Facing issues with installing armbian on Orange Pi Zero 2
Go to solution Solved by ALIGMSTEN,
Hello.
I tried installing Armbian_22.08.1_Orangepizero2_bullseye_current_5.15.63 on Orange Pi Zero 2.
I am using it without display. It did get installed. However after updating and upgrading it did not boot at all.
Can someone please help?
Regards,
Amol
  • Solution
Hello @Amol Right now OPIZ2 is community supported only.
Images that are booting and behaving as one might expect are the legacy images derived from original vendor sources: https://www.armbian.com/orange-pi-zero-2/  Kernel 4.9.y, Size: 385Mb, Release date: Apr 8, 2023.
Mainline based Armbian Edge: https://redirect.armbian.com/region/EU/orangepizero2/Bullseye_edge images are WIP and could have booting and upgrading issues, these and 'features' which might be considered normal may improve as development work happens.
Good luck with your progress.
Most Welcome .....
A big tip of the hat to the framework developers @rpardini, @Igor and @Werner for fixing the legacy images.
One might have to be careful when upgrading though... I've not had a serious look at the fix to concur what happens should one do so.
