Cyrill Posted May 3, 2023 Share Posted May 3, 2023 (edited) Опубликовано: только что · Hidden - This content must be approved before it can be edited. HOT NEWS!!! With Armbian Armbian 23.02.2 Jammy with Linux 5.15.93-rockchip64 on (rockpi-4b plus v.1.72) Add (do it elso on all booting fevices = MMC, NVME, MPD, SD) the following lines to /boot/armbianEnv.txt overlays=spi-jedec-nor param_spinor_spi_bus=1 Reboot If you shorted 23-25 pins in 1.) then: disconnect them after the ROCK Pi 4 fully boot's enable spi-nor by executing (as root): echo spi1.0 > /sys/bus/spi/drivers/spi-nor/bind verify that the SPI mtd interface is enabled by running ls /dev/mtdblock0 if the last command does not list any file then something went wrong between 3.) and 5.) Run sudo nand-sata-install choose option: "Boot from SPI or MPD - system on SATA, USB or NVMe" choose NVMe partition, eg. /dev/nvme0n1p1 accept erasing of the choosen partition with "Yes" choose fs type (tested with ext4) wait a few minutes for rootfs transfer to chosen partition choose writing SPI bootloader with "Yes" confirm that you want to flash it with "Yes" wait ~60 seconds for writing choose Exit IN /boot/armbianEnv.txt choose your needing booting UUID, use command: sudo blkid it look like this: /dev/nvme0n1p1: UUID="ca927a6a-b2f0-4184-ab0f-5719e34172db" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="19354531-01" /dev/mmcblk1p1: LABEL="armbi_root" UUID="cfd67d21-5d00-4032-823e-b68830ca3543" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="22fbd54f-01" /dev/zram0: UUID="de7c0efa-e9cc-11ed-885d-c3fae5811b14" TYPE="swap" /dev/zram1: LABEL="log2ram" UUID="906b40da-e43c-4971-bff5-e9e402eada77" BLOCK_SIZE="4096" TYPE="ext4" in /boot/armbianEnv.txt look like it: sudo nano /boot/armbianEnv.txt verbosity=1 bootlogo=true overlay_prefix=rockchip fdtfile=rockchip/rk3399-rock-pi-4b.dtb rootdev=UUID=ca927a6a-b2f0-4184-ab0f-5719e34172db rootfstype=ext4 overlays=spi-jedec-nor param_spinor_spi_bus=1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Reboot Enjoy Armbian booting with SPI / NVMe sudo curl https://raw.githubusercontent.com/TheRemote/PiBenchmarks/master/Storage.sh | sudo bash without pci2.0 in /boot/armbianEnv.txt verbosity=1 Category Test Result HDParm Disk Read 609.77 MB/s HDParm Cached Disk Read 726.72 MB/s DD Disk Write 232 MB/s FIO 4k random read 54613 IOPS (218453 KB/s) FIO 4k random write 16151 IOPS (64605 KB/s) IOZone 4k read 132479 KB/s IOZone 4k write 79127 KB/s IOZone 4k random read 54327 KB/s IOZone 4k random write 89006 KB/s Score: 19365 and with pci2.0 in sudo nano /boot/armbianEnv.txt verbosity=1 bootlogo=true overlay_prefix=rockchip fdtfile=rockchip/rk3399-rock-pi-4b.dtb rootdev=UUID=ca927a6a-b2f0-4184-ab0f-5719e34172db rootfstype=ext4 overlays=pcie-gen2 spi-jedec-nor param_spinor_spi_bus=1 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Category Test Result HDParm Disk Read 579.83 MB/s HDParm Cached Disk Read 695.44 MB/s DD Disk Write 225 MB/s FIO 4k random read 57206 IOPS (228826 KB/s) FIO 4k random write 18720 IOPS (74881 KB/s) IOZone 4k read 131620 KB/s IOZone 4k write 79301 KB/s IOZone 4k random read 65461 KB/s IOZone 4k random write 117974 KB/s Score: 22989 All it tested on Brand:Samsung M.2 NVMe 980 Pro Board: Radxa ROCK Pi 4B plus v.1.72 hardware Device: Samsung SSD 980 PRO 1TB Class:SSD (M.2 NVMe) Изменено только что пользователем Cyrill PS. Создано с использованием материала от пользователя Igor, на этом же сайте и танцев с бубнами с материали RADXA. За что и благодарю, чем могу, сообщество и его верных пользователей.... на базе данного решения настроен NAS на базе urbackup server/client 2.5.31 - но это отдельная песня... Edited May 3, 2023 by Cyrill дополнил 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 4, 2023 Share Posted May 4, 2023 https://forum.armbian.com/terms Quote The official forum language is English only. Please use a translator tool if necessary. Duplicate removed. 0 Quote Link to comment Share on other sites More sharing options...
