grunlab Posted April 3, 2023 Share Posted April 3, 2023 (edited) Hi, I've several Odroid HC1 boards (forming a kubernetes cluster of 8 nodes) currently running Armbian Buster Minimal image. I would like to upgrade the cluster (node by node) to Armbian Bullseye Minimal but I faced the following issue when I tried to reinstall the 1st node: - Used image: https://mirrors.dotsrc.org/armbian-dl/odroidxu4/archive/Armbian_23.02.1_Odroidxu4_bullseye_current_5.4.232_minimal.img.xz - Image flashed on SD card using BalenaEtcher - SD card plugged into the board + power up --> the OS is not booting (and not answering to ping) Here are the different tries I did: - I've tried to flash the image several times even using different SD cards and boards --> same issue, unable to boot - I've tried a rollback and flash the previous version Armbian Buster minimal --> OK, able to boot (so I don't think the issue is at SD card or board level) - I've tried to flash the Armbian Bullseye non-minimal image (https://mirrors.dotsrc.org/armbian-dl/odroidxu4/archive/Armbian_23.02.1_Odroidxu4_bullseye_current_5.4.232.img.xz) --> with this image, I'm able to boot but after installing the OS on the SATA drive (using armbian-config : System / Install / Boot on SD, system on SATA), the OS is not booting anymore. Unfortunately, I don't have an USB UART adapter to provide logs. I'm suspecting an issue at image level as: After flashing the image on the SD card, I noticed that a file "qemu_fstype_20230226-211008_10215.core" is present at the root of the SD card ... maybe a sign showing that the image build failed or something like this !? Thank you for your support. I would be happy to provide additional information if needed. Adrien Edited April 3, 2023 by grunlab 0 Quote Link to comment Share on other sites More sharing options...
grunlab Posted April 7, 2023 Author Share Posted April 7, 2023 (edited) There is effectively an issue with this image (containing a qemu core file at the root): https://mirrors.dotsrc.org/armbian-dl/odroidxu4/archive/Armbian_23.02.1_Odroidxu4_bullseye_current_5.4.232_minimal.img.xz I've rebuilt the image myself (https://github.com/armbian/build#getting-started) and the new built image is working like a charm (boot : OK, installing OS on SATA : OK) Waiting the image to be updated on Armbian website, people facing the same issue can get the image here: https://dl.grunlab.net/armbian/ Edited April 7, 2023 by grunlab 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 7, 2023 Share Posted April 7, 2023 @Igor Per this post, it looks like there is a corrupted stable build. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted April 9, 2023 Share Posted April 9, 2023 On 4/7/2023 at 10:45 PM, SteeMan said: it looks like there is a corrupted stable build. Possible. I ran a rebuilt for this board, but as I am out of office, those were not tested on hardware https://imola.armbian.com/dl/odroidxu4/archive/ 0 Quote Link to comment Share on other sites More sharing options...
grunlab Posted April 9, 2023 Author Share Posted April 9, 2023 Thank you SteeMan, Igor New image Armbian_23.02.3_Odroidxu4_bullseye_current_5.4.239_minimal.img.xz is now working perfectly. 1 Quote Link to comment Share on other sites More sharing options...
