SoC 	Rockchip RK3588 (8nm LP process)
CPU 	• 8-core 64-bit processor
		• 4 x Cortex-A76(2.4GHz), 4 x Cortex-A55(1.8GHz) and separate NEON co-processors
GPU 	• Arm Mali-G610
		• Built-in 3D GPU
		• Compatible with OpenGL ES1.1/2.0/3.2, OpenCL 2.2 and Vulkan 1.2
NPU 	Embedded NPU supports INT4/INT8/INT16/FP16 mixed operation, with up to 6Tops computing power
PMU 	RK806-1
RAM 	4GB/8GB/16GB (LPDDR4/4x)
Memory 	• QSPI Nor FLASH: 16MB/32MB
		• MicroSD card slot: up to 128GB
		• eMMC socket: 16GB/32GB/64GB/128GB/256GB eMMC module can be attached
		• M.2 2280 slot for NVMe SSDs (PCIe 3.0 x4) up to 2,000 MB/s
USB 	• USB3.0 × 2
		• USB2.0 × 2
		• Type-C ×1
Video 	• 2x HDMI 2.1 out up to 8k@60FPS
		• 1x Type-C with DP TX 1.4A,up to 8K@30FPS
		• 1x HDMI in with up to 4K@60FPS
		• 1 x MIPI DSI TX 4 Lane,up to 4K @60Hz
TP interface 	1x 6Pin FPC socket
Camera 	1 x MIPI CSI 4 Lane
Audio 	CODEC:ES8388
		• 1xAudio 3.5mm jack with mic
		• 1xMIC In
		• 1xHDMI 2.1 eARC
		• 1xSPK
Ethernet 	2xPCIe 2.5G LAN(RTL8125BG)
Expansion Port 	40Pin dual row pins with the following multiplexing functions: UART, I2C, SPI, CAN, I2S, PDM, AUDDSM, SDIO, PWM, GPIO
PCIe M.2 M-KEY Socket 	M.2 connector M key (bottom) for NVMe with PCIe 3.0 x4 lanes 2280 SSD
PCIe M.2 E-KEY Socket 	M.2 connector E key (top) for connectivity with PCIe 2.0 x1/PCM/UART/USB2.0,2230 Wi-Fi6 /BT supported
Button 	1×MaskROM key
1xRecovery
1×on/off key
Power Source 	Support Type-C power supply, 5V@4A
IR receiver 	1x IR receiver tube
LED 	RGB LED side light
FAN 	5V FAN
RTC 	2Pin: RTC backup battery
Debugging 	3Pin debug serial port (UART)
  • Werner pinned and locked this topic
  • Werner unpinned this topic
