Ketsa Posted June 2, 2023 Posted June 2, 2023 Tried both Debian and Ubuntu based 23.5 releases on my v1.4 board Boot process stops at "Starting kernel..." Also tried the "minimal CLI" debian release with same results. The previous versions 23.02 are fine. ▒ U-Boot SPL 2022.07-armbian (May 27 2023 - 19:26:49 +0000) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2022.07-armbian (May 27 2023 - 19:26:49 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB Core: 65 devices, 17 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial Out: serial Err: serial Net: phy interface1 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4121 bytes read in 3 ms (1.3 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 184 bytes read in 3 ms (59.6 KiB/s) 15848831 bytes read in 658 ms (23 MiB/s) 8477464 bytes read in 355 ms (22.8 MiB/s) Found mainline kernel configuration 35377 bytes read in 7 ms (4.8 MiB/s) 504 bytes read in 6 ms (82 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 6 ms (82 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 617 bytes read in 6 ms (99.6 KiB/s) Applying kernel provided DT overlay sun8i-h3-tve.dtbo 4185 bytes read in 6 ms (680.7 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 45000000 Kernel image @ 0x42000000 [ 0x000000 - 0x815b18 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 15848767 Bytes = 15.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 490e2000, end 49fff53f ... OK Loading Device Tree to 49071000, end 490e1fff ... OK Starting kernel ... 0 Quote
Werner Posted June 2, 2023 Posted June 2, 2023 Known issue. Allwinner 32bit seems to be in bad shape unfortunately. Research is needed 0 Quote
mc510 Posted June 11, 2023 Posted June 11, 2023 On 6/2/2023 at 4:52 PM, Werner said: Known issue. Allwinner 32bit seems to be in bad shape unfortunately. Research is needed Expand Is it best for Allwinner 32bit users to avoid Armbian 23.5 for the time being? 0 Quote
