ickam Posted April 29, 2023 Posted April 29, 2023 Hi, So I found out the hard way that neither jammy nor bullseye builds for odroid c2 actually allow ssh at first boot My board is headless, but has a wired connection to my lan and always gets assigned the same address. Which file or files do I need to edit to ssh into it without having to do initial setup first, please? 0 Quote
TRS-80 Posted May 7, 2023 Posted May 7, 2023 It has always been my understanding that ssh is enabled 'out of the box' in Armbian. So something must have slipped through the cracks here. I see this post is currently in 'community/unmaintained' section, but as of this writing I am showing Odroid C2 as a Supported device, with a maintainer. Perhaps @teknoid can shed some light? If they do not reply, and/or you find a solution on your own, please submit a patch to the build framework to fix it for everyone else with this board. It's probably a minor configuration issue. 0 Quote
teknoid Posted May 23, 2023 Posted May 23, 2023 @ickam, I just tested Armbian_23.05.0-trunk_Odroidc2_bullseye_current_6.1.29_minimal.img and could not reproduce your problem. After boot please wait 2-3 mins and carefully check your DHCP Server Log. For me it works as expected: May 23 11:04:36 tron dnsmasq-dhcp[2938540]: DHCPDISCOVER(enp6s0f0) 00:1e:06:33:b5:0a May 23 11:04:36 tron dnsmasq-dhcp[2938540]: DHCPOFFER(enp6s0f0) 192.168.25.16 00:1e:06:33:b5:0a May 23 11:04:36 tron dnsmasq-dhcp[2938540]: DHCPREQUEST(enp6s0f0) 192.168.25.16 00:1e:06:33:b5:0a May 23 11:04:36 tron dnsmasq-dhcp[2938540]: abandoning lease to 00:1e:06:33:b5:0a of 192.168.25.16 May 23 11:04:36 tron dnsmasq-dhcp[2938540]: DHCPACK(enp6s0f0) 192.168.25.16 00:1e:06:33:b5:0a c2 Welcome to ARMBIAN! Documentation: https://docs.armbian.com | Community: https://forum.armbian.com IP address: 192.168.25.16 Create root password: ********* Repeat root password: ********* Shell: BASH Creating a new user account. Press <Ctrl-C> to abort 0 Quote
