On 3/28/2023 at 8:39 PM, balbes150 said:
Enabled by default in u-boot NVMe. For SATA,  need to build the u-boot separately. I don't have any testing equipment. If there is someone willing to take a risk and check how the option for SATA in MTD will work, I can try to build it, but there will be no guarantees.
Hi @balbes150 I have SSD SATA im willing to test this if you can build it
15 часов назад, Darwin wu сказал:
I will try to build such a version next week.
Ver 20230713-edge kernel 6.4.3
Ver 20230714-edge kernel 6.5-rc1
user@192.168.1.17's password:
  ___  ____  _   ____
 / _ \|  _ \(_) | ___|
| | | | |_) | | |___ \
| |_| |  __/| |  ___) |
 \___/|_|   |_| |____/
Welcome to Armbian 23.06 Lunar with bleeding edge Linux 6.5.0-rc1-media
No end-user support: built from trunk
System load:   4%           	Up time:       4 min
Memory usage:  2% of 7.76G  	IP:	       192.168.1.17
CPU temp:      36°C           	Usage of /:    25% of 7.2G
RX today:      16.9 KiB
[ 0 security updates available, 1 updates total: apt upgrade ]
Last check: 2023-07-13 13:26
[ General system configuration (beta): armbian-config ]
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
user@orangepi5:~$ neofetch
                                 user@orangepi5
      █ █ █ █ █ █ █ █ █ █ █      OS: Armbian (23.06) aarch64
     ███████████████████████     Host: Orange Pi 5
   ▄▄██                   ██▄▄   Kernel: 6.5.0-rc1-media
   ▄▄██    ███████████    ██▄▄   Uptime: 4 mins
   ▄▄██   ██         ██   ██▄▄   Packages: 549 (dpkg)
   ▄▄██   ██         ██   ██▄▄   Shell: bash 5.2.15
   ▄▄██   ██         ██   ██▄▄   Terminal: /dev/pts/0
   ▄▄██   █████████████   ██▄▄   CPU: (8)
   ▄▄██   ██         ██   ██▄▄   Memory: 195MiB / 7943MiB
user@orangepi5:~$ su -
Password:
root@orangepi5:~# fdisk -l
Disk /dev/ram0: 16 MiB, 16777216 bytes, 32768 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram2: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram3: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram4: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram5: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram6: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram7: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram8: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram9: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram10: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram11: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram12: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram13: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram14: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/ram15: 16 MiB, 16777216 bytes, 32768 sectors
Disk /dev/zram0: 3.88 GiB, 4164464640 bytes, 1016715 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/mtdblock0: 16 MiB, 16777216 bytes, 32768 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 209E9F6E-F3DE-4E2D-9674-F497A9BE8D63
Device           Start   End Sectors  Size Type
/dev/mtdblock0p1    64  7167    7104  3.5M Linux filesystem
/dev/mtdblock0p2  7168  7679     512  256K Linux filesystem
/dev/mtdblock0p3  7680  8063     384  192K Linux filesystem
/dev/mtdblock0p4  8064  8127      64   32K Linux filesystem
/dev/mtdblock0p5  8128  8191      64   32K Linux filesystem
/dev/mtdblock0p6  8192 16383    8192    4M Linux filesystem
/dev/mtdblock0p7 16384 32734   16351    8M Linux filesystem
Disk /dev/nvme0n1: 119.24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: WDC PC SN520 SDAPMUW-128G-1101
Disklabel type: dos
Disk identifier: 0x027e8210
Device         Boot     Start       End   Sectors  Size Id Type
/dev/nvme0n1p1 *         2048 208058367 208056320 99.2G 83 Linux
/dev/nvme0n1p2      208058368 250068991  42010624   20G 82 Linux swap / Solaris
Disk /dev/mmcblk1: 7.5 GiB, 8053063680 bytes, 15728640 sectors
Disklabel type: gpt
Disk identifier: C60DA732-D085-8243-B363-128205738837
/dev/mmcblk1p1 32768 15400960 15368193  7.3G Linux filesystem
Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors
As someone who loves being always on bleeding edge updates, I can't express enough the gratitude for your always up-to-date builds. Thank you so much!
            -/oyddmdhs+:.                                                       *******@******
     -odNMMMMMMMMNNmhy+-`                                  ---------------
   -yNMMMMMMMMMMMNNNmmdhy+-                     OS: Gentoo Linux aarch64
`omMMMMMMMMMMMMNmdmmmmddhhy/`        Host: Orange Pi 5
omMMMMMMMMMMMNhhyyyohmdddhhhdo`        Kernel: 6.4.2-media
.ydMMMMMMMMMMdhs++so/smdddhhhhdm+`      Uptime: 19 hours, 21 mins
oyhdmNMMMMMMMNdyooydmddddhhhhyhNd.     Packages: 310 (emerge)
  :oyhhdNNMMMMMMMNNNmmdddhhhhhyymMh  Shell: bash 5.1.16
    .:+sydNMMMMMNNNmmmdddhhhhhhmMmy      Terminal: /dev/pts/0
       /mMMMMMMNNNmmmdddhhhhhmMNhs:        CPU: ARM Cortex-A55 (8)
    `oNMMMMMMMNNNmmmddddhhdmMNhs+`      Memory: 113MiB / 15722MiB
  `sNMMMMMMMMNNNmmmdddddmNMmhs/.
/NMMMMMMMMNNNNmmmdddmNMNdso:`
+MMMMMMMNNNNNmmmmdmNMNdso/-
yMMNNNNNNNmmmmmNNMmhs+/-`
/hMMNNNNNNNNMNdhs++/-`
`/ohdmmddhys+++/:.`
Thanks to you I was able to install Gentoo with a 6.y kernel.
I can't get an USB3 hub working properly, with either 6.2 or latest 6.5-rc kernel.
Plugging a single device works fine, but plugging a hub won't work. I get "Cannot enable. Maybe the USB cable is bad?" errors.
With 5.10 kernel everything works fine. Hub also works fine on another machine.
Anyone knows about this?
Ver 20230911-EDK2-EFI kernel legacy\current\edge
On the edge version, HDMI does not work in the kernel itself, but HDMI is supported at the level of the selection menu in GRUB, this allows you to have several different versions of the kernel\system (for example, add a self-assembled EDGE kernel with its own configuration) and choose on the monitor screen which kernel\system to run not using the UART console.
Hello @balbes150,
I still can't get neither USB3 nor USB-C working with edge kernel (log shows usb usb2-port1: Cannot enable. Maybe the USB cable is bad? for USB3 and nothing for USB-C). Is this expected?
Also, could you add wireguard module for current kernel?
Best regards,
Jean-Philippe
Has anyone spotted a change in very recent kernel driver of pancfs turning into 'panthor'?
It's mentioned here  https://lwn.net/Articles/940957/  and is about Mali Mesa continous work.
I guess I'll try to take a look at kernel repo's myself but I'm not used to doing that so thought I'd drop the info here as well.
Cheers
Update:  Nope if I'm looking in the right place I can't see it in linux kernel 6.6-rc4 even. I think it should be living here  'drivers/gpu/drm/panthor' as per
https://lore.kernel.org/linux-arm-kernel/20230809171017.64409d60@collabora.com/T/ for example.
I guess its still way too early.
Edited by fredrum
01.10.2023 в 22:27, Jean-Philippe сказал:
This is an experimental core, no guarantees of the operation of the equipment.
I'll check if it's possible or not.
Thank you for your reply. I understand there is no guarantee, and that mainline kernel is still a work in progress. I don’t have a problem with that, I was just wondering it usb-c and usb3 are supposed to be working (hence I should try to find why this isn’t working for me), or this known not to work (and I should stick with current kernel).
50 минут назад, Jean-Philippe сказал:
I tried this dtb and the kernel does not boot. Tried with loglevel 7 and there aren't any error messages, the boot just hangs at some point.
If you could add wireguard module to 6.2 current build, I would be more than happy to use this until mainline support is fixed.
Many thanks
1 час назад, m33ts4k0z сказал:
So the latest kernel with working HDMI for the OPI5+ is the 5.10.160?
This topic is only about OPI5. I don't have OPi5b, OPi5+, I have no idea what works there or not.
Hello @balbes150,
Sorry to insist, I'm still looking for a working 6.x kernel with wireguard and usb3 (or usb-c). I'm willing to try compiling the module by myself, but I'm not sure what repository to use. Could you share your building process?
Best regards
Thank you very much for the hard work!
I've spent the whole evening trying various combinations of kernels and dtbs. Unfortunately, I was not able to have that USB3 hub working (except for legacy 5.10). With 6.2 kernel and usb-c dtb, it shows as USB2 only.
What is strange is that I'm sure I had it working in the past, with a 6.2 kernel.
Plugging a single device in the USB3 port works. Plugging the hub on another machine works. Using 5.10 kernel works. Plugging the hub with 6.2 or 6.6 kernel on either USB3 or USB-C does not work.
If anyone is willing to help me debug this, it would be very welcomed. I'm not sure what I should try to go further.
06.12.2023 в 14:13, Shivan SpS сказал:
Any new image with 6.7 incluiding the partial hdmi patch and the last version of panthor?
Due to the termination of the support agreement between Orangepi and Armbian, support for this model has been discontinued and updates for this model are no longer being released.
For other models with support, I plan to publish new versions with the 6.7 kernel in the near future.
