Odroidn2+ with eMMC card flashed with latest Armbian 23.5 Jammy XFCE (Armbian_23.5.1_Odroidn2_jammy_current_6.1.30_xfce_desktop)
Having issue installing firefox. Chromium was already installed properly.
During the installation of firefox, the system remains waiting for something.
When eMMC flashed with Armbian_23.5.1_Odroidn2_jammy_current_6.1.30_xfce_desktop
testhost@odroidn2:~$ uname -a
Linux odroidn2 6.1.30-meson64 #8 SMP PREEMPT Wed May 24 16:32:53 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
testhost@odroidn2:~$ lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 22.04.2 LTS
Release:    22.04
Codename:    jammy
after upgrade
$ uname -a
$ lsb_release -a
Release:    22.04
Codename:    jammy
installing firefox
$ sudo apt install firefox
[sudo] password for testhost:
Reading package lists... Done
Building dependency tree... Done
The following additional packages will be installed:
  apparmor snapd squashfs-tools
Suggested packages:
  apparmor-profiles-extra apparmor-utils zenity | kdialog
The following NEW packages will be installed:
  apparmor firefox snapd squashfs-tools
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 22.5 MB of archives.
After this operation, 100 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://ports.ubuntu.com jammy-updates/main arm64 apparmor arm64 3.0.4-2ubuntu2.2 [573 kB]
Get:2 http://ports.ubuntu.com jammy/main arm64 squashfs-tools arm64 1:4.5-3build1 [156 kB]
Get:3 http://ports.ubuntu.com jammy-security/main arm64 snapd arm64 2.58+22.04.1 [21.7 MB]
Get:4 http://ports.ubuntu.com jammy/main arm64 firefox arm64 1:1snap1-0ubuntu2 [72.3 kB]
Fetched 22.5 MB in 33s (675 kB/s)
Preconfiguring packages ...
Selecting previously unselected package apparmor.
(Reading database ... 177783 files and directories currently installed.)
Preparing to unpack .../apparmor_3.0.4-2ubuntu2.2_arm64.deb ...
Unpacking apparmor (3.0.4-2ubuntu2.2) ...
Selecting previously unselected package squashfs-tools.
Preparing to unpack .../squashfs-tools_1%3a4.5-3build1_arm64.deb ...
Unpacking squashfs-tools (1:4.5-3build1) ...
Selecting previously unselected package snapd.
Preparing to unpack .../snapd_2.58+22.04.1_arm64.deb ...
Unpacking snapd (2.58+22.04.1) ...
Setting up apparmor (3.0.4-2ubuntu2.2) ...
Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
Reloading AppArmor profiles
Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
Setting up squashfs-tools (1:4.5-3build1) ...
Setting up snapd (2.58+22.04.1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.aa-prompt-listener.service → /lib/systemd/system/snapd.aa-prompt-listener.service.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.apparmor.service → /lib/systemd/system/snapd.apparmor.service.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.autoimport.service → /lib/systemd/system/snapd.autoimport.service.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.core-fixup.service → /lib/systemd/system/snapd.core-fixup.service.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.recovery-chooser-trigger.service → /lib/systemd/system/snapd.recovery-chooser-trigger.se
rvice.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.seeded.service → /lib/systemd/system/snapd.seeded.service.
Created symlink /etc/systemd/system/cloud-final.service.wants/snapd.seeded.service → /lib/systemd/system/snapd.seeded.service.
Unit /lib/systemd/system/snapd.seeded.service is added as a dependency to a non-existent unit cloud-final.service.
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.service → /lib/systemd/system/snapd.service.
Created symlink /etc/systemd/system/timers.target.wants/snapd.snap-repair.timer → /lib/systemd/system/snapd.snap-repair.timer.
Created symlink /etc/systemd/system/sockets.target.wants/snapd.socket → /lib/systemd/system/snapd.socket.
Created symlink /etc/systemd/system/final.target.wants/snapd.system-shutdown.service → /lib/systemd/system/snapd.system-shutdown.service.
snapd.failure.service is a disabled or a static unit, not starting it.
snapd.mounts-pre.target is a disabled or a static unit, not starting it.
snapd.mounts.target is a disabled or a static unit, not starting it.
snapd.snap-repair.service is a disabled or a static unit, not starting it.
Selecting previously unselected package firefox.
(Reading database ... 178083 files and directories currently installed.)
Preparing to unpack .../firefox_1%3a1snap1-0ubuntu2_arm64.deb ...
=> Installing the firefox snap
==> Checking connectivity with the snap store
==> Installing the firefox snap
2023-06-07T15:34:45-04:00 INFO Waiting for automatic snapd restart...
Progress: [ 76%] [####################################################################################################................................]
I'm not sure about your odroid, but I'm trying on a Cubox-I with 1 gb of ram, and I think it may just not fit anymore.  I'll have to hunt around for a light alternative, I guess.
Meantime, in your case 2gb is probably only runnable barely.  I get memory hangs from things on Firefox go south on 4gb desktops.
It's all just gotten out of hand these days.  Especially now with it being a snap denizen.
thanks
Jim
