RTL8188GU for armbian
Go to solution Solved by Werner,
Hi!, I just bought my orangepi pc and also installed Armbian desktop. I also bought a wifi dongle with rtl8188gu chip. Is there any steps on how to use this to connect to my network?
Thank you for the reply Werner!
At this point, Im still compiling it.
Will mark it as a solution if it works!
Currently, when I run inxi -Nn on terminal, it shows that the device driver is usb storage (Ill comment an update for this also)
I already compile and install the driver. Now I got another problem, and yes, its about my comment above. When I run inxi -Nn on terminal, the driver is still usb-storage so the wifi dongle cant use the driver I just install, and I dont know how to solve this.
