gitboy Posted May 19, 2023 Posted May 19, 2023 Hello everyone. I have a defunct Helm Email server which carries a Rockchip rk3399 SoC. I have flashed with a custom Armbian image provided by the Helm folks. After flashing the box with the .img file, I am able to ssh into the new armbian box and go through the basic initial armbian setup. The box recognizes my 1TB nvme drive, so I then create a primary partition and format the nvme using fdisk and mkfs. I then install armbian-config and use it to install the root system to the nvme0n1p1 by using the following option on the menu: System -> Install -> 1 Boot from SD, and chose the nvme0n1p1 partition. After that I verify the BootEnv option shows the uuid of the nvme, but then once I reboot I can no longer ssh into the device. The box's power LED remains lit, but I don't think its properly booting the OS. Any help would be greatly appreciated. Thanks. 0 Quote
Werner Posted May 20, 2023 Posted May 20, 2023 On 5/19/2023 at 10:35 PM, gitboy said: custom Armbian image Expand moved to unsupported. We cannot provide support for 3rd party modifications. 0 Quote
