I'm using armbian / Jessie on my cubietruck (installed on NAND):
$ uname -a
Linux cubietruck 3.4.108-sunxi #14 SMP PREEMPT Tue Aug 25 18:13:23 CEST 2015 armv7l GNU/Linux
However, I can't upgrade linux-image package:
$ sudo aptitude upgrade
The following partially installed packages will be configured:
  linux-image-sunxi
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Setting up linux-image-sunxi (4.3) ...
ln: failed to create symbolic link ‘/boot/zImage’: Operation not permitted
cp: error writing ‘/boot/zImage’: No space left on device
cp: failed to extend ‘/boot/zImage’: No space left on device
dpkg: error processing package linux-image-sunxi (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
 linux-image-sunxi
E: Sub-process /usr/bin/dpkg returned an error code (1)
Failed to perform requested operation on package.  Trying to recover:
 linux-image-sunxi
Apparently the /boot partition if full:
$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       7.1G  1.3G  5.5G  19% /
devtmpfs       1000M     0 1000M   0% /dev
tmpfs          1000M     0 1000M   0% /dev/shm
tmpfs          1000M   17M  983M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs          1000M     0 1000M   0% /sys/fs/cgroup
/dev/nand1       16M   16M     0 100% /boot
/dev/sda1       147G   62G   78G  45% /mnt/hdd
Here is what it is in /boot, do I need to remove something?
/boot $ tree .
├── bin
│   ├── aw-som-a20.bin
│   ├── bananapi.bin
│   ├── bananapilcd7.bin
│   ├── bananapipro.bin
│   ├── bananapiprolcd7.bin
│   ├── cubieboard2.bin
│   ├── cubieboard.bin
│   ├── cubietruck.bin
│   ├── lamobo-r1.bin
│   ├── lime2.bin
│   ├── lime-a10.bin
│   ├── lime.bin
│   ├── micro.bin
│   ├── orangepi.bin
│   └── pcduino3nano.bin
├── boot.axf
├── boot.ini
├── config-3.4.108-sunxi
├── linux
│   ├── linux.ini
│   └── u-boot.bin
├── magic.bin
├── script.bin
├── System.map-3.4.108-sunxi
├── uEnv.txt
├── uImage
├── vmlinuz-3.4.108-sunxi
└── zImage
Thanks
You just find a bug. Upgrade if system is on NAND will not go automatic even if there is enough free space, I need to fix it.  :( (nand bootloader doesn't recognize zImage kernel type)
Workaround:
1. Remove zImage, uImage, system.map-3.4.108-sunxi and vmlinuz-3.4.-108-sunxi ... located no /boot  (/dev/nand1)
2. Run this and pick up the correct board / kernel 3.4:
wget -q -O - http://upgrade.armbian.com | bash
