Hi boys(and gilrz and others) , i have a question plz;
Did Somebody manage to find a working img of armbian that match with the fake chinese X96Q the 1/8 gb with the H313 , because i tried every img that i find on the internet , and i did not manage to boot it correclty
You mentioned that it's a fake.  Possibly because it is a copy it may have not be a perfect copy and that may be why you can't find firmware that will work with it. Also, the only place to find official Armbian images.
Have you tried building your own image using the Armbian build tools?  That way you can customise the image you're building to your requirements.
Read the Armbian documentation:  https://docs.armbian.com/
  • Werner changed the title to fake chinese X96Q the 1/8 gb with the H313
I found it. after searching I came across this repo on GitHub https://github.com/warpme/miniarch/releases/tag/20231112-6.6.8
I have not tried it yet, but I have realized for the h313 x96q, now I have not tried anything, but here are the supposed steps
1- Wrote img to SD card using Etcher
2- Inserted SD card in Device
3- Powered ON the device and it Booted from SD card
4- followed update instructions on GitHub Repo.
5- Rebooted after all updates,
6- Basic Arch was ready to be used
Here USB keyboard , LAN, HDMI worked normally.
After reboot, logged in as root, and ran "start" command,
Now here selected option 5, which is install EndeavourOS
Process just ask you Yes/No questions, then you can select your DE, location etc. Automated script downloaded bunch of files and started its installation.
Got the message that installation is done successfully and came back to terminal.
Rebooted from terminal
After this point got only blank screen , dont know it is still booting without HDMI or not
So need to revert back to step -1 writing basic image to SD card.
And this time sticking to terminal only.
@Blaize The link you posted is not an Armbian image.  You should move this conversation to a forum that supports the software you intend to install.  We can't help you here for non-armbian related questions.
