This howto is very old and obsolete
mplayer is not maintained anymore -> use mpv
and there were many commit's to sunxi-vdpau ;-)
the attached howto is of course also outdated (the vdpau part)
but you should take a look at the
  1. Setupboot.cmd
section
sunxi_ve_mem_reserve=190 \
sunxi_g2d_mem_reserve=16 \
sunxi_no_mali_mem_reserve \
sunxi_fb_mem_reserve=32 \
the reserved memory must be increased
190 MB for cedarX is a save Maximum
more and the A20 crashes very often.
With VDR it took month to figure out why it didn't work.
-> to less memory :facepalm ;-)
before you start mpv do:
export VDPAU_DRIVER=sunxi;
export DISPLAY=:0.0;
export VDPAU_OSD=1;
export VDPAU_DEINT=1;
chmod 0777 /dev/disp;
chmod 0777 /dev/cedar_dev;
chmod 0777 /dev/g2d;
libvdpau-sunxi.pdf
Actually my problem is es2gear only shows 50fps, glmark-es2 also experience a low fps rate
my kernel boot arguments is
and sunxi-mali test is showing that render is MALI400MP and display a triangle properly.
es2_info is also showing that render is MALI400MP
but I still can't get a correct fps rate and cpu usage is 100%
I'm trying to check if the CedarX is working for me (I'm using the Armbian_4.5_Lime2_Ubuntu_trusty_3.4.109_desktop version). I've added the boot parameters and rebuild the boot.scr, rebooted the board, then I've exported the enironement variables in the terminal:
export VDPAU_OSD=1;
before I execute "mpv --fs big_buck_bunny_1080p_h264.mov", which should be supported as far as I'm informed. But still the video is not encoded propperly and a bit slow.
(My board is an Olimex OLinuXino A20 Lime2)
Is it correct to use "mpv"? Am I missing further steps?
Have you compiled ffmpg or is it from a package, when from a package maybe it's compiled without vdpau support. And you need access rights to /dev/disp /dev/cedar_dev /dev/g2d.
Thank you for this info. Actually there is no ffmped installed in the default image. But your answer brought me to do more experimenting with the codecs in mpv. Adding the argument "--hwdec=vdpau" did the tric so far. (I thought, it would be selected in some automagic way ;-) )
Actually I have all the permissions, because be default you are root in armbian desktop version.
Still the sound seams to be faster than the video. Is there any way of fixing this?
[edit]
"--framedrop=yes" is one possibility to keep audio and video in sync, but the of course the video isn't smooth anymore
