Andr Posted April 21, 2023 Posted April 21, 2023 Banani Pi M5, Armbian_23.02.2_Bananapim5_bullseye_current_6.1.11_xfce_desktop into SD card, USB drive connected and auto mounted in fstab. Boot loop looking for system into USB. I have to disconnect USB then it boots up from SD. Any help? 0 Quote
Werner Posted April 21, 2023 Posted April 21, 2023 moved since it boots w/o peripherals connected. 0 Quote
SoSie Posted August 1, 2023 Posted August 1, 2023 (edited) Hello, I managed to boot recently on external usb sata. here is the HOW-TO I would have seen somewhere.. I - Install armbian x86 UEFI I really recommend it ! You will be able to compile arm from it faster. just before going on, it possible to put it side by side with LMDE5 and share /home using garted copy and paste of partitions! II - Install armbian arm64 aside and outside 😎 1) I used gparted to make free space and create a new partition of size 14749 Mb (size of emmc) /dev/sdaX 2) then decompress the image you downloaded from (redirect).armbian.com big KISS to @Werner for the mirror ! here <foo> is for example jammy,bullseye,bookworm etc.. unxz -T0 Armbian_<version>_<foo>_arm64.img.tz 3) copy it to the partition (and SD) a) then you mount armbian_<version>_<foo>_arm64.img with gnome-disks utility or other way b) inside gnome-disk locate THE ARMBIAN_ROOT PARTITION and mount it. click on the link /media/$USER/armbian_root c) The fastest way to transfer I found is with partclone (see ubuntu manual that indicates partiitons should be umounted!): partclone.extfs -b -d -s /media/$USER/armbian_root -o /dev/sdaX 4) Fix the UUID if it does not match you can access to the /boot directory , in this directory you see the UUID in the boot/armbianEnv.txt like "SoSIe-Love-Armbian-It-R0cks" or in etc/fstab you use tune2fs to set the partition /dev/sdaX to it with: tune2fs /dev/sdaX -U <UUID> 5) then you copy it to a sdcard > 16Go to boot on it dd if=/dev/sdaX of=/dev/<sdcard> bs=10M 6) Put the sdcard on the sbc bananapiM5 and boot it recommend to install to emmc with armbian-install or dd way like i discribed before , then shutdown the sbc, remove the sdcard, light on to make all actions in the emmc because it is faster and safer 7 ) Now inside as root you can copy boot as boot-emmc mkdir /boot-emmc rsync -aPz /boot /boot-emmc 8 ) then you rename boot mv boot boot-usb-sata-<foo> 9) Adapt armbianEnv.txt and boot.cmd tfor usb sata target cd /boot-usb-sata-<foo> Check the armbianEnv.txt and boot.cmd to match target usb sata partition drive a) the UUID must match those of /dev/sdaX (or other armbian_root) b) rootdevfs is no more /dev/mmcblk1p1 but /dev/sdaX (or other armbian_root) 10) then you do symlink to usb sata boot, the one you want to boot rm boot # erase previous link, ln -sf does nothing ln -s boot-usb-sata-<foo> boot 11) Ensure your usb sata drive is connected to BPI M5 usb3 port.. I have a powered usb sata case. I notice the power is not enougth on USB3 to handle usb sata drive 11) Reboot the baby.. now you should boot on usb sata /dev/sdaX ! of course ONE WILL SAY, HEY DUDE, THERE IS THE ARMBIAN-INSTALL SCRIPT...yes but no it can not handle side by side boot without erasing all drive. Edited August 1, 2023 by SoSie fix 0 Quote
