n0153 Posted April 3, 2023 Posted April 3, 2023 Hi everyone! I tried to boot both Lunar and Sid and got similar UART-console output: Armbian_23.05.0-trunk-e33842ef2_Mangopi-mq_lunar_edge_6.1.0-rc3.boot.logFetching info... I noticed that "/boot/dtb/allwinner/sun20i-d1-nezha.dtb" is wrong choise, found it in extlinux.conf and changed it like this(hope commenting out strings works here): label Armbian kernel /boot/Image initrd /boot/uInitrd # fdt /boot/dtb/allwinner/sun20i-d1-nezha.dtb fdt /boot/dtb/allwinner/sun20i-d1-mangopi-mq-pro.dtb append root=UUID=5e7413f7-b308-4843-b9a9-063d99cb1700 console=ttyS0,115200n8 console=tty0 earlycon=sbi cma=96M rootflags=data=writeback stmmaceth=chain_mode:1 rw rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles the result was like this(this is just a tail of log): lunar_edge_tail.logFetching info... Am I on the right path? 0 Quote
Vladimir Dudnik Posted April 4, 2023 Posted April 4, 2023 >>Retrieving file: /boot/extlinux/pxelinux.cf_eth_start: Timeout MangoPi-MQ-Pro board does not have ethernet controller, but it seems OS try to initialize this (unexisting) device. Probably you need to change your image build configuration, to exclude ethernet device? Regards, Vladimir 0 Quote
balbes150 Posted April 4, 2023 Posted April 4, 2023 On 4/3/2023 at 3:36 PM, n0153 said: everyone! I tried to boot both Lunar and Sid and got similar UART-console output: Expand Where are these images taken from ? 0 Quote
n0153 Posted April 4, 2023 Author Posted April 4, 2023 Quote MangoPi-MQ-Pro board does not have ethernet controller, but it seems OS try to initialize this (unexisting) device. Probably you need to change your image build configuration, to exclude ethernet device? Expand Failover like this is typical for many platforms, it tries PXE after more usual options failed, which also visible in this log. For example it tries USB above, some other lines are also look like unsuccessful attempts to boot from different medias. I didn't build image myself, I took it from the location below. Do you think that building is preferable? Quote Where are these images taken from ? Expand from this location: https://www.armbian.com/mangopi-mq-pro/ 0 Quote
balbes150 Posted April 4, 2023 Posted April 4, 2023 On 4/4/2023 at 11:26 AM, n0153 said: Do you think that building is preferable? Expand No 0 Quote
riscvboy Posted May 13, 2023 Posted May 13, 2023 (edited) The images on the download page are broken and do not boot past U-Boot phase, last functioning one comes from February. There is a new maintainer for the board, hopefully we will get a functioning version soon. I can help with testing and debugging if there is such need. By the way, /usr/lib and /lib are EMPTY in the images, I've tested 3, so something is seriously broken? Edited May 13, 2023 by riscvboy 1 Quote
Vladimir Dudnik Posted May 28, 2023 Posted May 28, 2023 (edited) just tested the latest available build for mangopi-mq-pro, 26 May 2023 (from there: https://github.com/armbian-beta/os/releases/download/23.5.0-trunk.275/Armbian_23.5.0-trunk.275_Mangopi-mq_lunar_edge_6.1.0-rc3.img.xz), boot process still stop at the same stage: Retrieving file: /boot/extlinux/pxelinux.cfg/default sun8i_emac_eth_start: Timeout Config file not found sun8i_emac_eth_start: Timeout sun8i_emac_eth_start: Timeout => Edited May 28, 2023 by Vladimir Dudnik 0 Quote
markatlnk Posted June 9, 2023 Posted June 9, 2023 I also have a Mango Pi MQ Pro. I spent several hours attempting to figure out if I had a bad SD card or what. Just found this post and have the same problem. What image can I download that still works. Attempting to find a pre-built one from February seems to be a problem, can someone give me a link to the *.img file I need? Thanks, Mark 0 Quote
DarkevilPT Posted September 15, 2023 Posted September 15, 2023 I have the same issue. .. all images on 6.0 kernel are broken only the ones on 5.19 are working. Even the oficial ubuntu server riscv doesnt boots on me ... 0 Quote
