ZFS broken on 6.2 πŸ˜–
Go to solution Solved by Igor,
Dear All,
Β
I got a zfs upgrade today, I updated the packages but then it failed to build the module, thus I tried to update kernel and firmware but it failed the same:
Β
Β
hecking whether CONFIG_MODULES is defined... no
configure: error:
		*** This kernel does not include the required loadable module
		*** support!
		*** To build OpenZFS as a loadable Linux kernel module
		*** enable loadable module support by setting
		*** `CONFIG_MODULES=y` in the kernel configuration and run
		*** `make modules_prepare` in the Linux source tree.
		*** If you don't intend to enable loadable kernel module
		*** support, please compile OpenZFS as a Linux kernel built-in.
		*** Prepare the Linux source tree by running `make prepare`,
		*** use the OpenZFS `--enable-linux-builtin` configure option,
		*** copy the OpenZFS sources into the Linux source tree using
		*** `./copy-builtin <linux source directory>`,
		*** set `CONFIG_ZFS=y` in the kernel configuration and compile
		*** kernel as usual.
Β
Building for 6.2.0-rc3-meson64
Building initial module for 6.2.0-rc3-meson64
Error! Bad return status for module build on kernel: 6.2.0-rc3-meson64 (aarch64)
Consult /var/lib/dkms/zfs/2.1.9/build/make.log for more information.
dpkg: error processing package zfs-dkms (--configure):
 installed zfs-dkms package post-installation script subprocess returned error exit status 10
Processing triggers for initramfs-tools (0.140ubuntu13.1) ...
update-initramfs: Generating /boot/initrd.img-6.2.0-rc3-meson64
update-initramfs: Converting to u-boot format
Errors were encountered while processing:
 zfs-dkms
Β
uname -a
Linux odroidhc4 6.2.0-rc3-meson64 #23.02.2 SMP PREEMPT Fri Feb 17 23:06:22 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
Β
Any idea for fixing this issue?
Β
Thanks, πŸ™
Β
Freezr
Looks like is a license issue
Β
ERROR: modpost: GPL-incompatible module zcommon.ko uses GPL-only symbol 'kernel_neon_begin'
ERROR: modpost: GPL-incompatible module zcommon.ko uses GPL-only symbol 'kernel_neon_end'
ERROR: modpost: GPL-incompatible module zfs.ko uses GPL-only symbol 'kernel_neon_end'
ERROR: modpost: GPL-incompatible module zfs.ko uses GPL-only symbol 'kernel_neon_begin'
Β
Full:
cat  /var/lib/dkms/zfs/2.1.9/build/make.log
DKMS make.log for zfs-2.1.9 for kernel 6.2.0-rc3-meson64 (aarch64)
Sat May 13 12:54:14 PM EDT 2023
make  all-recursive
make[1]: Entering directory '/var/lib/dkms/zfs/2.1.9/build'
Making all in module
make[2]: Entering directory '/var/lib/dkms/zfs/2.1.9/build/module'
list='icp lua zstd'; for td in $list; do make -C $td; done
make[3]: Entering directory '/var/lib/dkms/zfs/2.1.9/build/module/icp'
mkdir -p api core spi io os algs algs/aes algs/edonr algs/modes algs/sha2 algs/skein asm-x86_64 asm-x86_64/aes asm-x86_64/modes asm-x86_64/sha2 asm-i386 asm-generic
make[3]: Leaving directory '/var/lib/dkms/zfs/2.1.9/build/module/icp'
make[3]: Entering directory '/var/lib/dkms/zfs/2.1.9/build/module/lua'
mkdir -p setjmp
make[3]: Leaving directory '/var/lib/dkms/zfs/2.1.9/build/module/lua'
make[3]: Entering directory '/var/lib/dkms/zfs/2.1.9/build/module/zstd'
mkdir -p lib
make[3]: Leaving directory '/var/lib/dkms/zfs/2.1.9/build/module/zstd'
make -C /lib/modules/6.2.0-rc3-meson64/build  \
	M="$PWD"  CONFIG_ZFS=m modules
make[3]: Entering directory '/usr/src/linux-headers-6.2.0-rc3-meson64'
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/avl/avl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-atomic.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/illumos-crypto.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lapi.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-condvar.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/avl/zavl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/api/kcf_cipher.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/api/kcf_digest.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-cred.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lauxlib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/api/kcf_mac.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/api/kcf_miscapi.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-err.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-generic.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/api/kcf_ctxops.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lbaselib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/core/kcf_callprov.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-kmem.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/core/kcf_prov_tabs.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lcode.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-kmem-cache.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/core/kcf_sched.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/core/kcf_mech_tabs.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lcompat.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-kstat.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/core/kcf_prov_lib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lcorolib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/spi/kcf_spi.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-proc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/io/aes.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lctype.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-procfs-list.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/io/edonr_mod.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/ldebug.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-taskq.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/io/sha2_mod.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/io/skein_mod.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/ldo.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-thread.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/os/modhash.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/os/modconf.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-trace.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lfunc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/cbc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/ccm.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-tsd.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lgc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/ctr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-vmem.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/ecb.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-xdr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/gcm_generic.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/llex.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/../os/linux/spl/spl-zlib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/gcm.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/modes/modes.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/spl/spl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/nvpair/nvpair.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lmem.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lobject.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/aes/aes_impl_generic.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lopcodes.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/aes/aes_impl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/aes/aes_modes.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lparser.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/nvpair/fnvpair.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/edonr/edonr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/sha2/sha2.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/nvpair/nvpair_alloc_spl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/skein/skein.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lstate.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/nvpair/nvpair_alloc_fixed.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/nvpair/znvpair.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/unicode/u8_textprep.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/skein/skein_block.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lstring.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/algs/skein/skein_iv.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lstrlib.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/icp/icp.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/cityhash.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/ltable.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfeature_common.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/ltablib.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/unicode/uconv.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/ltm.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_comutil.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lvm.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/unicode/zunicode.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/lzio.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/abd.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_deleg.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/aggsum.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_fletcher.o
  AS [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/setjmp/setjmp.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/lua/zlua.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zstd/zfs_zstd.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/arc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/blkptr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_fletcher_superscalar.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_fletcher_superscalar4.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zstd/lib/zstd.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_namecheck.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/bplist.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_prop.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/bpobj.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zpool_prop.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/bptree.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zprop_common.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/btree.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zfs_fletcher_aarch64_neon.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/zcommon/zcommon.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/bqueue.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dataset_kstats.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dbuf.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dbuf_stats.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/ddt.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/ddt_zap.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_diff.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_object.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_objset.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_recv.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_redact.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_send.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_traverse.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_tx.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dmu_zfetch.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dnode.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dnode_sync.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_bookmark.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_crypt.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_dataset.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_deadlist.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_deleg.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_destroy.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_dir.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_pool.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_prop.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_scan.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_synctask.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/dsl_userhold.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/edonr_zfs.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/fm.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/gzip.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/hkdf.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/lz4.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/lzjb.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/metaslab.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/mmp.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/multilist.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/objlist.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/pathname.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/range_tree.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/refcount.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/rrwlock.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/sa.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/sha256.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/skein_zfs.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zstd/zstd_sparc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_boot.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_checkpoint.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_config.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_errlog.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_history.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_log_spacemap.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_misc.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/spa_stats.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/space_map.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/space_reftree.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/txg.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/uberblock.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/unique.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_cache.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_draid.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_draid_rand.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_indirect.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_indirect_births.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_indirect_mapping.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_initialize.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_label.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_mirror.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_missing.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_queue.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_raidz.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_raidz_math.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/zstd/zzstd.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_raidz_math_scalar.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_rebuild.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_removal.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_root.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_trim.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zap.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zap_leaf.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zap_micro.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp_get.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp_global.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp_iter.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp_set.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zcp_synctask.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfeature.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_byteswap.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_fm.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_fuid.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_ioctl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_log.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_onexit.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_quota.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_ratelimit.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_replay.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_rlock.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_sa.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs_vnops.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zil.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zio.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zio_checksum.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zio_compress.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zio_inject.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zle.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zrlock.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zthr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zvol.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/abd_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/arc_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/mmp_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/policy.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/trace.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/qat.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/qat_compress.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/qat_crypt.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/spa_misc_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/vdev_disk.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/vdev_file.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_acl.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_ctldir.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_debug.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_dir.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_file_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_ioctl_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_racct.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_sysfs.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_uio.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_vfsops.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_vnops_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zfs_znode.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zio_crypt.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_ctldir.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_export.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_file.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_inode.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_super.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zpl_xattr.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/../os/linux/zfs/zvol_os.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_raidz_math_aarch64_neon.o
  CC [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/vdev_raidz_math_aarch64_neonx2.o
  LD [M]  /var/lib/dkms/zfs/2.1.9/build/module/zfs/zfs.o
  MODPOST /var/lib/dkms/zfs/2.1.9/build/module/Module.symvers
make[4]: *** [scripts/Makefile.modpost:138: /var/lib/dkms/zfs/2.1.9/build/module/Module.symvers] Error 1
make[3]: *** [Makefile:1960: modpost] Error 2
make[3]: Leaving directory '/usr/src/linux-headers-6.2.0-rc3-meson64'
make[2]: *** [Makefile:55: modules-Linux] Error 2
make[2]: Leaving directory '/var/lib/dkms/zfs/2.1.9/build/module'
make[1]: *** [Makefile:892: all-recursive] Error 1
make[1]: Leaving directory '/var/lib/dkms/zfs/2.1.9/build'
make: *** [Makefile:753: all] Error 2
Β
People have many problems when using latest kernels:Β https://github.com/openzfs/zfs/issuesΒ  Working ZFS and latest kernel is IMO too bold move.
Debian packages can be updated to ZFS 2.1.11 while Ubuntu is still on 2.1.9, which might not even be compatible with 6.2+
Do you recommend to switch to Armbian/Debian rather than continue with Armbian/Ubuntu? When I started it was the contrary... I am very tempted to move everything over BTRFS and using only Armbian/Debian instead...
Β
Thanks,
Β
F.
  • Solution
56 minutes ago, freezr said:
Do you recommend
No. Stick to kernel 6.1 if you want to use ZFS. Anything more recent is expecting miracles.
Thank you downgrading the kernel to 6.1. fixed the issue... However I lost the pool and I have to add it again... I hoped that it would be recognized automagically... uff... πŸ˜–
Β
Importing the pool did work... Just scrubbing it for security... πŸ™
Edited by freezr
Γ—
Γ—
