1 Posted June 7, 2023 Share Posted June 7, 2023 root@orangepi5:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 223.6G 0 disk ├─sda1 8:1 0 256M 0 part /boot └─sda2 8:2 0 221.1G 0 part /var/log.hdd / mtdblock0 31:0 0 16M 0 disk mmcblk1 179:0 0 29.8G 0 disk ├─mmcblk1p1 179:1 0 256M 0 part └─mmcblk1p2 179:2 0 29.2G 0 part zram0 254:0 0 7.7G 0 disk [SWAP] zram1 254:1 0 50M 0 disk /var/log root@orangepi5:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false overlay_prefix=rockchip-rk3588 overlays=orangepi-5-sata fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=cc730f4c-fc1b-4686-aaa5-2e9a8f44d888 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@orangepi5:~# blkid /dev/sda2: LABEL="armbi_root" UUID="cc730f4c-fc1b-4686-aaa5-2e9a8f44d888" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="de1a9525-6439-4243-bc2b-61d3221eb524" /dev/zram0: UUID="210234f3-105d-4c5e-83a8-b097366bfa26" TYPE="swap" /dev/zram1: LABEL="log2ram" UUID="466160e2-e334-40cb-84cd-49efa6845b86" BLOCK_SIZE="4096" TYPE="ext4" /dev/mtdblock0: PTUUID="829fc558-d7dd-4ef3-94fd-e1d0316bc4c5" PTTYPE="gpt" /dev/mmcblk1p1: SEC_TYPE="msdos" LABEL_FATBOOT="armbi_boot" LABEL="armbi_boot" UUID="A56C-57B5" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="bootfs" PARTUUID="0d48e4a3-6408-d045-aafd-06e643e73152" /dev/mmcblk1p2: LABEL="armbi_root" UUID="68c6335e-b3aa-4ad9-ac9a-e844e997ee75" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="2f417159-5a4c-d14e-97fb-650ad758e6d1" /dev/sda1: SEC_TYPE="msdos" LABEL_FATBOOT="armbi_boot" LABEL="armbi_boot" UUID="A56C-57B5" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="bootfs" PARTUUID="0d48e4a3-6408-d045-aafd-06e643e73152" root@orangepi5:~# cat /etc/fstab UUID=cc730f4c-fc1b-4686-aaa5-2e9a8f44d888 / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1 UUID=A56C-57B5 /boot vfat defaults 0 2 tmpfs /tmp tmpfs defaults,nosuid 0 0 Hello, could please somebody help me? my system doesn't want to boot without inserted SDcard 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 7, 2023 Share Posted June 7, 2023 Did you write boot loader to mtd? 0 Quote Link to comment Share on other sites More sharing options...
1 Posted June 7, 2023 Author Share Posted June 7, 2023 (edited) also a full log link https://paste.armbian.com/ujucivuwef I did armbian-install -> Install/Update the bootloader on MTD Flash other option like Boot from MTD Flash - system on SATA, USB or NVMe does not work for me, it reports an error that partition is to small Edited June 7, 2023 by 1 0 Quote Link to comment Share on other sites More sharing options...
1 Posted June 7, 2023 Author Share Posted June 7, 2023 is there an option to do such writing of boot loader without the armbian-install tool? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 7, 2023 Share Posted June 7, 2023 Can you adjust partition setup of your ssd so it has one partition only and retry? 0 Quote Link to comment Share on other sites More sharing options...
