Vodalex Posted March 22, 2023 Posted March 22, 2023 Hello! I have bought Odroid M1 and installed arbian Image Armbian BullseyeCLI it works great but after installing OMV using armbian-config and rebooting the is no network available. If i run ap addr i get for the LAN adapter following: eth0: <BROADCAST.MULTICAST> mtu 1500 qdisc noo state DOWN qlen 1000 How can this be fixed? When I reboot the system it gets stuck on network configuration writing "A start job is running for Wait for Network to be Configured. I wait two minutes and then the system boots without network. The only chance to get network back is to run omv-firstaid and configure it or run following commands in the terminal ip link set dev eth0 up dhclient eth0 This command gives warning: /etc/resolvcon/update.d/libc: Warning: /etc/resolv.conf is not symbolic link to /run/resolvconf/resolv.conf Any help would be highly appreciated. 0 Quote
Igor Posted March 23, 2023 Posted March 23, 2023 On 3/22/2023 at 8:28 PM, Vodalex said: but after installing OMV using armbian-config and rebooting the is no network available. Expand This means that OMV, which anyway completely changes OS, somehow breaks networking. OMV was working well for many years, Armbian was even official partner ... As we didn't change anything in this regard, I would assume they changed something so try also to find this answer on their forums. 1 Quote
Vodalex Posted March 23, 2023 Author Posted March 23, 2023 Ok, i will post it there.. Strange that it behaves like that. I wanted to build a NAS with OpenMediaVault using Armbian. 0 Quote
Igor Posted March 23, 2023 Posted March 23, 2023 On 3/23/2023 at 7:23 AM, Vodalex said: Strange that it behaves like that. Expand Nothing strange. All software has bugs and I don't fully exclude there is a problem with Armbian, just for this, I would say its probably on their side ... things are complex and is difficult to be sure without a research. 1 Quote
