Upgrade from Armbian_22.11.1_Orangepizero2_bullseye_edge_6.0.10.img
doesn't work.
After sudo apt upgrade and reboot can't boot.
I should reinstall everything to new image ? I can't upgrade ?
Thanks
error upgrade.txt
29 minutes ago, cabanak said:
edge
This topic is about legacy kernel, not edge kernel.
Started to test on Armbian_23.5.1_Orangepizero2_jammy_current_6.1.30.img.xz.
Currently running as a SAMBA server.
- Reboot OK
- Power down OK
- LAN OK
- USB hard drive OK
- HDMI NOT OK (don't know if this can be turned on somehow)
Seems to be running stable for now. @Werner: Thank you for providing this with the "ugly EOL-kernel". Seems to run nice as a SAMBA server. I will test some more, like update/upgrade and tightvncserver to see if things keep running smooth. Nice to see the OrangePi zero 2 running on 6.1.30.
PLEASE NOTE: This topic is for the Legacy images 4.9 kernel.
@Werner I think we need to make distinction between Legacy and then mainline kernels for Issues not sure if you have time to help move things around possibly?
For edge not yet available, this is in development/testing!
I will investigate, quickly looks like device tree is failing to load!
doesn't work
  • Werner locked this topic
