Armbian Armbian 23.02.2 Jammy with Linux 5.15.93-rockchip64 on (rockpi-4b plus v.1.72)
Опубликовано: только что · Hidden - This content must be approved before it can be edited.
HOT NEWS!!!
With Armbian Armbian 23.02.2 Jammy with Linux 5.15.93-rockchip64 on (rockpi-4b plus v.1.72)
Add (do it elso on all booting fevices = MMC, NVME, MPD, SD) the following lines to /boot/armbianEnv.txt
overlays=spi-jedec-nor
param_spinor_spi_bus=1
Reboot
If you shorted 23-25 pins in 1.) then:
disconnect them after the ROCK Pi 4 fully boot's
enable spi-nor by executing (as root):
echo spi1.0 > /sys/bus/spi/drivers/spi-nor/bind
verify that the SPI mtd interface is enabled by running
ls /dev/mtdblock0
if the last command does not list any file then something went wrong between 3.) and 5.)
Run sudo nand-sata-install
choose option: "Boot from SPI or MPD - system on SATA, USB or NVMe"
choose NVMe partition, eg. /dev/nvme0n1p1
accept erasing of the choosen partition with "Yes"
choose fs type (tested with ext4)
wait a few minutes for rootfs transfer to chosen partition
choose writing SPI bootloader with "Yes"
confirm that you want to flash it with "Yes"
wait ~60 seconds for writing
choose Exit
IN /boot/armbianEnv.txt choose your needing booting UUID, use command:
sudo blkid
it look like this:
/dev/nvme0n1p1: UUID="ca927a6a-b2f0-4184-ab0f-5719e34172db" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="19354531-01"
/dev/mmcblk1p1: LABEL="armbi_root" UUID="cfd67d21-5d00-4032-823e-b68830ca3543" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="22fbd54f-01"
/dev/zram0: UUID="de7c0efa-e9cc-11ed-885d-c3fae5811b14" TYPE="swap"
/dev/zram1: LABEL="log2ram" UUID="906b40da-e43c-4971-bff5-e9e402eada77" BLOCK_SIZE="4096" TYPE="ext4"
in /boot/armbianEnv.txt look like it: sudo nano /boot/armbianEnv.txt
verbosity=1
bootlogo=true
overlay_prefix=rockchip
fdtfile=rockchip/rk3399-rock-pi-4b.dtb
rootdev=UUID=ca927a6a-b2f0-4184-ab0f-5719e34172db
rootfstype=ext4
Reboot
Enjoy Armbian booting with SPI / NVMe
sudo curl https://raw.githubusercontent.com/TheRemote/PiBenchmarks/master/Storage.sh | sudo bash
without pci2.0 in /boot/armbianEnv.txt
verbosity=1
     Category                  Test                      Result
HDParm                    Disk Read                 609.77 MB/s
HDParm                    Cached Disk Read          726.72 MB/s
DD                        Disk Write                232 MB/s
FIO                       4k random read            54613 IOPS (218453 KB/s)
FIO                       4k random write           16151 IOPS (64605 KB/s)
IOZone                    4k read                   132479 KB/s
IOZone                    4k write                  79127 KB/s
IOZone                    4k random read            54327 KB/s
IOZone                    4k random write           89006 KB/s
                           Score: 19365
and with pci2.0 in sudo nano /boot/armbianEnv.txt
verbosity=1
bootlogo=true
rootfstype=ext4
overlays=pcie-gen2 spi-jedec-nor
HDParm                    Disk Read                 579.83 MB/s
HDParm                    Cached Disk Read          695.44 MB/s
DD                        Disk Write                225 MB/s
FIO                       4k random read            57206 IOPS (228826 KB/s)
FIO                       4k random write           18720 IOPS (74881 KB/s)
IOZone                    4k read                   131620 KB/s
IOZone                    4k write                  79301 KB/s
IOZone                    4k random read            65461 KB/s
IOZone                    4k random write           117974 KB/s
                          Score: 22989
All it tested on
Brand:Samsung M.2 NVMe 980 Pro
Board: Radxa ROCK Pi 4B plus v.1.72 hardware
Device: Samsung SSD 980 PRO 1TB
Class:SSD (M.2 NVMe)
Изменено только что пользователем Cyrill
PS. Создано с использованием материала от пользователя Igor, на этом же сайте и танцев с бубнами с материали RADXA.
За что и благодарю, чем могу, сообщество и его верных пользователей.... на базе данного решения настроен NAS на базе urbackup server/client 2.5.31 - но это отдельная песня...
Edited by Cyrill
дополнил
