5:arm64. Preparing to unpack .../500-libglibmm-2.4-1v5_2.66.2-2_arm64.deb ... Unpacking libglibmm-2.4-1v5:arm64 (2.66.2-2) ... Selecting previously unselected package libatkmm-1.6-1v5:arm64. Preparing to unpack .../501-libatkmm-1.6-1v5_2.28.2-1build1_arm64.deb ... Unpacking libatkmm-1.6-1v5:arm64 (2.28.2-1build1) ... Selecting previously unselected package libcairomm-1.0-1v5:arm64. Preparing to unpack .../502-libcairomm-1.0-1v5_1.12.2-4build3_arm64.deb ... Unpacking libcairomm-1.0-1v5:arm64 (1.12.2-4build3) ... Selecting previously unselected package libpangomm-1.4-1v5:arm64. Preparing to unpack .../503-libpangomm-1.4-1v5_2.46.2-1_arm64.deb ... Unpacking libpangomm-1.4-1v5:arm64 (2.46.2-1) ... Selecting previously unselected package libgtkmm-3.0-1v5:arm64. Preparing to unpack .../504-libgtkmm-3.0-1v5_3.24.5-1build1_arm64.deb ... Unpacking libgtkmm-3.0-1v5:arm64 (3.24.5-1build1) ... Selecting previously unselected package libgtop2-common. Preparing to unpack .../505-libgtop2-common_2.40.0-2build3_all.deb ... Unpacking libgtop2-common (2.40.0-2build3) ... Selecting previously unselected package libgtop-2.0-11:arm64. Preparing to unpack .../506-libgtop-2.0-11_2.40.0-2build3_arm64.deb ... Unpacking libgtop-2.0-11:arm64 (2.40.0-2build3) ... Selecting previously unselected package gnome-system-monitor. Preparing to unpack .../507-gnome-system-monitor_42.0-1_arm64.deb ... Unpacking gnome-system-monitor (42.0-1) ... Selecting previously unselected package gparted-common. Preparing to unpack .../508-gparted-common_1.3.1-1ubuntu1_all.deb ... Unpacking gparted-common (1.3.1-1ubuntu1) ... Selecting previously unselected package gparted. Preparing to unpack .../509-gparted_1.3.1-1ubuntu1_arm64.deb ... Unpacking gparted (1.3.1-1ubuntu1) ... Selecting previously unselected package gstreamer1.0-packagekit. Preparing to unpack .../510-gstreamer1.0-packagekit_1.2.5-2ubuntu2_arm64.deb ... Unpacking gstreamer1.0-packagekit (1.2.5-2ubuntu2) ... Selecting previously unselected package gstreamer1.0-tools. Preparing to unpack .../511-gstreamer1.0-tools_1.20.3-0ubuntu1_arm64.deb ... Unpacking gstreamer1.0-tools (1.20.3-0ubuntu1) ... Selecting previously unselected package gstreamer1.0-plugins-base-apps. Preparing to unpack .../512-gstreamer1.0-plugins-base-apps_1.20.1-1_arm64.deb ... Unpacking gstreamer1.0-plugins-base-apps (1.20.1-1) ... Selecting previously unselected package gstreamer1.0-pulseaudio:arm64. Preparing to unpack .../513-gstreamer1.0-pulseaudio_1.20.3-0ubuntu1_arm64.deb ... Unpacking gstreamer1.0-pulseaudio:arm64 (1.20.3-0ubuntu1) ... Selecting previously unselected package gtk2-engines:arm64. Preparing to unpack .../514-gtk2-engines_1%3a2.20.2-5build2_arm64.deb ... Unpacking gtk2-engines:arm64 (1:2.20.2-5build2) ... Selecting previously unselected package gtk2-engines-murrine:arm64. Preparing to unpack .../515-gtk2-engines-murrine_0.98.2-3build2_arm64.deb ... Unpacking gtk2-engines-murrine:arm64 (0.98.2-3build2) ... Selecting previously unselected package gtk2-engines-pixbuf:arm64. Preparing to unpack .../516-gtk2-engines-pixbuf_2.24.33-2ubuntu2_arm64.deb ... Unpacking gtk2-engines-pixbuf:arm64 (2.24.33-2ubuntu2) ... Selecting previously unselected package gvfs-common. Preparing to unpack .../517-gvfs-common_1.48.2-0ubuntu1_all.deb ... Unpacking gvfs-common (1.48.2-0ubuntu1) ... Selecting previously unselected package gvfs-libs:arm64. Preparing to unpack .../518-gvfs-libs_1.48.2-0ubuntu1_arm64.deb ... Unpacking gvfs-libs:arm64 (1.48.2-0ubuntu1) ... Selecting previously unselected package gvfs-daemons. Preparing to unpack .../519-gvfs-daemons_1.48.2-0ubuntu1_arm64.deb ... Unpacking gvfs-daemons (1.48.2-0ubuntu1) ... Selecting previously unselected package gvfs:arm64. Preparing to unpack .../520-gvfs_1.48.2-0ubuntu1_arm64.deb ... Unpacking gvfs:arm64 (1.48.2-0ubuntu1) ... Selecting previously unselected package libcdio19:arm64. Preparing to unpack .../521-libcdio19_2.1.0-3build1_arm64.deb ... Unpacking libcdio19:arm64 (2.1.0-3build1) ... Selecting previously unselected package libcdio-cdda2:arm64. Preparing to unpack .../522-libcdio-cdda2_10.2+2.0.0-1build3_arm64.deb ... Unpacking libcdio-cdda2:arm64 (10.2+2.0.0-1build3) ... Selecting previously unselected package libcdio-paranoia2:arm64. Preparing to unpack .../523-libcdio-paranoia2_10.2+2.0.0-1build3_arm64.deb ... Unpacking libcdio-paranoia2:arm64 (10.2+2.0.0-1build3) ... Selecting previously unselected package libplist3:arm64. Preparing to unpack .../524-libplist3_2.2.0-6build2_arm64.deb ... Unpacking libplist3:arm64 (2.2.0-6build2) ... Selecting previously unselected package libusbmuxd6:arm64. Preparing to unpack .../525-libusbmuxd6_2.0.2-3build2_arm64.deb ... Unpacking libusbmuxd6:arm64 (2.0.2-3build2) ... Selecting previously unselected package libimobiledevice6:arm64. Preparing to unpack .../526-libimobiledevice6_1.3.0-6build3_arm64.deb ... Unpacking libimobiledevice6:arm64 (1.3.0-6build3) ... Selecting previously unselected package libmtp-common. Preparing to unpack .../527-libmtp-common_1.1.19-1build1_all.deb ... Unpacking libmtp-common (1.1.19-1build1) ... Selecting previously unselected package libmtp9:arm64. Preparing to unpack .../528-libmtp9_1.1.19-1build1_arm64.deb ... Unpacking libmtp9:arm64 (1.1.19-1build1) ... Selecting previously unselected package libnfs13:arm64. Preparing to unpack .../529-libnfs13_4.0.0-1build2_arm64.deb ... Unpacking libnfs13:arm64 (4.0.0-1build2) ... Selecting previously unselected package gvfs-backends. Preparing to unpack .../530-gvfs-backends_1.48.2-0ubuntu1_arm64.deb ... Unpacking gvfs-backends (1.48.2-0ubuntu1) ... Selecting previously unselected package hplip-data. Preparing to unpack .../531-hplip-data_3.21.12+dfsg0-1_all.deb ... Unpacking hplip-data (3.21.12+dfsg0-1) ... Selecting previously unselected package libhpmud0:arm64. Preparing to unpack .../532-libhpmud0_3.21.12+dfsg0-1_arm64.deb ... Unpacking libhpmud0:arm64 (3.21.12+dfsg0-1) ... Selecting previously unselected package libsane-hpaio:arm64. Preparing to unpack .../533-libsane-hpaio_3.21.12+dfsg0-1_arm64.deb ... Unpacking libsane-hpaio:arm64 (3.21.12+dfsg0-1) ... Selecting previously unselected package printer-driver-hpcups. Preparing to unpack .../534-printer-driver-hpcups_3.21.12+dfsg0-1_arm64.deb ... Unpacking printer-driver-hpcups (3.21.12+dfsg0-1) ... Selecting previously unselected package python3-ptyprocess. Preparing to unpack .../535-python3-ptyprocess_0.7.0-3_all.deb ... Unpacking python3-ptyprocess (0.7.0-3) ... Selecting previously unselected package python3-pexpect. Preparing to unpack .../536-python3-pexpect_4.8.0-2ubuntu1_all.deb ... Unpacking python3-pexpect (4.8.0-2ubuntu1) ... Selecting previously unselected package mailcap. Preparing to unpack .../537-mailcap_3.70+nmu1ubuntu1_all.deb ... Unpacking mailcap (3.70+nmu1ubuntu1) ... Selecting previously unselected package mime-support. Preparing to unpack .../538-mime-support_3.66_all.deb ... Unpacking mime-support (3.66) ... Selecting previously unselected package libimagequant0:arm64. Preparing to unpack .../539-libimagequant0_2.17.0-1_arm64.deb ... Unpacking libimagequant0:arm64 (2.17.0-1) ... Selecting previously unselected package libraqm0:arm64. Preparing to unpack .../540-libraqm0_0.7.0-4ubuntu1_arm64.deb ... Unpacking libraqm0:arm64 (0.7.0-4ubuntu1) ... Selecting previously unselected package libwebpmux3:arm64. Preparing to unpack .../541-libwebpmux3_1.2.2-2_arm64.deb ... Unpacking libwebpmux3:arm64 (1.2.2-2) ... Selecting previously unselected package python3-pil:arm64. Preparing to unpack .../542-python3-pil_9.0.1-1ubuntu0.1_arm64.deb ... Unpacking python3-pil:arm64 (9.0.1-1ubuntu0.1) ... Selecting previously unselected package python3-reportlab-accel:arm64. Preparing to unpack .../543-python3-reportlab-accel_3.6.8-1_arm64.deb ... Unpacking python3-reportlab-accel:arm64 (3.6.8-1) ... Selecting previously unselected package python3-reportlab. Preparing to unpack .../544-python3-reportlab_3.6.8-1_all.deb ... Unpacking python3-reportlab (3.6.8-1) ... Selecting previously unselected package hplip. Preparing to unpack .../545-hplip_3.21.12+dfsg0-1_arm64.deb ... Unpacking hplip (3.21.12+dfsg0-1) ... Selecting previously unselected package hwdata. Preparing to unpack .../546-hwdata_0.357-1_all.deb ... Unpacking hwdata (0.357-1) ... Selecting previously unselected package indicator-common. Preparing to unpack .../547-indicator-common_16.10.0+18.04.20180321.1-0ubuntu5_all.deb ... Unpacking indicator-common (16.10.0+18.04.20180321.1-0ubuntu5) ... Selecting previously unselected package laptop-detect. Preparing to unpack .../548-laptop-detect_0.16_all.deb ... Unpacking laptop-detect (0.16) ... Selecting previously unselected package libao-common. Preparing to unpack .../549-libao-common_1.2.2+20180113-1.1ubuntu3_all.deb ... Unpacking libao-common (1.2.2+20180113-1.1ubuntu3) ... Selecting previously unselected package libao4:arm64. Preparing to unpack .../550-libao4_1.2.2+20180113-1.1ubuntu3_arm64.deb ... Unpacking libao4:arm64 (1.2.2+20180113-1.1ubuntu3) ... Selecting previously unselected package libaom3:arm64. Preparing to unpack .../551-libaom3_3.3.0-1_arm64.deb ... Unpacking libaom3:arm64 (3.3.0-1) ... Selecting previously unselected package libatk-adaptor:arm64. Preparing to unpack .../552-libatk-adaptor_2.38.0-3_arm64.deb ... Unpacking libatk-adaptor:arm64 (2.38.0-3) ... Selecting previously unselected package libavahi-ui-gtk3-0:arm64. Preparing to unpack .../553-libavahi-ui-gtk3-0_0.8-5ubuntu5_arm64.deb ... Unpacking libavahi-ui-gtk3-0:arm64 (0.8-5ubuntu5) ... Selecting previously unselected package libva2:arm64. Preparing to unpack .../554-libva2_2.14.0-1_arm64.deb ... Unpacking libva2:arm64 (2.14.0-1) ... Selecting previously unselected package libva-drm2:arm64. Preparing to unpack .../555-libva-drm2_2.14.0-1_arm64.deb ... Unpacking libva-drm2:arm64 (2.14.0-1) ... Selecting previously unselected package libva-x11-2:arm64. Preparing to unpack .../556-libva-x11-2_2.14.0-1_arm64.deb ... Unpacking libva-x11-2:arm64 (2.14.0-1) ... Selecting previously unselected package libvdpau1:arm64. Preparing to unpack .../557-libvdpau1_1.4-3build2_arm64.deb ... Unpacking libvdpau1:arm64 (1.4-3build2) ... Selecting previously unselected package ocl-icd-libopencl1:arm64. Preparing to unpack .../558-ocl-icd-libopencl1_2.2.14-3_arm64.deb ... Unpacking ocl-icd-libopencl1:arm64 (2.2.14-3) ... Selecting previously unselected package libavutil56:arm64. Preparing to unpack .../559-libavutil56_7%3a4.4.2-0ubuntu0.22.04.1_arm64.deb ... Unpacking libavutil56:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Selecting previously unselected package libcodec2-1.0:arm64. Preparing to unpack .../560-libcodec2-1.0_1.0.1-3_arm64.deb ... Unpacking libcodec2-1.0:arm64 (1.0.1-3) ... Selecting previously unselected package libdav1d5:arm64. Preparing to unpack .../561-libdav1d5_0.9.2-1_arm64.deb ... Unpacking libdav1d5:arm64 (0.9.2-1) ... Selecting previously unselected package libgsm1:arm64. Preparing to unpack .../562-libgsm1_1.0.19-1_arm64.deb ... Unpacking libgsm1:arm64 (1.0.19-1) ... Selecting previously unselected package libshine3:arm64. Preparing to unpack .../563-libshine3_3.1.1-2_arm64.deb ... Unpacking libshine3:arm64 (3.1.1-2) ... Selecting previously unselected package libsnappy1v5:arm64. Preparing to unpack .../564-libsnappy1v5_1.1.8-1build3_arm64.deb ... Unpacking libsnappy1v5:arm64 (1.1.8-1build3) ... Selecting previously unselected package libswresample3:arm64. Preparing to unpack .../565-libswresample3_7%3a4.4.2-0ubuntu0.22.04.1_arm64.deb ... Unpacking libswresample3:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Selecting previously unselected package libx264-163:arm64. Preparing to unpack .../566-libx264-163_2%3a0.163.3060+git5db6aa6-2build1_arm64.deb ... Unpacking libx264-163:arm64 (2:0.163.3060+git5db6aa6-2build1) ... Selecting previously unselected package libx265-199:arm64. Preparing to unpack .../567-libx265-199_3.5-2_arm64.deb ... Unpacking libx265-199:arm64 (3.5-2) ... Selecting previously unselected package libxvidcore4:arm64. Preparing to unpack .../568-libxvidcore4_2%3a1.3.7-1_arm64.deb ... Unpacking libxvidcore4:arm64 (2:1.3.7-1) ... Selecting previously unselected package libzvbi-common. Preparing to unpack .../569-libzvbi-common_0.2.35-19_all.deb ... Unpacking libzvbi-common (0.2.35-19) ... Selecting previously unselected package libzvbi0:arm64. Preparing to unpack .../570-libzvbi0_0.2.35-19_arm64.deb ... Unpacking libzvbi0:arm64 (0.2.35-19) ... Selecting previously unselected package libavcodec58:arm64. Preparing to unpack .../571-libavcodec58_7%3a4.4.2-0ubuntu0.22.04.1_arm64.deb ... Unpacking libavcodec58:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Selecting previously unselected package libudfread0:arm64. Preparing to unpack .../572-libudfread0_1.1.2-1_arm64.deb ... Unpacking libudfread0:arm64 (1.1.2-1) ... Selecting previously unselected package libbluray2:arm64. Preparing to unpack .../573-libbluray2_1%3a1.3.1-1_arm64.deb ... Unpacking libbluray2:arm64 (1:1.3.1-1) ... Selecting previously unselected package libchromaprint1:arm64. Preparing to unpack .../574-libchromaprint1_1.5.1-2_arm64.deb ... Unpacking libchromaprint1:arm64 (1.5.1-2) ... Selecting previously unselected package libgme0:arm64. Preparing to unpack .../575-libgme0_0.6.3-2_arm64.deb ... Unpacking libgme0:arm64 (0.6.3-2) ... Selecting previously unselected package libopenmpt0:arm64. Preparing to unpack .../576-libopenmpt0_0.6.1-1_arm64.deb ... Unpacking libopenmpt0:arm64 (0.6.1-1) ... Selecting previously unselected package librabbitmq4:arm64. Preparing to unpack .../577-librabbitmq4_0.10.0-1ubuntu2_arm64.deb ... Unpacking librabbitmq4:arm64 (0.10.0-1ubuntu2) ... Selecting previously unselected package libsrt1.4-gnutls:arm64. Preparing to unpack .../578-libsrt1.4-gnutls_1.4.4-4_arm64.deb ... Unpacking libsrt1.4-gnutls:arm64 (1.4.4-4) ... Selecting previously unselected package libssh-gcrypt-4:arm64. Preparing to unpack .../579-libssh-gcrypt-4_0.9.6-2build1_arm64.deb ... Unpacking libssh-gcrypt-4:arm64 (0.9.6-2build1) ... Selecting previously unselected package libnorm1:arm64. Preparing to unpack .../580-libnorm1_1.5.9+dfsg-2_arm64.deb ... Unpacking libnorm1:arm64 (1.5.9+dfsg-2) ... Selecting previously unselected package libpgm-5.3-0:arm64. Preparing to unpack .../581-libpgm-5.3-0_5.3.128~dfsg-2_arm64.deb ... Unpacking libpgm-5.3-0:arm64 (5.3.128~dfsg-2) ... Selecting previously unselected package libsodium23:arm64. Preparing to unpack .../582-libsodium23_1.0.18-1build2_arm64.deb ... Unpacking libsodium23:arm64 (1.0.18-1build2) ... Selecting previously unselected package libzmq5:arm64. Preparing to unpack .../583-libzmq5_4.3.4-2_arm64.deb ... Unpacking libzmq5:arm64 (4.3.4-2) ... Selecting previously unselected package libavformat58:arm64. Preparing to unpack .../584-libavformat58_7%3a4.4.2-0ubuntu0.22.04.1_arm64.deb ... Unpacking libavformat58:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Selecting previously unselected package libbrlapi0.8:arm64. Preparing to unpack .../585-libbrlapi0.8_6.4-4ubuntu3_arm64.deb ... Unpacking libbrlapi0.8:arm64 (6.4-4ubuntu3) ... Selecting previously unselected package libcairo-perl:arm64. Preparing to unpack .../586-libcairo-perl_1.109-2build1_arm64.deb ... Unpacking libcairo-perl:arm64 (1.109-2build1) ... Selecting previously unselected package libextutils-depends-perl. Preparing to unpack .../587-libextutils-depends-perl_0.8001-1_all.deb ... Unpacking libextutils-depends-perl (0.8001-1) ... Selecting previously unselected package libglib-perl:arm64. Preparing to unpack .../588-libglib-perl_3%3a1.329.3-2build1_arm64.deb ... Unpacking libglib-perl:arm64 (3:1.329.3-2build1) ... Selecting previously unselected package libcairo-gobject-perl:arm64. Preparing to unpack .../589-libcairo-gobject-perl_1.005-3build1_arm64.deb ... Unpacking libcairo-gobject-perl:arm64 (1.005-3build1) ... Selecting previously unselected package libdotconf0:arm64. Preparing to unpack .../590-libdotconf0_1.3-0.3fakesync1build2_arm64.deb ... Unpacking libdotconf0:arm64 (1.3-0.3fakesync1build2) ... Selecting previously unselected package libencode-locale-perl. Preparing to unpack .../591-libencode-locale-perl_1.05-1.1_all.deb ... Unpacking libencode-locale-perl (1.05-1.1) ... Selecting previously unselected package libept1.6.0:arm64. Preparing to unpack .../592-libept1.6.0_1.2.1_arm64.deb ... Unpacking libept1.6.0:arm64 (1.2.1) ... Selecting previously unselected package libevent-2.1-7:arm64. Preparing to unpack .../593-libevent-2.1-7_2.1.12-stable-1build3_arm64.deb ... Unpacking libevent-2.1-7:arm64 (2.1.12-stable-1build3) ... Selecting previously unselected package libexiv2-27:arm64. Preparing to unpack .../594-libexiv2-27_0.27.5-3ubuntu1_arm64.deb ... Unpacking libexiv2-27:arm64 (0.27.5-3ubuntu1) ... Selecting previously unselected package libtimedate-perl. Preparing to unpack .../595-libtimedate-perl_2.3300-2_all.deb ... Unpacking libtimedate-perl (2.3300-2) ... Selecting previously unselected package libhttp-date-perl. Preparing to unpack .../596-libhttp-date-perl_6.05-1_all.deb ... Unpacking libhttp-date-perl (6.05-1) ... Selecting previously unselected package libfile-listing-perl. Preparing to unpack .../597-libfile-listing-perl_6.14-1_all.deb ... Unpacking libfile-listing-perl (6.14-1) ... Selecting previously unselected package libfontenc1:arm64. Preparing to unpack .../598-libfontenc1_1%3a1.1.4-1build3_arm64.deb ... Unpacking libfontenc1:arm64 (1:1.1.4-1build3) ... Selecting previously unselected package libwinpr2-2:arm64. Preparing to unpack .../599-libwinpr2-2_2.6.1+dfsg1-3ubuntu2.3_arm64.deb ... Unpacking libwinpr2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Selecting previously unselected package libfreerdp2-2:arm64. Preparing to unpack .../600-libfreerdp2-2_2.6.1+dfsg1-3ubuntu2.3_arm64.deb ... Unpacking libfreerdp2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Selecting previously unselected package libfreerdp-client2-2:arm64. Preparing to unpack .../601-libfreerdp-client2-2_2.6.1+dfsg1-3ubuntu2.3_arm64.deb ... Unpacking libfreerdp-client2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Selecting previously unselected package libgail18:arm64. Preparing to unpack .../602-libgail18_2.24.33-2ubuntu2_arm64.deb ... Unpacking libgail18:arm64 (2.24.33-2ubuntu2) ... Selecting previously unselected package libgail-common:arm64. Preparing to unpack .../603-libgail-common_2.24.33-2ubuntu2_arm64.deb ... Unpacking libgail-common:arm64 (2.24.33-2ubuntu2) ... Selecting previously unselected package libgarcon-common. Preparing to unpack .../604-libgarcon-common_4.16.1-1_all.deb ... Unpacking libgarcon-common (4.16.1-1) ... Selecting previously unselected package libgarcon-1-0:arm64. Preparing to unpack .../605-libgarcon-1-0_4.16.1-1_arm64.deb ... Unpacking libgarcon-1-0:arm64 (4.16.1-1) ... Selecting previously unselected package libgarcon-gtk3-1-0:arm64. Preparing to unpack .../606-libgarcon-gtk3-1-0_4.16.1-1_arm64.deb ... Unpacking libgarcon-gtk3-1-0:arm64 (4.16.1-1) ... Selecting previously unselected package libgdk-pixbuf-xlib-2.0-0:arm64. Preparing to unpack .../607-libgdk-pixbuf-xlib-2.0-0_2.40.2-2build4_arm64.deb ... Unpacking libgdk-pixbuf-xlib-2.0-0:arm64 (2.40.2-2build4) ... Selecting previously unselected package libgeoip1:arm64. Preparing to unpack .../608-libgeoip1_1.6.12-8_arm64.deb ... Unpacking libgeoip1:arm64 (1.6.12-8) ... Selecting previously unselected package libglib-object-introspection-perl. Preparing to unpack .../609-libglib-object-introspection-perl_0.049-1+build2_arm64.deb ... Unpacking libglib-object-introspection-perl (0.049-1+build2) ... Selecting previously unselected package libgtk3-perl. Preparing to unpack .../610-libgtk3-perl_0.038-1_all.deb ... Unpacking libgtk3-perl (0.038-1) ... Selecting previously unselected package libgtkmm-2.4-1v5:arm64. Preparing to unpack .../611-libgtkmm-2.4-1v5_1%3a2.24.5-4ubuntu3_arm64.deb ... Unpacking libgtkmm-2.4-1v5:arm64 (1:2.24.5-4ubuntu3) ... Selecting previously unselected package libgtksourceviewmm-3.0-0v5:arm64. Preparing to unpack .../612-libgtksourceviewmm-3.0-0v5_3.18.0-4build1_arm64.deb ... Unpacking libgtksourceviewmm-3.0-0v5:arm64 (3.18.0-4build1) ... Selecting previously unselected package libhtml-tagset-perl. Preparing to unpack .../613-libhtml-tagset-perl_3.20-4_all.deb ... Unpacking libhtml-tagset-perl (3.20-4) ... Selecting previously unselected package liburi-perl. Preparing to unpack .../614-liburi-perl_5.10-1_all.deb ... Unpacking liburi-perl (5.10-1) ... Selecting previously unselected package libhtml-parser-perl:arm64. Preparing to unpack .../615-libhtml-parser-perl_3.76-1build2_arm64.deb ... Unpacking libhtml-parser-perl:arm64 (3.76-1build2) ... Selecting previously unselected package libhtml-tree-perl. Preparing to unpack .../616-libhtml-tree-perl_5.07-2_all.deb ... Unpacking libhtml-tree-perl (5.07-2) ... Selecting previously unselected package libio-html-perl. Preparing to unpack .../617-libio-html-perl_1.004-2_all.deb ... Unpacking libio-html-perl (1.004-2) ... Selecting previously unselected package liblwp-mediatypes-perl. Preparing to unpack .../618-liblwp-mediatypes-perl_6.04-1_all.deb ... Unpacking liblwp-mediatypes-perl (6.04-1) ... Selecting previously unselected package libhttp-message-perl. Preparing to unpack .../619-libhttp-message-perl_6.36-1_all.deb ... Unpacking libhttp-message-perl (6.36-1) ... Selecting previously unselected package libhttp-cookies-perl. Preparing to unpack .../620-libhttp-cookies-perl_6.10-1_all.deb ... Unpacking libhttp-cookies-perl (6.10-1) ... Selecting previously unselected package libhttp-negotiate-perl. Preparing to unpack .../621-libhttp-negotiate-perl_6.01-1_all.deb ... Unpacking libhttp-negotiate-perl (6.01-1) ... Selecting previously unselected package libindicator3-7. Preparing to unpack .../622-libindicator3-7_16.10.0+18.04.20180321.1-0ubuntu5_arm64.deb ... Unpacking libindicator3-7 (16.10.0+18.04.20180321.1-0ubuntu5) ... Selecting previously unselected package perl-openssl-defaults:arm64. Preparing to unpack .../623-perl-openssl-defaults_5build2_arm64.deb ... Unpacking perl-openssl-defaults:arm64 (5build2) ... Selecting previously unselected package libnet-ssleay-perl:arm64. Preparing to unpack .../624-libnet-ssleay-perl_1.92-1build2_arm64.deb ... Unpacking libnet-ssleay-perl:arm64 (1.92-1build2) ... Selecting previously unselected package libio-socket-ssl-perl. Preparing to unpack .../625-libio-socket-ssl-perl_2.074-2_all.deb ... Unpacking libio-socket-ssl-perl (2.074-2) ... Selecting previously unselected package libjs-highlight.js. Preparing to unpack .../626-libjs-highlight.js_9.18.5+dfsg1-1_all.deb ... Unpacking libjs-highlight.js (9.18.5+dfsg1-1) ... Selecting previously unselected package libjs-jquery. Preparing to unpack .../627-libjs-jquery_3.6.0+dfsg+~3.5.13-1_all.deb ... Unpacking libjs-jquery (3.6.0+dfsg+~3.5.13-1) ... Selecting previously unselected package libkeybinder-3.0-0:arm64. Preparing to unpack .../628-libkeybinder-3.0-0_0.3.2-1.1_arm64.deb ... Unpacking libkeybinder-3.0-0:arm64 (0.3.2-1.1) ... Selecting previously unselected package libxmu6:arm64. Preparing to unpack .../629-libxmu6_2%3a1.1.3-3_arm64.deb ... Unpacking libxmu6:arm64 (2:1.1.3-3) ... Selecting previously unselected package libxaw7:arm64. Preparing to unpack .../630-libxaw7_2%3a1.0.14-1_arm64.deb ... Unpacking libxaw7:arm64 (2:1.0.14-1) ... Selecting previously unselected package x11-xkb-utils. Preparing to unpack .../631-x11-xkb-utils_7.7+5build4_arm64.deb ... Unpacking x11-xkb-utils (7.7+5build4) ... Selecting previously unselected package libxklavier16:arm64. Preparing to unpack .../632-libxklavier16_5.4-4build2_arm64.deb ... Unpacking libxklavier16:arm64 (5.4-4build2) ... Selecting previously unselected package liblightdm-gobject-1-0:arm64. Preparing to unpack .../633-liblightdm-gobject-1-0_1.30.0-0ubuntu5_arm64.deb ... Unpacking liblightdm-gobject-1-0:arm64 (1.30.0-0ubuntu5) ... Selecting previously unselected package liblouis-data. Preparing to unpack .../634-liblouis-data_3.20.0-2ubuntu0.1_all.deb ... Unpacking liblouis-data (3.20.0-2ubuntu0.1) ... Selecting previously unselected package liblouis20:arm64. Preparing to unpack .../635-liblouis20_3.20.0-2ubuntu0.1_arm64.deb ... Unpacking liblouis20:arm64 (3.20.0-2ubuntu0.1) ... Selecting previously unselected package libnet-http-perl. Preparing to unpack .../636-libnet-http-perl_6.22-1_all.deb ... Unpacking libnet-http-perl (6.22-1) ... Selecting previously unselected package libtry-tiny-perl. Preparing to unpack .../637-libtry-tiny-perl_0.31-1_all.deb ... Unpacking libtry-tiny-perl (0.31-1) ... Selecting previously unselected package libwww-robotrules-perl. Preparing to unpack .../638-libwww-robotrules-perl_6.02-1_all.deb ... Unpacking libwww-robotrules-perl (6.02-1) ... Selecting previously unselected package libwww-perl. Preparing to unpack .../639-libwww-perl_6.61-1_all.deb ... Unpacking libwww-perl (6.61-1) ... Selecting previously unselected package liblwp-protocol-https-perl. Preparing to unpack .../640-liblwp-protocol-https-perl_6.10-1_all.deb ... Unpacking liblwp-protocol-https-perl (6.10-1) ... Selecting previously unselected package libminiupnpc17:arm64. Preparing to unpack .../641-libminiupnpc17_2.2.3-1build1_arm64.deb ... Unpacking libminiupnpc17:arm64 (2.2.3-1build1) ... Selecting previously unselected package libminizip1:arm64. Preparing to unpack .../642-libminizip1_1.1-8build1_arm64.deb ... Unpacking libminizip1:arm64 (1.1-8build1) ... Selecting previously unselected package libmousepad0. Preparing to unpack .../643-libmousepad0_0.5.8-1_arm64.deb ... Unpacking libmousepad0 (0.5.8-1) ... Selecting previously unselected package libnatpmp1:arm64. Preparing to unpack .../644-libnatpmp1_20150609-7.1build2_arm64.deb ... Unpacking libnatpmp1:arm64 (20150609-7.1build2) ... Selecting previously unselected package libnotify-bin. Preparing to unpack .../645-libnotify-bin_0.7.9-3ubuntu5.22.04.1_arm64.deb ... Unpacking libnotify-bin (0.7.9-3ubuntu5.22.04.1) ... Selecting previously unselected package libpam-gnome-keyring:arm64. Preparing to unpack .../646-libpam-gnome-keyring_40.0-3ubuntu3_arm64.deb ... Unpacking libpam-gnome-keyring:arm64 (40.0-3ubuntu3) ... Selecting previously unselected package libproxy1-plugin-gsettings:arm64. Preparing to unpack .../647-libproxy1-plugin-gsettings_0.4.17-2_arm64.deb ... Unpacking libproxy1-plugin-gsettings:arm64 (0.4.17-2) ... Selecting previously unselected package libproxy1-plugin-networkmanager:arm64. Preparing to unpack .../648-libproxy1-plugin-networkmanager_0.4.17-2_arm64.deb ... Unpacking libproxy1-plugin-networkmanager:arm64 (0.4.17-2) ... Selecting previously unselected package libqalculate-data. Preparing to unpack .../649-libqalculate-data_3.22.0-3build1_all.deb ... Unpacking libqalculate-data (3.22.0-3build1) ... Selecting previously unselected package libqalculate22:arm64. Preparing to unpack .../650-libqalculate22_3.22.0-3build1_arm64.deb ... Unpacking libqalculate22:arm64 (3.22.0-3build1) ... Selecting previously unselected package libqt5positioning5:arm64. Preparing to unpack .../651-libqt5positioning5_5.15.3+dfsg-3_arm64.deb ... Unpacking libqt5positioning5:arm64 (5.15.3+dfsg-3) ... Selecting previously unselected package libqt5printsupport5:arm64. Preparing to unpack .../652-libqt5printsupport5_5.15.3+dfsg-2ubuntu0.2_arm64.deb ... Unpacking libqt5printsupport5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Selecting previously unselected package libqt5qml5:arm64. Preparing to unpack .../653-libqt5qml5_5.15.3+dfsg-1_arm64.deb ... Unpacking libqt5qml5:arm64 (5.15.3+dfsg-1) ... Selecting previously unselected package libqt5qmlmodels5:arm64. Preparing to unpack .../654-libqt5qmlmodels5_5.15.3+dfsg-1_arm64.deb ... Unpacking libqt5qmlmodels5:arm64 (5.15.3+dfsg-1) ... Selecting previously unselected package libqt5quick5:arm64. Preparing to unpack .../655-libqt5quick5_5.15.3+dfsg-1_arm64.deb ... Unpacking libqt5quick5:arm64 (5.15.3+dfsg-1) ... Selecting previously unselected package libqt5quickwidgets5:arm64. Preparing to unpack .../656-libqt5quickwidgets5_5.15.3+dfsg-1_arm64.deb ... Unpacking libqt5quickwidgets5:arm64 (5.15.3+dfsg-1) ... Selecting previously unselected package libqt5webchannel5:arm64. Preparing to unpack .../657-libqt5webchannel5_5.15.3-1_arm64.deb ... Unpacking libqt5webchannel5:arm64 (5.15.3-1) ... Selecting previously unselected package libqt5webengine-data. Preparing to unpack .../658-libqt5webengine-data_5.15.9+dfsg-1_all.deb ... Unpacking libqt5webengine-data (5.15.9+dfsg-1) ... Selecting previously unselected package libre2-9:arm64. Preparing to unpack .../659-libre2-9_20220201+dfsg-1_arm64.deb ... Unpacking libre2-9:arm64 (20220201+dfsg-1) ... Selecting previously unselected package libqt5webenginecore5:arm64. Preparing to unpack .../660-libqt5webenginecore5_5.15.9+dfsg-1_arm64.deb ... Unpacking libqt5webenginecore5:arm64 (5.15.9+dfsg-1) ... Selecting previously unselected package libqt5webenginewidgets5:arm64. Preparing to unpack .../661-libqt5webenginewidgets5_5.15.9+dfsg-1_arm64.deb ... Unpacking libqt5webenginewidgets5:arm64 (5.15.9+dfsg-1) ... Selecting previously unselected package thunar-data. Preparing to unpack .../662-thunar-data_4.16.10-1_all.deb ... Unpacking thunar-data (4.16.10-1) ... Selecting previously unselected package libthunarx-3-0:arm64. Preparing to unpack .../663-libthunarx-3-0_4.16.10-1_arm64.deb ... Unpacking libthunarx-3-0:arm64 (4.16.10-1) ... Selecting previously unselected package libu2f-udev. Preparing to unpack .../664-libu2f-udev_1.1.10-3build2_all.deb ... Unpacking libu2f-udev (1.1.10-3build2) ... Selecting previously unselected package libvncclient1:arm64. Preparing to unpack .../665-libvncclient1_0.9.13+dfsg-3build2_arm64.deb ... Unpacking libvncclient1:arm64 (0.9.13+dfsg-3build2) ... Selecting previously unselected package libwmflite-0.2-7:arm64. Preparing to unpack .../666-libwmflite-0.2-7_0.2.12-5ubuntu1_arm64.deb ... Unpacking libwmflite-0.2-7:arm64 (0.2.12-5ubuntu1) ... Selecting previously unselected package libwmf-0.2-7:arm64. Preparing to unpack .../667-libwmf-0.2-7_0.2.12-5ubuntu1_arm64.deb ... Unpacking libwmf-0.2-7:arm64 (0.2.12-5ubuntu1) ... Selecting previously unselected package libwmf-0.2-7-gtk. Preparing to unpack .../668-libwmf-0.2-7-gtk_0.2.12-5ubuntu1_arm64.deb ... Unpacking libwmf-0.2-7-gtk (0.2.12-5ubuntu1) ... Selecting previously unselected package libwmf0.2-7-gtk:arm64. Preparing to unpack .../669-libwmf0.2-7-gtk_0.2.12-5ubuntu1_arm64.deb ... Unpacking libwmf0.2-7-gtk:arm64 (0.2.12-5ubuntu1) ... Selecting previously unselected package libxcvt0:arm64. Preparing to unpack .../670-libxcvt0_0.1.1-3_arm64.deb ... Unpacking libxcvt0:arm64 (0.1.1-3) ... Selecting previously unselected package libxfce4ui-utils. Preparing to unpack .../671-libxfce4ui-utils_4.16.1-1_arm64.deb ... Unpacking libxfce4ui-utils (4.16.1-1) ... Selecting previously unselected package libxfont2:arm64. Preparing to unpack .../672-libxfont2_1%3a2.0.5-1build1_arm64.deb ... Unpacking libxfont2:arm64 (1:2.0.5-1build1) ... Selecting previously unselected package libxpresent1:arm64. Preparing to unpack .../673-libxpresent1_1.0.0-2build1_arm64.deb ... Unpacking libxpresent1:arm64 (1.0.0-2build1) ... Selecting previously unselected package libxv1:arm64. Preparing to unpack .../674-libxv1_2%3a1.0.11-1build2_arm64.deb ... Unpacking libxv1:arm64 (2:1.0.11-1build2) ... Selecting previously unselected package libxxf86dga1:arm64. Preparing to unpack .../675-libxxf86dga1_2%3a1.1.5-0ubuntu3_arm64.deb ... Unpacking libxxf86dga1:arm64 (2:1.1.5-0ubuntu3) ... Selecting previously unselected package meld. Preparing to unpack .../676-meld_3.20.4-2_all.deb ... Unpacking meld (3.20.4-2) ... Selecting previously unselected package mesa-utils-bin:arm64. Preparing to unpack .../677-mesa-utils-bin_8.4.0-1ubuntu1_arm64.deb ... Unpacking mesa-utils-bin:arm64 (8.4.0-1ubuntu1) ... Selecting previously unselected package mousepad. Preparing to unpack .../678-mousepad_0.5.8-1_arm64.deb ... Unpacking mousepad (0.5.8-1) ... Selecting previously unselected package mousetweaks. Preparing to unpack .../679-mousetweaks_3.32.0-3build2_arm64.deb ... Unpacking mousetweaks (3.32.0-3build2) ... Selecting previously unselected package network-manager-gnome. Preparing to unpack .../680-network-manager-gnome_1.24.0-1ubuntu3_arm64.deb ... Unpacking network-manager-gnome (1.24.0-1ubuntu3) ... Selecting previously unselected package sshpass. Preparing to unpack .../681-sshpass_1.09-1_arm64.deb ... Unpacking sshpass (1.09-1) ... Selecting previously unselected package network-manager-ssh. Preparing to unpack .../682-network-manager-ssh_1.2.11-1_arm64.deb ... Unpacking network-manager-ssh (1.2.11-1) ... Selecting previously unselected package vpnc-scripts. Preparing to unpack .../683-vpnc-scripts_0.1~git20210402-1_all.deb ... Unpacking vpnc-scripts (0.1~git20210402-1) ... Selecting previously unselected package vpnc. Preparing to unpack .../684-vpnc_0.5.3+git20210125-1_arm64.deb ... Unpacking vpnc (0.5.3+git20210125-1) ... Selecting previously unselected package network-manager-vpnc. Preparing to unpack .../685-network-manager-vpnc_1.2.8-2_arm64.deb ... Unpacking network-manager-vpnc (1.2.8-2) ... Selecting previously unselected package libjs-modernizr. Preparing to unpack .../686-libjs-modernizr_2.6.2+ds1-4_all.deb ... Unpacking libjs-modernizr (2.6.2+ds1-4) ... Selecting previously unselected package libjs-requirejs. Preparing to unpack .../687-libjs-requirejs_2.3.6+ds-1_all.deb ... Unpacking libjs-requirejs (2.3.6+ds-1) ... Selecting previously unselected package libjs-mathjax. Preparing to unpack .../688-libjs-mathjax_2.7.9+dfsg-1_all.deb ... Unpacking libjs-mathjax (2.7.9+dfsg-1) ... Selecting previously unselected package notepadqq. Preparing to unpack .../689-notepadqq_2.0.0~beta1-3_arm64.deb ... Unpacking notepadqq (2.0.0~beta1-3) ... Selecting previously unselected package numix-gtk-theme. Preparing to unpack .../690-numix-gtk-theme_2.6.7-6_all.deb ... Unpacking numix-gtk-theme (2.6.7-6) ... Selecting previously unselected package numix-icon-theme. Preparing to unpack .../691-numix-icon-theme_0~20211031-1_all.deb ... Unpacking numix-icon-theme (0~20211031-1) ... Selecting previously unselected package numix-icon-theme-circle. Preparing to unpack .../692-numix-icon-theme-circle_22.01.10-1_all.deb ... Unpacking numix-icon-theme-circle (22.01.10-1) ... Selecting previously unselected package openprinting-ppds. Preparing to unpack .../693-openprinting-ppds_20220223-0ubuntu1_all.deb ... Unpacking openprinting-ppds (20220223-0ubuntu1) ... Selecting previously unselected package python3-brlapi:arm64. Preparing to unpack .../694-python3-brlapi_6.4-4ubuntu3_arm64.deb ... Unpacking python3-brlapi:arm64 (6.4-4ubuntu3) ... Selecting previously unselected package python3-louis. Preparing to unpack .../695-python3-louis_3.20.0-2ubuntu0.1_all.deb ... Unpacking python3-louis (3.20.0-2ubuntu0.1) ... Selecting previously unselected package python3-pyatspi. Preparing to unpack .../696-python3-pyatspi_2.38.2-1_all.deb ... Unpacking python3-pyatspi (2.38.2-1) ... Selecting previously unselected package python3-xdg. Preparing to unpack .../697-python3-xdg_0.27-2_all.deb ... Unpacking python3-xdg (0.27-2) ... Selecting previously unselected package python3-speechd. Preparing to unpack .../698-python3-speechd_0.11.1-1ubuntu2_all.deb ... Unpacking python3-speechd (0.11.1-1ubuntu2) ... Selecting previously unselected package speech-dispatcher-audio-plugins:arm64. Preparing to unpack .../699-speech-dispatcher-audio-plugins_0.11.1-1ubuntu2_arm64.deb ... Unpacking speech-dispatcher-audio-plugins:arm64 (0.11.1-1ubuntu2) ... Selecting previously unselected package libspeechd2:arm64. Preparing to unpack .../700-libspeechd2_0.11.1-1ubuntu2_arm64.deb ... Unpacking libspeechd2:arm64 (0.11.1-1ubuntu2) ... Selecting previously unselected package speech-dispatcher. Preparing to unpack .../701-speech-dispatcher_0.11.1-1ubuntu2_arm64.deb ... Unpacking speech-dispatcher (0.11.1-1ubuntu2) ... Selecting previously unselected package orca. Preparing to unpack .../702-orca_42.0-1ubuntu2_all.deb ... Unpacking orca (42.0-1ubuntu2) ... Selecting previously unselected package p7zip. Preparing to unpack .../703-p7zip_16.02+dfsg-8_arm64.deb ... Unpacking p7zip (16.02+dfsg-8) ... Selecting previously unselected package p7zip-full. Preparing to unpack .../704-p7zip-full_16.02+dfsg-8_arm64.deb ... Unpacking p7zip-full (16.02+dfsg-8) ... Selecting previously unselected package pamix. Preparing to unpack .../705-pamix_1.6~git20180112.ea4ab3b-4_arm64.deb ... Unpacking pamix (1.6~git20180112.ea4ab3b-4) ... Selecting previously unselected package pavucontrol. Preparing to unpack .../706-pavucontrol_5.0-2_arm64.deb ... Unpacking pavucontrol (5.0-2) ... Selecting previously unselected package pavumeter. Preparing to unpack .../707-pavumeter_0.9.3-4build3_arm64.deb ... Unpacking pavumeter (0.9.3-4build3) ... Selecting previously unselected package policykit-desktop-privileges. Preparing to unpack .../708-policykit-desktop-privileges_0.21_all.deb ... Unpacking policykit-desktop-privileges (0.21) ... Selecting previously unselected package printer-driver-all. Preparing to unpack .../709-printer-driver-all_0.20210903_all.deb ... Unpacking printer-driver-all (0.20210903) ... Selecting previously unselected package profile-sync-daemon. Preparing to unpack .../710-profile-sync-daemon_6.34-1_all.deb ... Unpacking profile-sync-daemon (6.34-1) ... Selecting previously unselected package putty-tools. Preparing to unpack .../711-putty-tools_0.76-2_arm64.deb ... Unpacking putty-tools (0.76-2) ... Selecting previously unselected package putty. Preparing to unpack .../712-putty_0.76-2_arm64.deb ... Unpacking putty (0.76-2) ... Selecting previously unselected package python3-problem-report. Preparing to unpack .../713-python3-problem-report_2.20.11-0ubuntu82.3_all.deb ... Unpacking python3-problem-report (2.20.11-0ubuntu82.3) ... Selecting previously unselected package python3-apport. Preparing to unpack .../714-python3-apport_2.20.11-0ubuntu82.3_all.deb ... Unpacking python3-apport (2.20.11-0ubuntu82.3) ... Selecting previously unselected package python3-configobj. Preparing to unpack .../715-python3-configobj_5.0.6-5_all.deb ... Unpacking python3-configobj (5.0.6-5) ... Selecting previously unselected package python3-cups:arm64. Preparing to unpack .../716-python3-cups_2.0.1-5build1_arm64.deb ... Unpacking python3-cups:arm64 (2.0.1-5build1) ... Selecting previously unselected package python3-cupshelpers. Preparing to unpack .../717-python3-cupshelpers_1.5.16-0ubuntu3_all.deb ... Unpacking python3-cupshelpers (1.5.16-0ubuntu3) ... Selecting previously unselected package python3-dateutil. Preparing to unpack .../718-python3-dateutil_2.8.1-6_all.deb ... Unpacking python3-dateutil (2.8.1-6) ... Selecting previously unselected package python3-psutil. Preparing to unpack .../719-python3-psutil_5.9.0-1build1_arm64.deb ... Unpacking python3-psutil (5.9.0-1build1) ... Selecting previously unselected package qalc. Preparing to unpack .../720-qalc_3.22.0-3build1_arm64.deb ... Unpacking qalc (3.22.0-3build1) ... Selecting previously unselected package qalculate-gtk. Preparing to unpack .../721-qalculate-gtk_3.22.0-1_arm64.deb ... Unpacking qalculate-gtk (3.22.0-1) ... Selecting previously unselected package regexxer. Preparing to unpack .../722-regexxer_0.10-5_arm64.deb ... Unpacking regexxer (0.10-5) ... Selecting previously unselected package remmina-common. Preparing to unpack .../723-remmina-common_1.4.25+dfsg-1_all.deb ... Unpacking remmina-common (1.4.25+dfsg-1) ... Selecting previously unselected package remmina. Preparing to unpack .../724-remmina_1.4.25+dfsg-1_arm64.deb ... Unpacking remmina (1.4.25+dfsg-1) ... Selecting previously unselected package remmina-plugin-rdp:arm64. Preparing to unpack .../725-remmina-plugin-rdp_1.4.25+dfsg-1_arm64.deb ... Unpacking remmina-plugin-rdp:arm64 (1.4.25+dfsg-1) ... Selecting previously unselected package remmina-plugin-vnc:arm64. Preparing to unpack .../726-remmina-plugin-vnc_1.4.25+dfsg-1_arm64.deb ... Unpacking remmina-plugin-vnc:arm64 (1.4.25+dfsg-1) ... Selecting previously unselected package slick-greeter. Preparing to unpack .../727-slick-greeter_1.5.6-1ubuntu1_arm64.deb ... Unpacking slick-greeter (1.5.6-1ubuntu1) ... Selecting previously unselected package ubuntu-advantage-desktop-daemon. Preparing to unpack .../728-ubuntu-advantage-desktop-daemon_1.10~22.04.1_arm64.deb ... Unpacking ubuntu-advantage-desktop-daemon (1.10~22.04.1) ... Selecting previously unselected package software-properties-gtk. Preparing to unpack .../729-software-properties-gtk_0.99.22.6_all.deb ... Unpacking software-properties-gtk (0.99.22.6) ... Selecting previously unselected package synaptic. Preparing to unpack .../730-synaptic_0.90.2build1_arm64.deb ... Unpacking synaptic (0.90.2build1) ... Selecting previously unselected package system-config-printer-common. Preparing to unpack .../731-system-config-printer-common_1.5.16-0ubuntu3_all.deb ... Unpacking system-config-printer-common (1.5.16-0ubuntu3) ... Selecting previously unselected package system-config-printer. Preparing to unpack .../732-system-config-printer_1.5.16-0ubuntu3_all.deb ... Unpacking system-config-printer (1.5.16-0ubuntu3) ... Selecting previously unselected package system-monitoring-center. Preparing to unpack .../733-system-monitoring-center_1.42.0_all.deb ... Unpacking system-monitoring-center (1.42.0) ... Selecting previously unselected package terminator. Preparing to unpack .../734-terminator_2.1.1-1_all.deb ... Unpacking terminator (2.1.1-1) ... Selecting previously unselected package thunar. Preparing to unpack .../735-thunar_4.16.10-1_arm64.deb ... Unpacking thunar (4.16.10-1) ... Selecting previously unselected package thunar-volman. Preparing to unpack .../736-thunar-volman_4.16.0-1_arm64.deb ... Unpacking thunar-volman (4.16.0-1) ... Selecting previously unselected package transmission-common. Preparing to unpack .../737-transmission-common_3.00-2ubuntu2_all.deb ... Unpacking transmission-common (3.00-2ubuntu2) ... Selecting previously unselected package transmission-gtk. Preparing to unpack .../738-transmission-gtk_3.00-2ubuntu2_arm64.deb ... Unpacking transmission-gtk (3.00-2ubuntu2) ... Selecting previously unselected package transmission. Preparing to unpack .../739-transmission_3.00-2ubuntu2_all.deb ... Unpacking transmission (3.00-2ubuntu2) ... Selecting previously unselected package transmission-remote-gtk. Preparing to unpack .../740-transmission-remote-gtk_1.4.1-5_arm64.deb ... Unpacking transmission-remote-gtk (1.4.1-5) ... Selecting previously unselected package update-notifier. Preparing to unpack .../741-update-notifier_3.192.54.5_arm64.deb ... Unpacking update-notifier (3.192.54.5) ... Selecting previously unselected package update-manager. Preparing to unpack .../742-update-manager_1%3a22.04.10_all.deb ... Unpacking update-manager (1:22.04.10) ... Selecting previously unselected package ubuntu-release-upgrader-gtk. Preparing to unpack .../743-ubuntu-release-upgrader-gtk_1%3a22.04.16_all.deb ... Unpacking ubuntu-release-upgrader-gtk (1:22.04.16) ... Selecting previously unselected package update-inetd. Preparing to unpack .../744-update-inetd_4.51_all.deb ... Unpacking update-inetd (4.51) ... Selecting previously unselected package upower. Preparing to unpack .../745-upower_0.99.17-1_arm64.deb ... Unpacking upower (0.99.17-1) ... Selecting previously unselected package viewnior. Preparing to unpack .../746-viewnior_1.6-1build3_arm64.deb ... Unpacking viewnior (1.6-1build3) ... Selecting previously unselected package vim-runtime. Preparing to unpack .../747-vim-runtime_2%3a8.2.3995-1ubuntu2.3_all.deb ... Adding 'diversion of /usr/share/vim/vim82/doc/help.txt to /usr/share/vim/vim82/doc/help.txt.vim-tiny by vim-runtime' Adding 'diversion of /usr/share/vim/vim82/doc/tags to /usr/share/vim/vim82/doc/tags.vim-tiny by vim-runtime' Unpacking vim-runtime (2:8.2.3995-1ubuntu2.3) ... Selecting previously unselected package vim. Preparing to unpack .../748-vim_2%3a8.2.3995-1ubuntu2.3_arm64.deb ... Unpacking vim (2:8.2.3995-1ubuntu2.3) ... Selecting previously unselected package x11-apps. Preparing to unpack .../749-x11-apps_7.7+8build2_arm64.deb ... Unpacking x11-apps (7.7+8build2) ... Selecting previously unselected package x11-utils. Preparing to unpack .../750-x11-utils_7.7+5build2_arm64.deb ... Unpacking x11-utils (7.7+5build2) ... Selecting previously unselected package x11-xserver-utils. Preparing to unpack .../751-x11-xserver-utils_7.7+9build1_arm64.deb ... Unpacking x11-xserver-utils (7.7+9build1) ... Selecting previously unselected package xapps-common. Preparing to unpack .../752-xapps-common_2.2.8-1_all.deb ... Unpacking xapps-common (2.2.8-1) ... Selecting previously unselected package xarchiver. Preparing to unpack .../753-xarchiver_1%3a0.5.4.17-3_arm64.deb ... Unpacking xarchiver (1:0.5.4.17-3) ... Selecting previously unselected package xbacklight. Preparing to unpack .../754-xbacklight_1.2.1-1build2_arm64.deb ... Unpacking xbacklight (1.2.1-1build2) ... Selecting previously unselected package xcursor-themes. Preparing to unpack .../755-xcursor-themes_1.0.6-0ubuntu1_all.deb ... Unpacking xcursor-themes (1.0.6-0ubuntu1) ... Selecting previously unselected package xdg-user-dirs-gtk. Preparing to unpack .../756-xdg-user-dirs-gtk_0.10-3build2_arm64.deb ... Unpacking xdg-user-dirs-gtk (0.10-3build2) ... Selecting previously unselected package xfce4-appfinder. Preparing to unpack .../757-xfce4-appfinder_4.16.1-1_arm64.deb ... Unpacking xfce4-appfinder (4.16.1-1) ... Selecting previously unselected package xfce4-panel. Preparing to unpack .../758-xfce4-panel_4.16.3-1_arm64.deb ... Unpacking xfce4-panel (4.16.3-1) ... Selecting previously unselected package xfce4-pulseaudio-plugin:arm64. Preparing to unpack .../759-xfce4-pulseaudio-plugin_0.4.3-1_arm64.deb ... Unpacking xfce4-pulseaudio-plugin:arm64 (0.4.3-1) ... Selecting previously unselected package xfce4-helpers. Preparing to unpack .../760-xfce4-helpers_4.16.2-1ubuntu2_arm64.deb ... Unpacking xfce4-helpers (4.16.2-1ubuntu2) ... Selecting previously unselected package xfce4-settings. Preparing to unpack .../761-xfce4-settings_4.16.2-1ubuntu2_arm64.deb ... Unpacking xfce4-settings (4.16.2-1ubuntu2) ... Selecting previously unselected package xfce4-session. Preparing to unpack .../762-xfce4-session_4.16.0-1ubuntu2_arm64.deb ... Unpacking xfce4-session (4.16.0-1ubuntu2) ... Selecting previously unselected package xfdesktop4-data. Preparing to unpack .../763-xfdesktop4-data_4.16.0-1_all.deb ... Unpacking xfdesktop4-data (4.16.0-1) ... Selecting previously unselected package xfdesktop4. Preparing to unpack .../764-xfdesktop4_4.16.0-1_arm64.deb ... Unpacking xfdesktop4 (4.16.0-1) ... Selecting previously unselected package xfwm4. Preparing to unpack .../765-xfwm4_4.16.1-1_arm64.deb ... Unpacking xfwm4 (4.16.1-1) ... Selecting previously unselected package xfce4. Preparing to unpack .../766-xfce4_4.16_all.deb ... Unpacking xfce4 (4.16) ... Selecting previously unselected package xfce4-power-manager-data. Preparing to unpack .../767-xfce4-power-manager-data_4.16.0-1_all.deb ... Unpacking xfce4-power-manager-data (4.16.0-1) ... Selecting previously unselected package xfce4-power-manager. Preparing to unpack .../768-xfce4-power-manager_4.16.0-1_arm64.deb ... Unpacking xfce4-power-manager (4.16.0-1) ... Selecting previously unselected package xfce4-screenshooter. Preparing to unpack .../769-xfce4-screenshooter_1.9.9-1_arm64.deb ... Unpacking xfce4-screenshooter (1.9.9-1) ... Selecting previously unselected package xfce4-terminal. Preparing to unpack .../770-xfce4-terminal_0.8.10-1_arm64.deb ... Unpacking xfce4-terminal (0.8.10-1) ... Selecting previously unselected package xfonts-encodings. Preparing to unpack .../771-xfonts-encodings_1%3a1.0.5-0ubuntu2_all.deb ... Unpacking xfonts-encodings (1:1.0.5-0ubuntu2) ... Selecting previously unselected package xfonts-utils. Preparing to unpack .../772-xfonts-utils_1%3a7.7+6build2_arm64.deb ... Unpacking xfonts-utils (1:7.7+6build2) ... Selecting previously unselected package xfonts-100dpi. Preparing to unpack .../773-xfonts-100dpi_1%3a1.0.4+nmu1.1_all.deb ... Unpacking xfonts-100dpi (1:1.0.4+nmu1.1) ... Selecting previously unselected package xfonts-75dpi. Preparing to unpack .../774-xfonts-75dpi_1%3a1.0.4+nmu1.1_all.deb ... Unpacking xfonts-75dpi (1:1.0.4+nmu1.1) ... Selecting previously unselected package xfonts-base. Preparing to unpack .../775-xfonts-base_1%3a1.0.5_all.deb ... Unpacking xfonts-base (1:1.0.5) ... Selecting previously unselected package xfonts-scalable. Preparing to unpack .../776-xfonts-scalable_1%3a1.0.3-1.2ubuntu1_all.deb ... Unpacking xfonts-scalable (1:1.0.3-1.2ubuntu1) ... Selecting previously unselected package xorg-docs-core. Preparing to unpack .../777-xorg-docs-core_1%3a1.7.1-1.2_all.deb ... Unpacking xorg-docs-core (1:1.7.1-1.2) ... Selecting previously unselected package xscreensaver-data. Preparing to unpack .../778-xscreensaver-data_5.45+dfsg1-2ubuntu1_arm64.deb ... Unpacking xscreensaver-data (5.45+dfsg1-2ubuntu1) ... Selecting previously unselected package xscreensaver. Preparing to unpack .../779-xscreensaver_5.45+dfsg1-2ubuntu1_arm64.deb ... Unpacking xscreensaver (5.45+dfsg1-2ubuntu1) ... Selecting previously unselected package xsensors. Preparing to unpack .../780-xsensors_0.70-5build1_arm64.deb ... Unpacking xsensors (0.70-5build1) ... Selecting previously unselected package xserver-common. Preparing to unpack .../781-xserver-common_2%3a21.1.3-2ubuntu2.7_all.deb ... Unpacking xserver-common (2:21.1.3-2ubuntu2.7) ... Selecting previously unselected package xserver-xorg-core. Preparing to unpack .../782-xserver-xorg-core_2%3a21.1.3-2ubuntu2.7_arm64.deb ... Unpacking xserver-xorg-core (2:21.1.3-2ubuntu2.7) ... Selecting previously unselected package xserver-xorg-input-libinput. Preparing to unpack .../783-xserver-xorg-input-libinput_1.2.1-1_arm64.deb ... Unpacking xserver-xorg-input-libinput (1.2.1-1) ... Selecting previously unselected package xserver-xorg-input-all. Preparing to unpack .../784-xserver-xorg-input-all_1%3a7.7+23ubuntu2_arm64.deb ... Unpacking xserver-xorg-input-all (1:7.7+23ubuntu2) ... Selecting previously unselected package xserver-xorg. Preparing to unpack .../785-xserver-xorg_1%3a7.7+23ubuntu2_arm64.deb ... Unpacking xserver-xorg (1:7.7+23ubuntu2) ... Selecting previously unselected package xserver-xorg-video-fbdev. Preparing to unpack .../786-xserver-xorg-video-fbdev_1%3a0.5.0-2build1_arm64.deb ... Unpacking xserver-xorg-video-fbdev (1:0.5.0-2build1) ... Selecting previously unselected package xwallpaper. Preparing to unpack .../787-xwallpaper_0.7.3-1_arm64.deb ... Unpacking xwallpaper (0.7.3-1) ... Selecting previously unselected package brltty. Preparing to unpack .../788-brltty_6.4-4ubuntu3_arm64.deb ... Unpacking brltty (6.4-4ubuntu3) ... Selecting previously unselected package brltty-x11. Preparing to unpack .../789-brltty-x11_6.4-4ubuntu3_arm64.deb ... Unpacking brltty-x11 (6.4-4ubuntu3) ... Selecting previously unselected package cups-bsd. Preparing to unpack .../790-cups-bsd_2.4.1op1-1ubuntu4.1_arm64.deb ... Unpacking cups-bsd (2.4.1op1-1ubuntu4.1) ... Selecting previously unselected package indicator-printers. Preparing to unpack .../791-indicator-printers_0.1.7+17.10.20171101-0ubuntu3_arm64.deb ... Unpacking indicator-printers (0.1.7+17.10.20171101-0ubuntu3) ... Selecting previously unselected package inputattach. Preparing to unpack .../792-inputattach_1%3a1.7.1-1build2_arm64.deb ... Unpacking inputattach (1:1.7.1-1build2) ... Selecting previously unselected package inxi. Preparing to unpack .../793-inxi_3.3.13-1-1_all.deb ... Unpacking inxi (3.3.13-1-1) ... Selecting previously unselected package libgsettings-qt1:arm64. Preparing to unpack .../794-libgsettings-qt1_0.2-4_arm64.deb ... Unpacking libgsettings-qt1:arm64 (0.2-4) ... Selecting previously unselected package libsbc1:arm64. Preparing to unpack .../795-libsbc1_1.5-3build2_arm64.deb ... Unpacking libsbc1:arm64 (1.5-3build2) ... Selecting previously unselected package lm-sensors. Preparing to unpack .../796-lm-sensors_1%3a3.6.0-7ubuntu1_arm64.deb ... Unpacking lm-sensors (1:3.6.0-7ubuntu1) ... Selecting previously unselected package lxtask. Preparing to unpack .../797-lxtask_0.1.10-1_arm64.deb ... Unpacking lxtask (0.1.10-1) ... Selecting previously unselected package mesa-utils. Preparing to unpack .../798-mesa-utils_8.4.0-1ubuntu1_arm64.deb ... Unpacking mesa-utils (8.4.0-1ubuntu1) ... Selecting previously unselected package pasystray. Preparing to unpack .../799-pasystray_0.7.1-1_arm64.deb ... Unpacking pasystray (0.7.1-1) ... Selecting previously unselected package pulseaudio-module-bluetooth. Preparing to unpack .../800-pulseaudio-module-bluetooth_1%3a15.99.1+dfsg1-1ubuntu2_arm64.deb ... Unpacking pulseaudio-module-bluetooth (1:15.99.1+dfsg1-1ubuntu2) ... Selecting previously unselected package redshift. Preparing to unpack .../801-redshift_1.12-4.2ubuntu1_arm64.deb ... Unpacking redshift (1.12-4.2ubuntu1) ... Setting up cups-ipp-utils (2.4.1op1-1ubuntu4.1) ... Setting up libgme0:arm64 (0.6.3-2) ... Setting up fonts-ubuntu-console (0.83-6ubuntu1) ... Setting up libssh-gcrypt-4:arm64 (0.9.6-2build1) ... Setting up libpwquality-common (1.4.4-1build2) ... Setting up libotf1:arm64 (0.9.16-3build1) ... Setting up bubblewrap (0.6.1-1) ... Setting up libcairo-script-interpreter2:arm64 (1.16.0-5ubuntu2) ... Setting up liblmdb0:arm64 (0.9.24-1build2) ... Setting up xsensors (0.70-5build1) ... Setting up libtext-iconv-perl (1.7-7build3) ... Setting up libsrt1.4-gnutls:arm64 (1.4.4-4) ... Setting up libxcb-dri3-0:arm64 (1.14-3ubuntu3) ... Setting up liblcms2-2:arm64 (2.12~rc1-2build2) ... Setting up distro-info (1.1build1) ... Setting up libmozjs-91-0:arm64 (91.10.0-0ubuntu1) ... Setting up libudfread0:arm64 (1.1.2-1) ... Setting up libglibmm-2.4-1v5:arm64 (2.66.2-2) ... Setting up gtk2-engines-murrine:arm64 (0.98.2-3build2) ... Setting up libqpdf28:arm64 (10.6.3-1) ... Setting up libcdparanoia0:arm64 (3.10.2+debian-14build2) ... Setting up libwayland-server0:arm64 (1.20.0-1ubuntu0.1) ... Setting up libpaper1:arm64 (1.1.28build2) ... Creating config file /etc/papersize with new version Setting up glmark2-data (2021.02-0ubuntu1) ... Setting up libtemplate-glib-common (3.34.1-1) ... Setting up libaom3:arm64 (3.3.0-1) ... Setting up libx11-xcb1:arm64 (2:1.7.5-1) ... Setting up libpciaccess0:arm64 (0.16-3) ... Setting up gir1.2-gstreamer-1.0:arm64 (1.20.3-0ubuntu1) ... Setting up libxcb-res0:arm64 (1.14-3ubuntu3) ... Setting up libpython3.10:arm64 (3.10.6-1~22.04.2) ... Setting up session-migration (0.3.6) ... Created symlink /etc/systemd/user/graphical-session-pre.target.wants/session-migration.service → /usr/lib/systemd/user/session-migration.service. Setting up librabbitmq4:arm64 (0.10.0-1ubuntu2) ... Setting up libre2-9:arm64 (20220201+dfsg-1) ... Setting up libdouble-conversion3:arm64 (3.1.7-4) ... Setting up libraw1394-11:arm64 (2.1.2-2build2) ... Setting up libsbc1:arm64 (1.5-3build2) ... Setting up libxft2:arm64 (2.3.4-1) ... Setting up libproxy1v5:arm64 (0.4.17-2) ... Setting up libdrm-nouveau2:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Setting up gir1.2-freedesktop:arm64 (1.72.0-1) ... Setting up libtag1v5-vanilla:arm64 (1.11.1+dfsg.1-3ubuntu3) ... Setting up libharfbuzz-icu0:arm64 (2.7.4-1ubuntu3.1) ... Setting up fonts-mathjax (2.7.9+dfsg-1) ... Setting up libcodec2-1.0:arm64 (1.0.1-3) ... Setting up libsodium23:arm64 (1.0.18-1build2) ... Setting up libmpg123-0:arm64 (1.29.3-1build1) ... Setting up libxcb-xfixes0:arm64 (1.14-3ubuntu3) ... Setting up libogg0:arm64 (1.3.5-0ubuntu3) ... Setting up python3-cairo:arm64 (1.20.1-3build1) ... Setting up desktop-file-utils (0.26-1ubuntu3) ... Setting up libportal1:arm64 (0.6-2) ... Setting up xfdesktop4-data (4.16.0-1) ... Setting up libgdk-pixbuf-xlib-2.0-0:arm64 (2.40.2-2build4) ... Setting up chromium-codecs-ffmpeg-extra (1:107.0.5304.62-0ubuntu1~ppa1~22.04.1) ... Setting up libspeex1:arm64 (1.2~rc1.2-1.1ubuntu3) ... Setting up libshine3:arm64 (3.1.1-2) ... Setting up libxpm4:arm64 (1:3.5.12-1ubuntu0.22.04.1) ... Setting up libpangoxft-1.0-0:arm64 (1.50.6+ds-2ubuntu1) ... Setting up libplist3:arm64 (2.2.0-6build2) ... Setting up libqt5webengine-data (5.15.9+dfsg-1) ... Setting up geany-common (1.38-1) ... Setting up libjs-mathjax (2.7.9+dfsg-1) ... Setting up libwmflite-0.2-7:arm64 (0.2.12-5ubuntu1) ... Setting up libtwolame0:arm64 (0.4.0-2build2) ... Setting up libxcb-xinput0:arm64 (1.14-3ubuntu3) ... Setting up libwoff1:arm64 (1.0.2-1build4) ... Setting up libvala-0.56-0:arm64 (0.56.0-1) ... Setting up libvte-2.91-common (0.68.0-1) ... Setting up cups-server-common (2.4.1op1-1ubuntu4.1) ... Setting up gir1.2-gdkpixbuf-2.0:arm64 (2.42.8+dfsg-1ubuntu0.2) ... Setting up libhyphen0:arm64 (2.8.8-7build2) ... Setting up libfontembed1:arm64 (1.28.15-0ubuntu1) ... Setting up xdg-user-dirs (0.17-2ubuntu4) ... Setting up libexo-common (4.16.3-1) ... Setting up libgspell-1-common (1.9.1-4) ... Setting up libgbm1:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Setting up libgsm1:arm64 (1.0.19-1) ... Setting up exuberant-ctags (1:5.9~svn20110310-16ubuntu0.22.04.1) ... update-alternatives: using /usr/bin/ctags-exuberant to provide /usr/bin/ctags (ctags) in auto mode update-alternatives: using /usr/bin/ctags-exuberant to provide /usr/bin/etags (etags) in auto mode Setting up python3-colorama (0.4.4-1) ... Setting up libminizip1:arm64 (1.1-8build1) ... Setting up anacron (2.3-31ubuntu2) ... Created symlink /etc/systemd/system/multi-user.target.wants/anacron.service → /lib/systemd/system/anacron.service. Created symlink /etc/systemd/system/timers.target.wants/anacron.timer → /lib/systemd/system/anacron.timer. Setting up evince-common (42.3-0ubuntu3) ... Setting up libvisual-0.4-0:arm64 (0.4.0-17build2) ... Setting up libarchive13:arm64 (3.6.0-1ubuntu1) ... Setting up libsoxr0:arm64 (0.1.3-4build2) ... Setting up gir1.2-atk-1.0:arm64 (2.36.0-3build1) ... Setting up python3-problem-report (2.20.11-0ubuntu82.3) ... Setting up libaspell15:arm64 (0.60.8-4build1) ... Setting up libdrm-radeon1:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Setting up libglvnd0:arm64 (1.4.0-1) ... Setting up libwnck-3-common (40.1-1) ... Setting up libsnmp-base (5.9.1+dfsg-1ubuntu2.5) ... Setting up libtdb1:arm64 (1.4.5-2build1) ... Setting up libpgm-5.3-0:arm64 (5.3.128~dfsg-2) ... Setting up libgusb2:arm64 (0.3.10-1) ... Setting up libhtml-tagset-perl (3.20-4) ... Setting up libijs-0.35:arm64 (0.35-15build2) ... Setting up libu2f-udev (1.1.10-3build2) ... Setting up cups-common (2.4.1op1-1ubuntu4.1) ... Setting up remmina-common (1.4.25+dfsg-1) ... Setting up libxcb-glx0:arm64 (1.14-3ubuntu3) ... Setting up libwebpdemux2:arm64 (1.2.2-2) ... Setting up bluez-tools (2.0~20170911.0.7cb788c-4) ... Setting up libdbusmenu-glib4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Setting up fonts-noto-cjk (1:20220127+repack1-1) ... Setting up python3-debconf (1.5.79ubuntu1) ... Setting up liblwp-mediatypes-perl (6.04-1) ... Setting up libxfce4util-common (4.16.0-1) ... Setting up libibus-1.0-5:arm64 (1.5.26-4) ... Setting up libnorm1:arm64 (1.5.9+dfsg-2) ... Setting up libgdata-common (0.18.1-2build1) ... Setting up libxcb-keysyms1:arm64 (0.4.0-1build3) ... Setting up libnatpmp1:arm64 (20150609-7.1build2) ... Setting up libxcb-shape0:arm64 (1.14-3ubuntu3) ... Setting up libgnome-autoar-0-0:arm64 (0.4.3-1) ... Setting up x11-common (1:7.7+23ubuntu2) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up libtry-tiny-perl (0.31-1) ... Setting up hplip-data (3.21.12+dfsg0-1) ... Setting up libjavascriptcoregtk-4.0-18:arm64 (2.38.5-0ubuntu0.22.04.1) ... Setting up libxxf86dga1:arm64 (2:1.1.5-0ubuntu3) ... Setting up m17n-db (1.8.0-3) ... Setting up libwebrtc-audio-processing1:arm64 (0.3.1-0ubuntu5) ... Setting up perl-openssl-defaults:arm64 (5build2) ... Setting up update-inetd (4.51) ... Setting up libfilezilla-common (0.36.0-2) ... Setting up libxpresent1:arm64 (1.0.0-2build1) ... Setting up libxcb-render-util0:arm64 (0.3.9-1build3) ... Setting up libencode-locale-perl (1.05-1.1) ... Setting up inxi (3.3.13-1-1) ... Setting up dconf-service (0.40.0-3) ... Setting up libept1.6.0:arm64 (1.2.1) ... Setting up libprotobuf23:arm64 (3.12.4-1ubuntu7.22.04.1) ... Setting up libpeas-common (1.32.0-1) ... Setting up profile-sync-daemon (6.34-1) ... Created symlink /etc/systemd/user/default.target.wants/psd-resync.service → /usr/lib/systemd/user/psd-resync.service. Created symlink /etc/systemd/user/default.target.wants/psd.service → /usr/lib/systemd/user/psd.service. Setting up libxcb-icccm4:arm64 (0.4.1-1.1build2) ... Setting up samba-common (2:4.15.13+dfsg-0ubuntu1) ... Creating config file /etc/samba/smb.conf with new version Setting up libatspi2.0-0:arm64 (2.44.0-3) ... Setting up gir1.2-javascriptcoregtk-4.0:arm64 (2.38.5-0ubuntu0.22.04.1) ... Setting up fonts-urw-base35 (20200910-1) ... Setting up libnfs13:arm64 (4.0.0-1build2) ... Setting up python3-click (8.0.3-1) ... Setting up python3-xdg (0.27-2) ... Setting up libjs-requirejs (2.3.6+ds-1) ... Setting up libcdio19:arm64 (2.1.0-3build1) ... Setting up libxvidcore4:arm64 (2:1.3.7-1) ... Setting up gir1.2-gdesktopenums-3.0:arm64 (42.0-1ubuntu1) ... Setting up libproxy1-plugin-networkmanager:arm64 (0.4.17-2) ... Setting up libwinpr2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Setting up libjs-modernizr (2.6.2+ds1-4) ... Setting up sshpass (1.09-1) ... Setting up libminiupnpc17:arm64 (2.2.3-1build1) ... Setting up gir1.2-harfbuzz-0.0:arm64 (2.7.4-1ubuntu3.1) ... Setting up libgpgme11:arm64 (1.16.0-1.2ubuntu4) ... Setting up openprinting-ppds (20220223-0ubuntu1) ... Setting up libcolord2:arm64 (1.4.6-1) ... Setting up python3-psutil (5.9.0-1build1) ... Setting up xxd (2:8.2.3995-1ubuntu2.3) ... Setting up cups-client (2.4.1op1-1ubuntu4.1) ... Adding group `lpadmin' (GID 118) ... Done. Setting up libpugixml1v5:arm64 (1.12.1-1) ... Setting up colord-data (1.4.6-1) ... Setting up gparted-common (1.3.1-1ubuntu1) ... Setting up xfce4-power-manager-data (4.16.0-1) ... Setting up libxcb-util1:arm64 (0.4.0-1build2) ... Setting up putty-tools (0.76-2) ... Setting up libxxf86vm1:arm64 (1:1.1.4-1build3) ... Setting up libextutils-depends-perl (0.8001-1) ... Setting up libflac8:arm64 (1.3.3-2ubuntu0.1) ... Setting up libsnappy1v5:arm64 (1.1.8-1build3) ... Setting up python3-apport (2.20.11-0ubuntu82.3) ... Setting up poppler-data (0.4.11-1) ... Setting up libgarcon-common (4.16.1-1) ... Setting up acl (2.3.1-1) ... Setting up libxcb-xkb1:arm64 (1.14-3ubuntu3) ... Setting up libxcb-image0:arm64 (0.4.0-2) ... Setting up libao-common (1.2.2+20180113-1.1ubuntu3) ... Setting up libqalculate-data (3.22.0-3build1) ... Setting up libxcb-present0:arm64 (1.14-3ubuntu3) ... Setting up libcairomm-1.0-1v5:arm64 (1.12.2-4build3) ... Setting up libtalloc2:arm64 (2.3.3-2build1) ... Setting up libexiv2-27:arm64 (0.27.5-3ubuntu1) ... Setting up gnome-desktop3-data (42.5-0ubuntu1) ... Setting up dmz-cursor-theme (0.4.5ubuntu1) ... update-alternatives: using /usr/share/icons/DMZ-White/cursor.theme to provide /usr/share/icons/default/index.theme (x-cursor-theme) in auto mode Setting up glmark2 (2021.02-0ubuntu1) ... Setting up gdisk (1.0.8-4build1) ... Setting up libatk-bridge2.0-0:arm64 (2.38.0-3) ... Setting up libvncclient1:arm64 (0.9.13+dfsg-3build2) ... Setting up libspeechd2:arm64 (0.11.1-1ubuntu2) ... Setting up libgtop2-common (2.40.0-2build3) ... Setting up python3-cups:arm64 (2.0.1-5build1) ... Setting up p11-kit-modules:arm64 (0.24.0-6build1) ... Setting up xorg-docs-core (1:1.7.1-1.2) ... Setting up bluez (5.64-0ubuntu1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of force-reload. Created symlink /etc/systemd/system/dbus-org.bluez.service → /lib/systemd/system/bluetooth.service. Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service → /lib/systemd/system/bluetooth.service. Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up libfontenc1:arm64 (1:1.1.4-1build3) ... Setting up gir1.2-pango-1.0:arm64 (1.50.6+ds-2ubuntu1) ... Setting up libsnmp40:arm64 (5.9.1+dfsg-1ubuntu2.5) ... Setting up libvala-0.56-dev:arm64 (0.56.0-1) ... Setting up libxcb-xinerama0:arm64 (1.14-3ubuntu3) ... Setting up python3-chardet (4.0.0-1) ... Setting up python3-configobj (5.0.6-5) ... Setting up numix-gtk-theme (2.6.7-6) ... Setting up vim-common (2:8.2.3995-1ubuntu2.3) ... Setting up libgles2:arm64 (1.4.0-1) ... Setting up libpwquality1:arm64 (1.4.4-1build2) ... Setting up liblouis-data (3.20.0-2ubuntu0.1) ... Setting up emacsen-common (3.0.4) ... Setting up libatasmart4:arm64 (0.19-5build2) ... Setting up libtevent0:arm64 (0.11.0-1build1) ... Setting up inputattach (1:1.7.1-1build2) ... Setting up libva2:arm64 (2.14.0-1) ... Setting up libwmf-0.2-7:arm64 (0.2.12-5ubuntu1) ... Setting up python3-certifi (2020.6.20-1) ... Setting up libmbedcrypto7:arm64 (2.28.0-1build1) ... Setting up libblockdev-utils2:arm64 (2.26-1) ... Setting up libepoxy0:arm64 (1.5.10-1) ... Setting up libnspr4:arm64 (2:4.32-3build1) ... Setting up libspa-0.2-modules:arm64 (0.3.48-1ubuntu3) ... Setting up ssl-cert (1.1.2) ... Setting up libxcb-sync1:arm64 (1.14-3ubuntu3) ... Setting up libjbig2dec0:arm64 (0.19-3build2) ... Setting up gnome-bluetooth-3-common (42.0-5) ... Setting up libdbus-glib-1-2:arm64 (0.112-2build1) ... Setting up libnotify4:arm64 (0.7.9-3ubuntu5.22.04.1) ... Setting up libqalculate22:arm64 (3.22.0-3build1) ... Setting up libraqm0:arm64 (0.7.0-4ubuntu1) ... Setting up libx264-163:arm64 (2:0.163.3060+git5db6aa6-2build1) ... Setting up python3-debian (0.1.43ubuntu1) ... Setting up xfonts-encodings (1:1.0.5-0ubuntu2) ... Setting up libmtp-common (1.1.19-1build1) ... Setting up libpipewire-0.3-0:arm64 (0.3.48-1ubuntu3) ... Setting up libopus0:arm64 (1.3.1-0.1build2) ... Setting up python3-reportlab-accel:arm64 (3.6.8-1) ... Setting up filezilla-common (3.58.0-1) ... Setting up libexif12:arm64 (0.6.24-1build1) ... Setting up libimagequant0:arm64 (2.17.0-1) ... Setting up libgd3:arm64 (2.3.0-2ubuntu2) ... Setting up python3-xapian (1.4.18-2build3) ... Setting up libxv1:arm64 (2:1.0.11-1build2) ... Setting up gtk2-engines-pixbuf:arm64 (2.24.33-2ubuntu2) ... Setting up libvorbis0a:arm64 (1.3.7-1build2) ... Setting up python3-idna (3.3-1) ... Setting up libidn12:arm64 (1.38-4build1) ... Setting up libevent-2.1-7:arm64 (2.1.12-stable-1build3) ... Setting up libio-html-perl (1.004-2) ... Setting up liborc-0.4-0:arm64 (1:0.4.32-2) ... Setting up gstreamer1.0-tools (1.20.3-0ubuntu1) ... Setting up network-manager-ssh (1.2.11-1) ... Setting up usb.ids (2022.04.02-1) ... Setting up gh (2.23.0) ... Setting up libabsl20210324:arm64 (0~20210324.2-2) ... Setting up numix-icon-theme (0~20211031-1) ... Setting up apt-xapian-index (0.51ubuntu1) ... Setting up libqt5core5a:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up libpangomm-1.4-1v5:arm64 (2.46.2-1) ... Setting up libgc1:arm64 (1:8.0.6-1.1build1) ... Setting up libltdl7:arm64 (2.4.6-15build2) ... Setting up libglapi-mesa:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Setting up libkpathsea6:arm64 (2021.20210626.59705-1build1) ... Setting up libmtdev1:arm64 (1.1.6-1build4) ... Setting up python3-urllib3 (1.26.5-1~exp1) ... Setting up libsoup2.4-common (2.74.2-3) ... Setting up lm-sensors (1:3.6.0-7ubuntu1) ... Created symlink /etc/systemd/system/multi-user.target.wants/lm-sensors.service → /lib/systemd/system/lm-sensors.service. Setting up libtimedate-perl (2.3300-2) ... Setting up libnotify-bin (0.7.9-3ubuntu5.22.04.1) ... Setting up libxcb-dri2-0:arm64 (1.14-3ubuntu3) ... Setting up libgif7:arm64 (5.1.9-2build2) ... Setting up libllvm14:arm64 (1:14.0.0-1ubuntu1) ... Setting up gstreamer1.0-packagekit (1.2.5-2ubuntu2) ... update-alternatives: using /usr/libexec/pk-gstreamer-install to provide /usr/bin/gstreamer-codec-install (gstreamer-codec-install) in auto mode Setting up libgail18:arm64 (2.24.33-2ubuntu2) ... Setting up libao4:arm64 (1.2.2+20180113-1.1ubuntu3) ... Setting up xdg-dbus-proxy (0.1.3-1) ... Setting up libnuma1:arm64 (2.0.14-3ubuntu2) ... Setting up libjack-jackd2-0:arm64 (1.9.20~dfsg-1) ... Setting up libgladeui-common (3.38.2-7) ... Setting up libwmf-0.2-7-gtk (0.2.12-5ubuntu1) ... Setting up libtag1v5:arm64 (1.11.1+dfsg.1-3ubuntu3) ... Setting up gir1.2-notify-0.7:arm64 (0.7.9-3ubuntu5.22.04.1) ... Setting up libjs-highlight.js (9.18.5+dfsg1-1) ... Setting up indicator-common (16.10.0+18.04.20180321.1-0ubuntu5) ... Setting up libparted-fs-resize0:arm64 (3.4-2build1) ... Setting up sound-theme-freedesktop (0.8-2ubuntu1) ... Setting up qalc (3.22.0-3build1) ... Setting up libva-drm2:arm64 (2.14.0-1) ... Setting up libdv4:arm64 (1.0.0-14build1) ... Setting up ocl-icd-libopencl1:arm64 (2.2.14-3) ... Setting up libasyncns0:arm64 (0.8-6build2) ... Setting up libxshmfence1:arm64 (1.3-1build4) ... Setting up libusbmuxd6:arm64 (2.0.2-3build2) ... Setting up gir1.2-polkit-1.0 (0.105-33) ... Setting up libvdpau1:arm64 (1.4-3build2) ... Setting up dbus-x11 (1.12.20-2ubuntu4.1) ... Setting up libqt5dbus5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up libwavpack1:arm64 (5.4.0-1build2) ... Setting up libxcb-randr0:arm64 (1.14-3ubuntu3) ... Setting up libdazzle-common (3.44.0-1) ... Setting up libllvm15:arm64 (1:15.0.6-3~ubuntu0.22.04.2) ... Setting up libtheora0:arm64 (1.1.1+dfsg.1-15ubuntu4) ... Setting up libgtksourceview-3.0-common (3.24.11-2build1) ... Setting up libspeexdsp1:arm64 (1.2~rc1.2-1.1ubuntu3) ... Setting up libv4lconvert0:arm64 (1.22.1-2build1) ... Setting up libxslt1.1:arm64 (1.1.34-4ubuntu0.22.04.1) ... Setting up vpnc-scripts (0.1~git20210402-1) ... Setting up libgeoip1:arm64 (1.6.12-8) ... Setting up libxcvt0:arm64 (0.1.1-3) ... Setting up libblockdev-part-err2:arm64 (2.26-1) ... Setting up libgtop-2.0-11:arm64 (2.40.0-2build3) ... Setting up libmd4c0:arm64 (0.4.8-1) ... Setting up libupower-glib3:arm64 (0.99.17-1) ... Setting up libdotconf0:arm64 (1.3-0.3fakesync1build2) ... Setting up gtk2-engines:arm64 (1:2.20.2-5build2) ... Setting up libical3:arm64 (3.0.14-1build1) ... Setting up libopenjp2-7:arm64 (2.4.0-6) ... Setting up libmtp9:arm64 (1.1.19-1build1) ... Setting up libgxps2:arm64 (0.3.2-2) ... Setting up python3-dateutil (2.8.1-6) ... Setting up libavahi-glib1:arm64 (0.8-5ubuntu5) ... Setting up libwxbase3.0-0v5:arm64 (3.0.5.1+dfsg-4) ... Setting up libjson-glib-1.0-common (1.6.6-1build1) ... Setting up libcairo-perl:arm64 (1.109-2build1) ... Setting up libvpx7:arm64 (1.11.0-2ubuntu2) ... Setting up libcairo-gobject2:arm64 (1.16.0-5ubuntu2) ... Setting up libtemplate-glib-1.0-0:arm64 (3.34.1-1) ... Setting up libxfce4util7:arm64 (4.16.0-1) ... Setting up libbrlapi0.8:arm64 (6.4-4ubuntu3) ... Setting up libwayland-egl1:arm64 (1.20.0-1ubuntu0.1) ... Setting up ubuntu-advantage-tools (27.13.6~22.04.1) ... Created symlink /etc/systemd/system/multi-user.target.wants/ua-reboot-cmds.service → /lib/systemd/system/ua-reboot-cmds.service. Created symlink /etc/systemd/system/timers.target.wants/ua-timer.timer → /lib/systemd/system/ua-timer.timer. Created symlink /etc/systemd/system/multi-user.target.wants/ubuntu-advantage.service → /lib/systemd/system/ubuntu-advantage.service. Setting up libxkbfile1:arm64 (1:1.1.0-1build3) ... Setting up libgphoto2-port12:arm64 (2.5.27-1build2) ... Setting up libdjvulibre-text (3.5.28-2build2) ... Setting up libatkmm-1.6-1v5:arm64 (2.28.2-1build1) ... Setting up ubuntu-wallpapers-jammy (22.04.4-0ubuntu1) ... Setting up policykit-desktop-privileges (0.21) ... Setting up fbi (2.10-4ubuntu1) ... Setting up libjs-jquery (3.6.0+dfsg+~3.5.13-1) ... Setting up dmidecode (3.3-3ubuntu0.1) ... Setting up libxfce4ui-common (4.16.1-1) ... Setting up libhunspell-1.7-0:arm64 (1.7.0-4build1) ... Setting up libaccountsservice0:arm64 (22.07.5-2ubuntu1.3) ... Setting up p11-kit (0.24.0-6build1) ... Setting up glib-networking-common (2.72.0-1) ... Setting up xfconf (4.16.0-2) ... Setting up gir1.2-nm-1.0:arm64 (1.36.6-0ubuntu2) ... Setting up libsane-common (1.1.1-5) ... Setting up vim-runtime (2:8.2.3995-1ubuntu2.3) ... Setting up libdav1d5:arm64 (0.9.2-1) ... Setting up libgck-1-0:arm64 (3.40.0-4) ... Setting up gir1.2-template-1.0:arm64 (3.34.1-1) ... Setting up libieee1284-3:arm64 (0.2.11-14build2) ... Setting up emacs-common (1:27.1+1-3ubuntu5) ... Setting up libbluray2:arm64 (1:1.3.1-1) ... Setting up python3-xkit (0.5.0ubuntu5) ... Setting up lxtask (0.1.10-1) ... Setting up llvm-14-linker-tools (1:14.0.0-1ubuntu1) ... Setting up libimobiledevice6:arm64 (1.3.0-6build3) ... Setting up transmission-common (3.00-2ubuntu2) ... Setting up libldb2:arm64 (2:2.4.4-0ubuntu0.22.04.1) ... Setting up libva-x11-2:arm64 (2.14.0-1) ... Setting up python3-gi-cairo (3.42.1-0ubuntu1) ... Setting up libwebpmux3:arm64 (1.2.2-2) ... Setting up printer-driver-all (0.20210903) ... Setting up gvfs-common (1.48.2-0ubuntu1) ... Setting up gir1.2-ibus-1.0:arm64 (1.5.26-4) ... Setting up mailcap (3.70+nmu1ubuntu1) ... Setting up libcmark0.30.2:arm64 (0.30.2-5) ... Setting up libhpmud0:arm64 (3.21.12+dfsg0-1) ... Setting up libxfont2:arm64 (1:2.0.5-1build1) ... Setting up thunar-data (4.16.10-1) ... Setting up libgcr-base-3-1:arm64 (3.40.0-4) ... Setting up libevdev2:arm64 (1.12.1+dfsg-1) ... Setting up libgtksourceview-4-common (4.8.3-1) ... Setting up libpam-gnome-keyring:arm64 (40.0-3ubuntu3) ... Setting up xdg-utils (1.1.3-4.1ubuntu3~22.04.1) ... update-alternatives: using /usr/bin/xdg-open to provide /usr/bin/open (open) in auto mode Setting up liburi-perl (5.10-1) ... Setting up foomatic-db-compressed-ppds (20220223-0ubuntu1) ... Setting up libxmuu1:arm64 (2:1.1.3-3) ... Setting up libcupsfilters1:arm64 (1.28.15-0ubuntu1) ... Setting up libgudev-1.0-0:arm64 (1:237-2build1) ... Setting up libzvbi-common (0.2.35-19) ... Setting up libsecret-common (0.20.5-2) ... Setting up xbacklight (1.2.1-1build2) ... Setting up libsane-hpaio:arm64 (3.21.12+dfsg0-1) ... Setting up p7zip (16.02+dfsg-8) ... Setting up libmp3lame0:arm64 (3.100-3build2) ... Setting up libgraphene-1.0-0:arm64 (1.10.8-1) ... Setting up libudisks2-0:arm64 (2.9.4-1ubuntu2) ... Setting up libhttp-parser2.9:arm64 (2.9.4-4) ... Setting up libvorbisenc2:arm64 (1.3.7-1build2) ... Setting up libsynctex2:arm64 (2021.20210626.59705-1build1) ... Setting up libmalcontent-0-0:arm64 (0.10.4-1) ... Setting up libxres1:arm64 (2:1.2.1-1) ... Setting up xfce4-helpers (4.16.2-1ubuntu2) ... Setting up laptop-detect (0.16) ... Setting up xcursor-themes (1.0.6-0ubuntu1) ... Setting up libaa1:arm64 (1.4p5-50build1) ... Setting up libiec61883-0:arm64 (1.2.0-4build3) ... Setting up python3-ptyprocess (0.7.0-3) ... Setting up libdrm-amdgpu1:arm64 (2.4.113-2~ubuntu0.22.04.1) ... Setting up libwacom-common (2.2.0-1) ... Setting up libatk-adaptor:arm64 (2.38.0-3) ... Setting up libstartup-notification0:arm64 (0.12-6build2) ... Setting up lightdm (1.30.0-0ubuntu5) ... Adding group `lightdm' (GID 121) ... Done. Adding system user `lightdm' (UID 112) ... Adding new user `lightdm' (UID 112) with group `lightdm' ... Creating home directory `/var/lib/lightdm' ... usermod: no changes usermod: no changes Adding group `nopasswdlogin' (GID 122) ... Done. Setting up libxkbcommon0:arm64 (1.4.0-1) ... Setting up libwayland-client0:arm64 (1.20.0-1ubuntu0.1) ... Setting up libnet-ssleay-perl:arm64 (1.92-1build2) ... Setting up gir1.2-graphene-1.0:arm64 (1.10.8-1) ... Setting up libgs9-common (9.55.0~dfsg1-0ubuntu5.1) ... Setting up libavc1394-0:arm64 (0.5.4-5build2) ... Setting up liblouis20:arm64 (3.20.0-2ubuntu0.1) ... Setting up viewnior (1.6-1build3) ... Setting up glib-networking-services (2.72.0-1) ... Setting up libzvbi0:arm64 (0.2.35-19) ... Setting up libice6:arm64 (2:1.0.10-1build2) ... Setting up libhttp-date-perl (6.05-1) ... Setting up libxfconf-0-3:arm64 (4.16.0-2) ... Setting up cups-ppdc (2.4.1op1-1ubuntu4.1) ... Setting up libdbusmenu-gtk3-4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Setting up libglib-perl:arm64 (3:1.329.3-2build1) ... Setting up vim (2:8.2.3995-1ubuntu2.3) ... update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vim (vim) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vimdiff (vimdiff) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/rvim (rvim) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/rview (rview) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vi (vi) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/view (view) in auto mode update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/ex (ex) in auto mode Setting up libfile-listing-perl (6.14-1) ... Setting up libzmq5:arm64 (4.3.4-2) ... Setting up mime-support (3.66) ... Setting up libgjs0g:arm64 (1.72.2-0ubuntu1) ... Setting up libblockdev-swap2:arm64 (2.26-1) ... Setting up libgs9:arm64 (9.55.0~dfsg1-0ubuntu5.1) ... Setting up libmbedx509-1:arm64 (2.28.0-1build1) ... Setting up gdebi-core (0.9.5.7+nmu6) ... Setting up ubuntu-drivers-common (1:0.9.6.1) ... Setting up libmbedtls14:arm64 (2.28.0-1build1) ... Setting up dconf-gsettings-backend:arm64 (0.40.0-3) ... Setting up xwallpaper (0.7.3-1) ... Setting up libgdm1 (42.0-1ubuntu7) ... Setting up dictionaries-common (1.28.14) ... Setting up python3-speechd (0.11.1-1ubuntu2) ... Setting up libgail-common:arm64 (2.24.33-2ubuntu2) ... Setting up xapps-common (2.2.8-1) ... Setting up libfilezilla24:arm64 (0.36.0-2) ... Setting up python3-talloc:arm64 (2.3.3-2build1) ... Setting up cups-bsd (2.4.1op1-1ubuntu4.1) ... Setting up libwacom9:arm64 (2.2.0-1) ... Setting up libcdio-cdda2:arm64 (10.2+2.0.0-1build3) ... Setting up libgit2-1.1:arm64 (1.1.0+dfsg.1-4.1build1) ... Setting up libxtst6:arm64 (2:1.2.3-1build4) ... Setting up libcdio-paranoia2:arm64 (10.2+2.0.0-1build3) ... Setting up libfreerdp2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Setting up libmanette-0.2-0:arm64 (0.2.6-3build1) ... Setting up libwmf0.2-7-gtk:arm64 (0.2.12-5ubuntu1) ... Setting up libqt5positioning5:arm64 (5.15.3+dfsg-3) ... Setting up libgl1-mesa-dri:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Setting up libdjvulibre21:arm64 (3.5.28-2build2) ... Setting up upower (0.99.17-1) ... Setting up vpnc (0.5.3+git20210125-1) ... Setting up libgnome-bluetooth-3.0-13:arm64 (42.0-5) ... Setting up redshift (1.12-4.2ubuntu1) ... Setting up libnet-http-perl (6.22-1) ... Setting up libclang1-14 (1:14.0.0-1ubuntu1) ... Setting up gnome-shell-common (42.5-0ubuntu1) ... update-alternatives: using /usr/share/gnome-shell/gnome-shell-theme.gresource to provide /usr/share/gnome-shell/gdm-theme.gresource (gdm-theme.gresource) in auto mode Setting up libcolorhug2:arm64 (1.4.6-1) ... Setting up libspectre1:arm64 (0.2.10-1) ... Setting up libblockdev-loop2:arm64 (2.26-1) ... Setting up libgstreamer-plugins-base1.0-0:arm64 (1.20.1-1) ... Setting up libobjc4:arm64 (12.1.0-2ubuntu1~22.04) ... Setting up p7zip-full (16.02+dfsg-8) ... Setting up libnss3:arm64 (2:3.68.2-0ubuntu1.2) ... Setting up libblockdev2:arm64 (2.26-1) ... Setting up gir1.2-atspi-2.0:arm64 (2.44.0-3) ... Setting up libgsettings-qt1:arm64 (0.2-4) ... Setting up libblockdev-part2:arm64 (2.26-1) ... Setting up ghostscript (9.55.0~dfsg1-0ubuntu5.1) ... Setting up xfonts-utils (1:7.7+6build2) ... Setting up gir1.2-accountsservice-1.0:arm64 (22.07.5-2ubuntu1.3) ... Setting up devhelp-common (41.2-2) ... Setting up libwbclient0:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Setting up libqt5network5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up libavutil56:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Setting up bluez-obexd (5.64-0ubuntu1) ... Setting up libjson-glib-1.0-0:arm64 (1.6.6-1build1) ... Setting up libinput-bin (1.20.0-1ubuntu0.2) ... Setting up python3-cupshelpers (1.5.16-0ubuntu3) ... Setting up librsvg2-2:arm64 (2.52.5+dfsg-3) ... Setting up hwdata (0.357-1) ... Setting up libphonenumber8:arm64 (8.12.44-1) ... Setting up libv4l-0:arm64 (1.22.1-2build1) ... Setting up libpoppler118:arm64 (22.02.0-2ubuntu0.1) ... Setting up python3-pil:arm64 (9.0.1-1ubuntu0.1) ... Setting up libvorbisfile3:arm64 (1.3.7-1build2) ... Setting up mutter-common (42.5-0ubuntu1) ... Setting up libgphoto2-6:arm64 (2.5.27-1build2) ... Setting up xfonts-base (1:1.0.5) ... Setting up libsecret-1-0:arm64 (0.20.5-2) ... Setting up libgstreamer-plugins-good1.0-0:arm64 (1.20.3-0ubuntu1) ... Setting up libegl-mesa0:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Setting up gstreamer1.0-plugins-base:arm64 (1.20.1-1) ... Setting up gir1.2-gck-1:arm64 (3.40.0-4) ... Setting up python3-louis (3.20.0-2ubuntu0.1) ... Setting up libxkbregistry0:arm64 (1.4.0-1) ... Setting up libqt5qml5:arm64 (5.15.3+dfsg-1) ... Setting up python3-pexpect (4.8.0-2ubuntu1) ... Setting up python3-requests (2.25.1+dfsg-2) ... Setting up libxkbcommon-x11-0:arm64 (1.4.0-1) ... Setting up numix-icon-theme-circle (22.01.10-1) ... Setting up libshout3:arm64 (2.4.5-1build3) ... Setting up python3-brlapi:arm64 (6.4-4ubuntu3) ... Setting up python3-ldb (2:2.4.4-0ubuntu0.22.04.1) ... Setting up libclang-common-14-dev (1:14.0.0-1ubuntu1) ... Setting up libgarcon-1-0:arm64 (4.16.1-1) ... Setting up libclang-cpp14 (1:14.0.0-1ubuntu1) ... Setting up libnma-common (1.8.34-1ubuntu1) ... Setting up libqt5webchannel5:arm64 (5.15.3-1) ... Setting up libblockdev-fs2:arm64 (2.26-1) ... Setting up librsvg2-common:arm64 (2.52.5+dfsg-3) ... Setting up libx265-199:arm64 (3.5-2) ... Setting up python3-reportlab (3.6.8-1) ... Setting up brltty (6.4-4ubuntu3) ... update-initramfs: deferring update (trigger activated) Setting up libwww-robotrules-perl (6.02-1) ... Setting up libgtkmm-2.4-1v5:arm64 (1:2.24.5-4ubuntu3) ... Setting up libwayland-cursor0:arm64 (1.20.0-1ubuntu0.1) ... Setting up libhtml-parser-perl:arm64 (3.76-1build2) ... Setting up libegl1:arm64 (1.4.0-1) ... Setting up gir1.2-upowerglib-1.0:arm64 (0.99.17-1) ... Setting up hunspell-en-us (1:2020.12.07-2) ... Setting up ubuntu-wallpapers (22.04.4-0ubuntu1) ... Setting up emacs-bin-common (1:27.1+1-3ubuntu5) ... update-alternatives: using /usr/bin/ebrowse.emacs to provide /usr/bin/ebrowse (ebrowse) in auto mode update-alternatives: using /usr/bin/emacsclient.emacs to provide /usr/bin/emacsclient (emacsclient) in auto mode update-alternatives: using /usr/bin/etags.emacs to provide /usr/bin/etags (etags) in auto mode Setting up gir1.2-json-1.0:arm64 (1.6.6-1build1) ... Setting up gir1.2-gnomebluetooth-3.0:arm64 (42.0-5) ... Setting up libsndfile1:arm64 (1.0.31-2build1) ... Setting up poppler-utils (22.02.0-2ubuntu0.1) ... Setting up xfonts-75dpi (1:1.0.4+nmu1.1) ... Setting up libgtk-4-common (4.6.6+ds-0ubuntu1) ... Setting up gstreamer1.0-plugins-base-apps (1.20.1-1) ... Setting up libsysprof-4:arm64 (3.44.0-1) ... Setting up gir1.2-rsvg-2.0:arm64 (2.52.5+dfsg-3) ... Setting up libcamel-1.2-63:arm64 (3.44.4-0ubuntu1) ... Setting up libgit2-glib-1.0-0:arm64 (1.0.0.1-1) ... Setting up libcairo-gobject-perl:arm64 (1.005-3build1) ... Setting up ubuntu-advantage-desktop-daemon (1.10~22.04.1) ... Setting up evolution-data-server-common (3.44.4-0ubuntu1) ... Setting up libpoppler-cpp0v5:arm64 (22.02.0-2ubuntu0.1) ... Setting up libsm6:arm64 (2:1.2.3-1build2) ... Setting up libopenmpt0:arm64 (0.6.1-1) ... Setting up libio-socket-ssl-perl (2.074-2) ... Setting up network-manager-vpnc (1.2.8-2) ... Setting up xfonts-scalable (1:1.0.3-1.2ubuntu1) ... Setting up libgtk-3-common (3.24.33-1ubuntu2) ... Setting up system-monitoring-center (1.42.0) ... Setting up libhttp-message-perl (6.36-1) ... Setting up libgoa-1.0-common (3.44.0-1ubuntu1) ... Setting up libglib-object-introspection-perl (0.049-1+build2) ... Setting up gsettings-desktop-schemas (42.0-1ubuntu1) ... Setting up libinput10:arm64 (1.20.0-1ubuntu0.2) ... Setting up libjsonrpc-glib-1.0-1:arm64 (3.42.0-1) ... Setting up libgweather-common (40.0-5build1) ... Setting up libcanberra0:arm64 (0.30-10ubuntu1) ... Setting up udisks2 (2.9.4-1ubuntu2) ... Running in chroot, ignoring request. Created symlink /etc/systemd/system/graphical.target.wants/udisks2.service → /lib/systemd/system/udisks2.service. Setting up libhttp-negotiate-perl (6.01-1) ... Setting up libqt5qmlmodels5:arm64 (5.15.3+dfsg-1) ... Setting up libglx-mesa0:arm64 (22.2.5-0ubuntu0.1~22.04.1) ... Setting up xfonts-100dpi (1:1.0.4+nmu1.1) ... Setting up libpoppler-glib8:arm64 (22.02.0-2ubuntu0.1) ... Setting up gnome-settings-daemon-common (42.1-1ubuntu2.1) ... Setting up libglx0:arm64 (1.4.0-1) ... Setting up libhttp-cookies-perl (6.10-1) ... Setting up libpulse0:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Setting up libenchant-2-2:arm64 (2.3.2-1ubuntu2) ... Setting up libhtml-tree-perl (5.07-2) ... Setting up cifs-utils (2:6.14-1ubuntu0.1) ... update-alternatives: using /usr/lib/aarch64-linux-gnu/cifs-utils/idmapwb.so to provide /etc/cifs-utils/idmap-plugin (idmap-plugin) in auto mode Setting up gir1.2-jsonrpc-1.0:arm64 (3.42.0-1) ... Setting up libobjc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ... Setting up samba-libs:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Setting up libpulsedsp:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Setting up libswresample3:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Setting up cups-filters-core-drivers (1.28.15-0ubuntu1) ... Setting up libsane1:arm64 (1.1.1-5) ... Adding scanner group... Setting up gnome-icon-theme (3.12.0-4) ... update-alternatives: using /usr/share/icons/gnome/scalable/places/debian-swirl.svg to provide /usr/share/icons/gnome/scalable/places/start-here.svg (start-here.svg) in auto mode Setting up libpipewire-0.3-modules:arm64 (0.3.48-1ubuntu3) ... Setting up gir1.2-ggit-1.0:arm64 (1.0.0.1-1) ... Setting up libgl1:arm64 (1.4.0-1) ... Setting up mesa-utils-bin:arm64 (8.4.0-1ubuntu1) ... Setting up libpulse-mainloop-glib0:arm64 (1:15.99.1+dfsg1-1ubuntu2) ... Setting up pulseaudio-utils (1:15.99.1+dfsg1-1ubuntu2) ... Setting up pamix (1.6~git20180112.ea4ab3b-4) ... Setting up libxt6:arm64 (1:1.2.1-1) ... Setting up libsmbclient:arm64 (2:4.15.13+dfsg-0ubuntu1) ... Setting up pavumeter (0.9.3-4build3) ... Setting up smbclient (2:4.15.13+dfsg-0ubuntu1) ... Setting up libavcodec58:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Setting up cups-filters (1.28.15-0ubuntu1) ... Setting up libfreerdp-client2-2:arm64 (2.6.1+dfsg1-3ubuntu2.3) ... Setting up libchromaprint1:arm64 (1.5.1-2) ... Setting up speech-dispatcher-audio-plugins:arm64 (0.11.1-1ubuntu2) ... Setting up libasound2-plugins:arm64 (1.2.6-1) ... Setting up libxmu6:arm64 (2:1.1.3-3) ... Setting up clang-14 (1:14.0.0-1ubuntu1) ... Setting up libavformat58:arm64 (7:4.4.2-0ubuntu0.22.04.1) ... Setting up colord (1.4.6-1) ... Setting up libqt5gui5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up libqt5widgets5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up ghostscript-x (9.55.0~dfsg1-0ubuntu5.1) ... Setting up libm17n-0:arm64 (1.8.0-4) ... Setting up libxaw7:arm64 (2:1.0.14-1) ... Setting up x11-xserver-utils (7.7+9build1) ... Setting up pipewire-bin (0.3.48-1ubuntu3) ... Setting up speech-dispatcher (0.11.1-1ubuntu2) ... Setting up libqt5printsupport5:arm64 (5.15.3+dfsg-2ubuntu0.2) ... Setting up libgstreamer-gl1.0-0:arm64 (1.20.1-1) ... Setting up mesa-utils (8.4.0-1ubuntu1) ... Setting up clang (1:14.0-55~exp2) ... Setting up chromium-browser (1:107.0.5304.62-0ubuntu1~ppa1~22.04.1) ... update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/x-www-browser (x-www-browser) in auto mode update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode Setting up x11-utils (7.7+5build2) ... Setting up brltty-x11 (6.4-4ubuntu3) ... Setting up pipewire:arm64 (0.3.48-1ubuntu3) ... Created symlink /etc/systemd/user/default.target.wants/pipewire.service → /usr/lib/systemd/user/pipewire.service. Created symlink /etc/systemd/user/sockets.target.wants/pipewire.socket → /usr/lib/systemd/user/pipewire.socket. Setting up libqt5quick5:arm64 (5.15.3+dfsg-1) ... Setting up x11-xkb-utils (7.7+5build4) ... Setting up libqt5svg5:arm64 (5.15.3-1) ... Setting up x11-apps (7.7+8build2) ... Setting up gstreamer1.0-pipewire:arm64 (0.3.48-1ubuntu3) ... Setting up libqt5quickwidgets5:arm64 (5.15.3+dfsg-1) ... Setting up libqt5webenginecore5:arm64 (5.15.9+dfsg-1) ... Setting up xserver-common (2:21.1.3-2ubuntu2.7) ... Setting up libxklavier16:arm64 (5.4-4build2) ... Setting up xserver-xorg-core (2:21.1.3-2ubuntu2.7) ... Setting up xserver-xorg-video-fbdev (1:0.5.0-2build1) ... Setting up libqt5webenginewidgets5:arm64 (5.15.9+dfsg-1) ... Setting up liblightdm-gobject-1-0:arm64 (1.30.0-0ubuntu5) ... Setting up notepadqq (2.0.0~beta1-3) ... update-alternatives: using /usr/lib/notepadqq/notepadqq.sh to provide /usr/bin/notepadqq (notepadqq) in auto mode Setting up xserver-xorg-input-libinput (1.2.1-1) ... Setting up xserver-xorg-input-all (1:7.7+23ubuntu2) ... Setting up xserver-xorg (1:7.7+23ubuntu2) ... Setting up python3-update-manager (1:22.04.10) ... Setting up liblwp-protocol-https-perl (6.10-1) ... Setting up libwww-perl (6.61-1) ... Setting up python3-distupgrade (1:22.04.16) ... Setting up ubuntu-release-upgrader-core (1:22.04.16) ... Setting up update-manager-core (1:22.04.10) ... Setting up xscreensaver-data (5.45+dfsg1-2ubuntu1) ... Setting up update-notifier-common (3.192.54.5) ... Created symlink /etc/systemd/system/timers.target.wants/update-notifier-download.timer → /lib/systemd/system/update-notifier-download.timer. Created symlink /etc/systemd/system/timers.target.wants/update-notifier-motd.timer → /lib/systemd/system/update-notifier-motd.timer. Setting up xscreensaver (5.45+dfsg1-2ubuntu1) ... Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.8+dfsg-1ubuntu0.2) ... Processing triggers for install-info (6.8-4build1) ... Processing triggers for fontconfig (2.13.1-4.2ubuntu5) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for libglib2.0-0:arm64 (2.72.4-0ubuntu1) ... Setting up libgtk-3-0:arm64 (3.24.33-1ubuntu2) ... Setting up libxfce4ui-2-0:arm64 (4.16.1-1) ... Processing triggers for libc-bin (2.35-0ubuntu3.1) ... Setting up slick-greeter (1.5.6-1ubuntu1) ... Setting up libnma0:arm64 (1.8.34-1ubuntu1) ... Setting up gir1.2-gtk-3.0:arm64 (3.24.33-1ubuntu2) ... Setting up libcanberra-gtk3-0:arm64 (0.30-10ubuntu1) ... Setting up xfce4-power-manager (4.16.0-1) ... Setting up libvte-2.91-0:arm64 (0.68.0-1) ... Setting up libayatana-ido3-0.4-0:arm64 (0.9.1-1) ... Processing triggers for man-db (2.10.2-1) ... Setting up libnautilus-extension1a:arm64 (1:42.2-0ubuntu2.1) ... Setting up libindicator3-7 (16.10.0+18.04.20180321.1-0ubuntu5) ... Setting up libwxgtk3.0-gtk3-0v5:arm64 (3.0.5.1+dfsg-4) ... Setting up libgtksourceview-3.0-1:arm64 (3.24.11-2build1) ... Setting up libproxy1-plugin-gsettings:arm64 (0.4.17-2) ... Processing triggers for cracklib-runtime (2.9.6-3.4build4) ... Setting up libgtksourceview-4-0:arm64 (4.8.3-1) ... Setting up libgarcon-gtk3-1-0:arm64 (4.16.1-1) ... Setting up transmission-remote-gtk (1.4.1-5) ... Processing triggers for dbus (1.12.20-2ubuntu4.1) ... Processing triggers for shared-mime-info (2.1-2) ... Setting up putty (0.76-2) ... Processing triggers for udev (249.11-0ubuntu3.7) ... Setting up libgoa-1.0-0b:arm64 (3.44.0-1ubuntu1) ... Setting up spice-vdagent (0.22.1-1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up gvfs-libs:arm64 (1.48.2-0ubuntu1) ... Setting up synaptic (0.90.2build1) ... Setting up emacs-gtk (1:27.1+1-3ubuntu5) ... update-alternatives: using /usr/bin/emacs-gtk to provide /usr/bin/emacs (emacs) in auto mode Install emacsen-common for emacs emacsen-common: Handling install of emacsen flavor emacs Install dictionaries-common for emacs install/dictionaries-common: Byte-compiling for emacsen flavour emacs Setting up xarchiver (1:0.5.4.17-3) ... Setting up codium (1.75.1.23040) ... Setting up xfce4-appfinder (4.16.1-1) ... Setting up gir1.2-gtksource-3.0:arm64 (3.24.11-2build1) ... Setting up at-spi2-core (2.44.0-3) ... Setting up libwnck-3-0:arm64 (40.1-1) ... Setting up libpeas-1.0-0:arm64 (1.32.0-1) ... Setting up libgtk-4-1:arm64 (4.6.6+ds-0ubuntu1) ... Setting up filezilla (3.58.0-1) ... Setting up libevdocument3-4:arm64 (42.3-0ubuntu3) ... Setting up libportal-gtk3-1:arm64 (0.6-2) ... Setting up gir1.2-vte-2.91:arm64 (0.68.0-1) ... Setting up gir1.2-gdm-1.0:arm64 (42.0-1ubuntu7) ... Setting up glib-networking:arm64 (2.72.0-1) ... Setting up qalculate-gtk (3.22.0-1) ... update-alternatives: using /usr/bin/qalculate-gtk to provide /usr/bin/qalculate (qalculate) in auto mode Setting up libgnome-desktop-3-19:arm64 (42.5-0ubuntu1) ... Setting up libayatana-indicator3-7:arm64 (0.9.1-1) ... Setting up libavahi-ui-gtk3-0:arm64 (0.8-5ubuntu5) ... Setting up firefox-esr (102.8.0esr+build2-0ubuntu0.22.04.1) ... Please restart all running instances of firefox-esr, or you will experience problems. Setting up xdg-user-dirs-gtk (0.10-3build2) ... Setting up terminator (2.1.1-1) ... update-alternatives: using /usr/bin/terminator to provide /usr/bin/x-terminal-emulator (x-terminal-emulator) in auto mode Setting up libgtk3-perl (0.038-1) ... Setting up libgspell-1-2:arm64 (1.9.1-4) ... Setting up bleachbit (4.4.2-1) ... Setting up libhandy-1-0:arm64 (1.6.1-1) ... Setting up geany (1.38-1) ... Setting up libxfce4ui-utils (4.16.1-1) ... Setting up gir1.2-gtk-4.0:arm64 (4.6.6+ds-0ubuntu1) ... Setting up mousetweaks (3.32.0-3build2) ... Setting up gir1.2-gtksource-4:arm64 (4.8.3-1) ... Setting up libgcr-ui-3-1:arm64 (3.40.0-4) ... Setting up system-config-printer-common (1.5.16-0ubuntu3) ... Setting up emacs (1:27.1+1-3ubuntu5) ... Setting up libdazzle-1.0-0:arm64 (3.44.0-1) ... Setting up gir1.2-nma-1.0:arm64 (1.8.34-1ubuntu1) ... Setting up libsoup2.4-1:arm64 (2.74.2-3) ... Setting up libxfce4panel-2.0-4 (4.16.3-1) ... Setting up xfwm4 (4.16.1-1) ... update-alternatives: using /usr/bin/xfwm4 to provide /usr/bin/x-window-manager (x-window-manager) in auto mode Setting up gdebi (0.9.5.7+nmu6) ... Setting up libexo-2-0:arm64 (4.16.3-1) ... Setting up gnome-screenshot (41.0-2) ... Setting up libkeybinder-3.0-0:arm64 (0.3.2-1.1) ... Setting up libgtkmm-3.0-1v5:arm64 (3.24.5-1build1) ... Setting up gstreamer1.0-plugins-good:arm64 (1.20.3-0ubuntu1) ... Setting up libevview3-3:arm64 (42.3-0ubuntu3) ... Setting up libostree-1-1:arm64 (2022.2-3) ... Setting up gparted (1.3.1-1ubuntu1) ... Setting up geoclue-2.0 (2.5.7-3ubuntu3) ... Setting up libadwaita-1-0:arm64 (1.1.0-1ubuntu2) ... Setting up libgtksourceviewmm-3.0-0v5:arm64 (3.18.0-4build1) ... Setting up gnome-font-viewer (41.0-2) ... Setting up gvfs-daemons (1.48.2-0ubuntu1) ... Setting up libmousepad0 (0.5.8-1) ... Setting up gcr (3.40.0-4) ... Setting up gir1.2-peas-1.0:arm64 (1.32.0-1) ... Setting up gir1.2-wnck-3.0:arm64 (40.1-1) ... Setting up gir1.2-gcr-3:arm64 (3.40.0-4) ... Setting up pinentry-gnome3 (1.1.1-1build2) ... Setting up gir1.2-gnomedesktop-3.0:arm64 (42.5-0ubuntu1) ... Setting up gnome-system-monitor (42.0-1) ... Setting up libayatana-appindicator3-1 (0.5.90-7ubuntu2) ... Setting up python3-pyatspi (2.38.2-1) ... Setting up xfce4-pulseaudio-plugin:arm64 (0.4.3-1) ... Setting up gir1.2-goa-1.0:arm64 (3.44.0-1ubuntu1) ... Setting up evince (42.3-0ubuntu3) ... Setting up libflatpak0:arm64 (1.12.7-1) ... Setting up gir1.2-handy-1:arm64 (1.6.1-1) ... Setting up libwebkit2gtk-4.0-37:arm64 (2.38.5-0ubuntu0.22.04.1) ... Setting up exo-utils (4.16.3-1) ... Setting up meld (3.20.4-2) ... Setting up libmutter-10-0:arm64 (42.5-0ubuntu1) ... Setting up xfce4-panel (4.16.3-1) ... Setting up pasystray (0.7.1-1) ... Setting up libsysprof-ui-4:arm64 (3.44.0-1) ... Setting up gnome-disk-utility (42.0-1ubuntu1) ... Setting up xfce4-notifyd (0.6.3-1) ... Setting up mousepad (0.5.8-1) ... Setting up orca (42.0-1ubuntu2) ... Setting up xfce4-settings (4.16.2-1ubuntu2) ... Setting up gstreamer1.0-pulseaudio:arm64 (1.20.3-0ubuntu1) ... Setting up libsoup-gnome2.4-1:arm64 (2.74.2-3) ... Setting up gir1.2-dazzle-1.0:arm64 (3.44.0-1) ... Setting up xfce4-screenshooter (1.9.9-1) ... Setting up xfce4-terminal (0.8.10-1) ... Setting up gir1.2-ayatanaappindicator3-0.1 (0.5.90-7ubuntu2) ... Setting up libsnapd-glib1:arm64 (1.60-0ubuntu1) ... Setting up libgdata22:arm64 (0.18.1-2build1) ... Setting up libgeocode-glib0:arm64 (3.26.2-2build2) ... Setting up regexxer (0.10-5) ... Setting up libgeoclue-2-0:arm64 (2.5.7-3ubuntu3) ... Setting up gvfs:arm64 (1.48.2-0ubuntu1) ... Setting up gnome-keyring (40.0-3ubuntu3) ... Created symlink /etc/systemd/user/graphical-session-pre.target.wants/gnome-keyring.service → /usr/lib/systemd/user/gnome-keyring.service. Setting up libthunarx-3-0:arm64 (4.16.10-1) ... Setting up pavucontrol (5.0-2) ... Setting up software-properties-gtk (0.99.22.6) ... Setting up libgweather-3-16:arm64 (40.0-5build1) ... Setting up libgladeui-2-13:arm64 (3.38.2-7) ... Setting up blueman (2.2.4-1) ... Created symlink /etc/systemd/system/multi-user.target.wants/blueman-mechanism.service → /lib/systemd/system/blueman-mechanism.service. Setting up gir1.2-adw-1:arm64 (1.1.0-1ubuntu2) ... Setting up xfdesktop4 (4.16.0-1) ... Setting up pulseaudio (1:15.99.1+dfsg1-1ubuntu2) ... Adding user pulse to group audio Running in chroot, ignoring request. Running in chroot, ignoring request. Created symlink /etc/systemd/user/default.target.wants/pulseaudio.service → /usr/lib/systemd/user/pulseaudio.service. Created symlink /etc/systemd/user/sockets.target.wants/pulseaudio.socket → /usr/lib/systemd/user/pulseaudio.socket. Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Setting up gir1.2-soup-2.4:arm64 (2.74.2-3) ... Setting up gir1.2-snapd-1:arm64 (1.60-0ubuntu1) ... Setting up gir1.2-mutter-10:arm64 (42.5-0ubuntu1) ... Setting up gvfs-backends (1.48.2-0ubuntu1) ... Setting up transmission-gtk (3.00-2ubuntu2) ... Setting up thunar (4.16.10-1) ... Setting up system-config-printer (1.5.16-0ubuntu3) ... Setting up remmina (1.4.25+dfsg-1) ... Setting up cups-daemon (2.4.1op1-1ubuntu4.1) ... Running in chroot, ignoring request. invoke-rc.d: policy-rc.d denied execution of start. Created symlink /etc/systemd/system/multi-user.target.wants/cups.path → /lib/systemd/system/cups.path. Created symlink /etc/systemd/system/printer.target.wants/cups.service → /lib/systemd/system/cups.service. Created symlink /etc/systemd/system/multi-user.target.wants/cups.service → /lib/systemd/system/cups.service. Created symlink /etc/systemd/system/sockets.target.wants/cups.socket → /lib/systemd/system/cups.socket. Setting up xfce4-session (4.16.0-1ubuntu2) ... update-alternatives: using /usr/bin/startxfce4 to provide /usr/bin/x-session-manager (x-session-manager) in auto mode Setting up gir1.2-geoclue-2.0:arm64 (2.5.7-3ubuntu3) ... Setting up libdevhelp-3-6:arm64 (41.2-2) ... Setting up pulseaudio-module-bluetooth (1:15.99.1+dfsg1-1ubuntu2) ... Setting up remmina-plugin-rdp:arm64 (1.4.25+dfsg-1) ... Setting up remmina-plugin-vnc:arm64 (1.4.25+dfsg-1) ... Setting up libedataserver-1.2-26:arm64 (3.44.4-0ubuntu1) ... Setting up transmission (3.00-2ubuntu2) ... Setting up libecal-2.0-1:arm64 (3.44.4-0ubuntu1) ... Setting up cups-core-drivers (2.4.1op1-1ubuntu4.1) ... Setting up libebook-contacts-1.2-3:arm64 (3.44.4-0ubuntu1) ... Setting up gir1.2-webkit2-4.0:arm64 (2.38.5-0ubuntu0.22.04.1) ... Setting up cups (2.4.1op1-1ubuntu4.1) ... Setting up libedataserverui-1.2-3:arm64 (3.44.4-0ubuntu1) ... Setting up indicator-printers (0.1.7+17.10.20171101-0ubuntu3) ... Setting up gnome-settings-daemon (42.1-1ubuntu2.1) ... Setting up gnome-builder (42.0-1) ... Setting up gir1.2-gweather-3.0:arm64 (40.0-5build1) ... Setting up xfce4 (4.16) ... Setting up thunar-volman (4.16.0-1) ... Setting up libebackend-1.2-10:arm64 (3.44.4-0ubuntu1) ... Setting up bluez-cups (5.64-0ubuntu1) ... Setting up ubuntu-release-upgrader-gtk (1:22.04.16) ... Setting up printer-driver-hpcups (3.21.12+dfsg0-1) ... Setting up update-notifier (3.192.54.5) ... Setting up hplip (3.21.12+dfsg0-1) ... Creating/updating hplip user account... Setting up libedata-cal-2.0-1:arm64 (3.44.4-0ubuntu1) ... Setting up libedata-book-1.2-26:arm64 (3.44.4-0ubuntu1) ... Setting up libebook-1.2-20:arm64 (3.44.4-0ubuntu1) ... Setting up evolution-data-server (3.44.4-0ubuntu1) ... Setting up gnome-shell (42.5-0ubuntu1) ... Setting up network-manager-gnome (1.24.0-1ubuntu3) ... Setting up update-manager (1:22.04.10) ... Processing triggers for dictionaries-common (1.28.14) ... Processing triggers for initramfs-tools (0.140ubuntu13.1) ... Processing triggers for libc-bin (2.35-0ubuntu3.1) ... Processing triggers for dbus (1.12.20-2ubuntu4.1) ... --> (1327) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1327) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1327) INFO: Checking MD5 sum of installed packages [ debsums ] --> (1327) COMMAND: debsums --silent --> (1346) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1346) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1346) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1346) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 autoremove --> (1348) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1348) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1348) INFO: Free disk space on rootfs [ SDCARD: 7% ] --> (1348) INFO: Recreating Synaptic search index [ Please wait ] --> (1348) COMMAND: [[ -f /usr/sbin/update-apt-xapian-index ]] && /usr/sbin/update-apt-xapian-index -u || true No Xapian index built yet: falling back to full rebuild Rebuilding Xapian index... Rebuilding Xapian index... 0% Rebuilding Xapian index... 0% Rebuilding Xapian index... 0% Rebuilding Xapian index... 0% Rebuilding Xapian index... 1% Rebuilding Xapian index... 1% Rebuilding Xapian index... 1% Rebuilding Xapian index... 2% Rebuilding Xapian index... 2% Rebuilding Xapian index... 2% Rebuilding Xapian index... 3% Rebuilding Xapian index... 3% Rebuilding Xapian index... 3% Rebuilding Xapian index... 4% Rebuilding Xapian index... 4% Rebuilding Xapian index... 4% Rebuilding Xapian index... 5% Rebuilding Xapian index... 5% Rebuilding Xapian index... 5% Rebuilding Xapian index... 5% Rebuilding Xapian index... 6% Rebuilding Xapian index... 6% Rebuilding Xapian index... 6% Rebuilding Xapian index... 7% Rebuilding Xapian index... 7% Rebuilding Xapian index... 7% Rebuilding Xapian index... 8% Rebuilding Xapian index... 8% Rebuilding Xapian index... 8% Rebuilding Xapian index... 9% Rebuilding Xapian index... 9% Rebuilding Xapian index... 9% Rebuilding Xapian index... 10% Rebuilding Xapian index... 10% Rebuilding Xapian index... 10% Rebuilding Xapian index... 10% Rebuilding Xapian index... 11% Rebuilding Xapian index... 11% Rebuilding Xapian index... 11% Rebuilding Xapian index... 12% Rebuilding Xapian index... 12% Rebuilding Xapian index... 12% Rebuilding Xapian index... 13% Rebuilding Xapian index... 13% Rebuilding Xapian index... 13% Rebuilding Xapian index... 14% Rebuilding Xapian index... 14% Rebuilding Xapian index... 14% Rebuilding Xapian index... 15% Rebuilding Xapian index... 15% Rebuilding Xapian index... 15% Rebuilding Xapian index... 15% Rebuilding Xapian index... 16% Rebuilding Xapian index... 16% Rebuilding Xapian index... 16% Rebuilding Xapian index... 17% Rebuilding Xapian index... 17% Rebuilding Xapian index... 17% Rebuilding Xapian index... 18% Rebuilding Xapian index... 18% Rebuilding Xapian index... 18% Rebuilding Xapian index... 19% Rebuilding Xapian index... 19% Rebuilding Xapian index... 19% Rebuilding Xapian index... 20% Rebuilding Xapian index... 20% Rebuilding Xapian index... 20% Rebuilding Xapian index... 20% Rebuilding Xapian index... 21% Rebuilding Xapian index... 21% Rebuilding Xapian index... 21% Rebuilding Xapian index... 22% Rebuilding Xapian index... 22% Rebuilding Xapian index... 22% Rebuilding Xapian index... 23% Rebuilding Xapian index... 23% Rebuilding Xapian index... 23% Rebuilding Xapian index... 24% Rebuilding Xapian index... 24% Rebuilding Xapian index... 24% Rebuilding Xapian index... 25% Rebuilding Xapian index... 25% Rebuilding Xapian index... 25% Rebuilding Xapian index... 25% Rebuilding Xapian index... 26% Rebuilding Xapian index... 26% Rebuilding Xapian index... 26% Rebuilding Xapian index... 27% Rebuilding Xapian index... 27% Rebuilding Xapian index... 27% Rebuilding Xapian index... 28% Rebuilding Xapian index... 28% Rebuilding Xapian index... 28% Rebuilding Xapian index... 29% Rebuilding Xapian index... 29% Rebuilding Xapian index... 29% Rebuilding Xapian index... 30% Rebuilding Xapian index... 30% Rebuilding Xapian index... 30% Rebuilding Xapian index... 30% Rebuilding Xapian index... 31% Rebuilding Xapian index... 31% Rebuilding Xapian index... 31% Rebuilding Xapian index... 32% Rebuilding Xapian index... 32% Rebuilding Xapian index... 32% Rebuilding Xapian index... 33% Rebuilding Xapian index... 33% Rebuilding Xapian index... 33% Rebuilding Xapian index... 34% Rebuilding Xapian index... 34% Rebuilding Xapian index... 34% Rebuilding Xapian index... 35% Rebuilding Xapian index... 35% Rebuilding Xapian index... 35% Rebuilding Xapian index... 35% Rebuilding Xapian index... 36% Rebuilding Xapian index... 36% Rebuilding Xapian index... 36% Rebuilding Xapian index... 37% Rebuilding Xapian index... 37% Rebuilding Xapian index... 37% Rebuilding Xapian index... 38% Rebuilding Xapian index... 38% Rebuilding Xapian index... 38% Rebuilding Xapian index... 39% Rebuilding Xapian index... 39% Rebuilding Xapian index... 39% Rebuilding Xapian index... 40% Rebuilding Xapian index... 40% Rebuilding Xapian index... 40% Rebuilding Xapian index... 41% Rebuilding Xapian index... 41% Rebuilding Xapian index... 41% Rebuilding Xapian index... 41% Rebuilding Xapian index... 42% Rebuilding Xapian index... 42% Rebuilding Xapian index... 42% Rebuilding Xapian index... 43% Rebuilding Xapian index... 43% Rebuilding Xapian index... 43% Rebuilding Xapian index... 44% Rebuilding Xapian index... 44% Rebuilding Xapian index... 44% Rebuilding Xapian index... 45% Rebuilding Xapian index... 45% Rebuilding Xapian index... 45% Rebuilding Xapian index... 46% Rebuilding Xapian index... 46% Rebuilding Xapian index... 46% Rebuilding Xapian index... 46% Rebuilding Xapian index... 47% Rebuilding Xapian index... 47% Rebuilding Xapian index... 47% Rebuilding Xapian index... 48% Rebuilding Xapian index... 48% Rebuilding Xapian index... 48% Rebuilding Xapian index... 49% Rebuilding Xapian index... 49% Rebuilding Xapian index... 49% Rebuilding Xapian index... 50% Rebuilding Xapian index... 50% Rebuilding Xapian index... 50% Rebuilding Xapian index... 51% Rebuilding Xapian index... 51% Rebuilding Xapian index... 51% Rebuilding Xapian index... 51% Rebuilding Xapian index... 52% Rebuilding Xapian index... 52% Rebuilding Xapian index... 52% Rebuilding Xapian index... 53% Rebuilding Xapian index... 53% Rebuilding Xapian index... 53% Rebuilding Xapian index... 54% Rebuilding Xapian index... 54% Rebuilding Xapian index... 54% Rebuilding Xapian index... 55% Rebuilding Xapian index... 55% Rebuilding Xapian index... 55% Rebuilding Xapian index... 56% Rebuilding Xapian index... 56% Rebuilding Xapian index... 56% Rebuilding Xapian index... 56% Rebuilding Xapian index... 57% Rebuilding Xapian index... 57% Rebuilding Xapian index... 57% Rebuilding Xapian index... 58% Rebuilding Xapian index... 58% Rebuilding Xapian index... 58% Rebuilding Xapian index... 59% Rebuilding Xapian index... 59% Rebuilding Xapian index... 59% Rebuilding Xapian index... 60% Rebuilding Xapian index... 60% Rebuilding Xapian index... 60% Rebuilding Xapian index... 61% Rebuilding Xapian index... 61% Rebuilding Xapian index... 61% Rebuilding Xapian index... 61% Rebuilding Xapian index... 62% Rebuilding Xapian index... 62% Rebuilding Xapian index... 62% Rebuilding Xapian index... 63% Rebuilding Xapian index... 63% Rebuilding Xapian index... 63% Rebuilding Xapian index... 64% Rebuilding Xapian index... 64% Rebuilding Xapian index... 64% Rebuilding Xapian index... 65% Rebuilding Xapian index... 65% Rebuilding Xapian index... 65% Rebuilding Xapian index... 66% Rebuilding Xapian index... 66% Rebuilding Xapian index... 66% Rebuilding Xapian index... 66% Rebuilding Xapian index... 67% Rebuilding Xapian index... 67% Rebuilding Xapian index... 67% Rebuilding Xapian index... 68% Rebuilding Xapian index... 68% Rebuilding Xapian index... 68% Rebuilding Xapian index... 69% Rebuilding Xapian index... 69% Rebuilding Xapian index... 69% Rebuilding Xapian index... 70% Rebuilding Xapian index... 70% Rebuilding Xapian index... 70% Rebuilding Xapian index... 71% Rebuilding Xapian index... 71% Rebuilding Xapian index... 71% Rebuilding Xapian index... 71% Rebuilding Xapian index... 72% Rebuilding Xapian index... 72% Rebuilding Xapian index... 72% Rebuilding Xapian index... 73% Rebuilding Xapian index... 73% Rebuilding Xapian index... 73% Rebuilding Xapian index... 74% Rebuilding Xapian index... 74% Rebuilding Xapian index... 74% Rebuilding Xapian index... 75% Rebuilding Xapian index... 75% Rebuilding Xapian index... 75% Rebuilding Xapian index... 76% Rebuilding Xapian index... 76% Rebuilding Xapian index... 76% Rebuilding Xapian index... 76% Rebuilding Xapian index... 77% Rebuilding Xapian index... 77% Rebuilding Xapian index... 77% Rebuilding Xapian index... 78% Rebuilding Xapian index... 78% Rebuilding Xapian index... 78% Rebuilding Xapian index... 79% Rebuilding Xapian index... 79% Rebuilding Xapian index... 79% Rebuilding Xapian index... 80% Rebuilding Xapian index... 80% Rebuilding Xapian index... 80% Rebuilding Xapian index... 81% Rebuilding Xapian index... 81% Rebuilding Xapian index... 81% Rebuilding Xapian index... 82% Rebuilding Xapian index... 82% Rebuilding Xapian index... 82% Rebuilding Xapian index... 82% Rebuilding Xapian index... 83% Rebuilding Xapian index... 83% Rebuilding Xapian index... 83% Rebuilding Xapian index... 84% Rebuilding Xapian index... 84% Rebuilding Xapian index... 84% Rebuilding Xapian index... 85% Rebuilding Xapian index... 85% Rebuilding Xapian index... 85% Rebuilding Xapian index... 86% Rebuilding Xapian index... 86% Rebuilding Xapian index... 86% Rebuilding Xapian index... 87% Rebuilding Xapian index... 87% Rebuilding Xapian index... 87% Rebuilding Xapian index... 87% Rebuilding Xapian index... 88% Rebuilding Xapian index... 88% Rebuilding Xapian index... 88% Rebuilding Xapian index... 89% Rebuilding Xapian index... 89% Rebuilding Xapian index... 89% Rebuilding Xapian index... 90% Rebuilding Xapian index... 90% Rebuilding Xapian index... 90% Rebuilding Xapian index... 91% Rebuilding Xapian index... 91% Rebuilding Xapian index... 91% Rebuilding Xapian index... 92% Rebuilding Xapian index... 92% Rebuilding Xapian index... 92% Rebuilding Xapian index... 92% Rebuilding Xapian index... 93% Rebuilding Xapian index... 93% Rebuilding Xapian index... 93% Rebuilding Xapian index... 94% Rebuilding Xapian index... 94% Rebuilding Xapian index... 94% Rebuilding Xapian index... 95% Rebuilding Xapian index... 95% Rebuilding Xapian index... 95% Rebuilding Xapian index... 96% Rebuilding Xapian index... 96% Rebuilding Xapian index... 96% Rebuilding Xapian index... 97% Rebuilding Xapian index... 97% Rebuilding Xapian index... 97% Rebuilding Xapian index... 97% Rebuilding Xapian index... 98% Rebuilding Xapian index... 98% Rebuilding Xapian index... 98% Rebuilding Xapian index... 99% Rebuilding Xapian index... 99% Rebuilding Xapian index... 99% Rebuilding Xapian index: done. --> (1409) COMMAND: rm -v /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf removed '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf' --> (1409) COMMAND: echo nameserver 1.0.0.1 > /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf --> (1409) COMMAND: echo uninitialized > /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/machine-id --> (1409) COMMAND: rm -v /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/dbus/machine-id removed '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/dbus/machine-id' --> (1409) COMMAND: systemctl mask systemd-firstboot.service Created symlink /etc/systemd/system/systemd-firstboot.service → /dev/null. --> (1409) INFO: Ending debootstrap process and preparing cache [ jammy ] --> (1409) INFO: Unmounting [ /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 ] --> (1409) COMMAND: grep -E '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/(dev|proc|sys|tmp)' /proc/mounts || true --> (1409) COMMAND: rm -rf /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/run/user/0 --> (1409) COMMAND: dpkg -l | grep ^ii | awk '{ print $2","$3 }' --> (1409) INFO: zstd tarball of rootfs [ jammy:: arm64-jammy-xfce-bcf5b56cab61Bed8f36.tar.zst :: compression 5 ] --> (1416) INFO: rootfs cache created [ /home/reds/patch_series_pcie_ep/build/cache/rootfs/arm64-jammy-xfce-bcf5b56cab61Bed8f36.tar.zst [1.5G] ] --> (1416) INFO: Actual rootfs size [ 4182MiB after basic/cache ] --> (1416) INFO: Unmounting recursively [ SDCARD - be patient ] --> (1416) INFO: Unmounting recursively [ MOUNT - be patient ] ------------------------------------------------------------------------------------------------------------ ### prepare_rootfs_build_params_and_trap.log --> (1416) COMMAND: rm -rfv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0 --> (1416) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0 /home/reds/patch_series_pcie_ep/build/cache/rootfs /home/reds/patch_series_pcie_ep/build/output/images mkdir: created directory '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0' mkdir: created directory '/home/reds/patch_series_pcie_ep/build/.tmp/mount-d42a3aa9-4268-47db-87f0-64b17653a3d0' --> (1416) INFO: Using tmpfs for rootfs build [ RAM available: 36835MiB > 5000MiB estimated ] ------------------------------------------------------------------------------------------------------------ ### extract_rootfs_artifact.log --> (1416) INFO: Extracting xfce-bcf5b56cab61Bed8f36 [ 0 days old ] --> (1424) COMMAND: rm -v /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf removed '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf' --> (1424) COMMAND: echo nameserver 1.0.0.1 > /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/resolv.conf --> (1424) INFO: Adding Armbian repository and authentication key [ /etc/apt/sources.list.d/armbian.list ] ------------------------------------------------------------------------------------------------------------ ### install_distribution_specific_jammy.log --> (1424) INFO: Applying distribution specific tweaks for [ jammy ] --> (1424) COMMAND: systemctl --no-reload disable smartmontools.service || true Synchronizing state of smartmontools.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install disable smartmontools Removed /etc/systemd/system/smartd.service. Removed /etc/systemd/system/multi-user.target.wants/smartmontools.service. --> (1424) COMMAND: systemctl --no-reload disable smartd.service || true Failed to disable unit, unit smartd.service does not exist. --> (1425) COMMAND: systemctl --no-reload disable hostapd.service || true Failed to disable unit, unit hostapd.service does not exist. --> (1425) COMMAND: rm -f /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/10-uname /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/10-help-text /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/50-motd-news /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/80-esm /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/80-livepatch /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/90-updates-available /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/91-release-upgrade /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/etc/update-motd.d/95-hwe-eol --> (1425) COMMAND: systemctl --no-reload disable ondemand.service || true Failed to disable unit, unit ondemand.service does not exist. --> (1425) COMMAND: systemctl --no-reload disable motd-news.service || true --> (1425) COMMAND: systemctl --no-reload disable motd-news.timer || true Removed /etc/systemd/system/timers.target.wants/motd-news.timer. ------------------------------------------------------------------------------------------------------------ ### install_distribution_agnostic.log --> (1425) COMMAND: chmod u+s /bin/ping --> (1425) COMMAND: dpkg-reconfigure -f noninteractive tzdata Current default time zone: 'Etc/UTC' Local time is now: Wed Mar 15 09:01:00 UTC 2023. Universal Time is now: Wed Mar 15 09:01:00 UTC 2023. --> (1426) COMMAND: ( echo '1234' ; echo '1234' ; ) | passwd root New password: Retype new password: passwd: password updated successfully --> (1427) INFO: Using extlinux, SRC_EXTLINUX: yes [ Image - uInitrd ] --> (1427) INFO: Temporarily disabling [ initramfs-tools hook for kernel ] --> (1427) COMMAND: chmod -v -x /etc/kernel/postinst.d/initramfs-tools mode of '/etc/kernel/postinst.d/initramfs-tools' changed from 0755 (rwxr-xr-x) to 0644 (rw-r--r--) --> (1427) INFO: Updating [ apt package lists ] --> (1427) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1427) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1427) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1427) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -q -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 update Ign:1 http://cli.github.com/packages stable InRelease Ign:2 http://apt.armbian.com jammy InRelease Ign:3 http://ports.ubuntu.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:5 http://ports.ubuntu.com jammy-security InRelease Ign:1 http://cli.github.com/packages stable InRelease Ign:2 http://apt.armbian.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:6 http://ports.ubuntu.com jammy-updates InRelease Ign:2 http://apt.armbian.com jammy InRelease Ign:1 http://cli.github.com/packages stable InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:7 http://ports.ubuntu.com jammy-backports InRelease Err:2 http://apt.armbian.com jammy InRelease Could not resolve 'apt.armbian.com' Err:1 http://cli.github.com/packages stable InRelease Could not resolve 'cli.github.com' Err:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Could not resolve 'paulcarroty.gitlab.io' Ign:3 http://ports.ubuntu.com jammy InRelease Ign:5 http://ports.ubuntu.com jammy-security InRelease Ign:6 http://ports.ubuntu.com jammy-updates InRelease Ign:7 http://ports.ubuntu.com jammy-backports InRelease Ign:3 http://ports.ubuntu.com jammy InRelease Ign:5 http://ports.ubuntu.com jammy-security InRelease Ign:6 http://ports.ubuntu.com jammy-updates InRelease Ign:7 http://ports.ubuntu.com jammy-backports InRelease Err:3 http://ports.ubuntu.com jammy InRelease Could not resolve 'ports.ubuntu.com' Err:5 http://ports.ubuntu.com jammy-security InRelease Could not resolve 'ports.ubuntu.com' Err:6 http://ports.ubuntu.com jammy-updates InRelease Could not resolve 'ports.ubuntu.com' Err:7 http://ports.ubuntu.com jammy-backports InRelease Could not resolve 'ports.ubuntu.com' Reading package lists... W: Failed to fetch http://ports.ubuntu.com/dists/jammy/InRelease Could not resolve 'ports.ubuntu.com' W: Failed to fetch http://ports.ubuntu.com/dists/jammy-security/InRelease Could not resolve 'ports.ubuntu.com' W: Failed to fetch http://ports.ubuntu.com/dists/jammy-updates/InRelease Could not resolve 'ports.ubuntu.com' W: Failed to fetch http://ports.ubuntu.com/dists/jammy-backports/InRelease Could not resolve 'ports.ubuntu.com' W: Failed to fetch http://apt.armbian.com/dists/jammy/InRelease Could not resolve 'apt.armbian.com' W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease Could not resolve 'cli.github.com' W: Failed to fetch http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/dists/vscodium/InRelease Could not resolve 'paulcarroty.gitlab.io' W: Some index files failed to download. They have been ignored, or old ones used instead. --> (1612) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1612) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1612) INFO: Installing AGGREGATED_PACKAGES_IMAGE packages [ ethtool ] --> (1612) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1612) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1612) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1612) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --dry-run install ethtool 2>&1 | { grep --line-buffered -v -e '^Conf ' -e '^Inst ' || true; } --> (1614) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1614) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1614) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1614) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1614) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1614) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends --download-only install ethtool --> (1616) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1616) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1616) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1616) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1616) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1616) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends install ethtool --> (1618) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1618) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1618) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/output/debs/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb '/home/reds/patch_series_pcie_ep/build/output/debs/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb' --> (1618) DEBINSTALL: Installing [ linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb ] --> (1618) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1618) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1618) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1618) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb Selecting previously unselected package linux-u-boot-nanopct4-edge. (Reading database ... 135592 files and directories currently installed.) Preparing to unpack .../linux-u-boot-nanopct4-edge_2022.04-Se4b6-Pd69e-B6324_arm64.deb ... Unpacking linux-u-boot-nanopct4-edge (2022.04-Se4b6-Pd69e-B6324) ... Setting up linux-u-boot-nanopct4-edge (2022.04-Se4b6-Pd69e-B6324) ... --> (1628) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1628) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1628) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/output/debs/linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb '/home/reds/patch_series_pcie_ep/build/output/debs/linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb' --> (1628) DEBINSTALL: Installing [ linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb ] --> (1628) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1628) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1628) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1628) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb Selecting previously unselected package linux-image-edge-media. (Reading database ... 135600 files and directories currently installed.) Preparing to unpack .../linux-image-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb ... Armbian 'linux-image-edge-media' for '6.2.6-media': 'preinst' starting. + export DEB_MAINT_PARAMS=install + DEB_MAINT_PARAMS=install + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/preinst.d + mountpoint -q /boot + set +x Armbian 'linux-image-edge-media' for '6.2.6-media': 'preinst' finishing. Unpacking linux-image-edge-media (6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8) ... Setting up linux-image-edge-media (6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8) ... Armbian 'linux-image-edge-media' for '6.2.6-media': 'postinst' starting. + export 'DEB_MAINT_PARAMS=configure ' + DEB_MAINT_PARAMS='configure ' + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/postinst.d + run-parts --arg=6.2.6-media --arg=/boot/vmlinuz-6.2.6-media /etc/kernel/postinst.d * dkms: running auto installation service for kernel 6.2.6-media ...done. + echo 'Armbian: update last-installed kernel symlink to '\''Image'\''...' Armbian: update last-installed kernel symlink to 'Image'... + ln -sfv vmlinuz-6.2.6-media /boot/Image '/boot/Image' -> 'vmlinuz-6.2.6-media' + touch /boot/.next + set +x Armbian 'linux-image-edge-media' for '6.2.6-media': 'postinst' finishing. --> (1654) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1654) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1654) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/output/debs/linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb '/home/reds/patch_series_pcie_ep/build/output/debs/linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb' --> (1654) DEBINSTALL: Installing [ linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb ] --> (1654) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1655) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1655) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1655) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb Selecting previously unselected package linux-dtb-edge-media. (Reading database ... 141627 files and directories currently installed.) Preparing to unpack .../linux-dtb-edge-media_6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8_arm64.deb ... Armbian 'linux-dtb-edge-media' for '6.2.6-media': 'preinst' starting. + rm -rf /boot/dtb + rm -rf /boot/dtb-6.2.6-media + set +x Armbian 'linux-dtb-edge-media' for '6.2.6-media': 'preinst' finishing. Unpacking linux-dtb-edge-media (6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8) ... Setting up linux-dtb-edge-media (6.2.6-Sfbe1-D2a58-P5f93-C7439Hfe66-Bd6b8) ... Armbian 'linux-dtb-edge-media' for '6.2.6-media': 'postinst' starting. + cd /boot + ln -sfT dtb-6.2.6-media dtb + set +x Armbian 'linux-dtb-edge-media' for '6.2.6-media': 'postinst' finishing. --> (1665) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1665) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1665) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/output/debs/armbian-firmware_1-SA56ad-Bf566_all.deb /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/armbian-firmware_1-SA56ad-Bf566_all.deb '/home/reds/patch_series_pcie_ep/build/output/debs/armbian-firmware_1-SA56ad-Bf566_all.deb' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/armbian-firmware_1-SA56ad-Bf566_all.deb' --> (1665) DEBINSTALL: Installing [ armbian-firmware_1-SA56ad-Bf566_all.deb ] --> (1665) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1665) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1665) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1665) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/armbian-firmware_1-SA56ad-Bf566_all.deb Selecting previously unselected package armbian-firmware. (Reading database ... 141726 files and directories currently installed.) Preparing to unpack .../armbian-firmware_1-SA56ad-Bf566_all.deb ... Unpacking armbian-firmware (1-SA56ad-Bf566) ... Setting up armbian-firmware (1-SA56ad-Bf566) ... --> (1678) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1678) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1678) COMMAND: cp -pv /home/reds/patch_series_pcie_ep/build/output/debs/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb '/home/reds/patch_series_pcie_ep/build/output/debs/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb' -> '/home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/root/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb' --> (1678) DEBINSTALL: Installing [ armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb ] --> (1678) COMMAND: mkdir -pv /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1678) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1678) COMMAND: mount --bind /home/reds/patch_series_pcie_ep/build/cache/aptcache/lists/jammy-arm64 /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1678) COMMAND: DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb E: Failed to fetch http://ports.ubuntu.com/pool/universe/f/fping/fping_5.1-1_arm64.deb Could not resolve 'ports.ubuntu.com' E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? -->--> command failed with error code 100 after 69 seconds --> (1747) WARNING: stacktrace for failed command [ exit code 100:chroot /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0 /bin/bash -e -o pipefail -c DEBIAN_FRONTEND=noninteractive apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 -o APT::Clean-Installed=0 --no-install-recommends install /root/armbian-bsp-cli-nanopct4_23.05.0-trunk_arm64.deb chroot_sdcard() --> lib/functions/logging/runners.sh:112 chroot_sdcard_apt_get() --> lib/functions/logging/runners.sh:97 install_deb_chroot() --> lib/functions/rootfs/apt-install.sh:41 install_distribution_agnostic() --> lib/functions/rootfs/distro-agnostic.sh:365 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:28 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:19 do_with_default_build() --> lib/functions/main/default-build.sh:26 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:26 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:135 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:173 main() --> compile.sh:50 ] --> (1747) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/cache/apt --> (1747) COMMAND: umount /home/reds/patch_series_pcie_ep/build/.tmp/rootfs-d42a3aa9-4268-47db-87f0-64b17653a3d0/var/lib/apt/lists --> (1747) ERROR: Error 1 occurred in main shell [ at /home/reds/patch_series_pcie_ep/build/lib/functions/rootfs/apt-install.sh:41 install_deb_chroot() --> lib/functions/rootfs/apt-install.sh:41 install_distribution_agnostic() --> lib/functions/rootfs/distro-agnostic.sh:365 do_with_logging() --> lib/functions/logging/section-logging.sh:81 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:28 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:19 do_with_default_build() --> lib/functions/main/default-build.sh:26 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:26 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:135 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:173 main() --> compile.sh:50 ] --> (1747) ERROR: Cleaning up [ please wait for cleanups to finish ] --> (1747) INFO: Unmounting recursively [ SDCARD - be patient ] --> (1748) INFO: Unmounting recursively [ MOUNT - be patient ] ------------------------------------------------------------------------------------------------------------ 0 Quote
Werner Posted March 15, 2023 Posted March 15, 2023 Cannot reproduce. Just built with your parameters successfully. BOARD=nanopct4 BRANCH=edge RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_ONLY=no KERNEL_CONFIGURE=yes DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DESKTOP_APPGROUPS_SELECTED="3dsupport browsers desktop_tools editors internet programming remote_desktop" COMPRESS_OUTPUTIMAGE=sha,img 0 Quote
rwk Posted March 15, 2023 Author Posted March 15, 2023 Thanks for trying this out, it is probably a network issue, if you have any pointers on how to debug this it would be great. I have issues with apt from within the build but not from outside the build. I wonder if the chroot may cause this. Running on Ubuntu 22.04.2 LTS It happens every-time, even when I delete / reclone. 0 Quote
rwk Posted March 20, 2023 Author Posted March 20, 2023 (edited) I have run the build on another machine, the build gives the same error. Edit : From the machine I can download the file in the error message without any issues when I use e.g., wget E: Failed to fetch http://ports.ubuntu.com/pool/universe/f/fping/fping_5.1-1_arm64.deb Could not resolve 'ports.ubuntu.com' E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? wget http://ports.ubuntu.com/pool/universe/f/fping/fping_5.1-1_arm64.deb Downloads the file no problem... Edited March 20, 2023 by rwk 0 Quote
rwk Posted March 21, 2023 Author Posted March 21, 2023 Hello, I solved my problem by adding the following line in https://github.com/armbian/build/blob/main/lib/functions/rootfs/distro-agnostic.sh#L270 (just before the updating apt package list) cp /etc/resolv.conf ${SDCARD}/etc/resolv.conf I had to copy the whole file (just copy the nameserver wasn't enough). I hope this helps if someone ends up with the same problem. Cheers, Rick 0 Quote
EvgeniyZh Posted August 11, 2024 Posted August 11, 2024 I had the same problem, running on an Ubuntu host with Docker, and adding Quote cp /etc/resolv.conf ${SDCARD}/etc/resolv.conf indeed solved the problem. I'll be happy to provide more information if needed. 0 Quote
rjbrown99 Posted November 15 Posted November 15 It's more than a year later - but the update to the distro-agnostic.sh to copy resolv.conf also fixed my native build as well. DNS for the apt/image build process was failing before I did that. 0 Quote
