primoitt Posted March 18, 2023 Posted March 18, 2023 Hello, I wanna test Armbian x86 on virtual machine. Is possible to convert its img file to some format (vdi or vmdk) and boot on Virtualbox? I made a attempt but it wont boot.. VBoxManage.exe convertfromraw --format VDI armbian.img ambian.vdi Thx a lot 0 Quote
Igor Posted March 19, 2023 Posted March 19, 2023 20 hours ago, primoitt said: Is possible to convert its img file to some format (vdi or vmdk) and boot on Virtualbox? This is how it goes on KVM ... if it helps. wget -q -O - "https://redirect.armbian.com/region/EU/uefi-x86/Jammy_current" | xz -d > image.iso sudo qemu-img convert -f raw -O qcow2 image.iso /var/lib/libvirt/images/image.qcow2 sudo qemu-img resize /var/lib/libvirt/images/image.qcow2 +10G virt-install --name Armbian --memory 2048 --vcpus 4 --disk /var/lib/libvirt/images/image.qcow2,bus=sata --import --os-variant ubuntu22.04 --network bridge=br1 --noautoconsole 0 Quote
walkin-corpse Posted December 8, 2023 Posted December 8, 2023 Well, we mostly use Win PCs. So using either Virtual Box or Hyper-V. And no any possible ways to use IMG in these engines. Could you distribute ISO-image for x64 build? On 3/19/2023 at 6:22 PM, Igor said: wget -q -O - "https://redirect.armbian.com/region/EU/uefi-x86/Jammy_current" | xz -d > image.iso This command doing nothing but rename IMG downloaded to ISO! So this is not ISO at all. 0 Quote
Igor Posted December 8, 2023 Posted December 8, 2023 2 minutes ago, walkin-corpse said: Could you distribute ISO-image for x64 build? They are ISO images, just compressed with .xz 1 minute ago, walkin-corpse said: This command doing nothing but rename IMG downloaded to ISO! Yes. this should be correct ISO image, just with fixed name. If you use this link https://redirect.armbian.com/region/EU/uefi-x86/Jammy_current our redirector will give you latest image. 0 Quote
walkin-corpse Posted December 8, 2023 Posted December 8, 2023 Just managed to boot in VBox using: "VBoxManage convertfromraw --format VDI [filename].img [filename].vdi" And NO, IMG-format and ISO-format aren't equal. 0 Quote
walkin-corpse Posted December 8, 2023 Posted December 8, 2023 Any ways to install to fresh virtual HDD? armbian-install not helps, not detect SATA VHD. 0 Quote
Igor Posted December 9, 2023 Posted December 9, 2023 14 hours ago, walkin-corpse said: IMG-format and ISO-format aren't equal. "Virtual disk images (such as VHD and VMDK) are intended to be used for cloud computing," https://en.wikipedia.org/wiki/IMG_(file_format)#Comparison_to_ISO_images Our build framework can generate cloud images directly https://github.com/armbian/build/blob/main/extensions/image-output-vhd.sh in case you need to automate this and you don't want to mess with additional scripting. ./compile.sh ENABLE_EXTENSIONS="image-output-vhd" 14 hours ago, walkin-corpse said: armbian-install not helps, not detect SATA VHD. Try using dd and copy entire image from USB to /dev/vdi or whatever disk device is. Please provide armbianmonitor -u and if you want to look into & help in this context, here are sources. You are also welcome to open a ticket and we both can hope someone will fix this soon. Even its probably just one-line fix, someone needs to find that line, test it to make sure it works and open a pull request. 1 Quote
BOFFBOY Posted February 12, 2024 Posted February 12, 2024 Hi all, kinder new to this, could someone point me to the right direction to download this in iso format for it to run in hyper v ? 0 Quote
